Official JTR speaker thread - Page 481 - AVS Forum | Home Theater Discussions And Reviews
 7784Likes
post #14401 of 36575 Old 01-06-2014, 10:29 AM
Gunner969's Avatar
Originally Posted by RMK! View Post
More often than not, Ausyssey (XT32) sets my Slanted 8 Height and Surround Back speakers to 50hz. I'm sure this is due to boundary effect as they are fairly close to 2 boundaries (ceiling/wall). I changed them to 100hz as that is their "normal" xover range and it's pointless to push them beyond that. I think the best choices for wides with JTR mains would be Single 8's, Triple 8HT-LP's or even better, the Noesis 228's but they require more room width to function properly.
How you are making wide speakers work in a 13' wide room is a mystery to me unless you have a single seat theater and/or sit very close to the LCR's.
I'll try the S8s when I get them and go from there. For once, I will show patience and experiment before doing something. smile.gif
As for the room layout, I've attached a pic to show the current configuration. I read somewhere on Audyssey's web page that if the room cannot do perfect 30 and 60 degrees, to double the angle of the fronts when placing the wides. So I ended up with the existing config: 23 degree fronts and 46 degree wides. I have to say that it works out pretty well - that Kris guy on audyssey does say that the point of the front wides is to really help when the LCR placement is narrow. I seem to be agreeing with that comment.
I totally agree with subyguy that it's like a wall of sound coming at you. My wife was convinced to go with wides literally after a 2 second AB comparison.
I do have another question: we decided to have two rows of seating. So, I'm thinking instead of doing rears, going with two sets of side surrounds. I'm thinking that putting the rears behind the back row, but optimizing them for listening in the first row will make them too loud for the back row viewers. Any thoughts from anyone?
Gunner969 is offline
post #14402 of 36575 Old 01-06-2014, 10:31 AM
Gunner969's Avatar
BTW, that big pink thing in the middle of my pic is the projector - not my big fat head. smile.gif
post #14403 of 36575 Old 01-06-2014, 10:36 AM
Gunner969's Avatar
Originally Posted by subyguy View Post
I run crown xls 1500's all around (was running one bridges on each of my T12's then switched to stereo when I added more surrounds) and love them. They are silent and have RCA inputs. I have added relays in them all so they turn on with my 4311. My room maybe isn't typical as it is basically the entire basement and is almost. 15,000ft3. When I'm lifting weights in the back I'm about 50ft from the speakers and like it loud so I'm using at least some of that power that's on tap.
What relay are you using? I'm thinking of adding a relay box for the S2.
post #14404 of 36575 Old 01-06-2014, 11:43 AM
jlpowell84's Avatar
Quoted: 1614 Post(s)
Liked: 712
Would anyone be interested in a pair of Triple 8's? 2008 model I drove a state away to pick up. Then shipped them to Jeff in Wisconsin to do driver/crossover upgrades as well as repair a couple of the female mounting nuts he uses for his drivers. He is installing and running full testing on them. They have the JTR logo engraved in the back and have speakon connectors. Basically brand new Triple 8's from the masters hands smile.gif I am not quite absolute 100% set on selling them. Just curious if someone would be interested smile.gif
jlpowell84 is online now
post #14405 of 36575 Old 01-06-2014, 12:05 PM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
Good point but which one and where its located makes the difference. When I had the amp out of my right (they are both up front corner loaded) OS the left one seemed to sound just about the same as two of them together. When I tried using a single OS in the middle under my center channel Noesis, the bass was essentially gone from my entire front row. With subs it is location, location, location. Having multiples helps mitigate many issues.
Re the best sounding, Jeff has stated several times that the OS is his favorite. You'll have to ask him what that means ... smile.gif
Honestly, I thought the original Captivators (bandpass PR version with a 12" driver and 18" PR) were the best I had heard for music.
BTW, since you are a photographer, what do you think about the Sony DSC RX-100 as a carry around daily shooter? I found them on ebay for $400 and couldn't resist.
I was just rereading some of the posts and saw I missed your question... Sorry about that. The Sony is very good, but my general advice for point and shoots is to not spend more than $200-300 because most won't utilize the features. This has a low aperture lens, hence more cost. This allows for shots in low light conditions where you don't want to use flash. Low light capability is great to have, which allows more of a natural look, but there is another option I've suggested to FAM & friends: canon s110 (prev models s95, s100). The Sony has a f/1.8 lens, and the canon has f/2.0...so hardly much diff for your likely use. Most ppl are setting to auto and shooting 3.5-5.6 range anyway. I'd save the cash and get the Canon, but nothing wrong with Sony either. The best camera is always the one you have with you.
