Computer speakers vs Home theater speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-09-2008, 08:38 AM - Thread Starter
Eakius's Avatar
I have a nice 7.1 setup in my apt, but some of the speakers are a bit too big. I have a set of logitech's from the z5500 package that I loved when I had a desktop. I now have a laptop for my portable internets, so I was thinking, what's the potential issues or downsides to using some of those logitech satelites as my rear or side speakers? Right now I have some classic 3 way Yamaha's in the back. My receiver is set to treat them as small speakers anyway (no bass).
I guess aside from possible performance loss, is there any technical problems with just switching the speakers straight up? Same wires, no further configuration; I was always curious about the technical differences between home theater speakers within the context of using pc speakers for home theater receivers.
Thanks in advance!
Eakius is offline
post #2 of 3 Old 11-09-2008, 09:10 AM
Matt1966's Avatar
You may want to find out what ohms the Z5500 are and see if it's compatible with your receiver.
Performance wise I can't say for certain, but I think they would be on par with a Sony HTIB system.
If it sounds good, it is good. ~ Duke Ellington
"Leave the gun. Take the cannoli." ~ Peter Clemenza
Visit my site for gear and photos
Matt1966 is offline
post #3 of 3 Old 11-11-2008, 10:23 AM - Thread Starter
Eakius's Avatar
Thanks for the tip, they are both 8 ohms, so this bodes well.
Eakius is offline
Reply Speakers
