Official JTR speaker thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 7802Likes
Old 12-06-2009, 07:34 PM
Kemet's Avatar
I will be powering the Q8 with the Emotiva XP-5 amp which does for 0.9Vrms at 300W @ 4Ohm below 0.1% THD.
At 9 ft listening distance that puts the volume at 114-117db from just 1 speaker, this assuming minimal compression effects from the speaker driver.
I am going to be deaf
Or do I need to get a pro amp to get another 3-6db @ 600-1200W??
Kemet is offline
Old 12-06-2009, 09:42 PM
steve morgan's Avatar
Quoted: 27 Post(s)
hahaha i love deaf people
oooh never thought of spades ummm not sure the post is huge i think it would take 6 gauge wire so the spade would have to be very wide . you could always try and put the spade inside the hole ? or part of it .
steve morgan is offline
Old 12-06-2009, 10:20 PM
allanf714's Avatar
Has anyone used one of Jeff's triples with one of the B&O ICE module based amps? They put out a pretty incredible amount of power into 4 Ohms.
You could almost give them close to recommended power for (dare I say--almost reasonable) $.
Allan
allanf714 is offline
Old 12-06-2009, 10:35 PM
Mathelo's Avatar
Allan
I'll be using mine with the Wired 4 Sound 5 channel. 1,000 watts into 4 ohms.
Mathelo is offline
Old 12-07-2009, 01:36 AM
Kemet's Avatar
Jeff,
Hope you have time to answer a few questions:
With the crossover design for the flushed cabinet what are the crossover frequencies for the T8 & Q8?
With the 4 8" woofers in the Q8 does the impedence curve challenge amps more than the T8 with dips below 4 Ohms?
Kemet is offline
Old 12-07-2009, 09:53 AM
Jeff Permanian's Avatar
Quoted: 664 Post(s)
Liked: 1401
Originally Posted by Kemet View Post
Jeff,
Crossover points for all the 2010 T8 and Q8 have been 500hz and 1600hz.
The Q8 is actually a little easier to drive because of the woofers being in series, parallel configuration.
Jeff Permanian is online now
Old 12-07-2009, 09:55 AM
goonstopher's Avatar
Quoted: 302 Post(s)
Liked: 60
My simple old onkyo 805 seems to be driving them fine...
goonstopher is online now
Old 12-07-2009, 12:41 PM
RMK!'s Avatar
Quoted: 1606 Post(s)
Liked: 1487
These speakers are capable of some huge SPL even in the largest rooms. Playing them too loud in a small room will sound bad. Regardless of the space, playing them @ high SPL with insufficent power will lead to amp clipping and related distortion.
As with most things, finding the correct balance is the key. If you have a big room and like to listen at concert or movie reference levels, then you will need a adequate power.
If you like more moderate volume and have a smaller space, most any AVR will do but you will not be taking advantage of what the JTR's do best.
Opinions are not facts.
RMK! is online now
Old 12-07-2009, 02:34 PM
radman12's Avatar
Liked: 27
what do you guys set your jtrs at in your avr. do you run them as large or small? and crossed at what frequency
radman12 is offline
Old 12-07-2009, 02:55 PM
orcarola25's Avatar
Kind of a stupid question? If your amp doesn't have a peak meter on it how could you test it for clipping?
orcarola25 is offline
Old 12-07-2009, 02:57 PM
RMK!'s Avatar
Liked: 1487
Triple 12HT LCR's, small with a 60hz xover.
RMK! is online now
Old 12-07-2009, 03:04 PM
Quoted: 664 Post(s)
Liked: 1401
and to small at 80hz with Triple 8HT's
Old 12-07-2009, 04:23 PM
fatsow's Avatar
Quoted: 121 Post(s)
Liked: 54
Just ordered two Quins and a triple 8. Can't wait.
Thanks Jeff
fatsow is offline
Old 12-07-2009, 05:50 PM
Jedirun's Avatar
Liked: 49
2010 Triple 8's crossed over at 80 hz. Audyssey always picks between 70 and 80 hz and I move it up to 80.
Jedirun is offline
Old 12-07-2009, 05:56 PM
Mathelo's Avatar
Does having / or not having a sub change this? i know they really need a sub but if you don't have that yet ...
