Best 5.1 for sub $400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 01-08-2009, 10:07 PM - Thread Starter
treepop's Avatar
Hey there guys/gals,
I am a newb to speakers...and I have found the best way for me to learn is just to throw a question out there and here what the experts have to say.
At first I thought what I needed was a HTIB for ~$500, but the more I read the more I felt that the best way to start a nice setup was to begin with some nice speakers. and get a decent Receiver for around $150(onkyo srs-506 refurb)
Maybe I am wrong, but from what I have read receivers go out of style much faster then a nice speaker setup.
I have a living room that is pre wired with surround sound. I have a 20'ft vaulted ceiling and the room is 20x20. So I need some power in the speakers, I suppose.
If I am wrong and could spend a bit more with a HTIB please let me know.
I currently have a ps3 so I don't need a blue ray player.
Thanks for all of the help you guys can give me!
treepop
treepop is offline
post #2 of 30 Old 01-08-2009, 10:21 PM
allanf714's Avatar
the speakers are the most important by a long shot. Invest in something decent there.
http://emptek.com/EMPOn-linestore/ca...products_id=58 get them while they last..designed and manufactured by RBH sound.
Also consider a refurbished, previous year model Onkyo receiver like this one.
http://www.accessories4less.com/make...ST-ONE-/1.html
A little higher than you were thinking but much better then ANY HTIB!!
Allan
allanf714 is offline
post #3 of 30 Old 01-08-2009, 11:32 PM
JBjunior's Avatar
Why do people keep pushing the EMPTEK speakers? Have you actually heard them? I haven't, and it seems no one else has either. I spent HOURS researching yesterday and went through every EMP thread on audioholics and other than the Admins. on the site, only 3-5 people had them or had heard them. I have found two reviews from people that have them, and these same people are spamming the boards trying to tell the world about them. I mean, one thread had someone asking about 3-5 thousand dollar speakers and the guy jumps in saying to get the EMPs and save the money. I almost bought these, audioholics saved me, thankfully. After I purchased them last night I did even more research and by the end of the night felt like I had been swindled from the lack of information on them. Seems like snake oil.
Anyway, OP, I am in the same place as you with an Onkyo receiver looking for a good 400-600 set of speakers, and I just want my moneys worth. I am almost sold on some polks, just have to figure out which ones.
JBjunior is offline
post #4 of 30 Old 01-09-2009, 06:16 AM
m_vanmeter's Avatar
for speakers, consider this setup of Energy C-300 speakers
http://www.wwstereo.com/#/ecommerce/...rs/33/144560//
add your refurb Onkyo and you are a little over budget, but your large room is going to take more than a pib-sqeak setup. Don't dismiss full HDMI processing in your receiver....what you have today as input may change next month....
http://www.accessories4less.com/make...r-BLACK/1.html
good luck
m_vanmeter is offline
post #5 of 30 Old 01-09-2009, 07:03 AM
Quoted: 73 Post(s)
Liked: 112
EMP is the very new internet division of RBH Sound which is a well-respected speaker manufacturer. The EMP and RBH lines are pretty much the same except the RBH have nicer cabinets, cosmetics, etc and cost more as a result. Don't worry about your purchase; if you don't like how they sound, simply return them.
OP: EMP, Mirage, and Energy are your best bets. I've seen the Nanosat 5,1 system around for pretty cheap. Check out Vann's.
rnatalli is offline
post #6 of 30 Old 01-09-2009, 07:05 AM
Quoted: 73 Post(s)
Liked: 112
Oops! Just noticed you need a receiver too. In that case, I'd go with the 5 Nanosats from Vann's, a Dayton sub from Parts Express, and an Onkyo receiver from AC4L or direct.
rnatalli is offline
post #7 of 30 Old 01-09-2009, 08:15 AM
calnbs's Avatar
EMP as stated by another poster is owned by RBH which is a well respected company. It is a new company. Some even claim that they use similar parts as RBH. That I can't say for sure. But as you stated, EMP should not be recommended to someone who has a larger budget. They are entry level speakers for people with limited budget.
