Official JTR speaker thread - Page 1006 - AVS Forum | Home Theater Discussions And Reviews
 7773Likes
Old 07-05-2015, 10:07 PM
rcohen's Avatar
Quoted: 1208 Post(s)
Liked: 518
Originally Posted by carp View Post
Your money is no good here, just pay for shipping and we'll call it even.
Now... to figure out how to ship it... I'll talk to you and we'll figure it out.
uship.com can be good for this kind of stuff.
rcohen is offline
Old 07-05-2015, 10:09 PM
rcohen's Avatar
Liked: 518
Originally Posted by Naylorman32 View Post
Here's what I did for a center stand. I bought 4 cement blocks from Lowes (maybe $8?), wrapped them in black felt from Joanne, and then purchased a pair of these when they were on sale for i think $40. I angled them up as high as I could to get ear level:
http://www.amazon.com/gp/product/B00...ilpage_o03_s00
So in total it was probably about $60, and I can always increase the height just by adding on more cement blocks
I've had good luck with this approach. Cheap and very solid, if you're not looking for something fancy.
Edit: ...although I used velvet, instead of felt.
rcohen is offline
Old 07-05-2015, 10:35 PM
jlpowell84's Avatar
Quoted: 1613 Post(s)
Liked: 712
Yea something about cement blocks as speaker stands for JTR Speakers (aka mini fridges) just sounds right
jlpowell84 is offline
Old 07-06-2015, 09:23 AM
ahmedreda's Avatar
Quoted: 301 Post(s)
Liked: 214
The cement block idea would would be the easiest / cheapest. If you want exact dimensions, you can build one from 2x4s and then cover it with cloth.. I did that with my triple 12LFs which is heavier / bigger than the 212HTs.
Cost was around $20 + the cost of the fabric.
Originally Posted by Reefdvr27 View Post
Does anybody know of a site that sells speaker stands for big speakers, like a center channel. I am looking for ideas for my 215RM. I really did not take an account to how big this speaker is. I mean I knew it was big on account to my RT's, but it makes my 228 look like a cork. I am not sure if I am going to just leave it on the floor and tilt it or bring it up closer to ear level. I have been looking, but I don't see anything.
My home theater
Speakers: 3 JTR 212HTR (LCR), 2 Jtr Single 8LP (S), 2 JTR Triple 12LF (SB)) , 4 Volt 10LX (Atmos)
Subwoofers: 10 Sealed UXL-18, 5 Crowson Shadow 8 transducers, 3 Buttkicker LFE
Display: JVC RS400
ahmedreda is online now
Old 07-06-2015, 11:43 AM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
You are a good dude Sheldon, but I would have to give something. I want to see if it works. I like the looks of it. I was looking at it last night in your thread.
I actually looked at it last week as I remembered you did a horizontal 212HT.
Reefdvr27 is offline
Old 07-06-2015, 03:28 PM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
For those that get the upgraditus itch...or rash in some cases...
New Upgrades for OS LFU, S1, and S2...
...and I don't get what Jeff means by 'more output' and 'less distortion'..makes no sense...I thought we were already at extremes of both
asoofi1 is offline
Old 07-06-2015, 08:42 PM
rjh65@verizon.ne's Avatar
Quoted: 219 Post(s)
Liked: 57
Hello all, more than likely going to purchase the 215RT's but am trying to get clarity in my head so i understand what i will need to purchase. I will probably be selling my Orbit Shifter and strictly be using the 215RTs for all of the bass duties (along with a 215RM as a center channel). I don't own an HTPC and would rather not use the DSP in an iNuke pro-amp or an expensive outboard processor. Looking at using a bridged Crown XLS2000 or XLS2500 per 215RT for power, my concern is since the 215RT will be providing all of the bass duties how do I boost the bass levels in the speakers? Since I will not be using the above equipment what is the best way to accomplish this inexpensively but still sound great? MiniDSP? If so, what model would work best? Any help with this question with some options would be great.
rjh65@verizon.ne is offline
Old 07-07-2015, 01:20 PM
carp's Avatar
Quoted: 2486 Post(s)
Liked: 1741
You could get the mini that has 2 inputs and 4 outputs.
