Last 2 questions before I finish my dream Home Theater. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-24-2009, 05:00 PM - Thread Starter
keshavp's Avatar
My Setup
HK AVR 254 off ebay
Energy Take 5.1 off Vanns
Current Shopping Cart on monoprice
620 12ft Coaxial Audio/Video RCA Cable M/M RG59U 75ohm (for S/PDIF, Digital Coax, Subwoofer & Composite Video)
2 X 3022 Speaker Stand - Black (SS-01) - Set of 2
2789 12AWG Enhanced Loud Oxygen-Free Copper Speaker Wire Cable - 100ft $22.93 $22.93
4959 High Speed HDMI 1.3a Category 2 Cable 28AWG - 12ft w/Ferrite Cores (Gold Plated Connectors) - BLACK $4.99 $4.99
2801 5 X 1 PAIR OF High-Quality Copper Speaker Banana Plugs - Closed Screw Type [JX-74043]
My question:
1. Will the banana plug fit behind the Energy Take 5 satellites (so that I can get 5 more pairs
2. Will the monoprice stands work for Energy Take 5 satellites ? (wall mount is not an option.)
Thanks so much to contributors on this forum.. I learnt so much from you guys!
keshavp is offline
post #2 of 4 Old 06-24-2009, 06:05 PM
Hrimnir's Avatar
Ok, from looking at the pictures, the stands should definitely work.
As for the banana plugs, its very hard to tell, take a look at these pictures:
http://www.amazon.com/gp/product/B0021L9BME
And it appears that they may just be screw down terminals. Now, those red and black plastic parts on the top *might* pull out so you can use a banana plug, but i can't be 100% certain.
If it were me, i'd buy enough banana plugs for the receiver side of the cable and go bare wire or a spade type of connection for the speaker side to be on the safe side.
Klipsch RF-62 L/R, RC-62 C, Energy C-100 SL/SR, HSU VTF-15H, Marantz SR7008.
"All speakers sound good when you're on a coke binge in the middle of an orgy." - Heebdawg16
Hrimnir is offline
post #3 of 4 Old 06-24-2009, 06:10 PM
WhiteSoxFan's Avatar
The red and black plastic plugs come out, you just unscrew the post all the way and pry them out. Banana plugs will work.
WhiteSoxFan is offline
post #4 of 4 Old 06-24-2009, 06:43 PM - Thread Starter
keshavp's Avatar
Thanks folks!
keshavp is offline
Reply Speakers