For me, my favorite budget speakers happens to come from Frys.com or their store, which sells the Infinity Primus 362 and Polk Rti8 for very cheap almost every week or every other week. From my research, it's best if you order them seperately to save shipping.
OP,
Receiver as with any electronics get outdated pretty fast, plus speakers play the biggest difference in sound. Your budget is quite limited.
Look into:
Thespeakercompany.com
Fluance.com
Insignia bookshelf speakers at BestBuys. (There is an owner's thread in this forum if you do a research. A lot of people seem to enjoy these low end speakers).
subwoofer:
http://www.parts-express.com/pe/show...number=300-635
monoprice.com for all wires, cables, and hdmi
calnbs is offline
post #8 of 30 Old 01-09-2009, 11:20 AM - Thread Starter
treepop's Avatar
Thanks so much for all of your input. I love all of the suggestions and have been looking into all of them.
I guess I have a few questions...
I like the emptek suggestion...but I am weary for two reasons
1)Size - does a bigger speaker mean better sound?
2)Comments that they have not been proven
I am also curious since the price is around the same as the Energy speakers suggested...how do they compare. That is the the emptek HTP-551 vs the Energy C-300.
That said. How do both of these setups compare to the insignia bookself speakers suggested? I went to best buy at lunch to feel them(the display was broke so I didn't get a listen) they felt pretty solid, but wanted $90/pair, which sorta kills the "budget speaker" idea. Since doing the math I might save $100 or so over the Empteks and the energy's suggested.
*****edit #1*
I forgot the nanostats 5.1 on vanns...I found several...they look small how would they compete to the other suggestions around the same price point?
*******/edit #1**
***EDIT #2**
I want to reemphasize that my room is 20x20x20valted
thanks
******/edit #2**
Do I need to match the quality of my center channel with the rest of the speakers? For example, I get the insignias for say $50/pair on sale and then spend $300 on a center since in movies thats your #1 most important speaker, or so I hear. Would it be off balance?
Finally....how much better is the Onkyo sr606 over the TX-SR575? Personally I dislike silver, so I don't know if it's even an option...but would the srs606 with the speaker choices I am looking at really matter all that much? wouldn't that money be better spent on better speakers?
whew thanks so much again for you suggestions....I am learning so much
treepop is offline
post #9 of 30 Old 01-09-2009, 01:15 PM
m_vanmeter's Avatar
the Onkyo SR606 will drive anything that has been mentioned so far.
Your basic problem is a very large room that really rerquires a lot of "cone area" to move a considerable amount of air (that is basically what speakers do, small speakers move small amounts, large speakers move much more).
My recommendation (and not necessarily what you originally asked) is to visit the Elemental Designs web site and consider a 3.0 system first....L-C-R - and note please these are NOT small speakers......
Consider using their A6-6T6 towers for L-R and an A6-6T6MTM for the center
http://www.wwstereo.com/#/ecommerce/...rs/33/144559//
http://www.edesignaudio.com/product_...roducts_id=616
you can save about $100 using their "package builder" for the 3.0 system
http://www.edesignaudio.com/htpackage.php
when budget allows, add an eD subwoofer, and then add the surround speakers, again when budget allows. In the end, you will be much more satisfied with the final results than buying a small 5.1 system now that is completely undersize for the room.
edit: YES, you do want your center channel speaker to "match" the Left and Right front speakers. You are creating a soundstage where the vocal tracts can move across the stage and NOT change "timbre" as they are passed from speaker to speaker. The surrounds are not as critical because there is far less audio information on the surround channels for movie soundtracts, and rarely is timbre an issue. IF you are playing full surround music however, you do not want the instruments to change timbre as they move to the surround speakers, so more closely matched speakers all around are necessary for music, if that is a high percentage of your listening.
good luck
post #10 of 30 Old 01-09-2009, 06:00 PM - Thread Starter
treepop's Avatar
good luck
I like your thinking.....about getting the 3.0 system..
How do the tower speakers you suggested compare to the
Since I heard you can snag those for $99/ea at frys every once in a while.
