Official JTR speaker thread - Page 1189 - AVS Forum | Home Theater Discussions And Reviews
 7783Likes
post #35641 of 36568 Old 08-23-2016, 08:41 AM
RMK!'s Avatar
Quoted: 1599 Post(s)
Liked: 1468
Originally Posted by Scott27 View Post
Hmm, so I can fit a couple of subs up the front behind the false wall, and I could definitely get one more behind seats at back of room, potentially 2. I think I might start with 2xS1's and see how they go, with the ability to upgrade to 3 or 4 down the track if the need arises (so to speak )
I think that is a well reasoned choice. I have had 4 subs in the room distributed in the 4 room corners and other variations of quad sub placement and frankly there were several locations that worked well bass wise. I have also had dual subs up front behind the screen with excellent results.
This is all room/LP dependent and the math is quite complex (for me ) so trial and error by listening and measuring was my methodology. I am running the JTR full range 215RT's and so the six 15"'s are up front behind an AT screen and it sounds perfect ... to me.
rhed likes this.
Opinions are not facts.
RMK! is offline
post #35642 of 36568 Old 08-23-2016, 03:04 PM
Scott27's Avatar
Quoted: 39 Post(s)
Wow! I would love to hear a set up like that one day!!
Scott27 is online now
post #35643 of 36568 Old 08-23-2016, 03:06 PM
Scott27's Avatar
Quoted: 39 Post(s)
Originally Posted by rcohen View Post
If it's a closed rectangular room, the free REW Room Simulator can give a pretty good estimate of frequency response with different quantities and sub&listener locations. Check the time alignment box. If you plan to use EQ, the main goal is to minimize nulls in the listening area. Without EQ, the goal is for the flattest natural frequency response in the listening area.
Here are a few layouts that I have found work best for minimizing nulls):
1) 4 subs in the corners (most output, good seat to seat consistency)
2) 4 subs on 1/4 3/4 positions on the front and back walls (best natural response, less output, good seat to seat consistency)
3) 2 subs wall centers on opposite sides of the room's longer axis (best natural response, less output, good seat to seat consistency)
4) 2 subs in opposite corners (more output than #3 , can EQ for good sound in 1 set, poor seat to seat consistency)
5) 1 nearfield sub (less predictable, but best way to get good results with 1 sub)
3 subs can be tricky, since you can't place them symmetrically. If you are against the back wall, it might work to have 1 behind you and 2 in front, since you would need less output so close. It's hard to get good frequency response when you sit close to a wall, though.
In general, I've gotten best results with #1 and #3 .
With 4 subs, you also have the option of placing them in pairs for the same results as #3 .
I got better results with #1 , but YMMV.
If you need room for the center speaker, one good option is to place 2xS1s on either side of the center speaker, and 1xS2 in back, for what is effectively layout #3. You can experiment with this kind of stuff in REW.
You can also place speakers on top of subs, if that gives you the right height.
For the S1s and S2s, overall, I'd suggest one of these, depending on placement practicalities:
1) 4xS1s in corners.
2) 2xS2s on the center walls of the long axis.
You can also do 2xS1 on the center walls of the long axis, although with less output. That might be enough, depending on your requirements.
Thanks rcohen, thats very helpful. I have a window in the centre of the back wall unfortunately, so corner placement is likely to be the way to go for me. It sounds like starting with 2xS1's and then going to 4 if needed. Will check out REW simulation, I havent played around too much with that part of REW yet.
post #35644 of 36568 Old 08-23-2016, 03:24 PM
rcohen's Avatar
Quoted: 1208 Post(s)
Liked: 519
Sounds like a good plan. Hopefully that window won't rattle. With 2 subs and the center wall off limits, make sure to try opposite corner placement. It's hard to predict what will work well in your room, but opposite walls worked well in my room, so I can at least say give that a try. For me, that gave good output, peaks that could be fixed with EQs, an minimal null problems. It gave less seat to seat consistency, but I'm the only one who really notices.
Later, I ended up going with 4 subs. That was a much smaller difference than going from 1 to 2. A bit more output, but the primary gain was better seat to seat consistency for the opposite corner placement. Front/back center wall gave good seat to seat consistency with 2 subs, but the output was MUCH lower than corner placement, so the corners won overall.
rcohen is online now
post #35645 of 36568 Old 08-23-2016, 08:22 PM
AlexBPM's Avatar
Are there any Noesis owners in Southern California that might be willing to give me a demo? I've been reading this thread for years and I've been dying to hear these speakers. I was even considering flying out to one of the GTG's but I keep missing them!
"Now, a clever man would put the poison into his own goblet, because he would know that only a great fool would reach for what he was given. I am not a great fool, so I can clearly not choose the wine in front of you. But you must have known I was not a great fool, you would have counted on it, so I can clearly not choose the wine in front of me" -Vizzini
AlexBPM is offline
post #35646 of 36568 Old 08-23-2016, 11:18 PM
RMK!'s Avatar
Liked: 1468
If you ever get up to Sacramento we might be able to arrange a couple of demos.
PM if interested.
rhed and HTPCat like this.
