**Official EMP Owner's Thread** - Page 261 - AVS Forum | Home Theater Discussions And Reviews
 999Likes
post #7801 of 7805 Old 04-28-2017, 08:09 PM
Zorba922's Avatar
Quoted: 2654 Post(s)
Liked: 1852
Originally Posted by Luisfc1972 View Post
it set the distance of the sub at 0.3 ft from mlp, which is actually around 12 feet.
Holy hell, that means the receiver's probably been muffling the heck out of that sub all this time, the subs has probably been playing at a fraction of its output capability...NO WONDER you were having trouble with fullness/bass!
Seriously, just try turning off Audyssey and setting the levels and distances manually. It's not really "user error," I think this is about the worst case of Audyssey-generated disaster I've ever read about.
Most receivers have a "Pure Direct" mode that turns off all signal modifications but keeps the subwoofer in play---usually just a matter of pushing a button, and then again to revert to previous settings.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is online now
post #7802 of 7805 Old 04-28-2017, 10:11 PM
dsrussell's Avatar
Quoted: 2236 Post(s)
Liked: 3035
now that i think about it when i got the empteks a few months ago i did the audyssey calibration again. apparently there was a hiccup. it set the distance of the sub at 0.3 ft from mlp, which is actually around 12 feet. i guess i could manually set the sub distance to 12 ft but not sure how that will affect everything.
The Audyssey setting for the sub isn't distance at all. It is time delay. Each subwoofer will have some sort of processing going on that delays the signal. Audyssey makes up for this with a filter shown as distance (for whatever reason). Normally, this delay sets the subwoofer at a greater number, not a lesser number. It's possible BIC isn't using any processing at all, however, I would run Audyssey again to check, or as Zorba pointed out, just set everything up without Audyssey. Audyssey is a good tool, but people have been integrating their subs far longer than Audyssey (or any bass management system) has been around.
Madmax67 likes this.
Music area: Magnepan 3.6, McIntosh MC2205 amp & C48 preamp, SVS SB13-Ultra, Oppo BDP 95, dbx 3BX, and assorted equipment.
Movie area: EMP Tek E5Bi (were rebadged to R5Bi), RBH/EMP Tek R55Ti, PSA S3000i, Denon X2000, Oppo BDP 83.
dsrussell is offline
post #7803 of 7805 Old Yesterday, 08:07 PM
Luisfc1972's Avatar
Quoted: 205 Post(s)
ok all is good now
ran audyssey again. it set the sub at 13.1 feet and -5.5 db. i did up the center and sub level 1db each. set the towers to 60 and center to 80. still have more experimenting to do.
audyssey flat and deq on still sounds best to me.
once in a while treble does sound slightly harsh.
i cant imagine this sounding better upgrading my bic f12 to something like an svs or hsu. im thinking maybe i dont need to but im curious.
Luisfc1972 is online now
post #7804 of 7805 Old Today, 09:15 AM
Zorba922's Avatar
Liked: 1852
Rather odd; everyone who's had the R55ti towers talks about how the treble is slightly rolled off, compared to the greater neutrality of the R5Bi bookshelves. This may be yet another Audyssey screw-up. Does this happen with Audyssey turned OFF?
The F12 as I understand it is great for its $200-ish pricepoint, but going up to a $500-600 sub like the Hsu, SVS, Rythmik, etc. gets you much more precise/tight bass that hits lower and faster and with a flatter frequency response. You could also try the RSL Speedwoofer 10s at $400 since (like the SVS PB1000) it comes with free return shipping in case you don't hear any significant improvement.
post #7805 of 7805 Old Today, 06:01 PM
Luisfc1972's Avatar
Quoted: 205 Post(s)
there was a harsh treble, a scene in the movie knowing, the airplane crash when the plane's wing hits the ground.
i still havent tried audyssey off yet
i think im going with the hsu vtf2 mk5 when theyre back in stock, or perhaps the speedwoofer.
Reply Speakers
Emp , Emp Tek , Emp Tek E10s Subwoofer , Emp Tek Ef30c Center Speaker , Emp Tek Ef30t Tower Speakers , Emp Tek E55tir Tower Speakers , Emp Tek Ef30 Bookshelf Speakers , Speaker Systems
