my own "little" speaker quest - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 125 Old 01-15-2009, 06:44 AM - Thread Starter
tpLouKY's Avatar
So you think the set from Paradigm would be a big step back? I thought it would be more of a sidestep from what I've read.
I loved the sound. But honestly, I really liked the sound that I had before with my little rocket tykes from av123. I want something that sounds good to really good and looks great. The sierras just didn't fit with the overall look of my room.
Thanks for the Polk RTi A7 suggestion!
Anything else? Perhaps Def Tech.
tpLouKY is offline
post #92 of 125 Old 01-15-2009, 07:06 AM
rydenfan's Avatar
Paradigm is a very good company. but you really need to go listen for yourself and see what appeals to you.
rydenfan is offline
post #93 of 125 Old 01-15-2009, 07:14 AM - Thread Starter
tpLouKY's Avatar
I hear you and I fully intend on doing so. I was just surprised to hear that all the options I posted were thought to be a step backward in SQ. I didn't know if that was the opinion of one or the opinion of many.
tpLouKY is offline
post #94 of 125 Old 01-15-2009, 08:44 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
If you don't mind used then 311computer.net is selling off their demo Tannoy Revolution Signatures.
- front towers for $800
- centre for $400
- rear bookshelves for $700
(MSRP for this set is $4550)
I've never heard these, but they get rave reviews.
Or IndependentAudioVideo.com has the DC4 bookshelves, refurbed at $475 each. 5 would be slightly over your budget but would fit standing under your screen.
rick240 is offline
post #95 of 125 Old 01-15-2009, 09:03 AM
cschang's Avatar
Quoted: 95 Post(s)
Liked: 154
Did you have the piano black or naturals? What stands did you use?
I just heard a pair of MA RS6's and would suggest a listen.
-curtis
Owner of Wave Crest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #96 of 125 Old 01-15-2009, 11:39 AM - Thread Starter
tpLouKY's Avatar
they were piano black and sitting on their sides on a media cabinet (pic above)
tpLouKY is offline
post #97 of 125 Old 01-15-2009, 12:20 PM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Originally Posted by ericm83 View Post
Those look really sharp paired with the stands, almost like an actual tower. I've seen the Sierra's on those stands in person and they look even better.
I do, yes. In my opinion you'd have to move into the Paradigm Studio line to get competitive with the Sierra's. Perhaps you could find some used Studio 60's or 100's on audiogon? Although, I doubt you'd be able to fit the entire 5.1 system into your budget if you went with the Studio towers. Bummer.
Well, like rydenfan said, listen to everything you can. Also, if you liked the AV123 speakers so much, why not give their ELT or x-series a shot?
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
post #98 of 125 Old 01-15-2009, 02:12 PM
ericm83's Avatar
Sitting them on their side could have been another problem unless you had 3 of the Sierra centers. For them to sound proper the tweeter needs to be turned if you are laying them on their side. It is also best to have speakers away from any reflective surfaces. So for bookshelves putting them on stands and pulling the away from walls is ideal. If they must go on a cabinet make sure that they are pulled up to the front edge. I'm not sure you may have had them pulled forward, I just couldn't see the photo you posted above.
edit: I think Nuance might be on the right track to suggest looking at the used market. You can get some great deals on audiogon/ebay.
ericm83 is offline
post #99 of 125 Old 01-15-2009, 02:38 PM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
+1. I missed the part about them laying on their sides. Unless you purchased three centers, this isn't ideal for sound quality. But you said you like the sound so... Anyway, I wish you the best on your quest.
Nuance is offline
post #100 of 125 Old 01-15-2009, 04:23 PM
ChicagoTC's Avatar
How about Totem? Someone is selling a 5 piece Forest for $3000. Perhaps they would split it up and be close to your budget. I've never heard them but they are on my short demo list when a 2 channel system comes around.
http://www.audiogon.com/cgi-bin/cls....est---model-1-
ChicagoTC is offline
post #101 of 125 Old 01-15-2009, 05:11 PM - Thread Starter
tpLouKY's Avatar
the sierras were all set up as centers and sounded really great.
tpLouKY is offline
post #102 of 125 Old 01-15-2009, 10:30 PM
MameXP's Avatar
Originally Posted by cschang View Post
Well, I think it depends on how small. Even a little toe-in with the speakers that close to the wall will still have a lot of reflection.
Draw a line parallel with the front speaker baffle and perpendicular with the side wall, and imagine how much toe-in you need to move that intersection a certain distance.
What if he put some acoustic panel at the reflection points along the side walls? Would that help? I ask because i will build a small HT room and consider to use floor speaker as well since i dont have any cabinet to begin with. I have considered bookselfs but stands cost too much for their functionality.
MameXP is offline
post #103 of 125 Old 01-19-2009, 04:08 PM - Thread Starter
tpLouKY's Avatar
I went to audition the monitor audio rs6's today. Long story short, I loved music on them (in 2 channel). Very clean, musical and loud. I was, however, quite disappointed once I went 5.1 and put in a bluray. The center channel (RSLCR) seem flat and anemic. Especially with voices.
I'm now beginning to realize how incredible the sierras sound. (I still have them.) I've been watching Ratatouille on Bluray and have been wowed again by their depth and purity.
