Official JTR speaker thread - Page 523 - AVS Forum | Home Theater Discussions And Reviews
 8531Likes
post #15661 of 37682 Old 02-05-2014, 08:29 AM
asoofi1's Avatar
Quoted: 934 Post(s)
Liked: 442
Originally Posted by coolgeek View Post
I so love to read about new people's experiences with their jtr setup... glad u like it...
asoofi1 is offline
post #15662 of 37682 Old 02-05-2014, 08:49 AM
asoofi1's Avatar
Quoted: 934 Post(s)
Liked: 442
Originally Posted by RMK! View Post
Very cool Asim, I can't imagine a better setup ... well, maybe one ... wink.gif . I know this is a temp setup but if you're going to leave the center horizontal you should rotate the horn.
Yeah, Audyssey dosn't know what to do with Oribit Shifters. I have some -15db XLR attenuators that will drop the OS's down into Audyssey's usable range and please PM me if you want them. The other option is to set the OS gain to one click above null. Most likely that will still be 80db or so with the Audyssey test tones (Integra and Marantz may be slightly different) but that's OK.
It's kind of funny how these speakers/sub turn "normal" people into SPL junkies. When the source material calls for loud/clean, you're ready and willing. Having all that power at your disposal is very intoxicating, isn't it? smile.gifcool.gif
Ha...I'm thinking of a separate 2-channel setup in another room to justify my next purchase wink.gif
Edit: The center will eventually be standing in final resting place, but will rotate horn if plans change for some reason...using as rack for now. Interesting thing though, I'm sitting in a chair and even with center 212 sitting on the ground, the dialogue in movies stills seems to be coming from the TV...where the center of the tv has a displacement of 50" from the horn. The dispersion can only get better from here but def don't recommend my current placement.
At -30db, the floor, pots and pots are vibrating in the kitchen thats right on top of the ht room. When standing in the kitchen, its like being next to that teenagers car with that obnoxious sound system blasting.
I'll try the click up one from null and see what happens. Right now, I have to keep volume at -60 to -50db to keep things just normal background music bass levels and it's like I'm fencing two bulls trying to get out and buck. Something is definitely not balanced yet. I think your attenuators might be necessary!
asoofi1 is offline
post #15663 of 37682 Old 02-05-2014, 08:51 AM
asoofi1's Avatar
Quoted: 934 Post(s)
Liked: 442
Originally Posted by logicators View Post
Asim,
By setting the LFE crossover to 80 Hz you are losing all bass sent to the LFE channel from 80 Hz to 120 Hz. Consider raising it to 120 Hz.
Note that this crossover is different from the crossovers for individual speakers which may be set lower.
In other words, if you set the center channel crossover to 60 Hz, everything below 60 Hz will go to your subs and everything above will go to your center speaker. In contrast, 80 Hz LFE crossover tells the receiver to send all bass sent to the LFE channel (which is separate from speaker channels) that is below 80 Hz to your subs and drop everything above that.
Yeah, I was about to say the same thing. You want the LFE set to 120 for sure.
Ok, I've set it back to 120. I thought it might trim back the bass at 80 and I didnt hear too much of a diff.
asoofi1 is offline
post #15664 of 37682 Old 02-05-2014, 08:54 AM
asoofi1's Avatar
Quoted: 934 Post(s)
Liked: 442
Originally Posted by Gooddoc View Post
There are some different schools of thought as to the LFE lpf setting. The issue is primarily with music mixes where less care may be taken with levels and content in the LFE channel. For most movie mixes it probably isn't an issue, but even so, the overwhelming majority of content that matters in the LFE channel is below 80 Hz. So just cutting it off at 80 likely has a minimal impact with movies and may save you from a fairly significant problem with music stuff. I have mine set to 80 Hz.
The flip side of that is that it is a Dolby spec and for those that want to be sure that they are catching everything up to 120 Hz and/or that don't listen to mc music, it seems to make sense to crank it all the way to 120.
