**Official EMP Owner's Thread** - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 579Likes
Old 01-30-2014, 12:26 PM
Transmaniacon's Avatar
Quoted: 1345 Post(s)
Liked: 1152
Originally Posted by lsturbointeg View Post
do you get any reflections or echoing having wood floors? haven't gone far back in the threads if you're running subs and surrounds?
When I first moved in I noticed a bit different sound compared to the old room they were in (carpet floors). I got an area rug, and Audyssey made a big improvement in the sound. I have the E5Bi surrounds and a BIC F-12 sub, check out my sig, but everything sounds great. It's not an ideal room but I am very satisfied with the sound.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is online now
Old 01-30-2014, 12:31 PM
lsturbointeg's Avatar
sweet! how do you like the E5bi's? I'm currently running the E5wi's for surrounds but was thinking about ordering the E5bi's for front heights.
lsturbointeg is offline
Old 01-30-2014, 12:47 PM
Dooleyone's Avatar
Thanks all for the help with the entertainment cabinet question. It seems like there really isn't a workable solution given my limitations. So, that brings me to my next question. E5 vs E56. Will I really be losing a lot with the E5? I really want to get a kick ass center. I feel like my current center (B&W LCR 60 s3) I which I've had for a long while, just isn't cutting it.
Dooleyone is offline
Old 01-30-2014, 01:01 PM
Liked: 1152
They are great, although pretty much anything will work well for surrounds. I think they would work well for your heights, they also have keyholes in the back so you can easily wall-mount them, I have mine on stands though (apartment).
The E56Ci from what I understand is a much better center. The E5Ci is fine if you are using the bookshelves or the now discontinued E5Tis as fronts, but to keep up with the E55Tis, people recommend the bigger center. What also makes it better is the driver layout. Horizontal centers are compromises in design to be more practical when it comes to placement with a TV. You don't want all the drivers on the same horizontal axis because this can create lobing. The E56Ci has the tweeter off-axis above the mid-range drivers, to help lessen that affect.
Old 01-30-2014, 01:29 PM
FMW
FMW's Avatar
Quoted: 1586 Post(s)
Liked: 1613
I agree with this. Personally, I think the surrounds are better matched to the E55 towers and would make a better center channel than the small center unit. I have the small center because of a furniture fit and it is OK as a center speaker but not terribly well matched. If you can't fit the large center, consider a surround instead.
FMW is offline
Old 01-30-2014, 01:44 PM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
looks sweet! another reason why I like the look of running 2 subs. anyone find any more info on what Emptek is doing about the new sub? wondering if its worth selling my klipsch and running 2 subs for .2?
I'm not sure what the new sub is going to be. But, you're definitely right about two subs, aside from the obvious higher LFE output, it sure does look nice having a matching pair! biggrin.gif
Of course, I got it modified with the TK-427, which cheeks it up another, maybe, 3 or 4 quads per channel.
MrEastSide is offline
Old 01-30-2014, 01:53 PM
FMW
FMW's Avatar
Liked: 1613
If they were to ask my advice I would tell them to make the same 1010 sub but with a plate amp that has a speaker level input feature. If the old model had had that, I would have bought a pair during the black friday sale.
FMW is offline
Old 01-30-2014, 04:48 PM
agree! adds to the bling factor haha! im not sure how Emptek would run 2 12" subs in one box. probably require more enclosure space which would probably mean a bigger box! any other manufacturer running 2 subs beside Emptek? I'm going to do a search on this.
Old 01-30-2014, 04:51 PM
Liked: 1152
RBH is the parent company, take a look at their SX line of speakers, you will notice some familiar faces. RBH sells a dual 10" sub and a dual 12" sub, in addition to their single 10 and 12.
Old 01-30-2014, 04:54 PM
Didn't know that! that means it is possible to see a e12i12i come out. wondering what the cost would be?
Old 01-30-2014, 04:58 PM
I remember reading somewhere here but when the E56ci first came out someone posted about be ready for loving lobing issues or something like that. there's an article he posted a link to that talked about it.
