Help With Klipsch GMX 5.1 System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-08-2008, 05:49 PM - Thread Starter
DontWannaName's Avatar
Hello everyone,
I have an old Klipsch 5.1 GMX 5.1 computer speaker system and my amp/control pod has been having problems. The system freezes a lot and wont turn on. Both problems can be temporarily fixed by taking the power out and putting it back in. Since support wont help me, I was wondering if anyone knew my options. The speakers are fine but the amp or control pod isnt. Is there something I can use to replace the amp and control pod or do I have to buy a whole new system? If I were to buy a system, it would be the Logitech Z5500 for $220 even though they are 4 years old now. Anyone know if they are actually going to make a new system?
DontWannaName is offline
post #2 of 3 Old 12-08-2008, 09:37 PM
Slare's Avatar
The GMX sats are pretty nice speakers for PC use. I'd recommend you just try to find a loose sub from a similar logi or klipsch system, because the cost of a suitable replacement amp likely won't make any sense.
Another thing to note is since they are pretty decent sats, if you buy a cheaper logi system that just has regular speaker outputs, you could sub them in. Most logi systems have good enough subs but the sats are pretty crappy.
Slare is offline
post #3 of 3 Old 12-08-2008, 10:30 PM - Thread Starter
I need a control pod and a new Sub I think. What are my options, I would love DTS since my Xplosion sound card has DTS connect.
Reply Speakers
