What the heck is causing that pop in my speakers? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #31 of 35 Old 05-01-2013, 06:58 AM
3DMakesMeDizzy's Avatar
I have the same cross-talk issue with a dimmer switch and fan speed control. I contacted Lutron and they recommended a Quiet Fan control. The problem is with solid-state electronic controls and the phenomenum that occurs when an inductive load (a motor coil for example) has a sudden change in the current going through it. Unlike a DC circuit in a car where this is called "load dumping", in an AC circuit the problem is similar but different (make sense?) The power supply in your audio equipment is picking up on the cross-talk that the ceiling fan 'dumps' into the neutral wire, and is especially more apparent when you have your equipment on the same circuit. Lutron suggested using a choke (but they didn't say where, so I'll guess it would go on the wire TO the ceiling fan) or a Quiet Fan speed control. Or, this will be expensive, rewiring your circuits to separate them.
My first guess is to try a high quality speed control on the fan. Next a choke.
3DMakesMeDizzy is offline
post #32 of 35 Old 06-24-2013, 11:08 PM - Thread Starter
toolwarrior's Avatar
Wow, suprised to see this thread is still alive. The response from the poster via Lutron does make some sense. I would like to understand this concept of "choking"
It may solve the issue, permenantly. Any other experts on the subject have more detail?
toolwarrior is offline
post #33 of 35 Old 02-20-2016, 08:47 AM
poster72's Avatar
Same issue here, what is the answer to this? I have a fireplace fan and when it is turned off the speakers pop. The amp is on the same circuit as the fireplace fan im sure. I don't believe it to be a wiring problem, but just typical issue with motors on a switch like this.
I don't have an easy way to put either on a different ckt, surprised my power filter doesn't clean it up (maybe it is some already?).
any solutions?
poster72 is offline
post #34 of 35 Old 02-20-2016, 11:47 PM
RayGuy's Avatar
Quoted: 923 Post(s)
Liked: 786
This should do the trick ... unless the interference is airborne:
http://www.psaudio.com/perfectwave-p5-power-plant/
RayGuy is offline
post #35 of 35 Old 03-08-2016, 06:49 AM
poster72's Avatar
yes, i imagine that should fix about any issue at that price.
seriously though, this quiet fan control idea....maybe putting a switch like this on there instead of the cheap throw switch that is on there would help the fan not "feedback" in to the circuit when turned off?
http://www.amazon.com/Lutron-Electro...et+fan+control
poster72 is offline
Reply Speakers
