What kind of speaker wire should I look for? - AVS Forum
post #1 of 8 Old 06-08-2009, 04:45 PM - Thread Starter
Don G.'s Avatar
Hey all, I'm about to purchase the Yamaha 591 BL home theater system and was looking to upgrade the speaker wire it comes with. I really don't know a thing about speaker wire so I was hoping someone here could help me out. I was checking out monoprice but I'm not sure what type of wiring guage I should get. I see 14, 16 & 18 awg. Not sure what the difference is.
Don G. is offline
post #2 of 8 Old 06-08-2009, 04:54 PM
Jay1's Avatar
Liked: 102
The guage is the thickness of the cable, the lower the number the thicker. Longer runs of cable and high power system require thicker cables. 14 awg is the typical thickness for most home setups.
Unless you have a very long run of cable just go with the 14 awg.
Jay1 is offline
post #3 of 8 Old 06-08-2009, 05:09 PM
westgate's Avatar
been using up to 35' lengths of 16 gauge for over 35 years.
works fine.
westgate is offline
post #4 of 8 Old 06-08-2009, 05:49 PM
Sycraft's Avatar
Depends on your speaker impedance and length of the run. You can have a look at a table if you like, but unless your run is over 20 feet, 16 gauge should be fine for anything.
Only other thing to consider is if you are adding any ends. Some ends are easier or harder to put on larger or smaller wire. For example the ends I like from Blue Jeans Cable fit really nicely on their large 10 gauge wire. They'd work on 16 gauge, just not fit as snug. Conversely, some other ends have real trouble with big wire bundles.
Sycraft is offline
post #5 of 8 Old 06-08-2009, 06:41 PM - Thread Starter
Don G.'s Avatar
Thanks guys. You've been a great help. I'll just go with the 16 awg. I'm not going to run them a very long distance.
Don G. is offline
post #6 of 8 Old 06-08-2009, 10:04 PM
Gandu's Avatar
Liked: 35
If you don't want to wait or pay shipping on Monoprice (great store btw), you can also get perfectly fine generic speaker wire at Home Depot or Lowes, by the foot, in the wire section.
NorthSeaSurfRadio.org - 100% Instrumental Surf Music. Commercial Free.
Gandu is offline
post #7 of 8 Old 06-08-2009, 10:10 PM
ShadowVlican's Avatar
+1 for monoprice
i live in canada and i still buy various cables from them!
ShadowVlican is offline
post #8 of 8 Old 06-09-2009, 06:14 AM
psgcdn's Avatar
Quoted: 31 Post(s)
Liked: 199
Originally Posted by ShadowVlican View Post
+1 for monoprice
As do I.
psgcdn is offline
Reply Speakers
User Tag List
