**Official EMP Owner's Thread** - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 956Likes
post #301 of 7652 Old 03-13-2012, 04:54 PM
jephdood's Avatar
Liked: 53
This thread needs more pics.
jephdood is offline
post #302 of 7652 Old 03-13-2012, 06:14 PM
cdub5's Avatar
Originally Posted by KRELL44 View Post
I've had many Klipsch speakers in the past and I currently have the emp 55ti's.This is a difficult comparison as they are completely different speakers.The horn tweeter is a very effecient design,requiring minimal power to drive.However,it does sound harsh and can become fatiguing.They are good for movies.....for music,not so much.
The emp's are a 3-way design with a fabric dome tweeter and 2 mid-range woofers,much better for music and vocals.....They are a nominal 6ohm speaker,but are easy to drive.The Klipsch are so efficient You could drive them witha mouse on a treadmill(lol).
For me,after having both Polk speakers and the Emp's,i could never go back to Klipsch and the horns....but,that's just me,I'm more of a 2-channel,music person,now....rolling tubes and buying the lastest Dac's.
For home theater,the Klipsch are pretty damn good.I would try out the Emp's,as they have a 30-day return policy....I'm extremely happy with my new 55ti's.....sometimes,it pays off to make a radical change.....hope this helps......peter
Thanks, Peter
cdub5 is offline
post #303 of 7652 Old 03-13-2012, 06:23 PM
h2oluver's Avatar
I'm new here. Been lurking for a while and following this thread with interest. I myself ordered a set of the E55ti's during the B stock sale. Took about 2 weeks for me to get them. I guess they were swamped. My B stocks looked like A stock. I couldn't find anything wrong with them and I have looked! I just ordered the large center channel and the dual sub. The sale wasn't quite as good as I had hoped it to be so I have to hold off on the surrounds. Anyway, I have a question in regards to the E55Ti towers. The power rating says 50 to 200 watts. Is this RMS rating or is the 200 peak? My current Onkyo Htib receiver doesn't drive these as well as I like so I am considering getting a new A/V receiver but with preouts so I have the option of using external amps if I want to. Anyway, I'm not clear on the power range for these speakers for my equipment consideration. I typed this on the phone app so sorry if any misspellings or such.
h2oluver is offline
post #304 of 7652 Old 03-13-2012, 06:32 PM
slammin86's Avatar
Quoted: 23 Post(s)
Liked: 29
200 rms. I'm giving my front 3 about 250 each.
slammin86 is offline
post #305 of 7652 Old 03-13-2012, 06:47 PM
h2oluver's Avatar
Ok, thanks slammin. Can I ask what you are powering yours with? I'm guessing they do fine with the extra power?
h2oluver is offline
post #306 of 7652 Old 03-13-2012, 06:51 PM
slammin86's Avatar
Quoted: 23 Post(s)
Liked: 29
Acurus a3-200 rated 200x3 @ 8 ohm and 300x3 @ 4 ohm.
post #307 of 7652 Old 03-13-2012, 07:08 PM
h2oluver's Avatar
Thanks again. Pretty frustrating that you have to spend a bunch of money to get a receiver with pre outs. I could deal with my sub par head unit if it had more power. The feature set while not great is good enough for me right now. Since I'm more of a music guy and not so much movies and have a large and unusual room I still like my music loud. So i want the option of more power. I love the emps and it took some begging to get my wife to give in and let me order them (it also helped was my birthday at the time). But she likes the look of them, her being particular on what can go in the room, plus shesmiles when she sees me acting all giddy cranking up some good old rock and roll while kicking back with a beer or two. Hmmm.... Forgot where i was going with this post.....
h2oluver is offline
post #308 of 7652 Old 03-13-2012, 08:04 PM
Scottyp3's Avatar
Anyone else notice the links in the package deals dont match up tot eh right info for each speaker?
Scottyp3 is offline
post #309 of 7652 Old 03-14-2012, 10:23 PM
bitterwaste's Avatar
Alright I got the E55ti speakers and Center, and WOW they are amazing looking!!! but for wires any suggestions? the run is less then 10' long so 16 gauge maybe? any company I should go with? just a quick few suggestion because I don't want to take away from the speakers them self.
