Official JTR speaker thread - Page 1225 - AVS Forum | Home Theater Discussions And Reviews
 8691Likes
post #36721 of 37926 Old 02-28-2017, 04:45 PM
farsider3000's Avatar
Quoted: 364 Post(s)
Liked: 140
Just ordered a Captivator S1 from Jeff for the center rear of my theater to compliment the Captivator S2 up front in the center of my baffle wall. The S1 will replace dual JL Audio F112 that were previously in the rear of the room.
I also have a Seaton Submersive on each side wall and wonder if replacing them with S1's would add any real benefit. I feel like I am chasing the last 1% of performance by replacing the Seaton's with S1s.
Datasat LS10__ Parasound Halo A31 , Parasound Zonemaster 1250, Parasound Zonemaster 450
Procella P8 LCR, Procella P5iw and P5v for surround & ceiling
JTR Captivator S2 dual 18", JTR Captivator S1 single 18", Dual Seaton Submersives with dual 15"
2.40:1 Seymour XD Acoustically Transparent (AT) screen, 128" diagonal / 118" wide __ Projector: JVC 4910
farsider3000 is offline
post #36722 of 37926 Old 02-28-2017, 05:09 PM
raynist's Avatar
Quoted: 1574 Post(s)
Liked: 1550
Originally Posted by jlpowell84 View Post
For those routing the LFE Channel to the 215's what gear are using. And if you are not why not?
MiniDSP Nano AVR when I decide to run full range in 7.1. Usually for movies I cross them over to 4 S2 subs
HTPCat likes this.
raynist is offline
post #36723 of 37926 Old 02-28-2017, 05:11 PM
raynist's Avatar
Liked: 1550
I am running the 215RT LCR's full range with no subs. My processor (Marantz 7702) allows the LCR's to be set as full range hence they get the LFE channel info. I originally did route the LFE to the LCR's via a Rane RPM 88. This allowed me to do the channel mixing and, place a 15hz HP filter on them as well. The Rane was noisy (fans always on) and I prefer fewer A/D conversions and connections so the current setup is direct per/pro to amp and no HP filters. Sans an HP filter I should be more cautious how hard I drive them ... but I'm not ...
lucky you! I can set my LCR to large in my Onkyo SC5509 but it does not send the LFE signal to the center channel unfortunately. This is why I have to use the Minidsp NanoAVR but it also has the benefit of being able to EQ as I wish.
RMK! likes this.
raynist is offline
post #36724 of 37926 Old 02-28-2017, 05:46 PM
RMK!'s Avatar
Quoted: 1698 Post(s)
Liked: 1630
Yeah, that's what I should do but I'm too lazy to tackle another even simple products learning curve. I keep thinking the ideal affordable 13 channel SSP or AVR with Dirac will come along and save the day.
Anxiety is contagious, please keep yours to yourself.
RMK! is offline
post #36725 of 37926 Old 02-28-2017, 05:50 PM
countryWV's Avatar
Quoted: 413 Post(s)
Liked: 593
Originally Posted by Jeff Permanian View Post
New Product idea. So, I've been working on a dual 12" professional subwoofer tuned to 38hz and realized these would work in a larger, lower tuned Noesis 212 and could make "tower" versions. Same specs as the Noesis 212HT and 212HTR but extend down to 38hz and would be called the Noesis 212T (tower) and Noesis 212RT (reference tower). The larger cabinet and high excursion drivers would add $300. I'm looking to see if there is any interest.
It may be to soon to ask but
How will these blend with the current 212HTR? A pair of the RT as L&R and use the 3 HTR as center and side surrounds in a 5.1.4 system.
Chris
countryWV is online now
post #36726 of 37926 Old 02-28-2017, 06:17 PM
jlpowell84's Avatar
Quoted: 1941 Post(s)
Liked: 915
I am running the 215RT LCR's full range with no subs. My processor (Marantz 7702) allows the LCR's to be set as full range hence they get the LFE channel info. I originally did route the LFE to the LCR's via a Rane RPM 88. This allowed me to do the channel mixing and, place a 15hz HP filter on them as well. The Rane was noisy (fans always on) and I prefer fewer A/D conversions and connections so the current setup is direct pre/pro to amp and no HP filters.
Ok so thats 7702 dependent. Is this a newer feature some pre's are coming out with? I honestly have not paid attention to the last couple years of options
Well quad S2 is just silly man! I was thinking more along the lines RMK uses them as subs essentially, six 15's across his front wall. Also having the top three up in the air to benefit for additional smoothing.
I mean LCR 215's with lets say 2-4 smoothing subs (18's) should add a pretty stellar visceral bass experience from 15-17hz on up.
And you get no noise from the mini dsp unit? I know several 4722 owners recently have had issues with them, quality control problems and noise. Of course 104db vs 95db sensitive...
