Jamo S606 HCS6 + Onkyo TX-SR606 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-26-2009, 06:53 PM - Thread Starter
Kelvin_M's Avatar
Hi,
I am a newbie to this HT setup, recently got into it.
I just purchased the above system and i do not completely understand the crossover settings ? I ran the Audessy Auto Setup and the results are as follows:
Front (L) - Full Band
Centre - Full Band
Front (R) - Full Band
Surrs - 60Hz
The decibel levels are :
Front (L) - (-3)
Centre - (-3)
Front (R) - (-1)
Surrs - (+1)
Sub - (-9)
The distance settings seem correct to me.
The only thing i adjusted was the crossover setting, i set it as follows:
AMP - 120Hz
Fronts - 60Hz
Centre - 80Hz
Surrs - 100Hz
Now it seems weird that the audessy lowers the decibels for the front and centres...especially as i am having problems hearing dialogue. Especially from the film 300 (BluRay).
I need some advise,
Is it ok to change the decibel setting in the amp or will it affect what audssey has done ?
Any advise on the crossover settings for my speakers ?
Regards
Any advise or help would be greatly appreciated you guys
Kelvin_M is offline
post #2 of 3 Old 01-26-2009, 07:20 PM
afrogt's Avatar
Quoted: 1090 Post(s)
Liked: 782
The sub setting seems very low. What kind of sub is it? Does it have the Auto power on feature? If so, you're going to want to adjust that -9 setting because such a low signal may not trigger the subwoofer to come on.
You can increase the db setting for the center if you wish. Its your system so set it so it sounds best to you!
Afro GT
afrogt is offline
post #3 of 3 Old 01-26-2009, 08:18 PM - Thread Starter
Kelvin_M's Avatar
The sub has an auto feature but it detect the sound even at low volume. I was wondering if i were to make adjustments to the db setting will it affect audessy eq ? or what audessy has adjusted ?
Kelvin_M is offline
Reply Speakers
