Official JTR speaker thread - Page 1126 - AVS Forum | Home Theater Discussions And Reviews
 8192Likes
post #33751 of 37226 Old 01-27-2016, 07:31 AM
SOWK's Avatar
Quoted: 493 Post(s)
Liked: 404
Originally Posted by desertdome View Post
They are a ported speaker and require a high pass filter - just like the Captivator 1400. Are you using a high pass filter?
Jeff said on his forum, "The Noesis 215RT need a 16hz highpass filter." Most use a 20 Hz HPF since they don't have the capability of using a lower filter.
Yes I have done that as well in my personal setup with a MiniDSP Nano AVR.
For the setup I did it last on. No HPF was in the system.
And its bottoming out around the 30Hz range, and not the sub 20Hz range.
SOWK is offline
post #33752 of 37226 Old 01-27-2016, 08:46 AM
jlpowell84's Avatar
Quoted: 1763 Post(s)
Liked: 768
@carp , @Archaea , or other omnimic users. Any suggestions on MINIMUM windows system requirements to run it? I am going to purchase an Omnimic system as I don't want to dive into trying to diagnose the REW issues on Mac. I found a windows 10 tablet with detachable keyboard normally $350ish on sale for $169 and am thinking about trying it out. I sure wish they made it Mac compatible! Or maybe I should think into it a bit more and research a HTPC and roll with that. I have a connection to a friend at an IT company who could build a PC for me...Any thoughts greatly appreciated Need to see what the new subs will measure!!!
jlpowell84 is online now
post #33753 of 37226 Old 01-27-2016, 09:12 AM
desertdome's Avatar
Quoted: 1210 Post(s)
Liked: 1339
It is fairly difficult to bottom out a pair of 15" drivers at 30 Hz at reference level and below. Are you using the Emotive XPA-5 on the 215RT's? The Emotive doesn't even have enough power to bottom out the drivers without a clipped signal. It is rated at 34v of output per channel. The 212HTR's can handle more than that at 40 Hz and they are tuned much higher than the 215RT's. The ported BMS 18N862 on data-bass.com has a very similar displacement and tuning to the 215RT. It can handle 259+ volts at 30 Hz without bottoming out!
One can bottom out a driver when the signal is clipped. One can clip the digital signal in a receiver, miniDSP, or a DSP amp like the iNukes.
rhed likes this.
High Impact AV
desertdome is offline
post #33754 of 37226 Old 01-27-2016, 09:44 AM
Stoked21's Avatar
Quoted: 1520 Post(s)
Liked: 922
Yes please. I will eventually need to figure out how to mount to my ceiling as well.
Will do when finished tonight. Be forewarned...I make it sound easier than it is. Obviously you have to find joists or you are in for it. Mine are installed on popcorn ceiling, which means panels don't lay completely flush...Especially since one of the 4x8 pieces of drywall is guppy bellied in the center. So it's not looking as good as I would like. But acoustic panels are going to hide a lot of that. I'll probably need to caulk around some sides of the panels too.
One of the Slant8s just took a 5' fall from a ladder onto it's front corner. I about cried.... No apparent or visible damage. Tested it and sounds fine. It really seems to be a 2 person job to get them up. They are a bear to line up with keyholes and you're working with arms above head for LONG time.....Very physical and tiring...
Got 3 up, 1 left.
Stoked21 is offline
post #33755 of 37226 Old 01-27-2016, 09:58 AM
SOWK's Avatar
Quoted: 493 Post(s)
Liked: 404
When I was running my 215RT's I was using a D-SONIC M3-4500-3, 3x2100w/4 ohm
And at the other location:
Crest Pro Lite 7.5 ~ 2000w/4 ohm
Also
MiniDSP was factory reset with ONLY HPF no other changes
Pre-Pro was Fully factory restored with no EQ or tone adj aka no clipping
SOWK is offline
post #33756 of 37226 Old 01-27-2016, 09:59 AM
SOWK's Avatar
Quoted: 493 Post(s)
Liked: 404
Got 3 up, 1 left.