If the Infinity Primus 362 and Polk Rti8 are indeed better, which center would I get to go with them.
Also is the onkyo tx-sr606 2 times as good as the tx-sr757?
Since I can get the sr757 for $160 and the sr606 for $300 refurb.
Thanks again
treepop is offline
post #11 of 30 Old 01-09-2009, 06:09 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
The Polk Rti8 at Fry's are never $99 each, they're $149. Other lesser polk models like the Monitor 50 have been $99 in the past.
The Infinity P362 comes on sale for $99 from time to time, currently they're $129 each in stores.
Afro GT
afrogt is offline
post #12 of 30 Old 01-09-2009, 06:27 PM
jgiddyup's Avatar
Quoted: 34 Post(s)
Liked: 34
For sub $400 get the HTIB solution!
Unless you get REALLY lucky in the used department, you've got no shot at getting anything better.
Jgiddyup
jgiddyup is offline
post #13 of 30 Old 01-09-2009, 07:53 PM
hockeynut's Avatar
Quoted: 66 Post(s)
Liked: 47
I just purchased the Boston Acoustics Horizon Series MCS100MDNT 5.1-Channel Speaker System for the bedroom. For just under $200 from Amazon, I am extremely pleased. Comes with an 8" sub. This system, however, is probably too small for your larger area.
Mike
xbox/psn: duke63031
hockeynut is offline
post #14 of 30 Old 01-09-2009, 09:11 PM
allanf714's Avatar
RBH sound has been manufacturing fantastic sounding speakers for over 30 years...... If you've been around this industry for awhile.. you would doubtfully question thier products. I will safely assume JB junior has not. The aforementioned EMP deal is an absolute steal. On the other hand...Vanmeter has a valid point. You've got a large room that would probably be served best by larger speakers. The Energy package with towers and no sub for $400 would get my first vote (add a sub later).
Re: the Refurbished Onkyo models. Be advised.. Onkyo both giveth and teketh away with the newer models.... some of the older models had better amps and higher resolution room equalization than the newer versions... while the newer versions may add things like (dynamic EQ). Choose carefully and remember to put more weight on the speakers... as thay are the only part of your system that actually produces sound... and accordingly makes the biggest difference in what you will hear.
Allan
post #15 of 30 Old 01-09-2009, 11:34 PM - Thread Starter
treepop's Avatar
Allan
you've got me worried I am missing out on the EMP deal....I will get them if they truly are that amazing, but will it work in my room?
you said the Energy would be the best bet without the sub, but the one linked had a sub included and was a total of $515. So was it another energy set you were thinking of?
*EDIT*
AH! I found it! it's actually a better deal to buy the sub later....hrmmmmmm......are they better speakers then the EMP setup?...Should I save and get the EMP 5.1 with two front towers?
Interesting....well even if they are $150 each.....the A6 - 6T6 - Tower's are $250 each...how do the ones at frys stack up?
treepop is offline
post #16 of 30 Old 01-10-2009, 03:24 AM
rickdog81's Avatar
*EDIT*
Let me know what yo uend up doing. I am in the same boat as you. College budget need speakers. I would love to hear another opinion on the EMP speakers if that is what you are getting. I would call and ask about the 351T which was on sale for I think $689 a few weeks ago maybe you can get that deal again. Bigger speakers more for more "cone area" on the 351T compared to the 551T or 351. The 351T have 8" woofers on the towers in adition to the two front speakers.
rickdog81 is offline
post #17 of 30 Old 01-10-2009, 08:29 AM - Thread Starter
treepop's Avatar
You would think that the 551T would be better then the 351T...Just because it's a larger number. Also the "standard" price of the 551T is greater. I guess I am wrong.
treepop is offline
post #18 of 30 Old 01-10-2009, 08:45 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
I think this is a way to get much better speakers.
Get 3.0, then add either sub or rears, then get the las piece.
I highly recommend what I bought:
- a pair of Kef iQ1's and a KEF iQ2 for centre
They can be had from Vann's for less than $400.
