Small 5.0 on a budget. $250 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-28-2009, 07:19 PM - Thread Starter
kinsale's Avatar
Hi all,
My wife and I were at Sams Club and we demoed a Bose setup. My wife loved the size of the speakers and how clear the sound was. My setup has a good powered subwoofer but my mains are old Cambridge Sound cubes and center is an very old Mordaunt Short Center. My wife complains that the dialogue is not clear enough when watching TV and Movies. I have old Sonys as rears.
Can you recommend a 5.0 setup with small speakers that would do well for under $300?
Ian
My receiver is a Onkyo SR505
kinsale is offline
post #2 of 7 Old 02-28-2009, 07:31 PM
aquaphile's Avatar
$300 wont get you much if you buy new. i mean no insult here, but im sorry to say it just wont.
if you look into used (ebay, craigslist), you can probably get a lot more bang for your buck. or browse around on amazon, see what kind of deals they have.
you can find setups that use small bookshelf speakers that arent the "cubes" you mentioned that will still stay out of site (for the most part), and actaully give you much better sound. possibly look into polk audio?
example:
get two pairs of these http://www.amazon.com/Polk-Audio-Two...874447&sr=8-15
and one of these http://www.amazon.com/Polk-Audio-Cen...5874540&sr=8-1
i know thats $300, not including shipping, but your budget is going to be tough.... unless you buy used
2.0 > 7.1
aquaphile is offline
post #3 of 7 Old 02-28-2009, 07:35 PM - Thread Starter
kinsale's Avatar
Well I've seen the Energy Take Classic 5.0 for $199. I had heard these were good. Just looking for other options.
kinsale is offline
post #4 of 7 Old 02-28-2009, 07:58 PM
PD50U's Avatar
Agreed, 5.0 at that price is tough. If you can find Take-5 for $200 might want to grab it. Although, if you have a sub, five of the C100's would likely sound better.
Energy @ Vanns
Hearing is believing vs Believing is hearing.
PD50U is offline
post #5 of 7 Old 02-28-2009, 08:03 PM
smellyhash's Avatar
http://cgi.ebay.com/Energy-Speakers-...3%3A1|294%3A50
Great for the price have it in bedroom.
http://www.cambridgesoundworks.com/s...&item=k1ht55ee
another cheaper selection MUCH better than bose and is a smaller cube kie speaker but also has a real sub.
http://www.wwstereo.com/#/ecommerce/...rs/33/144559//
For 400 dollars you cant beat this with a stick.
Can't fix stupid
smellyhash is offline
post #6 of 7 Old 02-28-2009, 08:51 PM
GregLee's Avatar
Quoted: 801 Post(s)
Liked: 259
Why think big? If your center is a problem, replace just the center. Just get a center that will go with fronts you can get later, if you choose to. I bought an Axiom M2 four years ago to use as center (does fine with dialogue), and only now am I in the process of upgrading to matching fronts.
Greg Lee
GregLee is offline
post #7 of 7 Old 03-01-2009, 05:14 PM
aquaphile's Avatar
yeah the energy set seems to be the best bang-for-budget-buck around here
i guess i didnt mention that because you said you wanted smaller speakers....
whats your definition of small?
2.0 > 7.1
Reply Speakers