RMK! is offline
post #35647 of 36568 Old 08-24-2016, 01:54 AM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Haven't visited the JTR thread in a while and it's great comfort to see a lot of the same posters hanging here. Always loved everyone's way of thinking around here.
JBL Pro Cinema/PSA&HSU subs/Crown power/Sony SXRD
MANCHESTER UNITED!!
Reddig is offline
post #35648 of 36568 Old 08-24-2016, 07:54 AM
desertdome's Avatar
Quoted: 1120 Post(s)
Liked: 1223
rjh65 has mentioned before that he is in Santa Barbara. He has an Orbit Shifter LFU, 215RT's, 215RM, and 210RT's.
High Impact AV
desertdome is offline
post #35649 of 36568 Old 08-24-2016, 02:26 PM
Jeff Permanian's Avatar
Quoted: 657 Post(s)
Liked: 1382
The Captivator 4000ULF test results are up on Data-Bass:
RMK!, staaled, rhed and 2 others like this.
Jeff Permanian is offline
post #35650 of 36568 Old 08-24-2016, 03:22 PM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
Should I replace my shifters with a pair of cap4000s? Specs are so intriguing...and might be the perfect os/s2 hybrid. Really curious to hear this new sub... @Reefdvr27 , have you let yours loose yet?
Jeff Permanian likes this.
asoofi1 is offline
post #35651 of 36568 Old 08-24-2016, 03:58 PM
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
I say do it? But, why not just add 2 more shifters?
rhed is offline
post #35652 of 36568 Old 08-24-2016, 04:15 PM
carp's Avatar
Quoted: 2489 Post(s)
Liked: 1752
Asim, I don't know man... IMO that big advantage that the OS has starting at 50 hz and above (small advantage at 50 hz but gets much larger quickly as you go higher) is a big deal. The OS can pound your chest into oblivion and I believe this is the reason why. I think you would miss that headroom in the chest punching region.
I'm not saying that the 4000 numbers aren't incredible, they are. But... for me if I had to trade output above 50hz with output below 20hz I wouldn't do it (haha, says the guy with an all sealed setup... ) Sometimes I think we overrate under 20 hz compared to the higher stuff.
carp is offline
post #35653 of 36568 Old 08-24-2016, 04:29 PM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
Well, to be perfectly honest, 2 already can destroy my room...and I keep them at 'conservative' levels compared to the hotter levels some run their subs...but I've considered adding 2 more shifters whenever they come up in the classifieds...more out of curiosity than necessity....but I think 4 would definitely do actual physical damage to my house and its contents at reference level. Now that I think about it...what kind of numbers could one hit with 4 shifters below 20hz...has anyone done the math?
asoofi1 is offline
post #35654 of 36568 Old 08-24-2016, 04:57 PM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
I can't argue with your logic, good sir...hence why I chose the OS...below 20hz never was a priority...I suffer from curiousititumupgradeitous disease...and thought, "oh, new toy that is good at two things" I really should run my shifters hotter than the already amazing setting XT32 has them at...pound the curiosity out of me. My motto about the shifters is still 'out of my cold dead hands'...I don't think I would let them go even if I tried something else.
carp likes this.
asoofi1 is offline
post #35655 of 36568 Old 08-24-2016, 05:52 PM
RMK!'s Avatar
Liked: 1468
Yeah, my only long term audio regret (many short term regrets ) was selling the OS's. There is something special about the sound and power of that sub. That said, I think the Cap-4000 is in the same class of subwoofer e.g. if you can fit it into your room, and afford it, you should probably do it.
Jeff Permanian and asoofi1 like this.
RMK! is offline
post #35656 of 36568 Old 08-24-2016, 10:29 PM
AlexBPM's Avatar
PM if interested.
RMK! I've been contemplating a trip to Sac...and you were definitely on my list or people to pester for a demo lol. Those 215's look studly in your theater room
AlexBPM is offline
post #35657 of 36568 Old 08-25-2016, 02:39 AM
coolgeek's Avatar
Quoted: 616 Post(s)
Liked: 278
I completely agree with this.. ALso, I think many rooms would have a gain in the lower bass regions... In fact, if I were to add another sub, I would definitely choose another OS... or, perhaps the OS Pro with an even bigger advantage in the chest pounding bass region?
coolgeek is offline
post #35658 of 36568 Old 08-25-2016, 02:56 AM
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
Yes.. RMK's HT with the 215's is perfectly setup right. The 215's really fills up the room nicely, punchy, and crisp. Oh, and it's on a suspended deck too.. And, the whole ATMOS experience, my first time listening ATMOS btw, just opened whole can of worms when I left his place. I knew then that ATMOS would be up on my list for upgrade. I don't need anymore stinking bass. It's starting to get much on a suspended deck. Actually it is . Too many things breaking too.. That's why I run just the 215's full range with subs off 85% of the time now. But even with those alone will pounder my room too. lol..
