Official JTR speaker thread - Page 52 - AVS Forum | Home Theater Discussions And Reviews
 8570Likes
post #1531 of 37759 Old 02-19-2010, 07:03 PM
goonstopher's Avatar
Quoted: 322 Post(s)
Liked: 66
Sub seems great but my elctricity is giving me issues
I had a horrible ground hum that got louder with higher volume. I fixed that with a cheater plug and actually it still hums for the first 10 seconds after turning it on then fades away.
What I can say is the sub already gave me something I have sought for 2 years and many subs, it is the kind of bass drop sound. By that I mean you feel it fade out cleanly like I had only heard in well treated demo rooms at stores. Almost like a bass frequency sweep but in normal material. Very impressive. Also I can tell it is powerful. I really don't need 2... but I also don't need 3 quintuples and 2 JBL 8340's (which are HUGE by the way!)
Off to take the passive off now...
goonstopher is offline
post #1532 of 37759 Old 02-19-2010, 07:12 PM
MKtheater's Avatar
Quoted: 1717 Post(s)
Liked: 1252
How are the JBL's?
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays for fronts and BFM TLAH for surrounds
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is online now
post #1533 of 37759 Old 02-19-2010, 11:51 PM
Troll
ufokillerz's Avatar
Liked: 47
Got my T8's and boy am i impressed!, definitely need to work on stands for these, my dts-10 seem to be working a lot better paired to T8's. Audyssey was having a heck of a hard time getting itself setup due to 89db sensitivity surrounds matched to these T8's with 98db sensitivity. Audyssey set reference level to 70db all around for some reason. and i watched the movie 9 at -5db. These speakers are great, the clarity, the little details, all i can say is WOW.
ufokillerz is offline
post #1534 of 37759 Old 02-20-2010, 11:58 AM
fatsow's Avatar
Quoted: 132 Post(s)
Liked: 61
So my 2 Q8 and triple 8 arrived 2 weeks ago. Of course I was traveling the last two weeks. It was a painful waiting. I just got them out of the box and am getting ready to run setup. I will give my thoughts if anyone is interested.
fatsow is offline
post #1535 of 37759 Old 02-20-2010, 12:01 PM
RMK!'s Avatar
Quoted: 1696 Post(s)
Liked: 1622
That would be great and please post some pics of the setup.
Anxiety is contagious, please keep yours to yourself.
RMK! is offline
post #1536 of 37759 Old 02-20-2010, 01:31 PM
Browninggold's Avatar
Liked: 37
would like to hear your review also of your new 3 8's.
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
post #1537 of 37759 Old 02-20-2010, 03:46 PM
Troll
ufokillerz's Avatar
Liked: 47
just wondering for people with the 2010 T8's, have you ever measured your speakers?
i measured mine and 2 were 13.25" deep, while another one was 12.75" deep, not including the grille.
post #1538 of 37759 Old 02-20-2010, 04:11 PM
mjg100's Avatar
Something must have been punched into the CNC incorrectly. I would be sure and use the odd one for the center.
mjg100 is offline
post #1539 of 37759 Old 02-20-2010, 04:46 PM
Troll
ufokillerz's Avatar
Liked: 47
i wonder if minor difference in cabinet dimensions would change the sound much.
post #1540 of 37759 Old 02-20-2010, 05:00 PM
RMK!'s Avatar
Liked: 1622
Mine are Baltic Birch and 12.75" deep. I believe the new MDF cabinets are slightly larger and that may account for the difference. In any case, they have the same drivers/crossover and should sound the same. I agree that you should use the 12.75" T8 as the center.
Did you buy them new?
RMK! is offline
post #1541 of 37759 Old 02-20-2010, 05:09 PM
Troll
ufokillerz's Avatar
Liked: 47
got them lightly used from avs member rossandwendy. The weight of them appears to be pretty much the same, if they were mdf their weights would have been a lot different i thought.
post #1542 of 37759 Old 02-20-2010, 05:16 PM
RMK!'s Avatar
Liked: 1622
Humm, Ross bought them used so I wonder who the original owner was? Jeff is going to have to start using serial numbers .
RMK! is offline
post #1543 of 37759 Old 02-20-2010, 05:56 PM
mjg100's Avatar
I was thinking they were 2010 models. Is that correct? They are already on their third owner?
mjg100 is offline
post #1544 of 37759 Old 02-20-2010, 06:52 PM
Troll
ufokillerz's Avatar
Liked: 47
they are 2010 models!
post #1545 of 37759 Old 02-21-2010, 05:42 PM
RMK!'s Avatar
Liked: 1622
Here is some T8 data provided by Jeff.
2007- 95db/1w, up too 600watt recommended amplification, 80hz-18khz, 12x12x28
2008- 95db/1w, up too 600watt recommended amplification, 80hz-18khz, 12x12x28 (revised cabinet and crossover)
2009- 95db/1w, up too 600watt recommended amplification, 80hz-20khz, 12x12x28 (new compression driver, crossover update, optional fabric grill)
2010- 98db/1w, up too 1200watt recommended amplification, 80hz-20khz, 12x14x26 (Complete re-design, first with movable mid/high)
From the dimensions, it seems as though you may have a mix of models.
