Official JTR speaker thread - Page 1216 - AVS Forum | Home Theater Discussions And Reviews
 8362Likes
post #36451 of 37438 Old 01-09-2017, 06:12 AM
ahmedreda's Avatar
Quoted: 317 Post(s)
Liked: 253
That is a fairly large space. It will be difficult for you to realize single digit output which is the primary advantage of going sealed. Ported would work much better IMO so my recommendation would be dual 4000ULF.
Originally Posted by obleo View Post
Construction begins today for my new theater build. It will be a 29L x 18W x 10H dedicated 11.2 space above my garage. I'm planning to outfit with JTR 212 for L/C/R and S8's for surround duty (not sure yet on which I'll use for atmos).
Could I get some candid feedback on the sub front? I have ~$6K budgeted for subs, so here are my options...
1) I already have one Seaton SubM. For about $5,600 I can add 3 more, giving me 4 SubM's.
2) Dual JTR S2's for ~$6K
3) Dual JTR 4000's
My initial leaning is towards SubM simply because I already have one and won't have to deal with trying to sell it. Plus, I'm assuming that 4 SubM's would provider greater / cleaner output than dual JTR's.
Any thoughts?
My home theater
Speakers: 3 JTR 212HTR (LCR), 2 Jtr Single 8LP (S), 2 JTR Triple 12LF (SB)) , 4 Volt 10LX (Atmos)
Subwoofers: 10 Sealed UXL-18, 5 Crowson Shadow 8 transducers, 3 Buttkicker LFE
Display: JVC RS400
ahmedreda is online now
post #36452 of 37438 Old 01-09-2017, 06:19 AM
raynist's Avatar
Quoted: 1479 Post(s)
Liked: 1418
3) Dual JTR 4000's
Any thoughts?
If you have the room go dual 4000's and never look back.
Use the sub m in a different room or sell it.
I would have 4 4000's in my setup if they would fit.
RMK! likes this.
raynist is online now
post #36453 of 37438 Old 01-09-2017, 06:34 AM
rcohen's Avatar
Quoted: 1348 Post(s)
Liked: 578
3) Dual JTR 4000's
Any thoughts?
I like option #1 , if you can place 4 subs in corners.
4 subs in corners gives you great output and seat to seat consistency.
All of these options are top-notch subs.
I wouldn't lose sleep over matching brands with subs.
4x subMs match in the ways that matter.
If you wanted center wall placement due to room layout issues, then it would be a tougher decision which way to go.
The 212HTRs are amazing. You are in for a treat if you haven't heard them.
The S8s should be awesome as surrounds.
rcohen is online now
post #36454 of 37438 Old 01-09-2017, 07:16 AM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
3) Dual JTR 4000's
Any thoughts?
Everything else is good, but I would do dual 4000...you won't need anymore subs for sure.
RMK! likes this.
asoofi1 is offline
post #36455 of 37438 Old 01-09-2017, 07:37 AM
Quoted: 47 Post(s)
Liked: 7
Thanks for the replies everyone, greatly appreciate it. So, I'm guessing I can sell the SubM for $1K which would take the cost of dual 4000's to ~$5.4K. Since I already have one SubM, adding the additional 3 would be ~$5.6K. Whichever the solution, all subs will need to go behind the AT screen wall.
Since these have to be behind the AT wall and cost is a wash, it sounds like JTR 4000's are the way to go.
obleo is offline
post #36456 of 37438 Old 01-09-2017, 09:23 AM
RMK!'s Avatar
Quoted: 1683 Post(s)
Liked: 1607
Yep ...
Opinions are not facts.
RMK! is online now
post #36457 of 37438 Old 01-09-2017, 01:06 PM
appleseed's Avatar
Quoted: 37 Post(s)
Liked: 24
I ordered (2) 118's. Still need a T8 or T12 or.... to complete the surround set. In the interim, I have been thinking about the room treatments and whatnot. Regardless if I get any, it would seem I'd still benefit from some form of room eq. So I've been mulling options over.
Keep the 3313 and get a miniDSP.
Get a newer receiver or preamp with XT32
Get an Anthem of some iteration with their version of REQ.
Save my money and get an Arcam 550?...............<--edited to ad this.
IF.. it matters. I got a good deal on a Sherwood Newcastle A 965 that I can put to use. Otherwise if I just get a new receiver, I'll probably give it to my father.
Any thoughts on these options?
