Official JTR speaker thread - Page 1117 - AVS Forum | Home Theater Discussions And Reviews
 8496Likes
post #33481 of 37595 Old 01-08-2016, 02:23 PM
N8DOGG's Avatar
Quoted: 1079 Post(s)
Liked: 1177
Originally Posted by staaled View Post
Congratulations.
The AVM60 was on my shortlist but I got the 7702Mk2.
I remember it had something to do with the fact that it will be around 6000 CAD here.
The retail is 3500$ CDN for the AV60 but I can get the 7702 now for over $1380 less and actually bought my volt 6's and my new Rotel 1095 with the money saved buy going with the marantz vs the Anthem.... plus the anthem doesn't have true dual sub outs.... That just leaves me more room when I decide on what projector to upgrade too lol
N8DOGG is offline
post #33482 of 37595 Old 01-08-2016, 04:04 PM
rhed's Avatar
Quoted: 642 Post(s)
Liked: 482
Originally Posted by carp View Post
Amazing man... complete and total overkill and I love it!! This will have to be one of the best systems.... ever.
I wimped out and never tried the 215's for surrounds when I had the 4722's as mains (or vice versa) because I was too afraid I would like it and I wouldn't be able to get it out of my head. I still haven't experienced a full range surround setup and I think I had better keep it that way. IMO it makes no sense that it would make much of a difference... but then again that's what most everyone says about full range mains too and I know first hand that isn't true.
Yea.. And I'm just goin by researching and reading with positive feedbacks. Guess I'll be the test subject on this one. And will post my opinion. If it doesn't make difference, well at least the bass will definitely bring more to the table..
who is using Towers or full range for the surrounds?
rhed is offline
post #33483 of 37595 Old 01-08-2016, 04:23 PM
Nabs17's Avatar
Quoted: 917 Post(s)
Liked: 513
Please post some pictures when you get this setup, I would love to see it.
Nabs17
Nabs17 is offline
post #33484 of 37595 Old 01-08-2016, 04:25 PM
Reefdvr27's Avatar
Quoted: 1572 Post(s)
Liked: 1054
So @Jeff Permanian ,
Check out the Rockford Fosgate T3S2-19 nineteen inch driver.
Ricci just tested it, and basically said it is the best single driver (not system) tested to date.
http://www.data-bass.com/data?page=s...d=125&mset=137
More displacement than any other driver he's tested except for the 24" SI, and exceptionally low distortion. Negative? $2500 each driver.
But no other single driver has tapped out his K20 amp bridged --- this one managed to.
I'm thinking it'd be good basis for a 219RT. The driver has the ability to play up into the mid 300hz range -- which would mate well with your compression driver handling 360hz and up!
Something new from JTR to keep rhed from thinking he's finished right? (BTW - nice system rhed, I'm definitely envious!)
Ricci brought that driver to Beast's house. It was incredible to say the least! I stared at it for like 15 minutes while it sat on the table.
Reefdvr27 is offline
post #33485 of 37595 Old 01-08-2016, 04:55 PM
N8DOGG's Avatar
Liked: 1177
The only thing holding them back is the price, although they are making at minimum, 1300$ profit on every driver, so I guess maybe they have it right LOL.
N8DOGG is offline
post #33486 of 37595 Old 01-09-2016, 12:28 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
Ah , OK.
I very much like the 7702Mk2 in my system.
Better than the 8801 I had before on normal surround ( Atmos will follow as soon as the speakers have arrived).
staaled is offline
post #33487 of 37595 Old 01-10-2016, 06:16 AM
Stoked21's Avatar
Quoted: 1525 Post(s)
Liked: 926
Been going through some more Audyssey issues since treating my room. Pretty sure I have a crappy calibration as it was pinging multiple times on each speaker. Potentially bad mic as there wasn't much ambient and it's never done multiple ping sequences before.
With that being said, I toed in my 228s more than usually so they are pointed almost directly at head of MLP as opposed to strafing past each ear. I'm thinking this is attributing to some brightness and harshness. I'm getting ready to re-run Audyssey and am going to proactively move the 228 toe-in a little further apart.
My question is with the 60x60 dispersion of the horn, do most run with less toe-in?
