Polk t15 Does anyone have these?? - AVS Forum | Home Theater Discussions And Reviews
Old 12-06-2008, 02:09 PM - Thread Starter
CMoe's Avatar
I am looking at these as surround speakers.
They are $100 less than the TSI100's
Am I gonna hear the difference???
They do not have them hooked up at Best Buy so I cant listen.
Tsi100 53Hz-25kmhz
T15 60Hz-24kmz
thats the only difference I could find, and the T15s will fit my speaker stands better.
CMoe is offline
Old 12-06-2008, 02:12 PM
juggy4805's Avatar
Tsi100 53Hz-25kmhz
T15 60Hz-24kmz
I have no idea how the Tsi's sound but the T-15 are cable as rears. I initially used them as fronts until I upgraded. Don't expect any bass and I had them crossed over at 100hz. If you want more information on them search for info on the Polk R15. Identical driver and tweeter. The only difference is the color. The match well with my Monitor 50 and CS1 if thats saying anything.
juggy4805 is offline
Old 12-06-2008, 06:36 PM - Thread Starter
CMoe's Avatar
Thanks for the info.....I went and picked these up since the adjustable speaker stands I bought wont hold my bose bookshelfs.
I get these home and they have a wall mount but not a stand mount.
I bought the only adjustable stnads I could find at both Circuit City and Best Buy. There are 5 different adapters for all types of speakers, but none for polk.
How Frustrating.....do i let them just sit on the stands like shelves?? Surely they will fall.
CMoe is offline
Old 12-06-2008, 06:45 PM
Big Wes's Avatar
I actually just installed the T15s I picked up on Black Friday as rears today. I ran into the same problem you did, so I secured them to the stands with a couple small wood screws. Yes, it left two small holes in the bottom of each speaker, but it was cheaper than buying new stands and much cheaper than buying a new set if they were to topple off the stands.
TWW resident bullet sponge
PSN: ThreeWulfMoon
Big Wes is offline