RMK! is offline
post #1546 of 37759 Old 02-21-2010, 06:17 PM
mjg100's Avatar
The measurements he gave do not fit any of the T8 sizes. ufokillerz can you give the width and heights? Also for those that do not go to Jeff's site, he has cosmetic blemish T8's for $999 plus shipping. Price is good to the end of the month.
mjg100 is offline
post #1547 of 37759 Old 02-21-2010, 06:38 PM
Jedirun's Avatar
Liked: 49
It sounds like the 12.75 is a 2010 model as it is the same as RMK!'s. I bet RMK! is right and the other 2 are MDF instead of Plywood and are also 2010 models. It sounds like the original owner bought a 2010 T8 center and liked it enough that he bought the left and right as well.
I am surprised that they are on their 3rd owner. You would have to pry mine from my dead fingers to get them away from me.
Jedirun is offline
post #1548 of 37759 Old 02-21-2010, 07:50 PM
Troll
ufokillerz's Avatar
Liked: 47
mine are 12x12.75x26 and 12x13.25x26
the 26 does indicate that they are 2010, so i would think. just weird having different sizes hah.
but yea these are great speakers, i am actually looking to get myself a Q8 for center (possibly) and 1 more T8, so i can have audyssey wide setup.
post #1549 of 37759 Old 02-21-2010, 08:43 PM
Quoted: 322 Post(s)
Liked: 66
Quick update,
Found a way to stop my hum so it is not the sub. I still don't have a workable solution but I was able to make it stop after a nightmare of trying different wires.
I am dying to turn it up and set it up properly. It really seems to be a BEAST of a subwoofer. I have been around the block with subs but this one shakes things so much that my chairs feel like those massage chairs almost and that is with the passive radiator of and not calibrated or placed properly.
Really need to find a workable solution to my electrical issues asap.
post #1550 of 37759 Old 02-21-2010, 09:22 PM
Brouham's Avatar
Originally Posted by goonstopher View Post
Quick update,
Goonstopher, how can you get a credible assessment of the sub if the passive radiator is removed. I would not even want to listen without the radiator because the radiator allows it to reach its rated spec in the sub bass region. I'm just saying.
Brouham is offline
post #1551 of 37759 Old 02-21-2010, 09:35 PM
Quoted: 322 Post(s)
Liked: 66
That is exactly what I am so excited about. It is set up poorly, half taken apart and has electrical noise working against it and it still has great power and clarity and is VERY tactile. I am just blown away by what it can do in this state.
I know it is not a fair assessment but it does hint at how good things are going to be!
I can put the PR back on and temporarily rig my electronic to get a better review. My problems between my circuits is all that is holding me back.
post #1552 of 37759 Old 02-21-2010, 09:37 PM
Brouham's Avatar
I see; fair enough.
Brouham is offline
post #1553 of 37759 Old 02-21-2010, 09:40 PM
Brouham's Avatar
One other thing Goonstopher, when do you expect your other captivator ? I hope that it arrives in good condition.
Brouham is offline
post #1554 of 37759 Old 02-21-2010, 09:46 PM
Quoted: 322 Post(s)
Liked: 66
I am sure it will. Freak things happen. I haven't heard of anyone else having shipping damage on any jtr products so there is a first for everything but it's still very safe. It was just one ding worth mentioning.
I am in no hurry to get my second because this electrical issue has completely destroyed my set up. Wires are torn out, crossed, tangled and god knows where. My wall has a hole in it and 2 electrical boxes are torn out. Speakers and amps are moved around. Its a war zone in here while I try to fix my electrical issue that I just CANT find the source of.
post #1555 of 37759 Old 02-22-2010, 01:28 AM
tommygee's Avatar
Hey Goonstopher,
Did you get a chance to try out your JBL surrounds yet?
tommygee is offline
post #1556 of 37759 Old 02-22-2010, 05:03 AM
mjg100's Avatar
I was surprized by that also. Are the sizes listed in the specs on the JTR site wrong?
T8 Birch 26 x 12 x 14 (14" is the depth)
T8 MDF 26.5 x 12.25 x 14 (14" is the depth)
ufokillerz gave 12.75" and 13.25" for depth on his T8's and RMK gave 12.75" for his T12LF's. Mine are 2008's and they are the 12" deep as listed.
mjg100 is offline
post #1557 of 37759 Old 02-22-2010, 07:27 AM
RMK!'s Avatar
Liked: 1622
My T12LF's are actually T12HT's and are 16.5" (Deep/Wide). Are you confused yet . CNC machines have pretty tight tolerances and I'm sure there is a logical explanation including measuring errors by the owners (that includes me ).
RMK! is offline
post #1558 of 37759 Old 02-22-2010, 07:39 AM
Troll
ufokillerz's Avatar
Liked: 47
Quite weird, seems like a lot of different sized speakers floating around, and the jtr website only has some specs partially updated it would seem.
post #1559 of 37759 Old 02-22-2010, 08:52 AM
orcarola25's Avatar
It seems like Jeff's website is always quite a bit behind as far as updates are concerned. The announcement area on his forums seem to be a little more accurate.
Anyone get tracking numbers on their T12s yet???
orcarola25 is offline
post #1560 of 37759 Old 02-22-2010, 08:59 AM
mjg100's Avatar
I did remember that you had the 12's. , but I was thinking they were LF's. I am an engineer and I even went back and checked my speakers again to double check myself.
mjg100 is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
