**Official EMP Owner's Thread** - Page 202 - AVS Forum | Home Theater Discussions And Reviews
 980Likes
Old 12-29-2015, 08:01 AM
Elihawk's Avatar
Quoted: 1114 Post(s)
Liked: 943
Originally Posted by Transmaniacon View Post
Yeah I have seen both, but only with my old F-12, I will definitely tread carefully.
I usually listen at -10dB, so it's a good thing you mention that I have seen EoT several times, when it was on HBO, but before the new sub and streaming is never as good. Should be a good chance to see what that Ultra can do
The compression thing can be pretty significant on HBO/Cinemax/Netflix...Oblivion, well, I had to re-adjust my subwoofer settings to prevent distortion from the BR and after recording and watching it on HBO, I couldn't make it make my subwoofer distort if I tried (and I watched the recorded versus at -8.5 dB).
So be prepared for the full LFE and that opening scene will give you a pretty good glimpse of what you are getting! btw, solid LFE throughout the movie...
Transmaniacon likes this.
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
Old 12-29-2015, 08:06 AM
bgtighe23's Avatar
Quoted: 1535 Post(s)
Liked: 857
Well I got Edge of Tomorrow and Interstellar for Christmas, so those are next on the list to watch with the new sub!
I have both and really enjoyed both movies. I thought the ending of Interstellar was a bit over done, but the concept and the first 80% of the movie was very engaging and enjoyable - with great LFE of course.
Edge of Tomorrow was a great ride. The entire movie was engaging, and the constant LFE was nice. The bass was very dynamic for the type of movie that it is and didn't seem one noted at all.
If the master volume is at -10dB, are your subs hotter than that? If not, I think you will be fine for Edge of Tomorrow. I listened to some music before starting the movie. I also let the main menu screen role for a few minutes to pick up the volume to about -12dB, but I usually run my subs 4-6dB hotter than the mains. Based on your gear, I think you will have the headroom suitable for Edge of Tomorrow. If you are at all worried, bump the signal down a several dB and watch it, then re-watch it again with more signal. You don't want to skip that scene
Another movie you want to get ahold of is John Wick and Lucy. Two movies I had set aside and never watched up until a couple weekends ago (John Wick) and Lucy a month or so ago. I didn't seem that engaged by watching the previews, but I was very wrong when I finally watched them both. Great LFE as well.
_____ _____ _____ _____ _____ _____ _____ _____ _____ _____ _____
Receiver : Denon x5200
Front Stage : Martin Logan Motion 60XTs/Elac Debut F5 Center
Surround Speakers : HTD Level 3 Towers/RBH R5Bi Front and Rear Heights
Subwooferage : Dual UM-18s/6 SI HT18s
Born in 1995 and still continuing my HT journey
bgtighe23 is online now
Old 12-29-2015, 08:08 AM
rahulp001's Avatar
Quoted: 88 Post(s)
Hi folks,
finally got my 7.1 set up completed. :-)
Here is how it looks.
the rear surrounds are straight behind the couch wall mounted.
Ran the audyssey again, sounds great. But.. there is that punch missing, cant quite put a finger on it but I am not getting that fullness you would expect in movie theaters for example.
Tried with blu ray as well as streaming netflix.
Looking for some suggestions on good blu-ray movies/scenes to assess the sound further.. preferably ones that are in 7.1
7.1 HT Setup: EMPTek E55Ti (L&R), E56Ci (Center), E5Bi (side and rear surrounds), SVS PB-2000, DENON AVR x2100W, BENQ W1070, SilverTicket 110" screen, 3DHeaven ultra clear HD glasses
rahulp001 is offline
Old 12-29-2015, 08:43 AM
Transmaniacon's Avatar
Quoted: 1551 Post(s)
Liked: 1345
My sub level is at -6dB right now from Audyssey, I usually keep it there and bump it up to -3dB if the bass is a little light in the movie. I will probably keep it at -6dB for EoT, and tread carefully. Maybe do a run through to see what I am dealing with and then rewatch when I know what to expect.
