Official JTR speaker thread - Page 1123 - AVS Forum | Home Theater Discussions And Reviews
 8691Likes
post #33661 of 37925 Old 01-23-2016, 11:46 AM
NWCgrad's Avatar
Quoted: 1272 Post(s)
Liked: 1311
Watched Everest last night...actually turned down the bass as the wife was not liking how it made her feel. I thought it was great. The storm in the movie mirrored the storm outside. Just got down shovelling snow, 32.5" so far.
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #33662 of 37925 Old 01-23-2016, 11:51 AM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
^As Rob said it must be a semantic thing. In the midwest when we say "biting you in the butt" its usually a negative thing. It was confusing because the room gain is what might end up saving the day! My ported 212's get a lot of room gain (+10dB) from about 125hz-80hz with close wall placement. It just proves there is such a thing as a free lunch!
lbrown105 is offline
post #33663 of 37925 Old 01-23-2016, 12:34 PM
RMK!'s Avatar
Quoted: 1698 Post(s)
Liked: 1630
Since the measurements showing the big "room gain" are from the primary LP it is very likely the result of a bass peak at that location. When DD was here he averaged the front row measurements and there was room gain but it was ARAIR within normal (for this thread) 6-10db range.
Oh and even though I live in California, being bitten in the butt is considered "a negative thing" by most of us (Kim Kardashian excluded).
lbrown105 likes this.
Anxiety is contagious, please keep yours to yourself.
RMK! is offline
post #33664 of 37925 Old 01-23-2016, 02:02 PM
dlbeck's Avatar
Quoted: 557 Post(s)
Liked: 662
Originally Posted by carp View Post
Do you listen to 2 channel music? If not, then go for the 212's. If however you think there is ever a chance that at some point you would be interested in running full range mains for music then I'd go with the 210 RT's. If there is any way possible to have a matching vertical center channel I highly recommend it. For years I fought that and had a horizontal 212 under my screen. A year ago I finally got an AT screen and put the center channel 212 behind it. Should have done it a long time ago...
Still, a horizontal 228 HTR will work a lot better than the smaller Salk center channel. However, I do really love your Salk towers for music, I've heard them many times. While I do prefer the JTR's even for music, the Salks provide a different flavor of awesome for music that I really enjoy.
A friend owns both your speakers - the same model of Salks for music upstairs and JTR's for his unbelievably awesome theater. He has the 212's and if I had his theater I would too because it is so well treated and very large so you would want as much headroom from the mains as possible and the 212's provide that pretty much better than any speaker I know of (recently measured at 105 sensitivity, much higher than the conservative rating by JTR).
He might chime in here with more advice.
@dlbeck
@Chriscorv58
I absolutely love my Salk HT2-TL's for 2 channel music...those ribbon tweeters are super smooth for those female vocals. But if you're also using them for movies, I understand why they are not fitting the bill. The JTR's are a lot more dynamic and I would follow what @carp said about the 210's vs the 212's. If you have the bottom end covered go with the 212's. Can't go wrong.
Oh...and save the Salk's for 2 channel.
carp likes this.
dlbeck is offline
post #33665 of 37925 Old 01-23-2016, 03:00 PM
Chriscorv58's Avatar
Quoted: 122 Post(s)
Liked: 82
Originally Posted by dlbeck View Post
@Chriscorv58
They truly are wonderful for female vocals, I need more rooms in the house in order to keep them.
I'd love them for strickly 2 channel. I'm so glad I didn't pull the trigger on a pair of soundscape 8s earlier this month. I still would not have been satisfied for movies.
Hopefully someone has jtr speakers in my area that will demo them for me.
Sent from my SM-N910V using Tapatalk
Sony 940c 75" Display, Marantz AV8801, HTPC, JTR 215RM Mains & JTR 210RM Center, DIY Surrounds, Crown Xti & Cdi Amps, Seaton Submersive HP+ Master and Slave.
Chriscorv58 is offline
post #33666 of 37925 Old 01-23-2016, 03:11 PM
raynist's Avatar
Quoted: 1574 Post(s)
Liked: 1550
Originally Posted by raynist View Post
Since it looks like I am not going to sell my 212's I moved them back up into the living room. I forgot how heavy they are when lugging them up a flight of steps, especially having bronchitis.
