Seaton Sound Catalysts arrive! - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 161 Old 01-21-2011, 07:02 PM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
A steal at ~$3.5k apiece.
Here is the product listing.
Yes, onboard power, and plenty of it.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #152 of 161 Old 01-22-2011, 03:17 AM
Kimwyn's Avatar
Thanks FOH! These speakers look like the real deal. Mark makes some awesome products, I am definitely looking at these as an option.
Question: when it says FR 50-20000Hz do they roll off quickly at 50Hz or do they actually have useful output at 50Hz?
Kimwyn is offline
post #153 of 161 Old 06-17-2011, 04:05 PM
nimbusnic's Avatar
I'm new to the Seaton Audio universe and am trying to soak up as much information as I can before I make a purchase.
This might be a dumb question, but I'll shoot it out there anyways. Besides the obvious differences in how the speakers are powered and varying price points, can someone please tell me how the Catalyst LCRs would compare to Triad's Platinum LCRs and Focal's Utopia III Viva offering? Are these speakers built for different purposes or different sized theater rooms?
I have seen photos of both Triad's and Mark's speakers used in similar installations, with three vertical LCRs behind an AT screen. I think this is a sexy setup, and I'm considering it for my own theater. Can someone please tell me, if I were to use three Catalysts alongside two Sumbersive HPs behind an AT screen, would there be the potential for screen movement due to the large amount of air being thrown about?
nimbusnic is offline
post #154 of 161 Old 06-19-2011, 01:37 PM - Thread Starter
fugueness's Avatar
I'm using three Catalysts + two Submersive HPs behind an AT screen and there is no screen movement. See here.
fugueness is offline
post #155 of 161 Old 04-16-2012, 05:38 PM
Dbuudo07's Avatar
Quoted: 238 Post(s)
Liked: 212
I was wondering if there are any max SPL numbers for the Cat 12's and 8's. Just getting an idea for the largest rooms these can handle.
David Budo
Dbuudo07 is offline
post #156 of 161 Old 08-13-2013, 12:28 AM
Marcus Gan's Avatar
Quoted: 12 Post(s)
Hi Guy,
If I place the Cat 12 Horizontally must I change the Tweeter orientation too?
If yes, is it going to be an easy job. Just unscrew and turn 90 degree and fix it back.
Thanks for you advise.
Marcus
Marcus Gan is offline
post #157 of 161 Old 08-13-2013, 02:09 PM
Mark Seaton's Avatar
Quoted: 695 Post(s)
Liked: 1869
Originally Posted by Marcus Gan View Post
Hi Guy,
Marcus
Hi Marcus,
The Catalyst speakers use a coaxial 8" driver which is perfectly symmetrical (round actually). No adjustments are needed when orienting them horizontally as the driver is the same no matter which way you rotate it.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is online now
post #158 of 161 Old 08-13-2013, 03:10 PM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
I currently use my center Cat12C horizontally, it works splendidly.
FOH is offline
post #159 of 161 Old 08-13-2013, 03:59 PM
Marcus Gan's Avatar
Quoted: 12 Post(s)
Hi Mark & FOH,
Thanks and glad to hear that. Horizontal position only temporary once I upgrade to AT screen will place back vertically.
Marcus
post #160 of 161 Old 09-14-2013, 07:12 PM
Marcus Gan's Avatar
Quoted: 12 Post(s)
Hi Guys,
Can I confirm do I need 3 power point for 3 catalyst or I can use 1 power point and connect the 1st spk power output to 2nd spk and 2nd spk output to the 3rd speaker.
Marcus
post #161 of 161 Old 07-02-2014, 08:04 PM
Marcus Gan's Avatar
Quoted: 12 Post(s)
Hi,
Thought of getting the JBL SCS 12 as ceiling speakers for Dolby Atmos.
Can this speakers match with Seaton Cat.
http://www.jblpro.com/www/products/c...2#.U7THyrGwrX4
Marcus
Reply Speakers
