**Official EMP Owner's Thread** - Page 113 - AVS Forum | Home Theater Discussions And Reviews
 584Likes
Old 08-04-2014, 08:10 AM
Transmaniacon's Avatar
Quoted: 1445 Post(s)
Liked: 1252
Originally Posted by ill_take_one View Post
Thanks guys.
I do realize that these speakers were never meant to produce lows. I have read through this entire thread before finally biting the bullet to order these.
However, even at very modest/low levels, with my sub shut off, they seemingly are distorting and losing volume. To me, that seems odd. My old crappy bose bookshelf speakers wouldn't even distort/sound like that.
Oh if that is what you are experiencing, you may have an issue with your receiver.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is online now
Old 08-04-2014, 09:18 AM
FMW
FMW's Avatar
Quoted: 1628 Post(s)
Liked: 1657
Thanks guys.
Losing volume compared to what? Do they start loud and then display reduced volume? If so then your receiver is probably broken. Can you describe the distortion? Is it ever clean? If so, in what situations? As an E55 user myself, I can tell you they will play loud enough to drive you out of the room and they sound very good, even at high volume. Something appears to be broken. After you eliminate the receiver and wiring from the problem, give EMP a call.
Transmaniacon likes this.
FMW is offline
Old 08-04-2014, 10:11 AM
ill_take_one's Avatar
Basically say you have a song that is playing and there's no bass during the music, like an intro...and then the bass starts kicking in during a song and the speakers volume noticably decreases. The complete sound coming from the speakers sounds like its distorted. It's hard for me to describe the exact sound that I'm hearing.
I did some research and I believe I have a Sony STR-DE885 receiver, or something of the like. It's obviously a cheap receiver as I stated before and many negative reviews. Could it be because the speakers are 6ohms and that receiver wouldn't be up to par for handling the extra load?
What receiver would you guys recommend in the $250-500 range for 5.1 receivers?
Thanks so much for the help!
ill_take_one is offline
Old 08-04-2014, 10:22 AM
Elihawk's Avatar
Quoted: 828 Post(s)
Liked: 714
Well, I can assure you that those Bose weren't even getting close to 50hz. A couple question, what volume/spl are you listening at? these speakers are really good, but I don't think they are designed to produce reference level! Second, what type of EQ have you tried?
Last night, I listened to some Tommy Bolin, so some very bass heavy classic rock with the smaller version of the towers (e5Ti) and man, those speakers rock and never waviered! I wasn't listening at ear splitting levels, but loud enough I would NOT have been able to talk with anyone!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
Old 08-04-2014, 10:25 AM
Elihawk's Avatar
Quoted: 828 Post(s)
Liked: 714
I have the Denon 1613 reciever and it has more than enough features and power for my use! I got mine for a few shekels over 200 dollars about a year ago...
Elihawk is offline
Old 08-04-2014, 10:30 AM
Liked: 1252
So you don't notice any problem when watching movies, just music causes the volume to fade?
The receiver should be able to power them alright unless something is not working correctly. I am a fan of Denon, you can get the Denon AVR-X2000 for $399.99 from www.crutchfield.com and it offers incredible value. You get the second best version of Audyssey, networking, and you have the 7 channels should you ever expand or want a second zone.
Old 08-05-2014, 08:39 AM
I believe I've found the culprit. For music, I was using my old Ipod and noticed the EQ setting was on. I turned the EQ off on my Ipod and this drastically improved the sound! I'll keep testing, but I think it's that simple!
Either way, I'll still be looking for a new receiver.
Thanks guys!
Old 08-05-2014, 10:43 AM
11427's Avatar
I used to have a Sony STR-DE995 quite a few years ago. It really struggled to drive the 6 ohm floor standers that I had at the time. Don't recall distortion unless it was really loud. It would get really hot and go into protection mode quite often while watching action films with dynamic soundtracks. I think a new receiver would be a pretty good idea.
Mark
11427 is offline
Old 08-14-2014, 06:15 AM
Elihawk's Avatar
Quoted: 828 Post(s)
Liked: 714
Btw, a freind of mine brought over his Bic f12 sub and we did a head to head challenge with the E10i10i sub. Not a perfect test by any means, but we set both subs in the best spot based on a sub crawl (which isn't where I normally have the sub, since it is in the way). I had done a similar challenge with my Klipsch 12Wd and the EMP was far away better in terms of SQ, and I think got as loud. A similar comparison with the SVS PB1000 and the EMP sub was every bit as good, perhaps not hitting quit as low but not very noticable difference.