WTB JTR Speakers and etc.
Dogs love me cuz I'm crazy sniffable
appleseed is offline
post #36458 of 37438 Old 01-09-2017, 09:39 PM
rcohen's Avatar
Liked: 578
It's usually MUCH better to have subs on opposite sides of the room. If you have a closed rectangular room, you can use the REW room simulator to give a good guess of nulls and frequency response. The nulls are the main concern, since the rest can be corrected with EQ.
IMO, it would be worth revising the plans around good sub placement, but everyone has different priorities.
post #36459 of 37438 Old 01-09-2017, 09:49 PM
rcohen's Avatar
Liked: 578
I'm a big fan of Dirac. If you have a PC and a calibrated mic, you can test the PC version for free.
http://www.dirac.com/online-store
If you have external amplification the Arcam 390 looks like a good value for an Atmos receiver with Dirac.
Some people have been running into trouble with the new Arcams, though, so you might want to wait to see if they get fixed.
For non-Atmos, there is the XMC-1.
I am using JRiver + Dirac for PC, plus an older XT32 surround preamp. This is great sounding and cost effective for non-atoms, but there's no way to get Dirac for PC to work with Atmos. Also, this doesn't support Dirac for other sources.
Outside of Dirac, some sort of EQ for bass frequencies is a must for hifi sound, IMO.
XT32 can do a pretty good job. The biggest thing it lacks is the ability to dial in a custom frequency response curve for your room and taste.
Some people use pure JRiver, since it has extremely flexible DSP.
post #36460 of 37438 Old 01-10-2017, 08:32 AM
desertdome's Avatar
Quoted: 1221 Post(s)
Liked: 1366
In the past month I've heard dual 4000ULF's, dual Orbit Shifter LFU's, and dual S2's. These vary in size so placement options become a consideration. Since you have an 18' wide room, and the 212HTR is 16.5" wide, you can place 4000ULF's with their backs to the center 212HTR and the front of the sub will be at about the 1/4 point of the width of the room. Since they fit, go for the 4000ULF's!
You are really going to like the 212HTR's and S8's. Should be an incredible theater!
High Impact AV
desertdome is online now
post #36461 of 37438 Old 01-10-2017, 09:33 AM
appleseed's Avatar
Quoted: 37 Post(s)
Liked: 24
Thank you. On the PC side of things. My local walmart had an ASUS T100TA-C2-GR that I picked up to resell, but maybe it'd be worth it to keep for this purpose?
https://www.asus.com/us/2-in-1-PCs/A...pecifications/
Atmos seems like it'd be great but I'm going to wait on that for now I think. Not sure how best to implement it in my room anyway.
In my want ad, I have a couple of miniDSP options I'm asking for. I will add a receiver with XT32 as an option also.
post #36462 of 37438 Old 01-10-2017, 09:40 AM
Point Source
beastaudio's Avatar
Quoted: 3793 Post(s)
Liked: 3090
In the event you didn't already know, the new audyssey app will allow for target curve manipulation, as well as limiting of correction similar to dirac. The app has not been released yet but I am waiting VERY impatiently to test it out when it does release later this month or next.... It will be available for late 2016 and on models of D&M. No update planned for earlier models that can still use audyssey pro.
beastaudio is online now
post #36463 of 37438 Old 01-10-2017, 11:55 AM
rcohen's Avatar
Liked: 578
Sounds promising. Took them long enough!
Where can I find more info?
post #36464 of 37438 Old 01-10-2017, 12:03 PM
rcohen's Avatar
Liked: 578
You can use pretty much any TV with JRiver. They also have a free trial. For something near your PC, the main concern is that you get something quiet.
My main HTPC is running JRiver and Plex server (free version), and I have Rokus in the rest of the house. I finally cancelled traditional cable for Playstation Vue via Roku. For the HTPC, I have a Thecus N5550 in my closet via iSCSI, which the HTPC boots of an SSD.
post #36465 of 37438 Old 01-10-2017, 12:18 PM
RMK!'s Avatar
Liked: 1607
Tarot cards?
beastaudio likes this.