Another pair of iQ1's for the rear would be nice. I ended up with 2001.2 from accessories4less.
Go to the subwwofer subforum when you gigure out what your budget for it is for suggestion in the <$250, <$500.
rick240 is offline
post #19 of 30 Old 01-10-2009, 12:51 PM - Thread Starter
treepop's Avatar
QUICK QUICK....should I get these c-100's by energy!????
http://www.woot.com/
treepop is offline
post #20 of 30 Old 01-10-2009, 12:55 PM
JBjunior's Avatar
Allan
I will say yet AGAIN, have you heard the speakers? This has nothing to do with my experience. These speakers have been on the market for over a year and I challenge you to find anything on google, here, or any other legitimate source of information on the quality of these speakers. If you are going off of what audioholics says, then good for you. I searched every EMPTEK thread on audioholics and it was the administrators on the website and TWO people who had the system who were touting its greatness. There are roughly TWO people on this website that have the system. So, in one year 4 people have heard the system and found it noteworthy enough to post about it. All of the connections between RBH was proposed by audioholics, and the EMPTEK website was changed to not note that connection. Someone even said that their speakers arrived produced by a third "sister" company. If this is such a steal why has no one with the internet posted about them, even on audioholics? Are they so enthused with them they can't tear themselves away to post about it? Or even say they have them? The one "unbiased" review I read spammed every thread asking about it with the same verbage in every thread, probably a copy and paste. I was going to buy the system because I thought I had seen many people recommending them, then when I went back I saw it was all the SAME PERSON. If you can find some good information of people who have them, have heard them, and recommend them at ANY price that are reliable sources (not audioholics) then jump on it.
ETA: Everyone always says there isn't any BAD reviews for these, but there is on audioholics. One guy said his fronts were horrible and were muffling things. The administrators on the website were trying to convince him he got a faulty pair, which he may have. Search for the thread, as I said I was hoping this was the greatest deal ever and was planning on jumping on it. If you spend HOURS searching for information (my googlefu is strong) see what opinion you get. If you don't want to spend the hours, then hopefully they accept the return if you don't like them. Also, I wasn't doubting the connection to RBH, just the quality compared to RBH and all of the stuff from audioholics of "All of the same internals." If I just bought RBH, I would be angry.
JBjunior is offline
post #21 of 30 Old 01-10-2009, 01:14 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
They are decent speakers at a great price. With the two pair limit it would give you 4 speakers for $200.
Get a friend to buy another pair and you have 5.0 with a spare for 300.
Certainly worth considering. Would be better if you had heard them and know you like them though...
rick240 is offline
post #22 of 30 Old 01-10-2009, 01:45 PM - Thread Starter
treepop's Avatar
Thanks...I am sitting here....debating...I found it very ironic that I am at my inlaws thinking about which set to get....energy vs the EMP's. And this woot deal shows up...a sign?
How would one of these sound as a center? Wouldn't it be better to get the c-c100 or the c-c50 then another one of these used as a center?
treepop is offline
post #23 of 30 Old 01-10-2009, 02:09 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
They are a great deal, and you have a limited budget. It's just it would really suck if YOU didn't like the sound after you bought them (that is why it is always best to go somewhere and hear them first).
Having an identical speaker to the L/R for C is actually extremely good; there are actually a lot of arguments against the standard M-T-M design for centre channels. Most people just don't want to have that shape of a speaker in the centre...
Good luck making a choice.
rick240 is offline
post #24 of 30 Old 01-10-2009, 02:14 PM
allanf714's Avatar
OK, just to clarify a bit of personally observed history of RBH. They started by designing and manufacturing speakers for other manufactures. I suspect that this continued for a period of years until they started with their own lines. The higher end lines were only available through high end retailers while the mid and lower lines were available through distributors (not to the general public). I'm assuming that they saw real potential via internet direct business and also wished to protect the "RBH" name for their high end retailers so they created two new names EMP (intended for internet direct business, sold through thier website and Audioholics) and Destination Audio (intended for custom installers and sold via distributors, destinationaudio.com). You will find a lot of overlap EMP and Destination Audio lines (i.e. same products with a different name on them) but none of the high end product is sold under the latter two names. The later two names were created maybe a couple of years ago... but the actual manufacturer (RBH) has been around for a long time. So, enough about RBH. If you would like to hear them, call up some high end stores in the area and see who carries them.