Anyways, here is a picture of them on top of a pair of SI18's in DIY 4cf boxes. I have 2 more subs to build too.
This is a secondary living room system so I don't want to go too crazy. I am trying to figure out how to get the center integrated. There is only 10 inches between the top shelf and the bottom of the TV. The TV can't go any higher on the stand mount. I could probably hang the TV higher on the wall, but I am not sure that stand can support 125lbs on the top shelf. I would like something lower and wider that I could perhaps put the Denon 4520 on top of with the center to get more airflow. If I got a stand like that I could probably put the TV on top of the center although I don't want to scratch the veneer.
Anyone have any ideas of what I could do to potentially keep the current stand and still use the center? I was also think of building something to go over the top shelf that would have legs down to the ground to support the center and tv weight. i am thinking combined they are 170-180.
I may move the subs at some point too and build/buy stands from JTR
Found this one at my local Best Buy
http://www.bestbuy.com/site/insignia-insignia-tv-stand-for-most-flat-panel-tvs-up-to-50-black/3088183.p?id=1218377796327&skuId=3088183&cmp=qrc00 586#
300lb rating!!!
raynist is offline
post #33667 of 37925 Old 01-24-2016, 01:58 AM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
you are squirming. So sorry you feel that way. it is a product of your misunderstanding of room gain at any position inn the room. I wish I hadn't pointed that out on a public forum. At first I truly thought there was another reason. You have crystallized it for all of us, so sorry it had to turn out like this for you.
Still friends? Room gain is your friend even if I am not.
post #33668 of 37925 Old 01-24-2016, 05:44 AM
rcohen's Avatar
Quoted: 1401 Post(s)
Liked: 630
Originally Posted by Chriscorv58 View Post
Using a Marantz 8801 and have a parasound A21 for mains and my older Acurus A250 for the center. I'm so used to listening to music with my seaton submersives. I have the HT2 TL's Crossed at 60Hz, center at 80hz
I am using a Parasound A51 with JTR 212s (coax version, now called HTR).
I tried a couple other amps, and I found the A51/212 combination to be exceptional.
The treble has ribbon-like smoothness and detail, combined with dynamics that no ribbon can touch.
Surprisingly, I found that the smoothness was significantly diminished with some Hypex NC400 amps I tried, and I couldn't fix it with EQ.
So, if you are crossing with subs and don't need 2000 watts, I'd highly recommend using that A21 with any coax-equipped JTR.
Chriscorv58 likes this.
rcohen is offline
post #33669 of 37925 Old 01-24-2016, 08:13 AM
RMK!'s Avatar
Liked: 1630
Put the pipe down Lance
RMK! is offline
post #33670 of 37925 Old 01-24-2016, 09:24 AM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
whew thanks because that thing is too heavy to carry around. did you find the ultimate cause? was it just excursion limits of the driver?
post #33671 of 37925 Old 01-24-2016, 09:44 AM
RMK!'s Avatar
Liked: 1630
Haven't had the time yet as I am a slave to the computer (working) and a sick wife this weekend. We did watch Out of Compton last night and I think that movie pretty much ruled out any problems with the woofers. That movie with 3 OS's would be interesting. I'm beginning to think that the sound(s) I heard on the Everest storm scene was intended.
RMK! is offline
post #33672 of 37925 Old 01-24-2016, 10:34 AM
carp's Avatar
Quoted: 2875 Post(s)
Liked: 2160
Could be... could also be accidental clipping by the sound dude. That happens in a scene in Ender's Game in a surround on the right side of the room. At first I thought my speaker was being over driven but when I turned the MV way down and re ran the scene the distortion sound is there no matter how low the volume is.
shivaji likes this.
carp is offline
post #33673 of 37925 Old 01-24-2016, 12:49 PM
raynist's Avatar
Liked: 1550
before center and 500 lb capacity insignia stand (300 lb top shelf, 100 other shelves)
Center and new shelf - not thrilled with the tv being higher, but it isn't as bad as some people I see that hang them over a fireplace. My wife informed me that I need to raise the clock She helped set everything up.
