Speaker Spacing for 7.1 Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-05-2009, 09:22 PM - Thread Starter
du_want_2's Avatar
Looking for help with speaker placement for a 7.1 setup. I have an Integra 8.9 receiver with an Elite 60" plasma and bought B&W speakers - 805SR / HTM4SR for the front / center speakers and CCM80 and CCM818 for the middle and back ceiling mount speakers. The "rule of thumb" is the front speakers should be as wide as the lenth from the TV to your seating area. How do you determine were to mount the middle and back sepakers for 7.1? My room is 25' by 14.5' and I am 12' from the TV. Any recommendations? Thanks!!!
du_want_2 is offline
post #2 of 4 Old 07-06-2009, 06:36 AM
BruceOmega's Avatar
I used the Dolby guidelines when I set up my 7.1 configuration: http://www.dolby.com/consumer/home_e...ide/index.html
They've updated their site since I last used it, and it appears you can now input your viewing distance.
Both my side surrounds and rear surrounds are ceiling mounted (suspended from the ceiling). I located them according to the Dolby guidelines, and positioned their mounting so they are angeled downward, toward the listening area.
Bruce
BruceOmega is offline
post #3 of 4 Old 07-06-2009, 07:04 AM
sdurani's Avatar
Quoted: 5122 Post(s)
Liked: 3605
I would follow the recommendations in the link that Bruce provided. My side speakers are at 90 degrees (directly to the sides of my couch) and my rear speakers are spread roughly 60 degrees apart on the back wall.
Surround sound is meant to be heard from all around you, not just above. When using in-ceiling speakers, it helps to spread them well away from the listening area. This way, they sound like they're high up on the rear and side walls rather than overhead. Should give you distinct left vs right vs back directionality in the surround field. If your speakers have pointable drivers, remember to aim them towards the listening area.
Sanjay
sdurani is online now
post #4 of 4 Old 07-06-2009, 11:07 PM - Thread Starter
du_want_2's Avatar
Thanks Bruce and Sanjay, I've taken a look at the Dolby site and it is very helpful. That was the tip I was looking for, thanks again - Shaun
Reply Speakers