Thank you!
SOWK is offline
post #33757 of 37226 Old 01-27-2016, 10:39 AM
RMK!'s Avatar
Quoted: 1677 Post(s)
Liked: 1598
I'm going to need Jeff to personally show me then.
I've been able to bottom out the Woofers on two full sets of 215RT's running that scene at reference or even close to reference with LFE routed to them.
He is the simplest setup I've done and it still happened.
Media Player
Pre-Amp
Amp
Speakers
Settings on each
Media Player:
Source: War Of The Worlds Blu-Ray POD emergence scene
Bitstream DTS Master Audio
Pre-Amp:
Full reset to factory defaults
Fronts set to Large all other speakers and sub set to "OFF"
Run Channel level tones to level match to 75dB on left and right channel
*no bass boost or EQ applied.*
Amp:
No settings required
Speakers:
Play anywhere near reference aka 0 in "relative scale" volume.
Bottom out the speakers
You can't get it any simpler then that!
Going to post once more....
If anyone downloads this file, and plays it and gets no sound once it hits the LFE channel, you ARE NOT routing LFE to the mains properly.
"http://s1.demo-world.eu/hd_trailers.php?filename=dts_hd_master_audio_sound _check_7_1_lossless-DWEU.mkv"
There is really no reason to go any farther with this unless Jeff can prove to me otherwise.
I would LOVE to be wrong here, as if I am, then I can learn. But this will bother me forever until I find out.
!!!!This is not a ding on Jeff's Speakers or the 215RT's as I myself have 13 speakers from him!!!!
I just don't understand how I am the only one who can bottom them out easily with nearly no effort at all.
OK no one is saying you are dinging Jeff but the info you are posting is not what others are experiencing. I checked my LFE output running full range and I do in fact have normal output from the woofers on the sub channel of the speakers test. That said, my speaker levels were all over the map. I attribute this to teenagers having used the system for gaming while I was on vacation recently ...
I have a new digital SPL meter so I level matched all the speakers and then played the Everest storm scene again this time at reference. It was intense (I think this one is mixed hot) but sounded great. I then put in War of the Worlds Bluray (DTS HDMA 5.1) and ran the entire chapter 5 (pod emerges) at reference and it sounded perfect. No bottoming or distress with my simple full range LCR setup. I don't know what your issue was but that scene on my system at reference was no problem. It had been quite a while since I watched it and it was interesting that the video is such poor quality but it remains a cool bass demo.
rhed and DRC3 like this.
Opinions are not facts.
RMK! is offline
post #33758 of 37226 Old 01-27-2016, 10:50 AM
SOWK's Avatar
Quoted: 493 Post(s)
Liked: 404
How did you do this? What did you use to test?
SOWK is offline
post #33759 of 37226 Old 01-27-2016, 11:21 AM
Point Source
beastaudio's Avatar
Quoted: 3736 Post(s)
Liked: 3008
Yea I don't get it at all. It is SUPER grainy and almost to the point I make sure I run quite a few other demo's with good PQ before I show anyone that clip.
beastaudio is offline
post #33760 of 37226 Old 01-27-2016, 11:35 AM
countryWV's Avatar
Quoted: 408 Post(s)
Liked: 588
Also
I've read a lot of complaints about the MiniDSP clipping.
Chris
countryWV is offline
post #33761 of 37226 Old 01-27-2016, 11:41 AM
SOWK's Avatar
Quoted: 493 Post(s)
Liked: 404
Only if you don't know how to use it....
countryWV likes this.
SOWK is offline
post #33762 of 37226 Old 01-27-2016, 12:25 PM
RMK!'s Avatar
Liked: 1598
I have several disks (blurays) that have speaker test signals on them. I used the Auro Demo disk this morning to confirm that I had bass coming from my LCR's when it reached the subwoofer channel. I do ...
I did the level adjustments on my Marantz SSP but I do not have individual LFE adjust capability so it's just what ever is there. Works for me ...
