Heavy speaker - How to mount? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 11-30-2008, 01:45 PM - Thread Starter
saiko's Avatar
Hi,
I am considering ordering the Infinity beta c250 center channel speaker. However, the speaker is quite heavy (16 lbs) and when I tried to find speaker mounts online, reviews point out that several of the mounts are rated incorrectly for weight and won't really hold up the heavy speakers.
Can someone please suggest a sturdy wall mount that will cost 50 bucks or less?
The speaker itself is @125 or so on amazon and so I feel I should not be spending a ton on a speaker mount.
saiko
saiko is offline
post #2 of 16 Old 11-30-2008, 01:49 PM
Zivman's Avatar
Quoted: 93 Post(s)
Liked: 62
Originally Posted by saiko View Post
Hi,
saiko
I have these holding up 20# HTD level 3 book shelf speakers
not sure how it will work with the horizontal orientation, but they are cheap and can easily hold 16#
Zivman is offline
post #3 of 16 Old 11-30-2008, 02:46 PM
Paul Scarpelli's Avatar
Liked: 54
How about a shelf??
Paul Scarpelli
aka TRIAD DUDE
I can tell people who are judgmental just by looking at them...
Paul Scarpelli is offline
post #4 of 16 Old 11-30-2008, 02:55 PM - Thread Starter
saiko's Avatar
Thanks , Zivman. Those are the first mounts I considered. HOwever, the customer reviews on that mount are enough to drive me away. People are having trouble mounting 10 pounders on that mount.
Paul, I thought of using a shelf but I already have the wall brackets etc where my existing center channel (a lame cambridge cube speaker) is. That space would look a little off hence I wanted to mount this speaker up there.
saiko is offline
post #5 of 16 Old 11-30-2008, 10:22 PM
jakewash's Avatar
Full Metal Bracket, I have 3 of these and they are very strong. Only issue is to make sure you can find a stud to mount them into to hold up the weight, otherwise it may pull out of the wall.
svencz likes this.
jakewash is offline
post #6 of 16 Old 12-01-2008, 05:22 AM
Chadci's Avatar
Quoted: 16 Post(s)
I needed to mount my center channel ( JBL EC35) From the ceiling for various reasons. I tried the mount listed above and it did not feel safe nor did it look safe. That half ball joint has to be in just perfectly and just testing it in my hands proved that with enough force it could easily seperate. I quickly changed the mount out and went with one of these
I was able to bolt it to a ceiling joist and then into the speaker. It's pretty solid and I have no fear with it like this.
Chadci is offline
post #7 of 16 Old 12-01-2008, 12:04 PM - Thread Starter
saiko's Avatar
Thanks for your suggestions, JakeWash and Chadci. I am not sure about how the mounting holes are laid out on the back of the speakers. Chadci's suggestion shows a VESA pattern (for TVs I think).
Do all center channels follow some standard for mounting holes ? How can I know whether my speaker will "fit" a mount properly and that the holes will align? Sorry, I'm a newbie to this stuff.
saiko is offline
post #8 of 16 Old 12-01-2008, 01:57 PM
Erik Tracy's Avatar
I use the B-Tech BT-77 wall mount for my Polk RTiA3s which also weigh 16lbs.
As long as you have the mounts centered over a wall stud and use a long wood screw, these mounts should be fine.
Erik
Erik Tracy is offline
post #9 of 16 Old 12-01-2008, 02:08 PM
tvdrew's Avatar
I imagine this is pretty much always true--if you mount on a stud, you can pretty much hang any speaker. If you are hanging from sheetrock/wallboard, you're going to have severe limits.
tvdrew is offline
post #10 of 16 Old 12-01-2008, 02:18 PM
Lemonade727's Avatar
I use the B-Tech BT15 for my center channel. It holds the weight well and the mount isn't obtrusive.
You can get it here or search elsewhere for it.
Lemonade727 is offline
post #11 of 16 Old 12-01-2008, 02:29 PM
Erik Tracy's Avatar
Oops- my bad - I missed that the OP wanted to mount a center.
+1 on the B-Tech BT15 - I use this one as well.
Erik
post #12 of 16 Old 12-01-2008, 03:01 PM
jakewash's Avatar
Unfortunately no, the way centers mount is up to each manufacturer, alot do not even have a system in mind for mounting. Axiom's FMB has a universal type of mounting system with varying spaced holes for screw and of course a center hole for their own speakers to mount to, as their speakers come with a threaded insert and bolt on the back making it very easy to mount their Bookshelf and center speakers.
jakewash is offline
post #13 of 16 Old 12-01-2008, 06:50 PM - Thread Starter
saiko's Avatar
Thanks, Lemonade and Eric.
In my case, the speaker will be above my 50" tv. It appears that the BT-15 brackets will not allow me to angle the center channel speaker down towards my seat/sofa. The speaker will be about 5 feet or so above my ear level and so I thought it might be important to be able to angle the speakers down. How important is directing the center channel towards the listener?
P.S: I just ordered the speaker from tigerdirect.com for 120 bucks shipped ! paid 2 bucks for shipping (cyber monday deal). Yay !
It seems to be much harder to figure out how to mount a speaker than to buy it :-)
saiko is offline
post #14 of 16 Old 12-01-2008, 06:59 PM
fireman325's Avatar
Saiko I was in the exact same position you're in when I started my speaker upgrade. I ended up going the other way and mounting my TV on the wall so the center speaker could sit on top of my ET stand just beneath the TV. If you're interested in pursuing this option instead, you can get a great quality TV mount from monoprice.com for your 50" TV for less than $30. I would recommend staying away from their full-motion mounts. Stick with a flush or tilt mount and you'll have nothing to worry about. My TV is a 50" 107 lb plasma and the $30 mount it's on is rock-solid. Good luck with whatever you decide to do.
Steve
fireman325 is offline
post #15 of 16 Old 12-11-2008, 11:03 AM - Thread Starter
saiko's Avatar
Originally Posted by Paul Scarpelli View Post
How about a shelf??
I ended up doing what Paul suggested yesterday. I got the speaker yesterday and it is VERY heavy. Also it has nothing in the back that would allow me to mount it. No mounting holes that I could see. I'll try and post a picture of my setup soon. Waiting for my blu-ray player to arrive today.
On a side note, the Infinity c250 is awesome. I truly didn't know what I was missing till I unplugged my old cambridge soundworks cube thingy and plugged in this bad boy. What a difference !
saiko is offline
post #16 of 16 Old 12-11-2008, 11:13 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Use a small CRT TV mount. They will hold your 16lb center easily as they can handle up to 60lbs. Comes with a mounting strap too.
http://www.vanptc.com/products16-17-4/19to21medium
http://www.buy.com/prod/vantage-poin.../90102436.html
http://www.fadfusion.com/selection.p...er=20041201060
Afro GT
afrogt is offline
Reply Speakers
