my own "little" speaker quest - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 12-04-2008, 11:21 AM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Originally Posted by Stephen Hopkins View Post
If it were me I'd take the feet off of the furniture you have up front... 2" more height would really open up your options.
That's a good idea, but then I don't think those sliding glass doors would work.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
Old 12-04-2008, 11:23 AM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Originally Posted by jvgillow View Post
Vandersteen VCC-1 would fit also. Coaxial design.
I have heard them....good choice.
-curtis
cschang is offline
Old 12-04-2008, 11:47 AM - Thread Starter
tpLouKY's Avatar
penngray, from what I've read bookshelfs can often be better than floorstanders in a smaller room. The room is only 12.5'x13.5'. Am I off on this?
I really do want this to be a long term solution that I'm not wanting to upgrade later.
If I go the floorstander route...
tpLouKY is offline
penngray's Avatar
Liked: 43
someone else suggested wall mounts on the side of the screen and a CC underneath?
There are some seriously good on-wall choices out there and if your budget is really $2K for three speakers you could find something pretty good. Paradigm has some very nice on-wall choices (more drivers the better for dynamics). Not sure what the height of the CC is though.
penngray is offline
Old 12-04-2008, 11:49 AM
penngray's Avatar
Liked: 43
I have never heard that but I personally I do like bookshelf designs with a proper sub system. Good Bookshelfs will do down to 80Hz, I never go lower then that even though manufacturing specs say some do 60Hz, I would rather have my sub handled anything below 80Hz.
Floorstands will allow for more drivers and therefore more dynamic SPL range....GOOD for HT experience.
penngray is offline
Old 12-04-2008, 11:53 AM
warlord260's Avatar
Originally Posted by tpLouKY View Post
wow ed, thanks for the suggestions. those kef speakers look really nice. my current receiver is a pioneer elite vsx50. not really sure about it's specs. came with the rocket tykes. thinking about getting an onkyo 606 or 805.
get the 805. the 606 shouldnt even be in the same sentance. there is a big difference in size between the 2. do what you have to to make room, if impossible the 705, is way better than 606. more power, better audessy,7 channel matrix, etc.
as for speakers maybe 3 ascend 340se centers. it should work. you could call ascend, or maybe curtis could chime in here.
warlord260 is offline
Old 12-04-2008, 11:56 AM
Stephen Hopkins's Avatar
You could even put larger bookshelfs on stands to the sides of the screen. It doesn't look as clean as what you have in mind, but opens your number of options up almost exponentially.
Since you do listen to a decent ratio of music in a small room, floor standers may have benefit for 2ch listening without the sub. Maybe look at the current $1800 Rocket package (RS850, RS450, RSC200) and see if they'll sub-in different surrounds for less... that is assuming there won't be floor space for the RS450 in the back with the sub back there...
Stephen Hopkins is offline
Old 12-04-2008, 12:11 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Floorstander would just be too close to the side walls IMO.
-curtis
cschang is offline
Old 12-04-2008, 12:16 PM
Out from the back-wall with 20deg of toe-in should be more than acceptable.
Old 12-04-2008, 12:28 PM
Airite68's Avatar
I can comment on the impressiveness of the Ascend HTM200 5.1 paired with an HSU sub, that's the combo I spec'd for a system here at work (yes, I'm spoiled!). A great choice value-wise I thought and unobtrusive.
Airite68 is offline
Old 12-04-2008, 12:33 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Maybe.....if that aims the speaker at the listener rather than the opposite wall. If it crosses before the listener, that can cause problems too. You also have the issue of the port firing right into the corner. Also, now where does the sub go?
It is a small room.
-curtis
cschang is offline
Old 12-04-2008, 02:38 PM
jhuang's Avatar
Originally Posted by edbayarea View Post
TP
Don't cross off all multi-driver centers from your list. Many designs address the lobing in different ways. KEF does it with a Coaxial design iQ6C, NHT Classic Two or Three C's have a stacked tweeter/mid, just to name a few. Center speakers are key in a multichannel set up.
Standard 2 way bookshelves would not have this lobing dispersion problem. I have used three identical bookshelves (normal orientation) and the sound was nearly perfect. and dispersion very god. Also have used currently a center with stacked tweeter mid. Excellent.
With the massive size of your screen it would be beneficial for you to have as much speaker as you can afford so the sound matches the size of those talking heads.
Consider these Bookshelves:
NHT Absolute Zero
PSB Alpha
Paradigm Atom
An interesting low profile (under 7" tall) set up option:
KEF iQ2C for Left/Right + KEF iQ6C at Center
that will give lots of sound for $740 at vanns dot com
What is your AV receiver and/or amp?
Go listen to some great speakers near you first! Good luck
According to measurements/analysis and many "convensional" wisdom, the issue with center channels is the horizonal orientation of the drivers. Stacked tweeter/mid with surrounded woofer is better, but still not as good as fully vertical. Audioholics has a great article:
http://www.audioholics.com/education...peaker-designs
Note, I believe a horizonal speaker will give much better vertical dispersion, so IF your "C" has to be located at a different height than the L/R, you may be better off with a horizontal designed center.