I loved John Wick, haven't seen Lucy. Would definitely like to pick that up though, will keep an eye out for a sale.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is online now
Old 12-29-2015, 08:44 AM
Liked: 1345
Originally Posted by rahulp001 View Post
Hi folks,
Looks good! Depending on your room size, you may want more low end to really pressurize that space. A second PB-2000 would be something to work towards in the future.
Old 12-29-2015, 08:45 AM
Liked: 1345
Yeah Oblivion on HBO was a bit disappointing sound-wise, the Blu-Ray sounds absolutely fantastic though.
Old 12-29-2015, 08:48 AM
bgtighe23's Avatar
Liked: 857
Hi folks,
Did you edit any settings after running audyssey? For starters, cross all your speakers over at 80Hz.
What percentage is the gain knob at on the back of the PB-2000? What is the subwoofer signal setting at in your receiver?
After you answer those questions, there is a couple more things to try. What I am thinking is that Audyssey set your mains at 60Hz crossovers and you're losing some oomph at the low end of your mains. Audyssey tends to set the sub a little bass light so we are going to check your current sub settings (with your response to asked questions above)
Old 12-29-2015, 08:56 AM
AllenA07's Avatar
Quoted: 684 Post(s)
Liked: 557
Hi folks,
Audyssey can be very conservative when it comes to bass. A lot of people around this site run their subs a few DB's hot to get that punch they're looking for.
My Theater: The Ugly Theater
AllenA07 is offline
Old 12-29-2015, 09:04 AM
rahulp001's Avatar
Quoted: 88 Post(s)
Yeah, audyssey had me at 40 for the LR and 60 for the center. I already switched them to 80Hz for all.
The subwoofer knob on the back is at about two clicks higher than the center position. The subwoofer signal setting after audyssey was at +5db (will confirm this once again tonite).
Old 12-29-2015, 09:39 AM
bgtighe23's Avatar
Liked: 857
Wow, that seems interesting that your receiver is possibly at +5dB. Did you turn up the gain knob after running Audyssey?
SVS subs usually really start to open up at about 70%. I would "click" it over several more times and re-run Audyssey.
BTW, after running Audyssey, you shouldn't adjust the gain knob. Only the signal level. If Audyssey sets the signal level at -4dB or anything more (-3db, -2dB, etc.), I would add some gain to the back of the sub and re run.
Old 12-29-2015, 09:42 AM
rahulp001's Avatar
Quoted: 88 Post(s)
Oh ok, did not know that. While running Audessey the set up recommends to have the subwoofer knob at the center position. So, left it there before i ran audyssey. After running audyssey I thought the bass was lacking so I went and moved the knob a bit higher.
Thanks for the input.
Old 12-29-2015, 10:03 AM
Elihawk's Avatar
Liked: 943
A couple really good suggestions in the thread. My thoughts, 1. you e55ti aren't producing much at 40hz, so as suggested, bump that up to 60 or 80 Hz crossover. 2. Second, agree, sub setting make a huge difference, so take heed to some suggestions here. 3, Finally, I know little of the PB2000, but have only heard good things about the SVS subs. Could be that for the size of your room, you will need more sub, but that sub should definately give you some PUNCH, so I don't think that it is. have you tried the subwoofer crawl to determine the best place for your sub?
Elihawk is offline
Old 12-29-2015, 10:50 AM
ereed's Avatar
Quoted: 948 Post(s)
Liked: 476
I do not have Audyssey or those special software since my rotel seperates are 12 years old and I do not have emp teks so I can't give opinions about that ...but I will tell you from my experience having multiple systems in the past I've always had to set my speakers to small and cross them at 80hz and bypass the xover at the sub for best performance in my room. Gave me the most punch that way. Maybe you do need another sub? I usually have my sub gained 5 db higher than my other speakers using spl meter when I calibrate it.