There's not a single correct answer, just what your goals are and the content you're listening to.
I'm trying to hear a difference as I change it, but maybe in between at 100 might be a good middle ground?
asoofi1 is offline
post #15665 of 37682 Old 02-05-2014, 08:56 AM
logicators's Avatar
Liked: 26
Leaving it at 120 ensures that you won't miss content, if it exists (it can't hurt). I do agree that most movies do not have much content between 80 and 120 Hz but if it exists you don't want to miss it.
asoofi1 likes this.
logicators is offline
post #15666 of 37682 Old 02-05-2014, 09:04 AM
asoofi1's Avatar
Quoted: 934 Post(s)
Liked: 442
Originally Posted by beastaudio View Post
Agreed here. You aren't going to "lose" everything above 80hz, the rolloff is just a little more shallow. It is still just a rolloff, not a brick wall filter. I believe the actual difference at 120hz really is only something like 2-3dB between the two.
This is my gripe with audyssey's pre-test. I always have to back the gains WAY down to get to an acceptable level that the Marantz/audyssey likes, but then I run through the sweeps and then audyssey sets my subs at like -10 FROM THAT!!!!!! To get my system back in line with a decent house curve I usually have to come all the way back up on the trims and then add some additional back on the DCX EQ that I use. Leaving audyssey's settings alone and listening to anything sounds like absolute garbage... Remember, always eq that bottom end to your own "preference" You paid good dough, make it sound like you want it to biggrin.gif I know your neighbor Austin is a staunch supporter of this mantra, so he can give you some added pressure here biggrin.gif
Austin already gave me a bunch of his measurement tools to hold over here. I'm definitely going to need his help to get things dialed in...but I may need to ducktape the remote to my hand before he comes over wink.gif
asoofi1 is offline
post #15667 of 37682 Old 02-05-2014, 09:05 AM
asoofi1's Avatar
Quoted: 934 Post(s)
Liked: 442
asoofi1 is offline
post #15668 of 37682 Old 02-05-2014, 09:11 AM
countryWV's Avatar
Quoted: 409 Post(s)
Liked: 591
My Wife watched the last half of "Through the Never" with me Saturday at -10. I won't go so far as to say she thoroughly enjoyed it but she did say that at least her ears were not hurting from the volume. She told me it would have been a lot more enjoyable had someone not been trying to play the drums on her chair the entire concert. biggrin.gif
Chris
Chris
countryWV is online now
post #15669 of 37682 Old 02-05-2014, 09:14 AM
KevinH's Avatar
Quoted: 192 Post(s)
Liked: 71
Originally Posted by countryWV View Post
My life watched the last half of "Through the Never" with me Saturday at -10. I won't go so far as to say she thoroughly enjoyed it but she did say that at least her ears were not hurting from the volume. She told me it would have been a lot more enjoyable had someone not been trying to play the drums on her chair the entire concert. biggrin.gif
Chris
If you can spin that disc and not have any air drums going....you don't deserve to own it. tongue.gif So you done good
-Kevin
JVC DLA-X550R projector/GIK Acoustic room treatments
Screen Innovations Black Diamond Zero Edge 1.4 110" 16:9
Marantz AV7702mkii pre-pro/Wyred4Sound 5-channel amp
Oppo BDP-105
JTR 3TX LCRs/Single8 HT-LP surrounds/2 RA Gamma21 master/slave pairs
KevinH is offline
post #15670 of 37682 Old 02-05-2014, 09:15 AM
Gooddoc's Avatar
Quoted: 3013 Post(s)
Liked: 2248
The problem is that when you pop in a mc disc and it doesn't sound so good because of some 115 Hz rumble in the LFE track it's likely you'll just think the disc sucks.
I can't remember who it was that spent the time to measure the problem, but it was random and prevalent enough for me to decide that 80 Hz is where I would set the LFE lpf moving forward. Roger Dressler maybe?? Can't say remember for sure, but he's a trusted member.