Louis
Mathelo is offline
Old 12-07-2009, 05:57 PM
pinktri's Avatar
Thanks Jeff
Congrats! You're gonna love em!
PRO-60X5FD
PRO-70X5FD
pinktri is offline
Old 12-07-2009, 06:08 PM
Jedirun's Avatar
Liked: 49
Louis
I do not know if it is possible to hurt them, by running them large, but one of the trade offs that Jeff made in order to make them more efficient was to limit the low end extension since that is handled better by a subwoofer.
I am sure they will still sound great without a sub, but I do not think they will remotely make up for it.
Jedirun is offline
Quoted: 302 Post(s)
Liked: 60
Louis
I am in the opposite, quints with a huge sub and as-eq1 with a second sub to come soon - I think I may cross the quints higher than recommended but thats the opposite situation.... Maybe someone could cover both of our questions
Old 12-07-2009, 06:59 PM
Mathelo's Avatar
I'm not really expecting them to and will get sub (s) sooner rather than later but I won't have one at the very beginning. So, just wondering in that situation if running large would make more sense.
Louis
Mathelo is offline
Old 12-07-2009, 08:00 PM
Quoted: 302 Post(s)
Liked: 60
My worry would be that below the tuning frequency they may be over driven and also it may lead the amps to clip as they ask for more power.
I'm no expert though
Old 12-08-2009, 07:57 AM
RMK!'s Avatar
Liked: 1487
Louis
All JTR speakers were designed to be used with a subwoofer for HT. You will not get much output below the listed frequency range but they are about as bullet proof as speakers get so it won't hurt them to try.
I have run my 12HT's full range for music with good results. But for HT, get a sub(s).
RMK! is online now
Old 12-08-2009, 03:04 PM
Decadent_Spectre's Avatar
Quoted: 330 Post(s)
Liked: 145
Jeff could you please post a short comparison of the old T12,Q8 and the new T12 in terms of SPL/mid-bass/SQ? Particularly in relation to music?
Decadent_Spectre is offline
Old 12-08-2009, 04:35 PM
Mathelo's Avatar
Yea ... just have to decide.
Mathelo is offline
Old 12-08-2009, 04:52 PM
MovieMike's Avatar
Since the Slanted 8s are similar to Seaton's Sparks (8" coaxial), could those of you with the Slanteds tell me if 5 would work in an economical set up?
MovieMike is offline
Old 12-08-2009, 07:38 PM
bioforce's Avatar
While I haven't had anyone do it yet, nor have I seen anyone post they have, there is no reason it couldn't be done if:
1) You mount the speakers to account for the firing angle
2) You have a PREPRO or AVR that allows 100hz crossover settings
3) You have a sub or subs that play accurately up to and a little past 100hz.
Granted, they won't be as good as T8s and up, but they will blow a lot of other systems out of the water.
John
CENTURY CITY AV
bioforce is offline
Old 12-09-2009, 03:24 AM
Mathelo's Avatar
What is the appropriate 'firing angle' for surrounds?
Louis
Mathelo is offline
Old 12-09-2009, 04:15 PM
MovieMike's Avatar
Thanks bioforce. I was thinking the same; the S8s (in a 5.1 config) should best a lot of other other run-of-the-mill set ups
Old 12-09-2009, 05:57 PM
Kemet's Avatar
Thank you for the clarification, so in the T8 the woofers are in parallel only then?
I will have the Q8 center on a stand horizontally, all listening postions should be within 25 degrees off-axis of the center.
Any concerns of noteable lobing from around the crossover frequency of 500hz?
Kemet is offline
Old 12-09-2009, 10:21 PM
Quoted: 664 Post(s)
Liked: 1401
Nope, the woofers have some directivity in the long dimenson but no lopes and plenty of dispersion.
Old 12-09-2009, 10:51 PM
Quoted: 302 Post(s)
Liked: 60
Hey Jeff,
Besides headroom what can I gain from more power?
Do you think that sitting 6-8 feet back that 150-200w is enough for the q8's
I am so happy with what I have that I am finally looking at amplification but have no money anyway so want to speculate about what I am/am not missing.
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