BTW, I had my SPL meter set to slow, C, peak and the peak in WOW CH 5 was 119.1db.
RMK! is offline
post #33763 of 37226 Old 01-27-2016, 01:39 PM
Stoked21's Avatar
Liked: 922
All 4 Slant8LPs up. The fourth one was a B**CH to get up! Screws must have been just a little out of line so it took about 8-10 attempts! Some touch-up paint, clean up, re-run Audy etc....Should be good to go tomorrow! Last of my panels go on ceiling tomorrow, so no rush.
Can't wait to hear the all 7.2.4 JTR setup going!! All 14 matched 8"s! I know, you 215 guys can laugh and/or make me jealous. But I bet my match has to sound seamless!!!!
carp, rhed and Chriscorv58 like this.
Rack (7.3.4 20,000W): Marantz AV7702mk2, Crown XLS1500 (9), iNuke3000DSP, miniDSP DDRC-88A (3), Samsung UHD HDR: UBD-K8500, Panamax M5400-PM, AppleTV Gen4
LCR: JTR 228HT (3) Surrounds: JTR S8 & S8LP (4) Atmos: JTR Slant8LP (4), RBH IC (2) Subs: JTR Captivator 1400 (2), Dayton UM18-22 NF PJ: JVC RS400 Screen: Seymour UF 130"W 2.35 Misc: SimpleControl, Philips Hue(15 light), Echo Control, Synology DS216play
STOKED Home Theater Build
Stoked21 is offline
post #33764 of 37226 Old 01-27-2016, 02:04 PM
RMK!'s Avatar
Liked: 1598
Should be an a$$ kicker system.
rhed, Chriscorv58 and Stoked21 like this.
RMK! is offline
post #33765 of 37226 Old 01-27-2016, 02:46 PM
N8DOGG's Avatar
Quoted: 1050 Post(s)
Liked: 1127
I can bottom out my 215s but that's with a Clone amp and running them 6dB hot and 5 or 6 dB over reference. And it's not a full bottom, more like a " that sound can't be good" type thing lol
N8DOGG is offline
post #33766 of 37226 Old 01-27-2016, 03:01 PM
carp's Avatar
Quoted: 2651 Post(s)
Liked: 1925
When I get a chance I'll try WOTW again, but I'll need to hook up my other inuke so that each inuke 3000 is bridged to a 215. A single inuke 3000 leaves me a couple db's short of reference on that scene before clip lights come on if I remember right.
carp is offline
post #33767 of 37226 Old 01-27-2016, 03:22 PM
rhed's Avatar
Quoted: 638 Post(s)
Liked: 479
I have a question.. If I'm level matched 80 dB on the rat meter, does that mean my "0" reference is -5?
rhed is offline
post #33768 of 37226 Old 01-27-2016, 04:22 PM
RMK!'s Avatar
Liked: 1598
AVR and SSP test tones are "normally" 75db. That being your case then yes, setting the levels at 80db with those 75db test tones would make ref -5. My Integra SSP's all did the fixed 75db thing regardless of the MV settings.
My Current Marantx allows me to adjust the MV which raises or lowers the test tones accordingly. I just ran them this morning at -10 db and set my levels to 75db. That makes my theoretical reference -10db ...
Isn't this a fun hobby ...
rhed likes this.
RMK! is offline
post #33769 of 37226 Old 01-27-2016, 04:25 PM
Stoked21's Avatar
Liked: 922
So posted some basic instructions for Slant8LP install. Not pretty pics, not pretty verbiage. But it's there and will get someone started.
Stoked Home Theater in KC
carp, RMK!, rhed and 4 others like this.
Stoked21 is offline
post #33770 of 37226 Old 01-27-2016, 06:03 PM
Archaea's Avatar
Quoted: 3014 Post(s)
Liked: 2608
PC requirements are really low. Omnimic will run fine on something as slow as an atom processor.