AlexBPM, RMK! and Jeff Permanian like this.
rhed is offline
post #35659 of 36568 Old 08-25-2016, 07:31 AM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
Rhed, I need to see a wide shot of your setup....with all of the speakers and subs in the pic. I lost count of everything you have...lol
asoofi1 is offline
post #35660 of 36568 Old 08-25-2016, 07:51 AM
raynist's Avatar
Quoted: 1263 Post(s)
Liked: 1198
As incredible as the number are for the 4000, the 215RT is pretty close from 20hz on up. I think I am most impressed with the numbers that puts up considering it isn't a dedicated sub.
RMK!, Jeff Permanian, rhed and 1 others like this.
raynist is offline
post #35661 of 36568 Old 08-25-2016, 08:17 AM
RMK!'s Avatar
Liked: 1468
You're welcome any time (I'm home ) and since HTPCat is only a couple of miles from me, I'm sure he would be happy to give you a Noesis 212HT/sub demo.
HTPCat likes this.
RMK! is offline
post #35662 of 36568 Old 08-25-2016, 08:30 AM
SOWK's Avatar
Quoted: 468 Post(s)
Liked: 360
Seems pretty weak sauce... Can't you make any better
Especially at 10Hz....
N8DOGG and Jeff Permanian like this.
SOWK is offline
post #35663 of 36568 Old 08-25-2016, 09:03 AM
desertdome's Avatar
Liked: 1223
Both are pretty awesome, but the Cap 4000ULF is a low frequency beast!
When integrating into a system, one needs to take the basic response into account. Look what happens when their responses are lined up at 80Hz. The Max Long Term Output is also an important metric.
Name:	4000ULF vs 215RT.png
ID:	1622369   Click image for larger version
Name:	4000ULF Max Long Term Output.PNG
High Impact AV
post #35664 of 36568 Old 08-25-2016, 09:41 AM
Quoted: 657 Post(s)
Liked: 1382
Don't forget that you personally have measured the Noesis 215RT in rooms, flat to 17-18hz.
post #35665 of 36568 Old 08-25-2016, 07:08 PM
carp's Avatar
Liked: 1752
Yep!! I said this exact same thing ^ in a group email today.
carp is offline
post #35666 of 36568 Old 08-25-2016, 07:52 PM
HTPCat's Avatar
Quoted: 495 Post(s)
Liked: 293
Yeah, just let us know when you are coming this way and we can give you various JTR listening experiences. Full range monsters 215RT or 212 (original 2014 version) with subs (Seaton master/slave in back and S1 in front). We both have Single 8s for surrounds
I still haven't installed my ceiling speakers (Thiel in ceiling) for Atmos/DTS-X/Auro, but Rob has very impressive Atmos setup.
AlexBPM likes this.
HTPCat
"I have a need to feed the hole with more Audio & Video toys"
HTPCat is offline
post #35667 of 36568 Old 08-25-2016, 09:44 PM
rjh65@verizon.ne's Avatar
Quoted: 221 Post(s)
Liked: 57
Hello Alex, you are welcome to come and listen to mine, may be a little bit however as my daughter is pregnant (she still lives at home) and is due any where's within the next week or so but after things settle a bit no problem.
rjh65@verizon.ne is offline
post #35668 of 36568 Old 08-25-2016, 10:20 PM
AlexBPM's Avatar
Wow congrats! Sounds like a very exciting time. I will absolutely take you up on that offer when things settle down. Love that drive up the coast!
AlexBPM is offline
post #35669 of 36568 Old 08-26-2016, 04:20 PM
carp's Avatar
Liked: 1752
Seriously. Look at this sh*t. The 215 is in light blue in all of these. From 20 hz and up (more like 17 hz actually) these are unreal. How many of you guys with 215 have been motivated to get a more powerful amp(s) for them since the measurements?
215 vs. Cap 1400
215 vs. Orbit Freaking Shifter:
215 vs. Cap 4000:
Just for fun, 215 vs well regarded sub the HSU VTF 15:
dwaleke, rhed and lukeamdman like this.
carp is offline
post #35670 of 36568 Old 08-26-2016, 07:45 PM
lukeamdman's Avatar
Quoted: 1080 Post(s)
Liked: 1200
215 vs. Cap 1400
215 vs. Cap 4000:
Here's a bassheads attempt to nudge a few 215RT owners into giving these speakers more wattage so they can really shine.
First off let me say that going into my amp testing of the NU4-6000 I wasn't expecting much but this amp pleasantly surprised me. It held really nice power all the way down to 5hz and took all the testing in stride. It never power cycled or muted, and also ran cool to the touch the whole time.
Second, the DB numbers lost going from a bridged K20 to an iNuke I'm showing below are conservative for several reasons, the most important being that the wattage numbers are only for a single channel driven. Once you're driving both channels into 4ohm loads on an inuke3k or two of four channels into 4ohm loads on an nu4-6000 the numbers only go down.
A doubling of wattage = 3db. A doubling of both the speaker and wattage = 6db. Going from (1) 215RT to (4) 215RT with 4 times the wattage = 12db.
That means from 50hz and up, if you're using a NU4-6000 not even (3) 215RT will match Ricci's K20 numbers for a single 215RT. At 100hz and 125hz, not even (4) 215RT will.
Food for thought
carp likes this.
lukeamdman is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