I'm currently using RBH in the living room and Energy Vertitas in the media room (so I like both companies) My favorite package (by a long shot) was the 351 (for something like $680) as these were the acoustic equivalent of the RBH TK series that won lots of praise. I do not believe that special is still available and this puts you way over the stated budget anyhow. The Energy package for $515 with the sub is, no doubt, a great deal... but I personally would would wait and buy a bigger sub when the budget allows. Your room is pretty big and the sub will need to pressurize the entire room, not just the immediate listening area. So if you start with the Energy tower special for $400 and add a refurbished Onkyo for around $160.... your probably sitting at around $600 total shipped (not too much over the stated budget and you can add a big sub later (every college students dream .
Allan
post #25 of 30 Old 01-10-2009, 02:21 PM - Thread Starter
treepop's Avatar
Allan
Do you think the c-c50 is near as good as the c-c100? I heard the center is mega important. Also...the woot.com deal....do you think the c-100's could do as good a job as the c-300's?
*EDIT*
The woofer on the c-300's is only 1" larger....is there more to it then that?...I was thinking of getting 4 speakers from woot.com. $170 and then getting a c-c100 ~$200...then the onkyo receiver ~$160. Total ~$530..then that dayton 12" sub for $150...total at $680. The key is how would the c-100's fill my room compared to the c-300's?
Thoughts?
*EDIT #2*
I guess, what I am really doing is upgrading my rears and my center, but downgrading my Front Left and Right....is that not wise?
treepop is offline
post #26 of 30 Old 01-10-2009, 03:22 PM - Thread Starter
treepop's Avatar
It's done...I bought 4 speakers from Woot.com. After speaking with my wife and my friend. The 4 c-100's were a better fit for me then the c-300's and c-50's.
My wife doesn't like the idea of 2 huge speakers taking up space in the living room. She things they are tacky and I tend to agree since we both like things to be low key.
My friend informed me that a c-c100 would be much better then a c-c50 for the overall sound of the room. And thought the c-300's wouldn't really be as huge a difference as a nicer center, since the voices etc. all rely on that center channel.
So after tax and shipping I received 4 c-100 energy speakers for $178.59!
Now I am off to find a stellar deal on a c-c100 center and a nice refurb onkyo reciever.
treepop is offline
post #27 of 30 Old 01-10-2009, 05:06 PM
allanf714's Avatar
The bookshelves will work fine as well... but you may now need stands (depending on your situation). The center channel generates about 80% of everything heard in a typical movie.....Definitely get the better center if you can.
Another suggestion on the budget sub.
http://www.theaudioinsider.com/produ...products_id/68
Allan
post #28 of 30 Old 01-11-2009, 07:54 PM
rickdog81's Avatar
$178.59! damn that is a great deal. I have been on AVS religiously, and this is one of the threads I was watching. Except for yesterday so I missed the woot. I would have snatched up two of the c-100s for my surrounds and two of the towers from wwwstereo... and the c-c100 from ebay. HSU sub later on down the road when I can afford it. ARGH.
How do you guys thing these energy c-300 or c-500 compare to Polk tsi 400 or RSi A5? In particular the sound quality, since obviously the polks have more woofers in the towers but I don't need loudness just clarity for movies.
post #29 of 30 Old 01-11-2009, 07:58 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Those same Energy-100 are on at Vann's for $100 / pair (today at least)
rick240 is offline
post #30 of 30 Old 01-11-2009, 08:01 PM
afrogt's Avatar
Liked: 755
You can still get the C-100 bookshelfs from vanns for $99 shipped. Not quite as cheap as woot but still a very good buy!
http://www.vanns.com/shop/servlet/it...?i_c=DOD011109
Afro GT
afrogt is offline
Reply Speakers