Can't get over how huge the center looks. The TV is a 60. Looks like I need a bigger TV now!
carp, N8DOGG, shivaji and 2 others like this.
raynist is offline
post #33674 of 37925 Old 01-24-2016, 06:27 PM
N8DOGG's Avatar
Quoted: 1111 Post(s)
Liked: 1217
To the guys with a marantx 7702's, has anyone experienced no sound when pausing a movie on their oppo? If I pause my oppo with a movie thats started, theres no sound when it returns. Though maybe someone else may have had that bug. Very weird.
N8DOGG is offline
post #33675 of 37925 Old 01-24-2016, 06:58 PM
Gooddoc's Avatar
Quoted: 3108 Post(s)
Liked: 2413
Never had the problem. Maybe it's an HDMI handshake issue?
Gooddoc is offline
post #33676 of 37925 Old 01-24-2016, 07:26 PM
N8DOGG's Avatar
Liked: 1217
Thats what I'm assuming as it's only with my 103D. It flat out refuses to work with my external darbee. Under no circumstance will it work, could have something to do with that too I guess. The darbee worked fine with my 80.3 and works fine attached to my old oppo 103 but won't work with the 7702 with any cable/input combo. Kinda weird.
N8DOGG is offline
post #33677 of 37925 Old 01-24-2016, 07:47 PM
Gooddoc's Avatar
Liked: 2413
Yeah, I've got the 103D as well. Curious, why you using an external Darbee? Is it better than the integrated solution in the Oppo?
Gooddoc is offline
post #33678 of 37925 Old 01-24-2016, 08:15 PM
N8DOGG's Avatar
Liked: 1217
The 103d was upstairs and the external was in the Ht room with the 103. I moved the 103d downstairs when the external wouldn't work. It's wierd.
N8DOGG is offline
post #33679 of 37925 Old 01-24-2016, 10:25 PM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 486
@RMK
Got home late from gym. Been at the gym almost all day today and yesterday. Though I stopped by bb and picked up the Everest copy. Will run that scene tomorrow after work. So far I've disabled all EQ on the 12000, set a HP @ 20. And 24 slope. My speakers are level matched @ 80 with a ratshack meter.. I'll post my findings after the run..
RMK! likes this.
rhed is offline
post #33680 of 37925 Old 01-25-2016, 06:56 AM
SomeOne Who Knows
SOWK's Avatar
Quoted: 578 Post(s)
Liked: 476
I'm running the 215RT's full range so no LFE channels. The 215's are level matched with no frequency boost and 18-50hz is running 20db hot (approx, OmniMic). Some like it hot () but it seemed like at a reasonably sane -7db MV I was pushing the woofers beyond their limits during the storm sequences of The Martian and Everest. I didn't check to see if the amps were clipping (they probably were) but at -7, they shouldn't.
Most of the time I'm fine with those frequencies running hot but certain movies with really aggressive audio point out the need to bring the +20db down. I could use Audyssey or the DSP in the Inukes or I could get a more powerful amp. Hope to have some time to run Audyssey today and see what that does. I don't like limits and I sure as hell don't like finding them at -7 MV.
If you are "properly" routing LFE to the 215's playing the pod scene in WOTW anywhere near reference you will find that limit immediately.. Just an FYI.
SOWK is online now
post #33681 of 37925 Old 01-25-2016, 07:01 AM
SomeOne Who Knows
SOWK's Avatar
Quoted: 578 Post(s)
Liked: 476
I suggest some of you don't go looking for the limits of some of your speakers, sometimes ignorance is bless.
SOWK is online now
post #33682 of 37925 Old 01-25-2016, 07:30 AM
RMK!'s Avatar
Liked: 1630
AV7702 and OPPO 103D here as well and no issues like you are having. I have all of my sources (HTPC and Xfinity cable box) routed through the OPPO via HDMI (bitstream). So I only have one HDMI input on the 7702 and it's a straight HDMI video pass through to the projector. I will occasionally get dropouts with my streaming service (VUDU) and then it seems to happen only on the main VUDU menu . Once I start the movie all is well. My HDMI cable is a 50'er and 5 years old so I'm thinking that is the culprit.
RMK! is offline
post #33683 of 37925 Old 01-25-2016, 07:37 AM
RMK!'s Avatar
Liked: 1630
I run the LCR's full range so the SSP routes the LFE to the front speakers. I have run the Pod emerging scene many times @ ref levels with no issues.
