Best Stands for JBL E50 Speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-21-2008, 12:26 PM - Thread Starter
jwat's Avatar
I just purchased a pair of JBL E50 speakers to match my JBL EC35 center channel. I need to find something to sit the E50's on, but they are pretty big. Can anyone recommend some sturdy, good looking stands that could support these speakers?
jwat is offline
post #2 of 3 Old 11-23-2008, 12:15 PM
blued888's Avatar
www.racksandstands.com
www.standsandmounts.com
Eclectic Electronics: A blog containing technology news, information about home theater, digital photography and more.
blued888 is offline
post #3 of 3 Old 11-23-2008, 02:31 PM
Stephen Hopkins's Avatar
Figure out the height you need, find something with a bottom base a few inches wider/deeper than the bottom of your speakers, and find something with an aesthetic you like. The JBL E series are great speakers, but speaker stands can get expensive and there's no reason to spend as much or more on the stands as you did on the speakers. I personally like the Sanus NF-series. The NF24B or NF30B would likely be great choices, and if you have the Cherry finish E-Series, the NF24C or NF30C would be a great match as well. Some other general features to look for are a single solid leg, or a hollow leg that can be filled with sand or gravel to add weight stability, as well as some sort of cable/wire management. More than anything, find something that matches the height and aesthetic you're looking for without having a base too small to be stable and without being too lightweight.
Stephen Hopkins is offline
Reply Speakers