All you need is a laptop with usb to use the inuke dsp, so I wouldn't rule out that possibility since you would save a lot of money.
carp is offline
Old 07-07-2015, 04:06 PM
NWCgrad's Avatar
Quoted: 1229 Post(s)
Liked: 1221
QSC GXD models are new and have full DSP, like the iNuke's they can provide the flexibility to dial in the speakers. Crown XTI's are also a good solution.
Is there an audible difference between Behringer, QSC, and crown? I guess that is up to the listener and environment. Crown is least likely to require a fan modification if located within 15' of the listener. My fan modded QSC is louder than a stock XLS, but I didn't use the quietest fan as it is being ran bridged on an 18" subwoofer.
NWCgrad is offline
Old 07-07-2015, 06:11 PM
Quoted: 219 Post(s)
Liked: 57
I think I have looked away from the inuke just because i have read so many positive reviews on the Crown XLS series SQ wise and the fan is so quite (I demoed an XLS2500 for 2 weeks). I think also because eventually, once finances permit, I would like to get the D-sonic 1500W x3 amp so the pro-amps would get me the necessary watts and inexpensively until I could afford the D-sonic. I read somewhere that someone has a D-sonic and the pro amp sounded just as good.
countryWV likes this.
Old 07-07-2015, 06:16 PM
Quoted: 219 Post(s)
Liked: 57
The XTI takes a big step up money wise for a louder fan and the same SQ as the XLS (per Harman tech), i will have to take a look at the QSC, if I remember these also jump up pretty significantly in price, probably similar to the Crown XTI. Sounds like the inuke with the DSP is the most cost effective way to go.
Old 07-07-2015, 06:46 PM
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
I have the XTI2002, XTI4002, and several XLS2000's. The fans on any one of these amps do not turn on unless they are under a heavy load. Once playing that loud there's no way the fans can be heard. Even when on the fans are about the same sound level.
I can't vouch fully for sound quality since I have never A-B'd them to each other but I've never had an issue with either one of them.
quizzicus likes this.
tsloms is offline
Old 07-07-2015, 06:54 PM
NWCgrad's Avatar
Liked: 1221
The XLS' s are getting pretty inexpensive with the upcoming release of the Series II models. Coupled with a miniDSP - or dbx - would offer a lot of value (especially if you plan to go with D-Sonic when funds allow as they lack DSP).
HTPCat likes this.
NWCgrad is offline
Old 07-07-2015, 08:23 PM
laeriq's Avatar
Quoted: 63 Post(s)
Liked: 90
The wife doesn't know what to make of the new sofa table...
carp, lz7j, rhed and 7 others like this.
laeriq is offline
Old 07-08-2015, 12:31 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Is that dual pros?
DotJun is offline
Old 07-08-2015, 05:48 AM
laeriq's Avatar
Quoted: 63 Post(s)
Liked: 90
Originally Posted by DotJun View Post
Is that dual pros?
Yup. Picked up a pro system from a guy getting out of the business. Two Triple 12x's, amps, and those bad boys. Hopefully get them set up tonight and rock something.
laeriq is offline
Old 07-08-2015, 06:24 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Wow congrats! Post up some reviews if your house doesn't fall down on you!
DotJun is offline
Old 07-08-2015, 11:13 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
I have a pair of XTI 4002's on a pair of Captivators.
MLP is 8 ft from amps.
Fan noise has never been an issue.
staaled is offline
Old 07-08-2015, 11:46 AM
NWCgrad's Avatar
Liked: 1221
Nice to see reports from actual XTI owners, if they are as quiet as the XLS amps I may have to look into them for the DSP.
NWCgrad is offline
Old 07-08-2015, 07:04 PM
laeriq's Avatar
Quoted: 63 Post(s)
Liked: 90
So uh... dual OS Pro's are a little intense. I'm running these behind my sofa with four sealed 18's in the front of the room... I ran XT32, threw a hpf of 35 on the OS's, threw a lpf of 60 on the sealed... here's the result. Obviously a huge peak in the 45-55 range but not too bad everywhere else. I'm sitting here watching one of the reference discs... wow. I need to do a lot more fine tuning, but so far these are awfully impressive.