For the OP, in a smaller room, you may be better off going with 3 same bookshelf speakers, vertically aligned (I would not lay them horizontally!) versus 2 tower and 1 "larger" center for same price. My logic is bookshelves in theory "saves" on cabinet and no large woofer versus tower, SO in theory at same price, a bookshelf should have better drivers. In your case, possibly having better drivers in bookshelf size gets better bang for buck.
jhuang is offline
Old 12-04-2008, 05:19 PM
It is a small room.
20deg was an estimate for a starting point, and most, if not all, of the speakers I recommend around here are front ported (especially towers). He's already said moving the sub to the back is an option as well. The room's not THAT small (I've had front-projection in smaller).
Old 12-04-2008, 05:26 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
My point was there are more considerations/issues by going that route.
It is all do-able, just a matter of what is best or less of a compromise.
-curtis
cschang is offline
Old 12-04-2008, 05:29 PM
Agreed 100%... I guess I wouldn't expect most around here to read me say "20deg" and just go do it without looking at the larger picture and at least experiment with different placements of whatever they do end up buying... maybe that's a false assumption? If so I might get delusions of grandeur
Old 12-04-2008, 06:10 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Understood, but from looking at the picture, with speakers that close to the wall, they are going need to be toed in a lot if you want to reduce interaction.
It isn't an issue with floorstanders, it is an issue with placement.
That is a good question; How far is the seating area from the front speakers?
-curtis
cschang is offline
Old 12-05-2008, 09:35 AM - Thread Starter
tpLouKY's Avatar
My seating is toward the back of the room. Ears are approximately 2-3 feet from the back wall.
Question, how well does an 805 do at driving 3 Sierras and 2 HTM 200 SE's?
tpLouKY is offline
Old 12-05-2008, 10:09 AM
Mudslide's Avatar
Quoted: 74 Post(s)
Liked: 84
A couple more for your consideration...both coming with excellent recommendations and within your budget:
5 @ <$2,000...http://www.audioc.com/speakers1/emeraldxl/emeraldxl.htm
5 @ <$500...http://www.behringer.com/B2030P/?lang=ENG
MARGARITAS,
they're not just for breakfast anymore.
Mudslide is offline
Old 12-05-2008, 11:53 AM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
The 805 will have no problem.
So if the speakers sit 1-2' from the front wall, you will be sitting 8-9' (maybe even closer)from the speakers...right?
-curtis
cschang is offline
Old 12-05-2008, 12:42 PM - Thread Starter
tpLouKY's Avatar
yes.
tpLouKY is offline
Old 12-05-2008, 03:47 PM
ericm83's Avatar
Speakers under 11" in height you should consider:
Era Design 5
Era Design 4
B&W CM1
Dynaudio Audience 42 (actually 11.1")
Elac 310.2 Jet
Silverline Minuet
ericm83 is offline
Old 12-05-2008, 04:19 PM
ericm83's Avatar
A short while ago I was looking for a small pair of speakers and compiled a spreadsheet of some of the options out there. It is by no means complete, but it might be of some use to you.
Speakers.zip 9.107421875k . file
ericm83 is offline
Old 12-05-2008, 06:00 PM
ChicagoTC's Avatar
Sorry I can't recommend anything as I'm a floorstanding guy(Dali) but I'm VERY jealous of your screen and beautiful room.
ChicagoTC is offline
Old 12-05-2008, 06:26 PM
Tool Guy's Avatar
1 reason and 2 suggestions:
The center channel is king in any movie situation. I base this on the fact that you already have a fantastic sub.
Paradigm Studio 20's on stands and a CC-590 center.
Hard to beat with movies and music. Probably 1800ish.
Paradigm CC-290/ 390 and a pair of V-5 or 6 Atoms. Probably 800ish.
A wall of sound for the money.
You can audition them, possibly bring them home for a weekend, and the new wenge finnish on the Monitors may compliment your decor objectives.
Tool Guy is offline
Old 12-05-2008, 07:28 PM
Pure-Evil's Avatar
Liked: 150
may i ask why you couldn't put 2 towers to the sides of your screen? you'd get a hell of a better more full sound with a full range tower rather than a bookshelf. just my thoughts
Pure-Evil is offline
Old 12-05-2008, 07:34 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
That's debateable, and putting speakers that closer to a sidewall is not a good thing.
-curtis
cschang is offline
Old 12-05-2008, 07:35 PM
Pure-Evil's Avatar
Liked: 150
i think with a little toe in he'd be just fine. i think small speakers are a huge mistake in this case as he has a nice big HT room. just my .02
Old 12-05-2008, 07:36 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Era Design 5
Era Design 4
B&W CM1
Elac 310.2 Jet
Silverline Minuet
I have heard the Eras, the CM1, and the 42. It would be worthwhile to get a listen to the Eras if you can, and the Dynaudio. IMO, the CM1 leaves a lot to be desired.
-curtis
cschang is offline
Old 12-05-2008, 07:41 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Well, I think it depends on how small. Even a little toe-in with the speakers that close to the wall will still have a lot of reflection.
Draw a line parallel with the front speaker baffle and perpendicular with the side wall, and imagine how much toe-in you need to move that intersection a certain distance.
-curtis
cschang is offline
Old 12-05-2008, 08:06 PM
Raymond Leggs's Avatar
Doesen't Definitive technologies make a very slim tower speaker? The OP might like those but the he'd have to move the sub to the back of the room.
Raymond Leggs is offline