RMK! is online now
post #36466 of 37438 Old 01-10-2017, 01:13 PM
Point Source
beastaudio's Avatar
Liked: 3090
That's all that we know basically atm. It will be $20 in de app stoah ("the app store" in ahnold.)
jlpowell84 likes this.
post #36467 of 37438 Old 01-10-2017, 05:47 PM
Quoted: 47 Post(s)
Liked: 7
Thanks for the feedback. Subs in the corners is a possibility, but would take a hit in the WAF. For about the same $$ I can do dual JTR 4000's up front or 4 SubM's in each of the corners. Would one really be that much of an improvement over the other? If not, I lean towards the simplicity and WAF of the JTR. But, if it would make a big improvement, I can do SubM's in the 4 corners.
obleo is offline
post #36468 of 37438 Old 01-10-2017, 06:02 PM
rcohen's Avatar
Liked: 578
It's different in every room, but yes, this difference can be huge, depending on the room.
If you have a closed rectangular room, the free REW room simulator can give a pretty accurate estimate for sub layouts and counts. The main concerns are minimizing nulls and maximizing output, since peaks can be EQed out. Make sure to turn on time alignment. This doesn't require a microphone to use the simulator. It's actually fun...try this right now!
https://www.roomeqwizard.com/
The trouble with all the subs on one side of a closed room is that you usually end up with bad nulls. You want a sub on the opposite side to cancel out the nulls. There's a lot you can read on sub placement, but here are some to try in the simulator (in no particular order):
1) Nearfield can work great when the room can accommodate it. This is an exception, where the sub is close enough for the direct sound to overpower the reflections.
2) 2 subs on the center of the opposing walls (preferably opposite the room's longer axis).
3) 2 subs on opposite corners.
4) 4 subs in 4 corners.
5) 4 subs at 1/4 3/4 positions on opposite walls (preferably opposite the room's longer axis).
Paper on placing multiple subs:
https://www.harman.com/sites/default...s/multsubs.pdf
post #36469 of 37438 Old 01-11-2017, 01:11 PM
DRC3's Avatar
Quoted: 90 Post(s)
Liked: 112
Got to visit JTR's Production Facility
Had business up in Milwaukee and dropped by to see Jeff's new digs.
I was with a couple of coworkers, but Jeff was kind enough to show us around and briefly test drove the dual Cap 4000 ULF's. He decided to play Bass I Love You and everything on the floor within 20 was literally blown away from the air movement. Just an amazing amount of output. The entire building was shaking and this is a big warehouse, LOL. He must have very understanding neighbors.
Jordan and Michael, my colleagues, not being familiar with anything but Sonos or HTIB stuff were stunned. They couldn't stop talking about the intensity. Definitely a fun time.
Thanks Jeff!
carp, desertdome, dlbeck and 4 others like this.
DRC3 is offline
post #36470 of 37438 Old 01-11-2017, 01:16 PM
Mike_WI's Avatar
Quoted: 174 Post(s)
Liked: 118
Thanks Jeff!
I used to work in Racine, WI.
I wish I knew about them then.
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & output x1 cards} - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520]
HT Details: link
Mike_WI is online now
post #36471 of 37438 Old 01-11-2017, 02:10 PM
bambam's Avatar
Quoted: 99 Post(s)
Liked: 80
Thanks Jeff!
Very cool. I hope to do the same in the near future. Did you just align the tour with Jeff prior to your arrival?
bambam is offline
post #36472 of 37438 Old 01-11-2017, 03:02 PM
DRC3's Avatar
Quoted: 90 Post(s)
Liked: 112
Yeah- I called a couple of days in advance and asked to drop by...Next time, a movie in the front office/theater would be in order.
Jeff Permanian likes this.
DRC3 is offline
post #36473 of 37438 Old 01-15-2017, 09:40 AM
appleseed's Avatar
Quoted: 37 Post(s)
Liked: 24
I have a strange curiosity that someone may be able to explain to me. Up until recently I've only been using a 3313CI receiver to power my speakers. With the Deftech's I had, in direct mode, they sounded ok. But with audyssey it was better. After getting the T12's, in direct mode they sound very good. I have not re-run the audyssey settings so its still set to the Deftech's. Just for curiosities sake I tried it with the T12's and even though it seemed like the stereo imaging was wider it was not to my liking as far as sound. To be expected I suppose. So, I've just been using direct for now thinking that I have no reason to use audyssey until I finish getting the rest of the surround system together, since it sounds so good already. Don't mess with a good thing right? However, now I have a separate amp and things have changed. Using the Denon as a preamp and a Sherwood Newcastle A-965 for the amp, I've notice the sound is not the same. Not bad, just not the same. Again in direct mode, the sound is now no longer as pleasing to listen to. It's hard to explain since I do not know what terminology I should use to convey to someone what I'm experiencing. I'll do my best. The imaging now seems off, not as expansive, like someone just stood in front of the speakers. Stereo to Mono is what it also reminds me of but still have stereo separation. Now what really seems weird is if I go back to the audyssey setting meant for the Deftech's things get much much better. In fact, so much improved that its better than it was in direct without the amp. This setting was un-listenable straight from the receiver but now its enjoyable with the amp? I'm not understanding why there is such a difference to be honest. I got the amp thinking I would benefit from a dedicated power amp and possibly have more control and better dynamics in movies and music. Also would be necessary if I wanted to add a miniDSP 88 in the future. I honestly did not expect the sound to change much if at all. But I was wrong. Could someone be so kind as to explain what is the reason for this. In layman's terms. lol
Recap.....