Sorry for the OT guys. Just to make this post relevant...what does JTR stand for? wink.gif
asoofi1 is offline
post #14406 of 36575 Old 01-06-2014, 12:08 PM
Point Source
beastaudio's Avatar
Quoted: 3500 Post(s)
Liked: 2831
Originally Posted by Archaea View Post
Has anyone ever played with one of these full band EQs for something like the JTR mains?
http://www.ebay.com/itm/Symetrix-533E-Graphic-Equalizer-31-Band-2-Channel-Stereo-/111249473788?pt=US_Signal_Processors_Rack_Effects&hash=item19e6fc40fc
Who hasn't enjoyed making the v-shaped EQ on their old bookshelf systems. I wonder how one of these EQ setups would pan out in a Home Theater Environment? It could be like Audyssey in tailoring response - except you'd have control over what it sounded like...
Yep, I have a DBX dual 31 band EQ. I messed around with it for a little while and it was good for a few filters, but if you really started dialing it in, the noise floor started going up pretty quickly. I learned that it really is a nice piece to use POST audyssey if you use it. Where just a couple filters would further improve the sound for certain. I have been thinking about popping it in and giving it another run with the Danleys though.
beastaudio is offline
post #14407 of 36575 Old 01-06-2014, 01:05 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
You're starting to change your mind as often as you do your undies!...lol. Once every two to three days!...lol tongue.gif
jbrown15 is offline
post #14408 of 36575 Old 01-06-2014, 01:18 PM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
Originally Posted by lbrown105 View Post
I am curious about the 215 but the 212 is awesome. still my favorite purchase so far. OS's are close second
Has anyone figured out how a pair/lcr set of 215 will negate the need for a sub(s)? Years ago, I had 5 speakers setup for dolby surround, but without a sub. The bass all came thru the LR channels and I never missed not having a sub...Cerwin Vegas btw. I can see this happening with the 215, but one would need lots of powah for the lows...unless the 215 are supposed to be active?? I like the idea of having all inclusive solution, but it seems you would have to get amps for 2ch/ht and subs for ht implementation. What am I missing?
asoofi1 is offline
post #14409 of 36575 Old 01-06-2014, 01:20 PM
jlpowell84's Avatar
Liked: 712
Wait, you change your underwear? Anyway, I'm just weighing my options out in front of me is all smile.gif I would be content with LCR T 8's but if I sold these for a much discounted price over a new pair of T 8's then I could have a shot at LCR Triad Golds. And it could work out great for someone on a pair of Triple 8's. Did you get my PM JB? Anything fun to do up there in Vancouver BC? Only thing about going to Canada is a couldn't carry my pistol. Not a dealbreaker though smile.gif
post #14410 of 36575 Old 01-06-2014, 01:39 PM
subyguy's Avatar
Liked: 26
Damn, if they were 228's I'd be all over them to use as wides with my 212's.
(3) JTR Noesis 212HT (LCR)
(2) JTR Single 8 (wides)
(2) JTR Slanted 8 (sides)
(2) DIY Eminence 10" coax (rear Surrounds)
(2) JTR Orbit Shifters
(2) Mach5 UXL-18's sealed
(2) Soundsplinter 15's sealed
Speakers powered by 6 crown xls 1500's
UXL's powered by Peavey IPR-7500
My theater:
http://www.avs...
subyguy is offline
post #14411 of 36575 Old 01-06-2014, 01:50 PM
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
Got a price in mind?
edoggrc51 is offline
post #14412 of 36575 Old 01-06-2014, 01:53 PM
RMK!'s Avatar
Quoted: 1599 Post(s)
Liked: 1470
Thanks for the belated camera info. I bought the Sony and love it. smile.gif
Opinions are not facts.
RMK! is offline
post #14413 of 36575 Old 01-06-2014, 02:02 PM
selkec's Avatar
do all jtr have it etched into the back like that?
Denon x4200,Samsung 4k TV,
Panasonic bluray
Comcast x1 cable box
Belkin pf60. Emotiva cmx-2
Klipsch rf82, RP-450 center
240s surrounds
selkec is offline
post #14414 of 36575 Old 01-06-2014, 02:15 PM
COACH2369's Avatar
Quoted: 803 Post(s)
Liked: 676
No, they don't. I know my T12's didn't and the Noesis I have now don't either. I believe it was something on the older models.
COACH2369 is online now
post #14415 of 36575 Old 01-06-2014, 02:21 PM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
Jeff Thadius Richardson
His maiden name.
popalock is offline
post #14416 of 36575 Old 01-06-2014, 02:22 PM
Frohlich's Avatar
Quoted: 1164 Post(s)
Liked: 1112
Just the older models, goes back to Jeff's pro audio roots. I think it stopped around 2009 (not sure exactly).