So now I'm either going to be keeping the sierra's or raising my budget to get a front three with comparable sound to the Sierras. I have to get the Sierras back by the 26th to get a full refund. So I've got a couple of days.
Nuance and others have said the Paradigm Studio series would be a good direction to head. I may have to purchase the two mains first and wait a year or so for the center channel. I'm thinking 1500-2000 for the left and right towers. Any suggestions?
As always, your comments and recommendations are always appreciated!
tpLouKY is offline
post #104 of 125 Old 01-19-2009, 04:11 PM
cschang's Avatar
Quoted: 95 Post(s)
Liked: 154
From your posts, I thought you sent the Sierras back already. Can you show a picture of what they look like in your room?
-curtis
cschang is offline
post #105 of 125 Old 01-20-2009, 10:44 AM - Thread Starter
tpLouKY's Avatar
Sure thing...
With grills
Without grills
Closeup 1
Closeup 2
tpLouKY is offline
post #106 of 125 Old 01-20-2009, 10:47 AM
cschang's Avatar
Quoted: 95 Post(s)
Liked: 154
Thanks. I may be biased, but I like the look. Maybe the natural color would blend better with the room.
-curtis
cschang is offline
post #107 of 125 Old 01-20-2009, 12:42 PM - Thread Starter
tpLouKY's Avatar
After my strikeout with the RS lineup from Monitor Audio, I'm closer and closer to just sticking with this setup. It really does sound phenomenal. And the looks are growing on me. Anybody else have an opinion on either the looks of the sierras or a speaker I should check out?
tpLouKY is offline
post #108 of 125 Old 01-20-2009, 01:14 PM
cschang's Avatar
Quoted: 95 Post(s)
Liked: 154
If you do stick with the Sierras, I would suggest contacting Ascend and trying their Q plugs.
-curtis
cschang is offline
post #109 of 125 Old 01-20-2009, 01:25 PM - Thread Starter
tpLouKY's Avatar
what do they do?
tpLouKY is offline
post #110 of 125 Old 01-20-2009, 01:26 PM
mziegler's Avatar
Just curious: at what height are your speakers? Having the three speakers is great, especially if they are high enough, and you can really take advantage of surround music if you are interested.
I really like the look of your set-up.
AVS: Where everything you write will be used against you.
mziegler is online now
post #111 of 125 Old 01-20-2009, 01:35 PM
cschang's Avatar
Quoted: 95 Post(s)
Liked: 154
what do they do?
Here is the announcement with good info.
http://forum.ascendacoustics.com/showthread.php?t=3781
-curtis
cschang is offline
post #112 of 125 Old 01-20-2009, 01:39 PM - Thread Starter
tpLouKY's Avatar
Thanks. The midpoint of the speakers is right at 23".
tpLouKY is offline
post #113 of 125 Old 01-20-2009, 01:54 PM
PWK2000's Avatar
Wow the Sierras look great in your setup. They really compliment the clean and minimal look of your room! So if they sound great keep them.
How far away do you sit?
PWK2000 is offline
post #114 of 125 Old 01-20-2009, 01:58 PM - Thread Starter
tpLouKY's Avatar
The room is 12.5'x13.5'. The speakers and screen are on the 12.5' wall.
I'm roughly 9 feet away from the speakers. (And about two feet away from the back wall.) Still playing around with it a bit.
tpLouKY is offline
post #115 of 125 Old 01-20-2009, 02:02 PM
mziegler's Avatar
That height will work well.
While the HTM-200s would work well for surround, a couple of Sierras on the Ascend stands would be phenomenal for 5 channel audio.
Either finish for the speakers should look really good in your room, but I would have leaned toward the natural finish like cschang.
post #116 of 125 Old 01-20-2009, 09:52 PM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Well, in that case, check out the Salk SongTower's. I've heard nothing better under $3500, and if you are considering the ribbon tweeter version (out of your budget), I've heard nothing better in the midrange department under $5000 (because I haven't head the HT3's yet ). Just my $0.02. I am an owner, so you can call me bias. Heck, we're all bias concerning what we own.
Nuance is offline
post #117 of 125 Old 01-20-2009, 10:01 PM
ChicagoTC's Avatar
I'll just say again, you could throw circa 1988 Cerwin Vega's in that room and it would still be beautiful!
post #118 of 125 Old 01-21-2009, 01:09 PM - Thread Starter
tpLouKY's Avatar
It's official. I'm sticking with the sierras. They just sound so good. For the price, I'm absolutely blown away. Watched Casino Royale on bluray and listened to some great music today. Thanks so much for all of your help guys. I really appreciate it. On my own, I would have been absolutely hopeless.
tpLouKY is offline
post #119 of 125 Old 01-21-2009, 01:26 PM
MameXP's Avatar
nice choice, Sierra is on my list as well. Did you get all 5 of them?
Where is the sub?
MameXP is offline
post #120 of 125 Old 01-21-2009, 01:39 PM - Thread Starter
tpLouKY's Avatar
just 3. the back two are htm 200se's. the sub is currently in the back where my wife likes it. (av123 mfw15).
tpLouKY is offline
Reply Speakers
