Shallow Depth In Walls - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-11-2008, 12:06 PM - Thread Starter
mschlee's Avatar
i'm in a newer construction codo and want to put 3 speakers for left center right channels in an interior wall. problem is that the wall is built with metal studs which are only about 2.75" wide. this means i have approx 3.125" depth from the surface of the wall to the back of the other side of the wall.
this setup will replace a set of totem arro free standing speakers. i am very happy with the sound from the arro's, but need something in wall. I mention the arros because they are small so I dont need any monser sound - just accurate (my other pair are b&w cdm1 se again not room rockers but very nice sound) i'm probably 80% music and i dont need a ton of bass for movies.
I want something with an enclosure for both sound quality and isolation from adjoining rooms.
I found the speakercraft accufit iw7 that seem to meet my needs but I have never heard them.
any suggestions are greatly appreciated
mschlee is offline
post #2 of 3 Old 11-11-2008, 04:55 PM
mazersteven's Avatar
When I read your thread title, this is exactly the speaker that came to mind.
mazersteven is offline
post #3 of 3 Old 11-11-2008, 05:12 PM - Thread Starter
mschlee's Avatar
thanks mazer - have you ever heard them?
mschlee is offline
Reply Speakers