Old 01-30-2014, 05:16 PM
gregoryperkins's Avatar
Quoted: 271 Post(s)
Liked: 98
Right, ideally all the tweeters would be at the same level so that panning across the screen not go up down up (depending on where the center is) with the mids having a less directional effect. That's why they have acoustically transparent screens, so that the speakers can go behind the screen and be at the appropriate height (mid screen as I recall).
I do not have that luxury on my 106" screen and I do not notice a problem. My system sounds great, but if you are more on top of your system with a smaller tv, you might. My center is about 1 foot below the lr tweeters.
gregoryperkins is offline
Old 01-30-2014, 05:35 PM
checked out RBH and the sx1212p looks sweet! I didn't see a listed price for it. they also have the sx1212n but would require an external amp.
Old 01-30-2014, 06:22 PM
Pain Infliction's Avatar
Quoted: 971 Post(s)
Liked: 494
Dual opposed drivers work well in a smaller box but I have only seen sealed versions of this. There are a few manufacturers that do this such as epik, seaton, psa, jtr, jl, and more. PSA actually has three drivers in an enclosure called the triad.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
Old 01-30-2014, 06:53 PM
Elihawk's Avatar
Quoted: 821 Post(s)
Liked: 708
List price on the powered RBH dual 12 inch subs is a shade over 5,000 dollars!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
Old 01-30-2014, 07:13 PM
well damn!
Old 01-30-2014, 08:02 PM
AllenA07's Avatar
Quoted: 531 Post(s)
Liked: 422
allen807...I had my center sit just like yours and many members advised to pull the center forward towards the edge and boy did it make a difference.
My center is as far forward as I can get it. Most surprising part of the e56 is how tall it is. It's large, but it is a great center and I highly recommend it, especially if you've got the e55 towers.
AllenA07 is offline
Old 01-30-2014, 08:08 PM
Gmash's Avatar
Quoted: 144 Post(s)
Liked: 137
This new company, Reaction Audio, is shipping their dual 12" sealed subs and will soon be shipping the dual 15" version. There is a thread in the sub section. The owner has been active on there and he seems like a good guy.
http://reaction-audio.myshopify.com/products/bps-212-powered-subwoofer
Gmash is offline
Old 01-30-2014, 08:44 PM
Quoted: 971 Post(s)
Liked: 494
You can get it cheaper though. There are way better values out there too.
Old 01-30-2014, 11:31 PM
ljmart's Avatar
Liked: 184
mine are about 8.5' separation...not ideal but it's what I have to work with. what are most of you guys running space wise on your mains?
Mine are only about 7' apart, but that's as wide as I can go without blocking a door or sticking one way out in the room. I don't sit very far back so I think it works out alright for me.
same here. about 7.5 due to similar restrictions of blocking door on one side and a tall piece of furniture would block the other side. i sit 9' away. what is ideal? 9'? i assume they should have less toe in since they can't be at 9'?
Samsung PN51F8500 ~ Marantz SR5008 ~ Oppo BDP 103D ~ EMP Tek R55TiB LR, R56CiB, R55WiB ~ Sennheiser Momentum ~ Sennheiser 598
ljmart is offline
Old 01-31-2014, 04:15 AM
Liked: 1152
I have mine at about 9 feet away as well, slightly toed in but that is mainly because I was running a phantom center. My E56Ci should arrive Tuesday so I may reduce the toe-in and run it all in direct to get it where I like, then re-run Audyssey.
Old 01-31-2014, 05:25 AM
Quoted: 971 Post(s)
Liked: 494
It is actually recommended to have your speakers toed in. I would keep them that way.
Old 01-31-2014, 05:27 AM
Liked: 1152
Yeah I plan to maintain some, but I want to experiment with maybe a little less toe-in.
Old 01-31-2014, 08:06 AM
ousooner2's Avatar
Quoted: 240 Post(s)
Liked: 142
PSA, Epik (bye bye lol), Funk Audio, RBH, Seaton, JL Audio and a few others
I HIIIIIIGHLY doubt it's going to be dual 12" though. That'd be more enclosure space (if they went ported....which they would), more power needed most likely, higher costs, etc etc. It'd be awesome, but unlikely. I still would love to pull the EMP drivers out of mine someday and replace them with 2 10's that model well with this enclosure. Then bypass that amp and run a Crown or Behringer amp with a lot of power. Could be a sweet quad 10" setup!
