What in-ceiling speakers to use with Monitor Audio RS6s - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-01-2008, 06:26 AM - Thread Starter
karllutz's Avatar
Can anyone recommend what Monitor Audio ceiling speakers I should use to match up with my front Monitor Audio RS6s. I need a center and two surrounds and one back. I also want to add two more speakers ( one in dining room and one in kitchen ) for second zone music listening. Also, any recommendations on other options and where to buy in Georgia. Thanks a ton.
karllutz is offline
post #2 of 3 Old 12-01-2008, 07:24 AM
kwkshift's Avatar
For your center, the match to your RS6's are either the C265-LCR (6.5" woofer) or the C280-LCR, (8" woofer). For your surrounds, you can use the C265's and for the back surround the C265-FX will fit your needs.
For your Dining room and Kitchen, you can use the C165-T2's or the C180-T2's depending if you want a 6.5" woofer or an 8" woofer.
kwkshift is offline
post #3 of 3 Old 12-01-2008, 09:58 AM - Thread Starter
karllutz's Avatar
Thanks a ton,,,,hey, one last question......if I wanted to go with a 5.1 instead of the 6.1 system would you use two c265's or two c265-fx's?
karllutz is offline
Reply Speakers