JLPowell84's Room
FTW21 Ported Build
Spoiler!
jlpowell84 is offline
post #36727 of 37926 Old 02-28-2017, 06:27 PM
raynist's Avatar
Liked: 1550
No noise at all. I also have one in a different system with 212HT(R)'s. The NanoAVR accepts a PCM signal over hdmi and you tweak that signal in the digital domain. No additional D/A conversion. I primarily use it for a HPF on my 215RT's. Downside for some would be it doesn't work with atmos but I don't have that and don't plan on adding it any time sooon.
raynist is offline
post #36728 of 37926 Old 02-28-2017, 06:29 PM
HTPCat's Avatar
Quoted: 724 Post(s)
Liked: 448
I have seaton master/slave up front and s1 in back. I sometimes want to add something and i think about changing out the seatons for s1s, but then I listen and think why.....i would like to eventually add another s1 to back to balance it out.
HTPCat
"I have a need to feed the hole with more Audio & Video toys"
HTPCat is online now
post #36729 of 37926 Old 02-28-2017, 06:30 PM
raynist's Avatar
Liked: 1550
The 215's themselves don't need subs. I can tune in all of the bass boost I could ever want. I sit about 15-16 feet from them and to really get the couch rocking I need to play them really loud. 2 S2's placed nearfield give me all the tactile feedback I could want (and I have 2 more up front for good measure).
raynist is offline
post #36730 of 37926 Old 02-28-2017, 06:34 PM
jlpowell84's Avatar
Liked: 915
^That's overkill "good measure" but in a good way
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #36731 of 37926 Old 02-28-2017, 06:40 PM
Nabs17's Avatar
Quoted: 918 Post(s)
Liked: 513
2 S2's nearfield....OMG!!!!
Does that ever feel overwhelming?
Nabs17
Nabs17 is offline
post #36732 of 37926 Old 02-28-2017, 06:53 PM
raynist's Avatar
Liked: 1550
Yes - during hacksaw ridge in particular. I also have 4 midbass modules on top of the S2's.
raynist is offline
post #36733 of 37926 Old 02-28-2017, 06:56 PM
raynist's Avatar
Liked: 1550
Did you see my comment about using the NanoAVR which is Hdmi only? I also use one on my system with 3 212HTR's and zero noise. I think the one you are talking about is the 88A like @carp had. I think he had noise problems. No issue with these units but they also don't work with atmos, 7.1 PCM only.
raynist is offline
post #36734 of 37926 Old 02-28-2017, 07:10 PM
Nabs17's Avatar
Quoted: 918 Post(s)
Liked: 513
I have dual 88a's and I don't have any noise problems.
Nabs17
Nabs17 is offline
post #36735 of 37926 Old 02-28-2017, 07:11 PM
Nabs17's Avatar
Quoted: 918 Post(s)
Liked: 513
I've heard nothing but good things (sonically) about Hacksaw Ridge and I can't wait to watch it.
Nabs17
Nabs17 is offline
post #36736 of 37926 Old 02-28-2017, 07:13 PM
raynist's Avatar
Liked: 1550
Which speakers are you using with them?
raynist is offline
post #36737 of 37926 Old 02-28-2017, 07:18 PM
Nabs17's Avatar
Quoted: 918 Post(s)
Liked: 513
Same as you my friend, except I have a 215RM for center.
Nabs17
Nabs17 is offline
post #36738 of 37926 Old 02-28-2017, 07:24 PM
raynist's Avatar
Liked: 1550
I knew that LOL, sorry!
I think Carp had noise problems with his 88A and the JBL4722, but they are 9db more sensitive than the 215's and would magnify any noise.
Nabs17 likes this.
raynist is offline
post #36739 of 37926 Old 02-28-2017, 08:25 PM
rjh65@verizon.ne's Avatar
Quoted: 229 Post(s)
Liked: 62
This is VERY interesting Jeff, I mentioned this in another forum the other day thinking it was this forum and didn't realize it until after I posted it but as I stated in the other forum if these would have been available before my 215RT/215RM/210RT purchase this is the route I would have chosen with not even a second guess as i have and was hoping for quite some time before my purchase that you would have had this exact speaker option available as, for me this intermediate size between the 210RT and 215RT would have fit my HT room perfectly and obviously the performance would and will be there if you make these and for a measly $300 up charge that is a steal! I would have taken the money savings over my 215RT's and purchased another sub from you in addition as i am having 4000ULF lust even though I own an OS!
obleo likes this.
rjh65@verizon.ne is offline
post #36740 of 37926 Old 03-01-2017, 12:00 AM
jlpowell84's Avatar
Liked: 915
You need help
Yes, I am familiar with the HDMI based nano AVR. I like not adding an extra DA conversion.