Name:	7-8-15 after OS try 1.jpg
laeriq is offline
Old 07-08-2015, 07:14 PM
carp's Avatar
Liked: 1741
The chest slam/punch has to be insane!!
carp is offline
Old 07-08-2015, 07:27 PM
laeriq's Avatar
Quoted: 63 Post(s)
Liked: 90
Yeah the sofa has turned into a massage chair. Going to pop in Jupiter ascending and release the brain for a couple hours. The wife is giving me sideways looks 😈
carp and lbrown105 like this.
laeriq is offline
Old 07-08-2015, 08:29 PM
Quoted: 219 Post(s)
Liked: 57
Thank you, i will have to take a closer look at these as well. Hopefully these are discounted heavily but from what i remember they take a significant jump up cost wise.
Old 07-08-2015, 08:59 PM
Nabs17's Avatar
Quoted: 891 Post(s)
Liked: 488
Significant over a xls1500
Nabs17
Nabs17 is offline
Old 07-09-2015, 01:36 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
I needed the DSP.
And they do feel and look a lot sturdier compared to XLS.
staaled is offline
Old 07-10-2015, 02:11 PM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
No new posts since yesterday.
Is my word final ?
Not much going on in my system last 12 months or so.
I did get a nano avr , but it is still boxed.
Just enjoying the current setup is too inviting.
Linn has introduced room optimisation for DS players,
so I could tame 855 and 125 Hz peaks which were present in stereo playback.
Nice improvement.
One has to choose a speaker though for it to work , so I chose Linns
klimax 350.
And sent a request to Linn for JTRs addition to the list.
staaled is offline
Old 07-10-2015, 06:56 PM
Reefdvr27's Avatar
Liked: 1038
Is my word final ?
Nice improvement.
klimax 350.
What is you're current system?
I am at some point going to get the Mini DSP with Dirac DDRC-88A, I mean I would get it now, but I have not been in my theater for 2+ weeks, so mine would most likely be in a box like yours. Hopefully this weekend I can get my system finally tuned up. I could really use a week off right about now, I could get everything I need to get done, DONE!
Old 07-11-2015, 01:38 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
I hope you will find the time to do so.
And then enjoy the result.
For HT :
Oppo 103 , Marantz 8801, Lyngdorf amplifiers (SDA2175 and TDAi2200)
212HT LP's ( LCR) 228's (LS/RS)
2 Captivators ( Crown XTI 4002 amplifiers, bridge mode)
Stereo:
Linn DS/ Transrotor Fat Bob S
Lyngdorf amplifier ( does double duty stereo/HT on speakers listed above)
212 HT LP's
The nano avr I will use to see if it can improve on XT32.
And eventually get the Dirac license to compare it to XT32.
RMK! likes this.
staaled is offline
Old 07-11-2015, 02:00 PM
Gorilla Killa's Avatar
Quoted: 431 Post(s)
Liked: 434
Ive been around here long enough to know I wasted a bunch of money on crap, now that I have triple 12s those days are done, . my question is do I spend more on the amps or the pre processor. I see qsc, crown, and behringer used frequently. ill be getting amps first as I have pre outs on my avr and can use immediately. curious as to what everyone else is using, pro vs commercial offerings. i have 3k budgeted for now and would like to not exceed that as the wife was buggin out a bit about the size of these speakers, she has quieted down, like to keep it that way
Gorilla Killa is offline
Old 07-11-2015, 02:24 PM
RMK!'s Avatar
Quoted: 1599 Post(s)
Liked: 1465
Along those lines (eg not wasting money) if your AVR is working for you why switch? The JTR's high efficiency means that anything up to and beyond reference is possible in all but the largest rooms with AVR type power. If you're, looking for additional channels, then maybe new AVR or a separates option would be good. If you're wanting better sound quality via EQ, there are many options but treating the room should be the first order of business unless that is a bridge too far for the wife. Many ways to spend your time and money in this hobby.
You might just want to enjoy what you have a bit longer but if that cash is burning a hole in your pocket, play on ... you have lot's of company here.
Nabs17 and MiniHT like this.
Opinions are not facts.
RMK! is offline
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