Stoked21 is offline
post #33488 of 37595 Old 01-10-2016, 06:20 AM
Reefdvr27's Avatar
Liked: 1054
Nope, I have my 215RT's as wide as the room lets them and toe'd into the center seat.
post #33489 of 37595 Old 01-10-2016, 07:49 AM
N8DOGG's Avatar
Liked: 1177
My room is 14 feet wide and I sit 13 feet away from the speakers and they are pointed right at me.
N8DOGG is offline
post #33490 of 37595 Old 01-10-2016, 09:20 AM
Archaea's Avatar
Quoted: 3060 Post(s)
Liked: 2664
Turn off all your EQ and play with the Toe-In to see what you like.
Some people like the horns crossed in front of their listening position. (helping to further avoid sound spray onto the walls) ---
When I had the 228HT - I liked them toed in directly to my in the center listening position or a little bit in front of my listening position - but I also didn't have any treatments in my room at the time. At my old place my room was very "live" and reflective.
Archaea is online now
post #33491 of 37595 Old 01-10-2016, 11:03 PM
rcohen's Avatar
Quoted: 1364 Post(s)
Liked: 592
There is also a secondary benefit, where crossing the horns a bit can grow the sweet spot.
It's a psychoacoustic trick where a slight volume boost from the far speaker (due to toe in) counteracts the precedence (Haas) effect from the near speaker. If you overdo it, the imaging at the MLP degrades, but in the right balance, the imaging stays intact, but with a nice big sweet spot.
lbrown105 likes this.
rcohen is offline
post #33492 of 37595 Old 01-11-2016, 06:10 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
S8's have arrived.
Name:	S8 LP 1.jpg
ID:	1178010   Click image for larger version
Name:	S8 LP 2.jpg
Nabs17, rhed, HTPCat and 2 others like this.
staaled is offline
post #33493 of 37595 Old 01-11-2016, 10:11 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1994
Okay so be honest, how much do you miss this old setup?....lol
I know I miss my old HT room a LOT!...lol
jbrown15 is offline
post #33494 of 37595 Old 01-13-2016, 08:44 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
I will be using Trespa as a mounting/backplate for the SL8 HT-LP.
Although a bit glossy it has a dimpled surface and complements the JTR finish.
ID:	1182066   Click image for larger version
staaled is offline
post #33495 of 37595 Old 01-13-2016, 08:52 AM
Nabs17's Avatar
Quoted: 917 Post(s)
Liked: 513
Are you using the keyholes to mount to the backplate?
Nabs17
Nabs17 is offline
post #33496 of 37595 Old 01-13-2016, 09:05 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
Yes.
I have drilled the plates for nut or bolt to go into the keyholes.
The speaker will be fixed to the plate and the plate will be mounted to the ceiling ( 4 holes in corners ).
Trespa, 8mm, is very solid.
staaled is offline
post #33497 of 37595 Old 01-13-2016, 09:10 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
And a large center hole in the Trespa backplate.
staaled is offline
post #33498 of 37595 Old 01-13-2016, 09:22 AM
Nabs17's Avatar
Quoted: 917 Post(s)
Liked: 513
Yep...I used the keyholes as well mounted directly to the ceiling but on 2 of the 4 I had to go into the attic to mount 2x4's between the joists to screw into...wasn't fun.
Backplate looks nice.
Nabs17
Nabs17 is offline
post #33499 of 37595 Old 01-13-2016, 09:45 AM
Archaea's Avatar
Liked: 2664
I REALLY loved this setup! No doubt!
post #33500 of 37595 Old 01-13-2016, 09:50 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
I would be calling on the neighbours in your situation.
staaled is offline
post #33501 of 37595 Old 01-13-2016, 09:53 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
Although the 8's are compact one can feel the heft.
Real JTR DNA.
I can hardly wait to fire them up.
staaled is offline
post #33502 of 37595 Old 01-13-2016, 01:01 PM
RMK!'s Avatar
Quoted: 1691 Post(s)
Liked: 1615
Nice solution ...
RMK! is offline
post #33503 of 37595 Old 01-14-2016, 12:42 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
Nice solution ...
I will use Regupol between plate and ceiling :http://www.akoestiekwinkel.nl/regupo...pelingsstroken
Four 2 inch squares on each corner and 4 squares more central on the plate.
It will control (some) resonance and allow the speakercable to go between plate and ceiling.
staaled is offline
post #33504 of 37595 Old 01-14-2016, 05:28 AM
Nabs17's Avatar
Quoted: 917 Post(s)
Liked: 513
I did something similar. I placed some of this between the s8's and the ceiling:
http://www.auralex.com/product/studiofoam-dst-112/
I used 14" long strips of it and wedged it between the four sides and the ceiling. I used this because I have a bunch of it and it was easy to cut.
