**Official EMP Owner's Thread** - Page 241 - AVS Forum | Home Theater Discussions And Reviews
 1003Likes
Old 11-22-2016, 02:26 PM
keyweez360's Avatar
Quoted: 85 Post(s)
https://twitter.com/EMPTek/status/801173825429901314
The official blessing! Order has been placed
keyweez360 is offline
Old 11-22-2016, 02:27 PM
Elihawk's Avatar
Quoted: 1226 Post(s)
Liked: 1039
I have the EMPe5ti, the EMP10i10i subwoofer and the EMPe5bi as surrounds, all ordered on closeout or B stock. I have yet to find a single flaw, with the exception of the large chip in my e5Ti that my dog did after they arrive- he decided to knock the speaker over! So no, I haven't found anything in my three purchases that I could see and say- that is why they are B stock!
keyweez360 likes this.
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is online now
Old 11-22-2016, 02:48 PM
hyperactiveme's Avatar
Quoted: 119 Post(s)
Liked: 73
No b stock anywhere. Was hoping for another sub or center channel
hyperactiveme is offline
Old 11-22-2016, 02:55 PM
banyar's Avatar
Quoted: 127 Post(s)
Liked: 24
what will be best for clear dialogs on movies as fronts?
three identical R5bi
or
two R5bi and R5Ci?
banyar is offline
Old 11-22-2016, 03:50 PM
Quoted: 119 Post(s)
Liked: 73
or
two R5bi and R5Ci?
I have 3 of the R5bi, sitting 13' away without issue. However I don't have the center to compare them vs each other.
Old 11-22-2016, 06:07 PM
ousooner2's Avatar
Quoted: 291 Post(s)
Liked: 179
3 identical speakers up front is the best route 99% of the time
Transmaniacon likes this.
ousooner2 is offline
Old 11-22-2016, 06:12 PM
Luisfc1972's Avatar
Quoted: 290 Post(s)
Liked: 29
well with this bf sale i think im finally going to jump on emptek. upgrade from 1st generation andrew jones pioneer speakers
having a hard time between two choices
3 bookshelves or
towers and their center
around $600 price difference between the two choices
for a room that is roughly 12 x 18 or so (havent measured) that opens up to the dining room, would the towers and center be overkill?
i dont have a problem spending the extra money, but thats a big price difference.
primarily for movies but do listen to music. id say 80%/20%
Luisfc1972 is offline
Old 11-22-2016, 11:28 PM
dsrussell's Avatar
Quoted: 2251 Post(s)
Liked: 3060
Luisfc: It depends. For me, I began with 3 R5Bi's. A year and a half later, I tried out the towers and was surprised there wasn't a greater difference. With the R5Bi's you're going to need a good subwoofer. With the R55Ti's, you will also need a good subwoofer, but it can wait a bit. The towers are 3 dB more sensitive, so you can play those louder than the R5Bi's (but I found the R5Bi's got more than loud enough for me). I'd rank the R5Bi's as a bit better for music, while the R55Ti's a bit better for movies. Others will rank them differently.
Music area: Magnepan 3.6, McIntosh MC2205 amp & C48 preamp, SVS SB13-Ultra, Oppo BDP 95, dbx 3BX, and assorted equipment.
Movie area: EMP Tek E5Bi (were rebadged to R5Bi), RBH/EMP Tek R55Ti, PSA S3000i, Denon X2000, Oppo BDP 83.
dsrussell is offline
Old 11-23-2016, 02:08 PM
ousooner2's Avatar
Quoted: 291 Post(s)
Liked: 179
So I'm selling my 5.0 to a friend and as I was taking them down I decided to run the bookshelves as fronts with the subs to see how it sounds compared to the r55ti towers. I prefer the bookshelves actually. More midrange clarity and top end.
... I was thinking about trying some other bookshelves, but now I might just order a pair of these and call it a day. Maybe 2 pairs of I want some surrounds again. $150/pr is so darn cheap
Was going to try the Rp-160m or something sensitive as I have a very large, open layout.