It's surprising how much the SX line looks like the EMP stuff. It's a little different here and there, but the dimensions are spot on. I've always wondered this, but didn't say anything....the EMP drivers are listed as larger than they should be. Likely another reason why the bass isn't as pronouced as people think they should be with 3 6.5" drivers. If you measure from surround to surround, the 6.5's and midranges aren't near as big. Makes me wonder if it's the same faceplate as the RBH SX line and if those drivers would drop in. That'd be one hell of an upgrade haha
Well they charge $399 for the dual 10, so I'd say $499 or $550 for a dual 12 if that was to happen. Doubt it though.
RBH is only sold a select few dealers so the prices usually can be had for quite a bit lower than what the MSRP on them is
I'm going to play with this this weekend. I have mine directly on axis to the main listening position, but I wanted to toe them out a little more and see what happens. With the top end rolling off like they do it's only going to get worse the more they're off-axis to where you're listening.
Panny 65st60 / Denon X1000 / EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
ousooner2 is offline
Old 01-31-2014, 08:07 AM
ousooner2's Avatar
Quoted: 240 Post(s)
Liked: 142
I wonder what driver(s) they're using. Sealed design with a 200rms amp! No way that's getting down to what they say. 24db is their -3dB point...and that's if they're telling the truth. With a sealed setup and very little power I have to wonder about that
Old 01-31-2014, 10:42 AM
FMW
FMW's Avatar
Liked: 1613
Perhaps when you consider room gain. My 15" sealed has an F3 of 32HZ and it seems to handle 20hz pretty competently.
FMW is offline
Old 01-31-2014, 12:02 PM
ousooner2's Avatar
Quoted: 240 Post(s)
Liked: 142
What amp are you using? What driver and what's the enclosure size?
Edit: Just realized their setup on that website is weird. Both the $399 and $699 say dual 12" so I just saw the $699 said dual 12". Anyways, for a dual 12" sealed for $400 that's not terrible, but I'd bet they aren't super sensitive drivers with the xmax/xmech anywhere near a Dayton Ultimax like yours. Not to mention it's a smaller enclosure for less cone area, which will hurt efficiency even more down low. Dual 12's with a 200rms amp just seem crazy to me. Why the hell are plate amps so expensive when you can get a Crown, Behringer, etc for $250-300. Charge and extra $100 for the sub and put 4-5x the power to it in my opinion. I'd like to see what people get measurement wise for these though. Interesting, that's for sure. Love to see some in room measurements, ground plane, etc.
Old 01-31-2014, 12:26 PM
FMW
FMW's Avatar
Liked: 1613
300 watt Class D plate amp. 24" cube.
FMW is offline
Old 01-31-2014, 12:52 PM
ousooner2's Avatar
Quoted: 240 Post(s)
Liked: 142
Not sure of the driver specs on the Reaction sub, but you're about the same cone area, with more power and a much larger enclosure. He mentioned they were were fairly efficient drivers, but that could mean anything to different people. How about you buy the Reaction sub and send me you Ultimax? biggrin.gifbiggrin.gif Still, the Reaction setup is nice looking. DIY is still going to be cheaper, but for most that don't have the time or products to properly build/paint/etc then this could be a nice sub. Looks similar to Epik's stuff and those were great (besides the amps). Can't wait to see what kind of SPL #'s it has
Old 01-31-2014, 01:04 PM
moussaka's Avatar
Quoted: 24 Post(s)
Liked: 42
Since we're talking about subs. I finally got my XS30 yesterday... Planning on putting it through it's paces over the weekend. But, I did a quick calibration and threw on WWZ (skipped to the grenade part in the walled city) and I can tell I am going to thoroughly enjoy this thing. It is insane what I was missing before with my old garbage sub.
Panasonic 60VT60 | Denon x2000 | EMP E55Ti | E56Ci | E55Wi | PSA XS30 x2
moussaka is offline
Emp , Emp Tek , Emp Tek E10s Subwoofer , Emp Tek Ef30c Center Speaker , Emp Tek Ef30t Tower Speakers , Emp Tek E55tir Tower Speakers , Emp Tek Ef30 Bookshelf Speakers , Speaker Systems
taboola here
