Speaker Cable for Bose? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-03-2008, 12:02 PM - Thread Starter
PLUCKYHD's Avatar
I know don't shoot me for having bose but wife loves it and won't let me swap it out.
My question is where do I get RCA speaker cable with RCA on one end and open wires on the other to replace the factory Bose speaker cables with some good 14gauge?
I know they sell the adapter but that is for inwall installations which i don't have for the fronts.
PLUCKYHD is offline
post #2 of 10 Old 12-03-2008, 12:42 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
How long a speaker run are you talking about? 18ga is good for up to 32 ft with 8ohm speakers. I'm guessing since you're talking about front speakers you don't need a length any more than that.
24ft of 18 gauge wire from Radio Shack may do the trick
http://www.radioshack.com/product/in...ductId=2102959
Afro GT
afrogt is offline
post #3 of 10 Old 12-03-2008, 12:44 PM - Thread Starter
PLUCKYHD's Avatar
I got over 50' to my rears and suggestions there?
18ga seems small but i am not going to act like I know.
PLUCKYHD is offline
post #4 of 10 Old 12-03-2008, 01:09 PM
CADOBHuK's Avatar
Cable upgrades are pretty worthless in most cases, even with good speakers imho. When its bose it's kind of an amusing thing to do isn't it?
CADOBHuK is offline
post #5 of 10 Old 12-03-2008, 01:14 PM - Thread Starter
PLUCKYHD's Avatar
Well my problem is my wires aren't good and got cut in the attic by mistake and new ones with the stupid rca plug bose puts on there are not easy to find. I will get the ones from ready shack I am sure they will work okay
PLUCKYHD is offline
post #6 of 10 Old 12-03-2008, 01:16 PM
cybe's Avatar
Why not just splice [better] wire in to replace the wires that've been cut?
cybe is offline
post #7 of 10 Old 12-03-2008, 02:57 PM
afrogt's Avatar
Liked: 755
Yes, run the 50ft of 14ga wire from your rear speakers all the way to the sub and then splice with the old wire about a 6" - 12" from the RCA jack. that way only a foot or less will be using the old wire.
Afro GT
afrogt is offline
post #8 of 10 Old 12-03-2008, 04:38 PM
Jacobisthe's Avatar
Well I have heard that for that run 14awg would work well, but if you are getting new wire, might as well get 12awg (don't see any reason that 14awg is better). Monoprice has great prices.
Jacobisthe is offline
post #9 of 10 Old 12-03-2008, 05:04 PM
afrogt's Avatar
Liked: 755
Will 12ga wire actually fit into the Bose spring clips on the cube speaker?
Afro GT
afrogt is offline
post #10 of 10 Old 12-03-2008, 05:54 PM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
Forgive me but, imho, using these heavier cables is kinda pointless. If you don't like the ones you have, simply put an RCA plug on the end of some decent twinlead from Home Depot. Or see what they have at RadioShack like this http://www.radioshack.com/product/in...ductId=2102959
Kal
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
Reply Speakers