You may have gain issues on windows 8 or 10. You just have to run omnimic in windows 7 compatibility mode. This is well documented.
jlpowell84 likes this.
Archaea is offline
post #33771 of 37226 Old 01-27-2016, 06:51 PM
jlpowell84's Avatar
Liked: 768
Thanks for responding. I shall read up, just wanted to see if there was any "insider" tips
post #33772 of 37226 Old 01-27-2016, 07:42 PM
Stoked21's Avatar
Liked: 922
I run a Mac as well. Use REW and same gripe about omnimic not being supported. However, I was concerned about all the REW nightmares I heard about. Come to find out, non existent issues on Mac. It runs great. If you read @AustinJerry guide it's great and easy.
Only issue I've had is getting 7.1 out of a several year old Mac Air. I guess newer ones are okay. Typically you are only looking at lcr and sub. So it's been fine. If you want to measure surrounds or Atmos, you have to run multi-ch stereo and unplug the speakers you are not measuring. I just turn off the amps for those channels so it's simple. I'm sure there's a workaround to get 7.1 out of the minidisplay port to HDMI adapter. But I havent looked, since my solution has been quick and easy with a wall of proamps that have power switches.
Stoked21 is offline
post #33773 of 37226 Old 01-28-2016, 07:10 AM
RMK!'s Avatar
Liked: 1598
Those are great looking HT chairs. What make/model?
Only problem is I have white dogs that shed so the black cloth fabric would be a no go.
RMK! is offline
post #33774 of 37226 Old 01-28-2016, 10:48 AM
carp's Avatar
Liked: 1925
They are VERY comfortable too.
RMK! and Stoked21 like this.
carp is offline
post #33775 of 37226 Old 01-28-2016, 11:33 AM
Stoked21's Avatar
Liked: 922
Seatcraft Signature. Don't remember model name..Got them from 4seating. Couple other places sell them too. I was worried about the black myself and wanted to go with "pomegranate". Wife said....No too many reds. Black it was.
RMK! likes this.
Stoked21 is offline
post #33776 of 37226 Old 01-28-2016, 02:38 PM
DRC3's Avatar
Quoted: 87 Post(s)
Liked: 111
Haha- Same thing happened when I had someone over to demo things a while back. I put in the WOTW Chap.5 and let it rip. Afterwords he said sounds incredible, but whats wrong with the video and your projector. Not only was it grainy, as everyone knows, it was vibrating too. For such a great bass demo scene...the video needs editing, LOL.
I agree and usually demo some other stuff first (try to fill up the CIH screen too or they think somethings wrong).
DRC3 is online now
post #33777 of 37226 Old 01-29-2016, 08:49 AM
RMK!'s Avatar
Liked: 1598
That's about what I recall when I had the LG driving the 215's. I had to be over +10db to hear TCBG "that can't be good" sounds. That said, the OS's would start to make some unusual sounds at +15db. These things could be room resonances chiming in as at those levels, it's hard to pinpoint the origin of anything .
Are you using an HP filter?
RMK! is offline
post #33778 of 37226 Old 01-29-2016, 08:54 AM
N8DOGG's Avatar
Liked: 1127
When I did run full range for movies, it was 18Hz when I boosted them and nothing when they were flat. It only ever happened once or twice before I knew where the cutoff line was...... At those volumes though, they were just hammering. I still can't believe that much bass comes out of that speaker lol.
Though with my dsonic, I don't run a filter as they don't have enough power to bottom the drivers, just the clone did.
N8DOGG is offline
post #33779 of 37226 Old 01-29-2016, 09:40 AM
RMK!'s Avatar
Liked: 1598
Makes me wonder why Jeff didn't include a band-pass filter (HP) in the 215's crossover ... seems like a simple solution.
RMK! is offline
post #33780 of 37226 Old 01-29-2016, 09:52 AM
desertdome's Avatar
Liked: 1339
See this thread for a related discussion: Can't I just solder together a 19hz high pass filter?
High Impact AV
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