Anyway, I think we both agree that the EMP was a more faithful sub and performed better except maybe in very bass heavy movies. During a couple scenes of Oblivion, I get some minor distortion with the EMP which we didn't hear with the F12. Anyway, we spend about 2 hour with both subs for music and some selected scenes from movie and wouldn't hesitate to won either subwoofer. However, I would't trade my EMP for the Bic either! If EMP hadn't discontinued this sub, I would own two of them right now!
Elihawk is offline
Old 08-14-2014, 06:20 AM
Liked: 1252
I really would have liked to get one of those es1010i! It's nice to know it can roll with the likes of SVS I own a F-12 and am ready to ditch it, but being in an apartment has that on hold Did you find the output to be similar between the EMP and BIC subs?
Anxious to see what EMP has in store for their new sub, Brian said it is due out this winter in time for the holidays.
Old 08-14-2014, 06:51 AM
AllenA07's Avatar
Quoted: 555 Post(s)
Liked: 440
I'm not at all surprised to hear that the 1010i outperformed the F12, it's really in an entirely different class. I would be curious to see some charts comparing the SVS PB1000 to the 1010i. Both subs are in a similar class and I've heard good about both. The F12 is good for what it is, a solid $200 subwoofer, however I wouldn't really expect to be in the same playing field as anything from SVS.
It is amazing what a good sub does for the EMP towers. I've got my SVS PC12+ crossing over at 80hz and am thrilled with the overall sound from my system.
AllenA07 is offline
Old 08-14-2014, 08:09 AM
Elihawk's Avatar
Quoted: 828 Post(s)
Liked: 714
Yes, there is no way I would say the EMP sub outperformed the SVS, but it held its own very nicely and I really couldn't tell any difference, except in the deepest lows. And that EMP sub really put out good output. Mine is in a pretty large room (14x24) and no way do I think I need a second sub for more output, perhaps just to even out the bass responses through the room.
one more thing about the EMP vs Bic challenge. While the Bic didn't distort on a couple bass heavy scenes from Oblivion, it was always less accurate, especially at the low end. Much of the low sounded muddy and not clear. Much like the EMP towers, the sub performs very well within its limits and doesn't try to get below where it can play comfortably (which I would say is 30hz and above)!
Elihawk is offline
Old 08-14-2014, 08:23 AM
AllenA07's Avatar
Quoted: 555 Post(s)
Liked: 440
My experience with the F12 is that it did a good job down to about 35hz. Between 30-35hz there was a dramatic roll off of ability, and by the time you got down to 30hz (really by the time you hit 32hz) the sub was passing into unusable territory. I had my F12 in the setup for 2 years and was pleased with it while I had it. I would love to see EMP come out with a solid sub in the $250 range!
AllenA07 is offline
Old 08-14-2014, 10:37 AM
FMW
FMW's Avatar
Liked: 1657
I have an F12 on my personal computer audio. It only plays music and not very loud. i would say that if you use a sub like i do with my computer, the F12 is fine. If you want loud and deep, perhaps not so much.
FMW is offline
Old 08-14-2014, 10:41 AM
Elihawk's Avatar
Quoted: 828 Post(s)
Liked: 714
I would get if you used the +/- 3db standard, the EMP sub probably does hit below 35 either...maybe down in to the low 30 hz, but not much more...but it seem to hold up very well to that point. Like I said, except several scenes in Oblivion, I have never heard an issue with the SQ of the EMP sub. And while the SQ is very good, it is far and away the best looking sub in anything less than 1000 range!
Elihawk is offline
Old 08-14-2014, 12:25 PM
ousooner2's Avatar
Quoted: 240 Post(s)
Liked: 142
Distortion can sound loud also
Definitely with you in that the e1010i's are some of the best looking subs out there. The RBH stuff looks close, but not glossy. I think I'd like it to be not glossy at times. I can't tell you how much I'd love to have a pair of RBH sx-8300/r's and the sx-1212/r subs. Dream setup! You can amp the 3 woofers on the bottom of the sx-8300/r from a standalone amp, eq them separately, etc. They're essentially subs! Combine that power/midbass with some solid subs, likely incredible midrange and one of the best tweeters ever made.....wow
Panny 65st60 / Denon X1000 / EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
ousooner2 is offline
Old 08-14-2014, 02:20 PM
Liked: 0
Hi guys, I am getting ready to pull the trigger on these in red burl.
E55Ti Towers
E56Ci Center
E5Bi Bookshelfs
They are giving me about 65 bucks off of the package. Hope these are the right choice!
EDIT: I will be using these for sports/satellite tv, music and bluray. Will these work for everything?