A) receiver in direct mode with T12's = great.
B) receiver with audyssey for Deftech's but with T12's instead = not good. Obviously.
C) receiver in direct mode but with separate amp and T12's = not terrible, just not as good as (A)
D) receiver with audyssey for Deftech's but with separate amp and T12's = sounds great, actually better than (A)
BTW still looking for a T8 WTB JTR Speakers and etc.
post #36474 of 37438 Old 01-15-2017, 10:01 AM
RMK!'s Avatar
Liked: 1607
Recap.....
You need to re-run Audyssey with the T12's. Then try direct mode vs Audyssey. Many of us who use Audyssey have run it many times with different results being the norm rather than the exception. It only takes a few minutes and practice makes it easier (if not perfect).
RMK! is online now
post #36475 of 37438 Old 01-15-2017, 10:09 AM
appleseed's Avatar
Quoted: 37 Post(s)
Liked: 24
I'm going to definitely, but why such a difference in direct mode with receiver + T12 ...VS...receiver + amp + T12? Just curious why it sounds better without the amp in the chain.
post #36476 of 37438 Old 01-15-2017, 10:59 AM
RMK!'s Avatar
Liked: 1607
It shouldn't sound different unless the amp or connection cables are are introducing distortion noise. If anything, the amp should add head room but with the T12's very high efficiency, they should be plenty loud with the AVR.
RMK! is online now
post #36477 of 37438 Old 01-15-2017, 11:45 AM
appleseed's Avatar
Quoted: 37 Post(s)
Liked: 24
I guess that's why it's intriguing me. I did not expect there to be a difference, better or worse, just more head room as you put it. The cables I'm using are older but a short run of only 3ft so I wouldn't think that'd make much of an impact, but I may try different cables if I can find some somewhere.
post #36478 of 37438 Old 01-15-2017, 01:41 PM
rcohen's Avatar
Liked: 578
Recap.....
It's really easy to end up chasing your tail if you aren't using measurements to help make these types of comparisons.
If you don't already have it, pick up a $20 boom mic stand and a calibrated mic, like a UMIK-1, and take some measurements with REW.
As was said, with Audyssey, it's important to remeasure with any equipment or layout change.
Also, make sure you have silence during the measurements (air conditioning, pool equipment, etc.)
Once you have REW figured out, you can take a measurement in under a minute.
It's much faster than doing an Audyssey calibration.
post #36479 of 37438 Old 01-15-2017, 02:52 PM
Gooddoc's Avatar
Quoted: 2920 Post(s)
Liked: 2038
Just wandered in here, but sounds to me like a phase problem. Check all of your wiring and double check the amp is not doing a phase inversion on one of the channels. Or, just switch + and - on one of the speakers and see if that fixes it.
Gooddoc is online now
post #36480 of 37438 Old 01-15-2017, 06:49 PM
appleseed's Avatar
Quoted: 37 Post(s)
Liked: 24
I switched out the RCA's with the only ones I have around. No change that I can discern. Did a polarity check and everything is as it should be and also switched them to double check. The only difference I can hear is changing from receiver amp to outboard amp. Also noticed while being closer to the speakers that the amp has a low hiss even with no RCA's plugged in. Whereas connected to the receiver it's dead silent. It's very low and can't hear it from normal listening distance so I'm not worried about it. What I am worried about is that the receiver seems to get hotter even though the onboard amps are not being used and it's not sitting on top of the outboard amp. One curiosity after another. lol
How do you add links in your sig like I see with most? I would like this link to show up without me having to drag and drop.
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