Old 11-23-2016, 02:14 PM
WCoast02's Avatar
I was considering buying E3 series speakers to mount on the ceiling as back speakers and side speakers in a 7.1 system. has anyone ever mounted these before? Any suggestion on a speaker mount? Thx in advance
WCoast02 is offline
Old 11-23-2016, 02:52 PM
ereed's Avatar
Quoted: 1157 Post(s)
Liked: 651
I do have the RP160 as my rears (which is overkill) but have ran it as 2.0 and they can go really loud and clear. I was never a fan of Klipsch til I ran across the new rp line from local classified for really cheap so I couldn't refuse. I noticed its not bright sounding as lower line or older series because of rubber horn instead of hard plastic. Its hard to compare it to R5bi since it cost more. Both do music really well and both would benefit from a sub if you want full range sound. RP160 will definetly play deeper and higher frequencies but for the price R5bi is something special. Only way is to compare but you should compare for few hours to see if you like the sound, after all your friend has it so it should't be hard to go back and forth to see what you like.
Theater: Sony 45es, 120 inch 16:9 screen, Panny BDT500, Rotel RMB-1075, Rotel RSP-1068, Klipsch RP-280F, RP-450C, RP-160M, SVS PB13 x 2, Monster Power Conditioner, GIK acoustic panels
TV Room: Panasonic 60" plasma, Integra DTR-30.3, Axiom Audio M60, VP150, QS8, EP500
ereed is offline
Old 11-23-2016, 07:19 PM
Luisfc1972's Avatar
Quoted: 290 Post(s)
Liked: 29
hmm, when you say a good subwoofer im assuming you dont mean a bic f12. i own that one and happy with it but its a little boomy with music. i could sell it. any good ones you recommend on black friday sales? something better than the f12 but id like to not go overkill using those bookshelves and a room of my size, roughly 12x18.
Old 11-23-2016, 08:03 PM
Elihawk's Avatar
Liked: 1039
I was going to recommend the black friday sale SB12 NSD from SVS, but apparently it sold ot today.
Old 11-23-2016, 11:21 PM
dsrussell's Avatar
Liked: 3060
I suspect that between the two rooms you are around 3,500 cu. ft. (lower end of what is considered “large” for a subwoofer). The larger the area, the more difficult it becomes for a subwoofer to handle. BIC makes very decent low-end equipment and always has. But for music AND handling the low frequency effects (LFE), which can hit below 20 Hz, a better choice is warranted. One that has good output around that 20 Hz mark. Once you hear/feel it, you will understand.
Right now is a good time to buy. Many are running black Friday specials. Look at Rythmik, Outlaw Audio, EMP Tek and Hsu for subwoofers around the $500 to $600 range (ported 12-inch designs).
BTW, the subwoofer I matched with those little R5Bi’s was a PSA S3000i (two opposing 15-inch drivers with 1,700 watt amplifier). This is in a fairly open room (4 foot and 6 foot openings) and it's around 3,400 cu. ft. The PSA wasn’t overkill for those speakers, although it could have been if not setup properly.
Old 11-23-2016, 11:28 PM
dsrussell's Avatar
Liked: 3060
This doesn't surprise me. While I have a slightly brighter room than you (where the R55Ti's performed pretty well at the top end), the R5Bi's had a better top end and a more pristine upper midrange. The R5Bi's actually put out a bit larger soundstage as well. Where I felt the R55Ti's showed their muscle was in the lower midrange and upper bass frequencies.
Since you know the R5Bi's strengths, it might be a good idea to check other speakers as well. You just never know ... I've found 2 speakers that I prefer (but only marginally), but there isn't anything I've heard that I've liked better than the R5Bi's close to their price point.
Old 11-24-2016, 05:13 AM
gregoryperkins's Avatar
Quoted: 466 Post(s)
Liked: 178
I got one last year and really regretted not getting a second. I'm not sure where they came from since SVS hasn't sold them since last year's sale. I got a second the other day.
They play significantly lower than my 1010i and are quite small compared to a ported box.
gregoryperkins is online now
Old 11-24-2016, 07:06 AM
Elihawk's Avatar
Liked: 1039
the subwoofer is still available from amazon, and free shipping if you are a prime member!