Theater: Sony 45es, 120 inch 16:9 screen, Panny BDT500, Rotel RMB-1075, Rotel RSP-1068, Klipsch RP-280F, RP-450C, RP-160M, SVS PB13 x 2, Monster Power Conditioner, GIK acoustic panels
TV Room: Panasonic 60" plasma, Integra DTR-30.3, Axiom Audio M60, VP150, QS8, EP500
ereed is offline
Old 12-29-2015, 05:41 PM
taxman48's Avatar
Quoted: 311 Post(s)
Liked: 303
Originally Posted by ereed View Post
Would love you to post pics of those EMP Teks with emotive gear!
Originally Posted by AllenA07 View Post
How are you liking the monoliths for the EMP's? I've got an XPA-5 powering my fronts, and have been very happy with it.
The speakers are outstanding, watching football and listening to some cds again.. Very nice sound, beautiful and worth the wait..I will watch a loud BD as soon as I set up my new player that was also in Santas sled..My 100" screen comes down in front of 52" set..
ID:	1150354   Click image for larger version
taxman48 is offline
Old 12-30-2015, 10:02 PM
ViperVenom18's Avatar
Quoted: 68 Post(s)
Liked: 57
Just added this!
ViperVenom18 is offline
Old 12-31-2015, 04:31 AM
Liked: 1345
That is a heck of an amp!
By the way, watched EoT the other night, you guys weren't kidding about the opening scene bass! I don't think the HBO version even had that in it... but the movie sounded fantastic. That initial scene where he is dropped in was fantastic, the Ultra did a great job.
Old 12-31-2015, 05:15 AM
bgtighe23's Avatar
Liked: 857
Originally Posted by ViperVenom18 View Post
[URL=http://s197.photobucket.com/user/vipervenom18/media/IMG_7890.jpg.html][/URL
I was about to say, have you considered putting the center under the TV and the AV gear inside the entertainment center? Then I saw the 2nd pic The setup looks great! Love the look of the new Impression subs!
Glad you enjoyed that scene and also the Ultra did a good job with it! I think you should splurge a little this weekend and grab some good blu-rays for the weekend! Because I know I am! I have a nice list of movies to watch while I have the house to myself for the entire weekend!
Old 12-31-2015, 05:31 AM
Elihawk's Avatar
Liked: 943
All IMHO...best movie I have heard for LFE only:
Godzilla, 2014...but man, not a great movie. IF I want a crappy-acted movie, I could watch Zombie movies, which often have great soundtracks.
Best movies that are actually good movies for LFE:
EoT, Oblivion, Battle for LA, Fury, Intrastellar
Best surround content movies:
2012, Avatar, Lone Survivor
Man, Viper, you have an intimidating front stage!
Elihawk is offline
Liked: 1345
I've got Interstellar to watch and might pick up Mad Max as well!
Old 12-31-2015, 05:37 AM
AllenA07's Avatar
Quoted: 684 Post(s)
Liked: 557
Mad Max is an assault on the senses in every sense of the term. I used it as one of my debut Atmos movies, and it is now pretty firmly entrenched as my demo for immersive audio. It's a fun movie and will give a theater a good workout.
AllenA07 is offline
Old 12-31-2015, 05:39 AM
bgtighe23's Avatar
Liked: 857
Good list. I would add lot's too it, but there are just so many!
YAYYY, seriously...get Lucy I was rather surprised by the LFE.
OH, PS! I got one of those Tripp Lite things you have your sub plugged into. Pretty solid little box
I also got a flat, and angled extension so I can cover both with the sub itself instead of bending the wire.
Name:	Screen Shot 2015-12-31 at 8.00.44 AM.png
ID:	1152914   Click image for larger version
Name:	Screen Shot 2015-12-31 at 8.02.13 AM.png
Old 12-31-2015, 05:44 AM
Elihawk's Avatar
Liked: 943
I need to rewatch Lucy...
Elihawk is offline
Old 12-31-2015, 06:30 AM
Liked: 1345
Yeah I need to pick that up as well! My Amazon wishlist is basically a bunch of Blu Rays
That was a good idea getting that cable, and yeah it seems like a well-built adapter.