RMK! is offline
post #33684 of 37925 Old 01-25-2016, 07:49 AM
SomeOne Who Knows
SOWK's Avatar
Quoted: 578 Post(s)
Liked: 476
I suggest you try this via the Oppo 103D.
http://www.demo-world.eu/download-2d...1_lossless.jpg
and download this file by clicking on the picture
http://s1.demo-world.eu/hd_trailers....sless-DWEU.mkv
put the file onto a USB stick and play DIRECTLY from the Oppo 103D for best accuracy and not from the HTPC.
If it gets to the LFE channel and you hear no output, you're not routing the LFE properly.
And please make sure all test tones play at the same level dB.
Including the LFE channel.
SOWK is online now
post #33685 of 37925 Old 01-25-2016, 08:08 AM
SomeOne Who Knows
SOWK's Avatar
Quoted: 578 Post(s)
Liked: 476
RMK, if you find out you have not been routing LFE to the 215's, please do NOT do it.
That's all I am going to say.
SOWK is online now
post #33686 of 37925 Old 01-25-2016, 08:15 AM
RMK!'s Avatar
Liked: 1630
If it gets to the LFE channel and you hear no output you're not routing the LFE properly.
Thank you for the suggestions but I'm running the 215RT's full range and not doing bass management in the OPPO. I do use JRiver for BM on the HTPC where the LFE is mixed into the LCR's. When streaming or playing a bluray, all LFE is routed to my LCR's by the SSP and nothing is connected to the LFE channel. The net result is the same hence Full Range output including LFE to my LCR's regardless of the source.
RMK! is offline
post #33687 of 37925 Old 01-25-2016, 08:17 AM
SomeOne Who Knows
SOWK's Avatar
Quoted: 578 Post(s)
Liked: 476
Then play the file via your HTPC. No harm in trying it.
SOWK is online now
post #33688 of 37925 Old 01-25-2016, 08:21 AM
SomeOne Who Knows
SOWK's Avatar
Quoted: 578 Post(s)
Liked: 476
What is your config?
Where does the SSP fit in?
HTPC (JRiver) > Oppo 103D > SSP > Pre-Amp?
SOWK is online now
post #33689 of 37925 Old 01-25-2016, 08:37 AM
RMK!'s Avatar
Liked: 1630
The OPPO is the HDMI switch for the Cable box (Cable TV, internet and VUDU) and HTPC (Jriver and Internet). All sources are set to HDMI bitstream to the OPPO via HDMI and then one HDMI out of the OPPO to the SSP. The SSP passes the video (untouched) to the PJ and outputs the audio to my amps.
I used to have a Rane RPM 88 multiprocessor which took the output from the SSP and mixed in the LFE channels and did some other DSP but I found that was unnecessary and prefer the much cleaner Full Range setup I have now. I will test the LFE via the program link you sent and let you know what I find.
RMK! is offline
post #33690 of 37925 Old 01-25-2016, 08:52 AM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 486
I don't just do the midbass since I have the 215's. That's part of why I love them so much, when I tweak the bass I can do it all at once I don't have to EQ the speakers midbass and then turn up the subs. It happens at the same time since all the sound comes out of the 215's.
I use the dsp on the inuke amp, it's awesome IMO. I can't tell you exactly where I set the EQ because it depends on the song playing and my mood. Here are examples of what I use but I can change it on the fly since I have my laptop always next to my main LP and it's remote desktop controlling the PC in the next room that is connected to my AVR and that is the PC my inukes are plugged into with the usb cord.
Here is an example:
Here is where it gets more interesting. I love using the dynamic EQ function. Notice I'm not actually using the dynamic part of it since the threshold level is set to 0. What I am doing is tayloring in a nice crazy house curve for when the mood strikes for house shaking low end bass and nice tight punchy boosted mid bass.
The left and right side of the EQ you see below affect BOTH left and right speakers together. It's NOT like the left side is the left speaker and the right side is the right speaker. I've had some confusion with people in the past after posting the inuke dsp pics.
These are just quick examples, I change it all the time. For movies though I use the same setting. I just boost 3 db's and let the subs do the heavy lifting.
Hey carp.. I'm not to familiar with the DEQ function in the inuke. So if I boost say the the frequency range 100 and down in channel A. And do the same at channel B. Does that considered stacking? I'm confused between the 2 channels.. Thanks
rhed is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
