Definitive Technology Mythos Series Thread - Page 191 - AVS | Home Theater Discussions And Reviews
Old 05-16-2015, 02:08 PM
seattleike's Avatar
Quoted: 18 Post(s)
Thanks. When I get home I'll try recalibrating with the sub volume set to 25%. So just to clarify I set the lf to 150 and just leave it there before and after the calibration right? I know my main speakers (ST-L's have subs in them so I make sure they are set to large.
seattleike is offline
Old 05-21-2015, 07:28 AM
mitchlewis's Avatar
Quoted: 13 Post(s)
So if I buy a pair of Mythos floor-standing speakers with the built-in powered sub, will I really not need a separate powered sub for home theater use? I like powerful bass, and I find that hard to believe. (wish there was somewhere I could go to hear them)
mitchlewis is offline
Old 05-21-2015, 07:13 PM
Maddmaster's Avatar
Quoted: 17 Post(s)
If you like powerful Bass you might need a separate Powered Sub. Much depends on your room though. Some are more than satisfied with the Bass from the Floor standing built in Sub's. Keep in mind it sometimes is hard to dial in the subs.
Front - Mythos ST, Center - Mythos 8 and 10
Front Height - Gems, Side Surround - Gem XL
Back Surround - Gem XL
Sub - Supercube Ref
There can never be enough music
Maddmaster is offline
Old 05-22-2015, 08:31 AM
mitchlewis's Avatar
Quoted: 13 Post(s)
Thanks! I think I'm going to go with Mythos Ten on-wall speakers and a big HSU powered sub. My tv is over the fireplace so I think floor standing speakers would be too far away.
Old 05-22-2015, 02:21 PM
jdg345's Avatar
I've been thinking about going this route also. I have an SVS PC12Plus, should that be enough to handle the lower frequencies?
I would be replacing some Wharfdale Floor Standing Units with the (2) Mythos Ten's. The rest would be my Center as a Polk CS20, TL2's for the Sat's and RC80i's in the ceiling.
Thoughts?
jdg345 is offline
Old 05-22-2015, 07:08 PM
mitchlewis's Avatar
Quoted: 13 Post(s)
Sorry, but I don't have any experience with those items. Good to know that someone else is considering the Mytho's Ten though.
Old 05-22-2015, 07:52 PM
Maddmaster's Avatar
Quoted: 17 Post(s)
Thoughts?
Tens will work very well and your SVS PC12Plus should handle your lows with no problem.
Sub - Supercube Ref
Old 05-22-2015, 10:06 PM
dapala's Avatar
I'd like some input. Do you think Mythos One's are "a lot" better then the Mythos Four's?
I bought the pair of Four's for $300 each from Newegg a couple years ago. Also an Eight for center for $250 and two Two's for $200 each. Really great deals now that I see what these (old) speakers are selling for now. Looking back I wish I would've gone Eight's all around at that price... It's clearly the best speaker in the group.
Considering how much I like the Eight, is $1500 worth an upgrade to the One's from the Four's? I could sell the Two's or Four's and use the other pair as surrounds.
So my main question is how much better the Ones would be over the Four's.
dapala is offline
Old 05-23-2015, 12:14 AM
ALtlOff's Avatar
Quoted: 187 Post(s)
Liked: 61
Personally I think the One's are one of the best Mythos speakers ever produced (short of the ST-S or ST-L) but I've only heard the Fours one time so really couldn't say how much better, if it were me and you could use floor standers for your surrounds, I'd sell the Two's and use One's up front and Four's in back.
But don't pay $1500 for the One's unless you are only comfortable with NOS, One's go for les than $1000 on e-bay all the time and most people who bought them new tool really good care of them. (I recently bought a complete package, One's, a Three and Gem's on stands for les than $1k, just be patient)
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
Old 05-23-2015, 05:59 AM
pftechnician's Avatar
Quoted: 46 Post(s)
I have mythos ones for main speakers and I went out and got really good Sewell locking banana plugs. They fit super, super snug in my Studio Monitor SM55's but they only go in half way and do not lock in on the Mythos ones. I gave it some force too but just not going in all the way. Anyone else have this problem? Am I doing something wrong? Should they fit snug? Thanks for any help.
pftechnician is offline
Old 05-23-2015, 07:33 AM
ALtlOff's Avatar
Quoted: 187 Post(s)
Liked: 61
Mine are the same, but so are all of my vintage towers as well, I'm not using locking so they stay in ok, I just backed out the screw caps all the way so it doesn't look to odd on the speakers that are out in the open, the only way to go real secure would be something like the Sewell Deadbolt Crows Foot, that's what I used in my floor standers that have the connections on the bottom. (At least with them you don't have to worry about stray broken or frayed wire strands)
My Build Thread:
ALtlOff is offline
Old 05-23-2015, 08:25 AM
Quoted: 46 Post(s)
Ok I guess I'll try that. Is it just they way the Mythos ones were designed? Shouldn't banana plugs and speaker connections be universal by now?
Old 05-26-2015, 01:38 PM
jdg345's Avatar
Even for music ?
jdg345 is offline
Old 05-27-2015, 12:09 PM
geomatic's Avatar
Hey all! I just purchased a pair of Mythos 4s and a Pro Sub 800 for an amazing price (although the glass bases are MIA). I'm very excited to finally have some Def Tech in my house! I'm now moving on to replacing my center followed by the surrounds eventually. What center would you all recommend to match the Mythos 4s? I'm pretty sure the 3 is to wide for my entertainment cabinet but I'll double check the measurements tonight. The pro2000, CS-8040, or any other recommendations? My budget is $200-$350ish. I can go higher if needed but would like to stay in that ball park. Let me know your thoughts. Thanks!
geomatic is online now
Old 05-27-2015, 12:50 PM
ALtlOff's Avatar
Quoted: 187 Post(s)
Liked: 61
Double check your measurement, I've still got a Three for sale, but if it won't fit, the PC-2000 would be my next choice.
My Build Thread:
ALtlOff is offline
Old Today, 10:31 AM
geomatic's Avatar
I've measured the opening and it's 24.5". To small for the Mythos 3 or 7. What does every one think about the Mythos XTR-40 as a center channel? Also looking at the C/L/R 2002. As suggested before, the PC-2000 is also on the list. Any more opinions? Thanks!
Definitive Technology Bp8 Tower Loudspeaker Single Black , Definitive Technology Mythos 6 Aluminum Stand , Definitive Technology Mythos 1 Tower Speaker , Definitive Technology Mythos St 120v Supertower Speaker Single Black , Definitive Technology Mythos Sts 120v Supertower Speaker Single Black , Definitive Technology Bp7006 120v Tower Speaker Single Right Channel Black , Definitive Technology Mythos 4 Tower Speaker Single Black , Definitive Technology Mythos 5 Tower Speaker Single Black , Definitive Technology Mythos 7 Center Speaker , Definitive Technology Mythos 3 Center Channel Speaker Single Black , Speaker Systems , Definitive Technology , Definitive Technology Mythos Xtr 50 On Wall Or Shelf Mounting Ultra Thin Loudspeaker Black