Old 11-24-2016, 09:03 AM
ereed's Avatar
Liked: 651
There is also like new svs sb2000 in piano gloss black for $600 shipped in classifieds. Thats even cheaper than svs outlet price! Great sub if you're looking in that budget.
ereed is offline
Old 11-24-2016, 11:08 AM
Luisfc1972's Avatar
Quoted: 290 Post(s)
Liked: 29
i just ordered 3 bookshelves in red burl.
any good stands for the bookshelves? i think someone posted some $60 ones but too tired and stuffed to look through each page.
not sure if i need to buy screws or double sided tape.
Old 11-25-2016, 08:01 AM
ereed's Avatar
Liked: 651
Sanus makes nice stands. Look at their steel foundations or natural series if you want to save money. Amazon has nice pricing on those stands. Just make sure you get right height where tweeter is ear height when sitting. If you don't have pets or small children or if the stands are out of your way then placing on top will be just fine. I have my Klipsch RP160m (which is HUGE bookshelf) on speaker stand with 6x6 inch plate and no issues as long as you don't bump to the stand. EMP teks are small so really any stand will work.
ereed is offline
Old 11-25-2016, 08:41 AM
Transmaniacon's Avatar
Quoted: 1581 Post(s)
Liked: 1380
I would go with a metal stand like the Sanus Steel Foundations or VFI stands. They are a bit more money but much more stable and offer things like adjustable spikes, cable routing, and a fillable center column. As for attaching the speaker, I would look for Blu-Tak found in your office supply area, it won't damage the finish.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Old 11-25-2016, 01:26 PM
Apotheosis's Avatar
Liked: 0
some help please.
I am running the bookshelves and center up front in a 14x14 room, with the couch about a foot from the back wall.
Now I would like to purchase surrounds but im not sure what to do since I can only mount on the rear wall. Side walls is not an option.
Would i be better off buying the bipole R55Wi surround speakers (overkill?) or just buying another pair of bookshelves?
thanks!
Apotheosis is offline
Old 11-25-2016, 01:34 PM
Liked: 1380
Originally Posted by Apotheosis View Post
some help please.
thanks!
In your case the bipoles could work since you have some space behind then couch. Or you could use the bookshelves with some of the video secu clamp mounts and angle them in.
Apotheosis likes this.
Old 11-25-2016, 01:37 PM
Quoted: 26 Post(s)
Liked: 0
wall mount for R5Ci Center Channel Speaker
I just purchased the R5Ci Center Channel Speaker during Emptek's Black Friday sale. Is there a wall mount you all recommend for this speaker? Thanks.
sheets1982 is offline
Old 11-25-2016, 02:00 PM
Apotheosis's Avatar
Liked: 0
Thanks Transmaniacon.
Went with the bipoles since it came out to the same price with shipping as the bookshelves.
Old 11-25-2016, 02:07 PM
Liked: 1380
That works then!
Old 11-26-2016, 11:44 AM
lsturbointeg's Avatar
Quoted: 113 Post(s)
Liked: 31
hey guys i'm wondering if it's worth picking up another pair of R55WI's for side surrounds as my current E55WI's are used as my rear surrounds? or instead pickup the R5BI's as my rears instead and swap the E55WI's as side surrounds? my thinking was the bipole could give me a better wrap around effect for surrounds?
lsturbointeg is offline
Old 11-26-2016, 11:52 AM
Luisfc1972's Avatar
Quoted: 290 Post(s)
Liked: 29
any idea when theyl start shipping bf deals out? i just got a receipt of purchase but no shipping notice yet.
Old 11-26-2016, 01:37 PM
ereed's Avatar
Liked: 651
In 5.1 system there are no rear surrounds, they are side surrounds. They should be at 90 degrees to begin with. If you are upgrading to 7.0 then you should have your bipoles at sides and bookshelf at rears. There is not much information in the rear surrounds as the side surrounds so you may or may not hear any difference but def go with bookshelfs and they are cheaper as well for the rear surrounds.
ereed is offline
Old 11-26-2016, 04:47 PM
Luisfc1972's Avatar
Quoted: 290 Post(s)
Liked: 29
is this the stuff people use to mount speakers on stands?
https://www.amazon.com/gp/product/B0...=A9DP0U9HEFC10
Emp , Emp Tek , Emp Tek E10s Subwoofer , Emp Tek Ef30c Center Speaker , Emp Tek Ef30t Tower Speakers , Emp Tek E55tir Tower Speakers , Emp Tek Ef30 Bookshelf Speakers , Speaker Systems