EMP tek 5.1 theater setup, Marantz SR6006, Oppo BDP-95
Salk Songtowers, Emotiva XPA-2, ERC-1.
This is a horrible hobby!!  My wallet hates me, takes up to much space, neighbors want me to move, but man my house sounds amazing!
bitterwaste is offline
post #310 of 7652 Old 03-14-2012, 10:29 PM
vv132's Avatar
Hey I just made a purchase of the Denon 2112CI reciever and a 5.1 EMP tek speaker set up which includes :
E5Bi Bookshelf Speakers
E5Ci Center Speaker
E5Ti Tower Speakers
ES10i SUBWOOFER.
I have my fios cable set up, wdtv live, and xbox360(mw3).
I ran the wizard/auto set up and it recognized the front towers as small/centers small/bookshelve surrounds small. Should i set the front towers to large?(feel like these speakers have alot more base power than there outputting right now). Is this correct? For bass settings auto set it up as LFE, should i set it to LFE plus main? lfe is set at 120 hz. For cross over freq. it says advanced )front full bad_ but shaded out cant change it, and center is 80hz. I found the volume to be pretty low which seems to be my problem. I have small svs book shelf speakers that have more bass than these so far. I have to set the receiver to -5db which believe has to be messed up. I turned dyn volume off.
Also i set the notice on and there was no firmware update. If i just got the receiver should there be a firmware update or is it already likely updated? I cant see the firmware version in the set up menu.
Also the setup has the Front towers at -5.5db , center at -3.5db, and sub at -7.5db
Should I make any changes to the sub changes? I did what was rec. before running the setup. Should I lower the frequency? on my svs sub upstairs i manually changed it to 80 hz dont know if i should do it for this?
Thanks for the help!!!
vv132 is offline
post #311 of 7652 Old 03-15-2012, 04:21 AM
slammin86's Avatar
Quoted: 23 Post(s)
Liked: 29
E5Ci Center Speaker
E5Ti Tower Speakers
ES10i SUBWOOFER.
If it were me I would start by disabling all the room correction software for the time being. The set the towers to full range and get an idea of the sound they produce. Give them a few days to see if they "loosen up" at all then re run all the room correction software.
post #312 of 7652 Old 03-15-2012, 06:15 AM
NewToHT's Avatar
http://www.monoprice.com/products/su...02&cp_id=10239
16 or 14 is absolutely fine! Don't spend a bundle on wires.....it is a waste of money.
NewToHT is offline
post #313 of 7652 Old 03-15-2012, 06:52 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Me too. Emotiva XPA-3. Sounds wonderfull too. even with low sensitivity teh speakers are still louder than the surrounds that have horn tweeters. ypao had to turn the surrounds a lot louder when calibrated. They dont have that ear piercing horn tweeter sound either.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #314 of 7652 Old 03-15-2012, 06:57 AM
Quoted: 978 Post(s)
Liked: 506
I agree. After a week of listening the speakers sounded even better to me. People say that they dont have all that great bass, but when I put the E55Ti's in a small room and compaired them to my Klipsch's they prevailed. They sounded soo good down low.
post #315 of 7652 Old 03-15-2012, 08:06 AM
slammin86's Avatar
Quoted: 23 Post(s)
Liked: 29
What are your surrounds? My emptek bookshelves should arrive today to serve surround duty.
post #316 of 7652 Old 03-15-2012, 08:28 AM
Quoted: 978 Post(s)
Liked: 506
Klipsch s1 for the surrounds and some polk's for the surround backs. Let me know how the Emp's sound. I am curious about their surrounds. What are you using right now for your surrounds?
post #317 of 7652 Old 03-15-2012, 10:16 AM
slammin86's Avatar
Quoted: 23 Post(s)
Liked: 29
Did you ever try them without the amp? I am tempted to try feeding them off of my onkyo just to see what the difference is.