Hoeft87 is offline
Old 08-14-2014, 03:09 PM
Liked: 1252
E55Ti Towers
E56Ci Center
E5Bi Bookshelfs
Excellent choices! I think you will be very happy with them
What do you plan to use for a sub woofer?
Old 08-14-2014, 03:10 PM
Liked: 1252
I think that exact setup from RBH is my end-game system.
Old 08-14-2014, 03:35 PM
Liked: 0
I am not sure, what do you guys suggest? I'd like to keep it under 400 bucks.
Hoeft87 is offline
Old 08-14-2014, 04:18 PM
Liked: 1252
I would recommend saving up a little more and going with an SVS PB-1000. $500 is the starting point for good subs, there really isn't much in that $350-450 range. You can get the PB-1000 from their outlet for $475, http://www.svsound.com/specials/outl...pb-1000-outlet
If you don't want to go that high then I would just recommend getting an NXG BAS 500 for $260, it's a good budget sub that is surprisingly musical.
Old 08-15-2014, 08:52 AM
Liked: 0
So the EMP ES10i sub is not the greatest?
Hoeft87 is offline
Old 08-15-2014, 08:58 AM
Liked: 1252
I would wager it sounds good, but a 10" sub isn't going to have great output (PB-1000 excluded). For music it would work well, but for movies I would want something with better output.
Old 08-21-2014, 10:02 AM
Liked: 0
E55Ti Towers
E56Ci Center
E5Bi Bookshelfs
FINALLY pulled the trigger...hoping to get them next week! Thanks for the help fellas
Hoeft87 is offline
Old 08-21-2014, 10:44 AM
Liked: 1252
Congrats! I think you made a great choice there, that FedEx guy can't come soon enough
Old 08-23-2014, 08:49 AM
mhaider's Avatar
I've been tossing around the idea of upgrading my current speaker system to the EMP E55Ti, E56Ci, and E55Wi. What I'm struggling with is it going to be worth it. What I have now are 16 year old Infinity RS 4 towers, CC3 center, QPS1 quadrapole surrounds, and a BU2 sub. I think they do a good job with movies, but could be better with music. I realize I could order the EMP's and audition them at home and the most I'd be out if I didn't want to keep them is the return shipping cost, but I thought I'd reach out to the forum and get your thoughts. Possibly there is someone out there that had my Infinity's and upgraded. Thanks for your input.
mhaider is offline
Old 08-23-2014, 12:43 PM
FMW
FMW's Avatar
Liked: 1657
That's a tough one because I've never heard the RS4. It is fair to say, however, that speakers have certainly improved overall since the 1970's. These were pretty respected speakers back in the day, however. I would personally be really interested in someone's direct comparison so I'm hoping you bring in a pair of E55's for the comparison.
Personally I have only two negatives about the E55. It is a little weak in the tweeter and the bass is also weak below about 45 or 50hz. This is pretty common with the little woofers they are using these days. I would bet your Infinities would handle the bass better.
I solved the tweeter issue by upgrading the driver and integrating a subwoofer more than took care of the bass. The midrange on these speakers is scary good. I get high end sound from my E55's but not without those two issues being resolved. Without a sub and a better tweeter I would rate them at the higher end of mid fi. Don't know if that helps. I sure like the E55's and would be interested to hear your comparison with the old Infinities.
FMW is offline
Old 08-23-2014, 12:52 PM
FMW
FMW's Avatar
Liked: 1657
Just curious. Has anybody ever removed one of the woofers from an E55? I ask only because I wonder how the enclosure is stuffed. If not well stuffed it might be possible to add some to make the enclosure look a little larger acoustically to the drivers.
FMW is offline
Old 08-25-2014, 04:40 AM
Liked: 1252
If by RS4 you mean the Infinity Reference 2000.4, then I actually owned a pair of these before I got my E55Tis. The difference is pretty significant in my opinion. Much clearer and well defined mid-range, with a more relaxed sound. I found the EMPs played clearer at high volumes than the Infinitys did, bass was a wash between the two.
I think you would be a making a nice upgrade, but I would also prioritize a new sub afterwords.
Old 08-25-2014, 05:33 AM
Elihawk's Avatar
Quoted: 828 Post(s)
Liked: 714
hoeft, you are getting a really nice speaker set! Enjoy...
Hoeft87 likes this.
Elihawk is offline
Emp , Emp Tek , Emp Tek E10s Subwoofer , Emp Tek Ef30c Center Speaker , Emp Tek Ef30t Tower Speakers , Emp Tek E55tir Tower Speakers , Emp Tek Ef30 Bookshelf Speakers , Speaker Systems
taboola here