Frohlich is online now
post #14417 of 36575 Old 01-06-2014, 02:23 PM
countryWV's Avatar
Quoted: 405 Post(s)
Liked: 579
His maiden name.
Chris
Chris
countryWV is online now
post #14418 of 36575 Old 01-06-2014, 02:23 PM
jbrown15's Avatar
Liked: 1993
Yeah sorry, I was going to put together a list of cool things that you could do while you're here. I'll send you a PM reply when I get a chance.
jbrown15 is offline
post #14419 of 36575 Old 01-06-2014, 02:24 PM
jbrown15's Avatar
Liked: 1993
If they were 228HT's,I don't think he'd be thinking of selling them.....lol tongue.gif
jbrown15 is offline
post #14420 of 36575 Old 01-06-2014, 02:25 PM
countryWV's Avatar
Quoted: 405 Post(s)
Liked: 579
Those are the Originals in 2008 - 09.
Check this picture out.
http://jtrspeakers.websitetoolbox.com/post/awesome-picture-jeff-3533591
Reddig likes this.
Chris
post #14421 of 36575 Old 01-06-2014, 02:33 PM
RMK!'s Avatar
Liked: 1470
With row seating proximity to surrounds is always an issue for those sitting at the end of the row. Using dI-poles/bi-poles can mitigate this to an extent, but closer proximity is what it is. I have sat at all locations in both of my rows and never found this as a significant factor. Essentially, you don't know what you don't know when you are in those seats smile.gif.
RMK! is offline
post #14422 of 36575 Old 01-06-2014, 02:54 PM
jlpowell84's Avatar
Liked: 712
Thanks JB!
post #14423 of 36575 Old 01-06-2014, 02:55 PM
MKtheater's Avatar
Quoted: 1590 Post(s)
Liked: 1122
I had some of the first home 888's and did not have the etching in them, maybe the pro version?
2007!
http://www.avsforum.com/t/907823/the-jtr-triple-8s/0_100
Marantz 7702 Atmos
MKtheater is online now
post #14424 of 36575 Old 01-06-2014, 03:06 PM
jlpowell84's Avatar
Liked: 712
2007!
Yes I believe they were. Speakon connectors too. Easy enough though. Just screw in - and + and have at it! The logo etched in the back looks really cool. If your room was open so the back of your surrounds were exposed that would be pretty cool. And of course the main differences we have the BMS compression driver and eminence drivers and upgraded handbuilt crossovers from Jeff in these smile.gif
post #14425 of 36575 Old 01-06-2014, 03:20 PM
jlpowell84's Avatar
Liked: 712
Can someone confirm was it in 2010 that Jeff made the switch to BMS drivers? For example the 2010 Triple 8's still had the selenium 220 drivers correct?
post #14426 of 36575 Old 01-06-2014, 03:32 PM
subyguy's Avatar
Liked: 26
T
Don't you recognize that was a subconscious post hoping someone thinking of selling there 228 would see and contact me...that way I can tell my wife that out of nowhere I got an offer to buy some more speakers at an amazing deal. Sheesh, some of you guys are slow wink.gif
Crazy like a fox!
My theater:
http://www.avs...
subyguy is offline
post #14427 of 36575 Old 01-06-2014, 04:18 PM
selkec's Avatar
Frolich
I have been responding back to you. Not sure what is going on. 3179030267 just text me since something is not working
Panasonic bluray
240s surrounds
selkec is offline
post #14428 of 36575 Old 01-06-2014, 04:18 PM
countryWV's Avatar
Quoted: 405 Post(s)
Liked: 579
http://jtrspeakers.websitetoolbox.com/post/2011-speaker-improvements-4956031
I looked at this picture 10 times a day for 6 months salivating for the T12. smile.gif
Chris
Reddig likes this.
Chris
post #14429 of 36575 Old 01-06-2014, 04:21 PM
jlpowell84's Avatar
Liked: 712
Nice, you are very resourceful! I noticed he did not list the change from Dayton mid drivers to Eminence though. I'm sure that was just a quick bullet point. seems like that would've been an important one to list though. Just simply from curiosity what mid range drivers that on the single eight? Obviously it has a bit more X max being that only one driver per speaker
post #14430 of 36575 Old 01-06-2014, 05:20 PM
jbrown15's Avatar
Liked: 1993
T
Crazy like a fox!
Okay, so what you're saying is that you want me to contact you in about 6 months then?....lol
jbrown15 is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