Watched Hacksaw ridge tonight on the 4722's and 17cu ft ported FTW 21's (15.7 hz port tune) and dang it was intense. The newer Dolby thing before the movie was sweet too, seriously amazing actually. But I have a sudden desire to experience a 215RT . Crossover points are 350hz and what else? It's a 3-way right unless I'm blanking. Also what is the CD height?
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #36741 of 37926 Old 03-01-2017, 08:59 AM
beastaudio's Avatar
Quoted: 4152 Post(s)
Liked: 3514
Originally Posted by d_c View Post
No problem! I hope you like them as much as I do. I would imagine the 15 in your tempest would give the 210 a run for the money, but everything else would be no contest. I'm test driving Carp's Crown xti4002 so I can use the 30hz hpf in its dsp to protect the drivers. I will also try crossing a sealed hs24 for 34hz down. This combo I think will be my huckleberry.
But then what would you do with those sweet Ghorns? Basement duty?
Perhaps a few of those arcam units will show up used soon enough, the avr's should be at a decent price.
beastaudio is online now
post #36742 of 37926 Old 03-01-2017, 11:16 AM
RMK!'s Avatar
Liked: 1630
Yeah, with my full range LCR's and no separate subs, I may be one of the few who could use the units as is with the BM issues. Does give me pause though and I wonder if the amp channels are assignable since I would not be powering the LCR's with the AVR but would like to use the AVR for the 4 surround and 4 Atmos channels.
rcohen and beastaudio like this.
RMK! is offline
post #36743 of 37926 Old 03-01-2017, 12:08 PM
d_c
d_c's Avatar
Quoted: 900 Post(s)
Liked: 1044
The 210s are going downstairs in the ht for 2ch, or 2.1 with the nearfield hs24. Movies will have 11 Radian 5210, pair of Othorns, and hs24.
I've been watching the Arcam thread and their Dirac issue. Looks like they are getting closer to sorting it out with the firmware update on Monday.
d_c is offline
post #36744 of 37926 Old 03-01-2017, 12:18 PM
beastaudio's Avatar
Liked: 3514
Duh, I knew that....
post #36745 of 37926 Old 03-01-2017, 11:14 PM
jlpowell84's Avatar
Liked: 915
So how can one tell if an AVR/Pre is capable of routing LFE to mains? This a new 2016+ feature on select few?
And what do you all think of the Crown DSi 1000 Amplifer for the 215RT? 1400 watts rated @4ohm s, Harman's DSP is decent for EQ manipulation, HP filter available of course...
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #36746 of 37926 Old 03-02-2017, 01:06 AM
bscool's Avatar
Quoted: 752 Post(s)
Liked: 587
I think they pretty much all let you run "double bass", LFE+Main or whatever they call it. I knew Jeff planted a seed the other day with his male voices being low comment huh
What AVR do you have?
HTPC, Sony 40es, 120" Silver Ticket, 7702mkii, Sunfire Amp 225w, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is offline
post #36747 of 37926 Old 03-02-2017, 06:44 AM
rcohen's Avatar
Quoted: 1401 Post(s)
Liked: 630
I've never seen one that couldn't do this, although they use varying terminology. I wouldn't be surprised if it's part of the spec.
rcohen is offline
post #36748 of 37926 Old 03-02-2017, 06:55 AM
HTPCat's Avatar
Quoted: 724 Post(s)
Liked: 448
Not assignable. You can use 4 internal amps to run surrounds, but would need external amps for atmos speakers.
HTPCat
post #36749 of 37926 Old 03-02-2017, 07:16 AM
RMK!'s Avatar
Liked: 1630
Thanks for the confirmation Scott. I downloaded the Arcam manual thought that was the case. To bad really as with all the new immersive formats, and additional channels, the HT AVR manufacturers need to allow for amp channel assignment. Looks like a pre/pro is the only option for me.
RMK! is offline
post #36750 of 37926 Old 03-02-2017, 07:20 AM
desertdome's Avatar
Quoted: 1334 Post(s)
Liked: 1524
On any receiver/processor I've tested, the only way to route LFE to the mains is to set the subwoofer to off. You can't use the subwoofer output if you want to route the LFE to the mains. When the sub is set to off, the LFE is routed to either LR or LCR.
The LFE+MAIN is always a subwoofer setting, not a speaker setting. It determines what is sent to the subwoofer. If on, it routes low frequencies from speakers to sub even if the speaker is set to large. Onkyo has called it "Double Bass" and Yamaha has called it "Both." Yamaha no longer includes it as an option. When subwoofer output is set to None on a Yamaha, the LFE and bass from surrounds is routed to the LCR.
Marantz's answer to What is “LFE” and what is the difference between “LFE” and "LFE+MAIN?” has been up for 9 years now.
HTPCat and jlpowell84 like this.
High Impact AV
desertdome is online now
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