Nabs17
Nabs17 is offline
post #33505 of 37595 Old 01-15-2016, 08:11 AM
Stoked21's Avatar
Liked: 926
You SOBs made me jealous so I had to call Jeff to get four slant8 LPs on order too....So I should be all JTR 7.2.4 by end of the month.
Seems excessive with the Trespa, auralex, etc. But I can see why for the aesthetics of it. I'm going to cut plywood (probably 1/2") and paint panels white to match ceiling. Long enough to span 2 joists with fostner hole in the center for wiring. 4 screws in the panel for keyhole mounting. Small 1"x2" brace strip painted color of ceiling as well; screw it into the plywood to prevent the keyholes/screws from disengaging. Easy-on and easy-off, only a couple hours of work, low-cost at maybe $40 total for all 4 speakers, and will camouflage with the ceiling to showcase only the speaker.
Nabs17, RMK!, staaled and 2 others like this.
Rack (7.3.4 20,000W): Marantz AV7702mk2, Crown XLS1500 (9), iNuke3000DSP, miniDSP DDRC-88A (3), Samsung UHD HDR: UBD-K8500, Panamax M5400-PM, AppleTV Gen4
LCR: JTR 228HT (3) Surrounds: JTR S8 & S8LP (4) Atmos: JTR Slant8LP (4), RBH IC (2) Subs: JTR Captivator 1400 (2), Dayton UM18-22 NF PJ: JVC RS400 Screen: Seymour UF 130"W 2.35 Misc: SimpleControl, Philips Hue(15 light), Echo Control, Synology DS216play
STOKED Home Theater Build
Stoked21 is offline
post #33506 of 37595 Old 01-16-2016, 10:06 AM
RMK!'s Avatar
Liked: 1615
This pic made me nostalgic for the good old days of my journey into HT. I seem to recall the floor above this ^ room was a bit compromised by a dual Orbit Shifter demo ...
Re the toe-in issue, I have tried every possible angle for the main speakers and always preferred the speakers "aimed" at or very close to the main LP. If I used the extreme toe-in suggested by some, it collapsed the sound stage and imaging of the mains for 2 channel listening. Maybe it works for MC, but with 2 channel ... not so much.
Here is an old pic of my room pre my contracting the JTR influenza. Note: the relative narrowness of the front wall space (13') as that may be a contributing factor to my lack of success with extreme toe-in.
carp, Archaea and countryWV like this.
RMK! is offline
post #33507 of 37595 Old 01-16-2016, 04:22 PM
Reefdvr27's Avatar
Liked: 1054
I tried something very similar using painted plywood. I am no carpenter, but I tried for hours trying to line up the keyholes to the plywood and I just could not get it to where I felt it would be "safe" to mount to the wall. I am sure somebody with better common sense than me would have done it in a snap, but again I just could not line it up that the speakers and screws sat flush in the keyholes. I hope you have better luck than me. I did not want to do it, but I winded up drilling into the cabs with the Axiom full metal brackets. If I go to sell them I will repair the holes, but I don't see myself selling them. My thought was, these speakers are meant to be wall mounted and I felt that the full metal brackets offered the best support.
post #33508 of 37595 Old 01-16-2016, 06:04 PM
Nabs17's Avatar
Quoted: 917 Post(s)
Liked: 513
The Martian in DSU is spectacular for all you Atmos folks....just finished it. Ralph gave is a 5 star DSU rating and he's right.
nash23 likes this.
Nabs17
Nabs17 is offline
post #33509 of 37595 Old 01-17-2016, 09:00 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
I tried to mount the 8's to the plate today and could not attach them
securely.
Holes were aligned but nuts and bolts couldnt be tightened hard.
So I will use either Linn Brakits or Dynaudio's wall mount.
These will also allow some alignment on LP's.
staaled is offline
post #33510 of 37595 Old 01-17-2016, 09:14 AM
Nabs17's Avatar
Quoted: 917 Post(s)
Liked: 513
securely.
This was one of the reasons for me sticking the 14" strips of the Auralex between the S8 and the ceiling. There was not much room between the S8 and ceiling so it keeps the speaker from moving. They are really secure with no movement at all.
Nabs17
Nabs17 is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
