Impedance Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-07-2009, 03:29 PM - Thread Starter
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 84
Hi All,
I have a quick impedance question: I just bought new speakers (PSB Image) and the specs on all five of them state the following:
Impedance:
6 ohms nominal
4 ohms minimum
I'm wondering how to set up my receiver (Onkyo TX-DS797). There are two settings on the unit:
1 - Minimum: 6 ohms
2 - Minimum: 4 ohms
The owner's manual for the receiver says the following:
"If the impedance of all speakers are between 6 and 16 ohms, select '6 ohms.' If the impedance of even one speaker is between 4 and 6 ohms, select '4 ohms.'"
Can anyone provide a bit of guidance?
Thanks a lot,
Ben
AirBenji is offline
post #2 of 9 Old 04-07-2009, 03:40 PM
fireman325's Avatar
Quoted: 14 Post(s)
As I understand it, you should pay the most attention to the nominal rating of 6 ohms, and set your receiver accordingly at 6 ohms. All speakers' impedance fluctuates during use and many that are rated at 8 ohms can occasionally dip a couple of ohms or so.
Steve
fireman325 is offline
post #3 of 9 Old 04-07-2009, 05:05 PM
Ivan Beaver's Avatar
Quoted: 16 Post(s)
Liked: 59
Originally Posted by fireman325 View Post
All speakers' impedance fluctuates during use and many that are rated at 8 ohms can occasionally dip as low as 2.
Do you have any examples of that? A 8 ohm rated loudspeaker dipping to 2 ohms that is.
Yes they may dip a bit below 8 ohms, but something that goes down to 2 should NOT be rated at 8 ohms
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
post #4 of 9 Old 04-07-2009, 05:13 PM
Paul Scarpelli's Avatar
Liked: 56
Good point. But many 4 ohm speakers have dipped lower. Currently, the "4 ohm" Triad Gold LCR dips to 3.2 ohms at one frequency. In the past, the Apogee Scintilla, rated at either 3 or 4 ohms, presented a toxic 1 ohm load at 20 Hz, and only a few amplifiers could handle it. If a speaker dips to 2 ohms at any frequency, it isn't an 8 ohm speaker.
Paul Scarpelli
aka TRIAD DUDE
I can tell people who are judgmental just by looking at them...
Paul Scarpelli is offline
post #5 of 9 Old 04-07-2009, 05:36 PM
fireman325's Avatar
Quoted: 14 Post(s)
OMG!! What a typo! Thanks for catching that guys. That's not what I meant to type, but I guess it's what I get for trying to do several things at once. Original post corrected. Tanks again!!
Steve
post #6 of 9 Old 04-07-2009, 07:46 PM
Sirquack's Avatar
Ben, this lower setting does not optimize the receiver for handling the speakers with a lower impedance rating, as some imagine. This is basically a safety-related measure intended to limit the possibility of overheating, pursuant to UL requirements. This limits the voltage which is available on the power supply rails. When following Ohm's Law, when voltage goes down, so does current and power. Yes, this will reduce the possibility of overheating, but does it at the expense of maximum performance.
___________
"Don't worry about the future, it is already tomorrow in Australia..."
My Website
Sirquack is offline
post #7 of 9 Old 04-07-2009, 08:56 PM
ekb
ekb's Avatar
I don't think that speaker impedance changes during use. It is what it is. I think what you mean to say is that impedance is a function of frequency and, at some frequencies, it probably dips lower than the quoted "nominal" (single) value. The problem is that there is no standard way to compute the nominal impedence. It's too wishy washy - how can it be that there are no 7 ohm speakers?
Ed
ekb is offline
post #8 of 9 Old 04-07-2009, 09:29 PM
fireman325's Avatar
Quoted: 14 Post(s)
Ed
A much better explanation. Thank you.
Steve
post #9 of 9 Old 04-08-2009, 11:10 AM - Thread Starter
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 84
Hi All,
Looks like I should go with 6 ohms. Thanks a lot for all of the responses and information!!
Ben
AirBenji is offline
Reply Speakers