Old 12-31-2015, 07:48 AM
ereed's Avatar
Quoted: 948 Post(s)
Liked: 476
Just added this!
Wow! I have one subwoofer in my huge open floor plan and its already loud so I can't imagine how 4 subs sound! Love the setup! How would you describe the sound of those emp tek towers? How are they for 2 channel music vs home theater in your room? Any screen shots of the rear surrounds or back of the room?
ereed is offline
Old 12-31-2015, 07:56 AM
ereed's Avatar
Quoted: 948 Post(s)
Liked: 476
Nice setup! How much bigger is 100 inches from your 52 inch? Maybe a picture showing both side by side. How far do you sit from the screen?
ereed is offline
Old 12-31-2015, 08:16 AM
bgtighe23's Avatar
Liked: 857
There are also these little puppies. I don't own them personally. They should be fine for basic outlets, but they don't specify the max power draw these can handle.
http://www.amazon.com/gp/product/B00...mh_gw_g23_i1_r
Oh, here's the link for the extension cable I got. I needed about 8" more, so it's the reason I chose to get the 1ft. extension over this hug-a-plug. The 1ft. extension also takes up less space, so I can put my sub half an inch closer to the wall
http://www.amazon.com/gp/product/B00...mh_gw_g23_i2_r
Both products save solid 5 star reviews, and I've used longer SF Cables and they seem fine.
Name:	Screen Shot 2015-12-31 at 10.09.29 AM.png
ID:	1153226   Click image for larger version
Name:	Screen Shot 2015-12-31 at 10.09.35 AM.png
Transmaniacon and yanks1 like this.
Old 12-31-2015, 08:46 AM
Montucky's Avatar
Quoted: 404 Post(s)
Liked: 265
Intimidating is right! I love Viper's setup. I work with a lot of high end homes around here where people have spent ungodly amounts of money on their A/V, yet I'd take Viper's basement over 99% of the high end, beautifully finished "home theaters" in those places. Absolutely epic.
BTW, how's your house holding up, Viper? Foundation's still intact?
Montucky is offline
Old 01-01-2016, 07:46 AM
bgtighe23's Avatar
Liked: 857
^ Just a few Acoustic Panels to really maximize his speaker's potential and I think he is set! Really has a nice "bassment" feel to it
Old 01-01-2016, 12:51 PM
dsrussell's Avatar
Quoted: 2234 Post(s)
Liked: 3033
Very good list (2012 and Battle for LA) I rented (one-time view for me). San Andreas is a bass heavy movie, but again, a one-time view for me. I just couldn't get into Mad Max (took me several days to watch it, but it does have very good LFE content). Really enjoyed EoT, Oblivion, Fury, Interstellar, Avatar and Lone Survivor. Lucy is better than I thought it would be and it is a short movie (around 80 minutes). Loved the song track when the final credits rolled by. Another nice surprise for me was 3 Days to Kill.
Music area: Magnepan 3.6, McIntosh MC2205 amp & C48 preamp, SVS SB13-Ultra, Oppo BDP 95, dbx 3BX, and assorted equipment.
Movie area: EMP Tek E5Bi (were rebadged to R5Bi), RBH/EMP Tek R55Ti, PSA S3000i, Denon X2000, Oppo BDP 83.
dsrussell is offline
Old 01-01-2016, 03:58 PM
bgtighe23's Avatar
Liked: 857
That song is by Damon Albarn. Song title is Sister Rust. I purchased it right after I watched Lucy. The bassline is featured throughout the movie which I ran pretty hot
This song does a pretty great job at covering lot's of areas to test speakers and some sub.
dsrussell likes this.
Emp , Emp Tek , Emp Tek E10s Subwoofer , Emp Tek Ef30c Center Speaker , Emp Tek Ef30t Tower Speakers , Emp Tek E55tir Tower Speakers , Emp Tek Ef30 Bookshelf Speakers , Speaker Systems
