How should I ugrade? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-08-2008, 07:56 AM - Thread Starter
terminal33's Avatar
Quoted: 122 Post(s)
Liked: 65
Ok I currently have the KEF 3005 SE system. However, after visiting a Magnolia showroom at Best Buy tonight, I realized I want more...especially from my subwoofer. They were playing Iron Man and it was so impressive that I decided to upgrade my system. (I tried to look at the brand of the sub and I think it was Fresco.)
I've been reading about all the iQ's that Kef has to offer. The XQ's are out of my price range. But I've been reading about so many possible combinations. The overall message I've gotten is that the front 3 speakers are the most important. Therefore I plan to use my 3005 speakers as surround speakers and get 3 brand new speakers up front.
But will all the IQ's be a definite upgrade from the 3005 speakers? I want a significant difference. My current possible combinations are listed below and I was wondering which one is best...
1.) iQ1 - iQ6C
2.) iQ5 - iQ6C
3.) iQ7 - iQ6C
4.) iQ9 - iQ6C
Is there a better combo than the one's above? My room is about 33' x 24' x 12'. I have hard wood floors and my couch is about 10 feet from the TV, which means there is about 23' of space behind me. So I need a system that will fill the room. I think the 3005 SE are a little weak for my room.
The sub is another issue. Does KEF have good subs or should I go with another brand? I want more rumble for my movies.
I plan to spend about $1000-1200 for the front 3 speakers and another $600-800 for the sub, so about $2000 in all. Once again, I plan to use m 3005 as the surround speakers. I'm hoping the iQ's will be a significant upgrade from the 3005 set. If not, then can someone make suggestion? The speakers will be mainly used for blu ray movies and not music. Please let me know your thoughts. Thanks!
Epson 5040ub
Hsu VTF-15H MK2
Ascend Acoustics 340 & 170
Denon X2300W
Philips UHD player
terminal33 is online now
post #2 of 4 Old 12-08-2008, 08:15 AM
gunbunnysoulja's Avatar
Originally Posted by terminal33 View Post
I plan to spend $600-800 for the sub
Epik Knight or Caliber
SVS SB12-Plus or PB12-NSD/2
HSU VTF-3 MK3
eD A5 - 350 or A7S - 450
AV123 MFW-15
gunbunnysoulja is offline
post #3 of 4 Old 12-08-2008, 10:37 AM
Knucklehead90's Avatar
Quoted: 501 Post(s)
Liked: 431
HSU VTF-3 MK3
AV123 MFW-15
+1 on the sub recommendations. Winners all.
You will need big speakers to fill that room. I can see why you are impressed with the setup Magnolia has. Remember they have set up a sound room that is ideal for listening. Taking home what sounds good there won't guarantee similar results at home. In fact, I'd bet on it based on your description.
You may need to concentrate some on the acoustics of such a large room. You may be able to significantly improve your current setup, and any subsequent gear will also benefit. Look to spend some of your budget on improving the acoustics of the room.
Some acoustic panels behind you would help. A large throw rug in front of you would help also.
You didn't mention the ceiling height.
Larger speakers and more power may only serve to make an acoustically challenged room worse. You'll get more 'loud' but it may be worse than what you have now. This is usually the case.
Perhaps you could post a few pictures or a drawing of the listening space.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #4 of 4 Old 12-08-2008, 03:46 PM - Thread Starter
terminal33's Avatar
Quoted: 122 Post(s)
Liked: 65
My ceiling height is about 12 feet. I know my room is big and acoustically challenged. I just ordered a SVS PB 13 Ultra subwoofer. Hopefully I'll hear the rumble that I'm looking for. The only thing I've done acoustically is put a blanket on top of my coffee table that's in front of the TV. I will eventually upgrade from my KEF 3005 speakers, or use two as my surrounds and get a whole new soundstage to go with my PB 13. Any suggestions?
Epson 5040ub
Hsu VTF-15H MK2
Denon X2300W
Philips UHD player
Reply Speakers