I did have polk m30 surrounds but sold them weeks ago with the m70's and cs2 center for $350.
post #318 of 7652 Old 03-15-2012, 01:39 PM
Quoted: 978 Post(s)
Liked: 506
I did connect them to another receiver with the vf-35's that I replaced them with and they were not as loud. Keep in mind that the vf-35's had a sensitivity of 96db.
post #319 of 7652 Old 03-15-2012, 05:50 PM
KRELL44's Avatar
The bass is very,very accurate....We've all become accustomed to how low the woofers go,We've forgotten what "accurate" bass sounds like(myself included).With a fast musical sub,these are very revealing......I have the Revel T-1 and with the 55ti's,it makes for an incredible combo for music.
KRELL44 is offline
post #320 of 7652 Old 03-15-2012, 05:56 PM
KRELL44's Avatar
Anyone get EMP's newsletter today?....it says the current sale is good until 3/31/2012....I don't think you're going to see any "B" stock 55ti's until the sale ends and they get rid of the clearance E5Ti's.
KRELL44 is offline
post #321 of 7652 Old 03-15-2012, 06:29 PM
slammin86's Avatar
Quoted: 23 Post(s)
Liked: 29
Got my bookshelves today. Packaging was great.
So I hooked them straight to my receiver and played them for a bit without the sub. These sounded much bigger than they were. Very nice soundstage even with them being so close together.
Listened for about 20 min then unhooked them to drill some holes in them. Because I need to wall mount these I had to come up with something.
Before...
After...
Notice anything?
I also removed the rubber foot pads from the bottom.
And finally put a coat of spray wax on them and put them on the wall. LOL. They are not hooked up yet have to go under the house again and secure some wires and cut to length. Last weekend I replaced my old 22 ga htib wire under the house with 12 ga monoprice wire.
It looks like my $747.50 dollar emp tek system is complete. If all goes well I will run audyssey this weekend and be done.
post #322 of 7652 Old 03-15-2012, 08:53 PM
Thanks NewToHT, I think I will go with that!
post #323 of 7652 Old 03-15-2012, 08:56 PM
Before...
After...
Notice anything?
That is awesome slammin86, will you give us a small review on your final thoughts on the full system?
mhaider likes this.
post #324 of 7652 Old 03-16-2012, 08:05 AM
slammin86's Avatar
Quoted: 23 Post(s)
Liked: 29
Yeah when all is hooked up and calibrated and I have some good time listening to it I will.
post #325 of 7652 Old 03-16-2012, 08:20 AM
bigtim2000's Avatar
The e5b look great. Nice to that the sound great too!
bigtim2000 is offline
post #326 of 7652 Old 03-16-2012, 07:10 PM
Scottyp3's Avatar
has anyone had experience with the surround speakers they offer?
Scottyp3 is offline
post #327 of 7652 Old 03-17-2012, 05:57 PM
gene c353's Avatar
Quoted: 138 Post(s)
Liked: 99
I just posted the E5Ti's I bought last week in the for sale forum. They are absolutely gorgeous in Red Burl for the price and packing truly is first rate. Bass response is more akin to a good bookshelf but so what...you're going to use a sub anyway. Not sure I'd pay $500/pr for them but at $275 they were a treat. They look way above their price range and sound pretty good as well. I was going to use them in a new bedroom system but I have two other setups already and that's enough. I should have taken some pictures before I boxed them back up. Oh well.
gene c353 is offline
post #328 of 7652 Old 03-17-2012, 06:24 PM
vv132's Avatar
why wouldnt u you just return them to emp if you just bought them?
vv132 is offline
post #329 of 7652 Old 03-17-2012, 11:00 PM
gene c353's Avatar
Quoted: 138 Post(s)
Liked: 99
No returns on "B" stock items.
post #330 of 7652 Old 03-17-2012, 11:00 PM
bigtim2000's Avatar
Clearance speakers are not returnable except to be replace.
Reply Speakers
Emp , Emp Tek , Emp Tek E10s Subwoofer , Emp Tek Ef30c Center Speaker , Emp Tek Ef30t Tower Speakers , Emp Tek E55tir Tower Speakers , Emp Tek Ef30 Bookshelf Speakers , Speaker Systems