Gooddoc is online now
post #15671 of 37682 Old 02-05-2014, 09:29 AM
logicators's Avatar
Liked: 26
You must be right. I personally don't have any experience with MC concerts (my HT is almost exclusively used for movies or 2 channel music).
I participated in a similar thread several years ago about movies, and the conclusion was that the right crossover for movies was 120 Hz. It was in the context of pioneer receivers as they (at-least in those days) only provided a global crossover for the whole system and dropped everything above that threshold on the LFE channel. So people with full range speakers were forced to set the crossover very high or risk losing quite a bit of information.
So if Asim is primarily a movies guy he can use 120 Hz. Otherwise he can use a lower crossover and change it when watching movies (which is a pain).
post #15672 of 37682 Old 02-05-2014, 09:31 AM
countryWV's Avatar
Quoted: 409 Post(s)
Liked: 591
I have a 13' x 18' area between the seats and the front Speakers/entertainment cabinent that serves as my Own Private Mosh Pit for whenever I feel the Urge. smile.gif
My room is not so much a dedicated HT room as it is A dedicated Clubhouse. Chris's Clubhouse to be exact.
Chris
KevinH likes this.
Chris
post #15673 of 37682 Old 02-05-2014, 09:37 AM
asoofi1's Avatar
Quoted: 934 Post(s)
Liked: 442
I knew this would happen with the 212 and part of the reason I chose these over the 228, but I am listening to more music than watching movie demos. I can see music taking the ratio of usage as time goes by. The bass for music performance is really something I have to tame...movie performance varies so far for each demo clip but overall bass is not too overwhelming than when I put on music. I think this is where a full range would be a far easier speaker to setup, but I'm confident I can make this work. Otherwise it is a slight nuisance to change the LFE each time...maybe the sr7008 can save settings in diff modes...I'll have to see.
asoofi1 is offline
post #15674 of 37682 Old 02-05-2014, 09:42 AM
KevinH's Avatar
Quoted: 192 Post(s)
Liked: 71
I knew this would happen with the 212 and part of the reason I chose these over the 228, but I am listening to more music than watching movie demos. I can see music taking the ratio of usage as time goes by. The bass for music performance is really something I have to tame...movie performance varies so far for each demo clip but overall none are overwhelming than when I put on music. I think this is where a full range would be a far easier speaker to setup, but I'm confident I can make this work. Otherwise it is a slight nuisance to change the LFE each time...maybe the sr7008 can save settings in diff modes...I'll have to see.
I apologize if I missed it but have you run XT32 yet?
-Kevin
Oppo BDP-105
KevinH is offline
post #15675 of 37682 Old 02-05-2014, 09:44 AM
asoofi1's Avatar
Quoted: 934 Post(s)
Liked: 442
Yes, but I think I should run it again. I just put the LR on boxes to raise to ear level.
asoofi1 is offline
post #15676 of 37682 Old 02-05-2014, 09:45 AM
countryWV's Avatar
Quoted: 409 Post(s)
Liked: 591
The LFE setting is separate of the XO setting on XT32 in the menu. Is that what's being discussed? Example = LFE set at 120hz while the speaker XO setting is 80hz. The Oppo 95 has these separated too.
Chris
post #15677 of 37682 Old 02-05-2014, 09:46 AM
Gooddoc's Avatar
Liked: 2248
Hearing a difference is entirely dependent on the content you're listening to, so very hard to a/b for this issue and even if you did every new disc you introduce to your system would have to be tested. So it's sort of a philosophical approach setting.
If multichannel music is a high priority for you, then you set it to 80 Hz. If movies is a bigger priority then set it to 120 Hz. But there's no right answer for everyone.
post #15678 of 37682 Old 02-05-2014, 09:53 AM
asoofi1's Avatar
Quoted: 934 Post(s)
Liked: 442
Yes. I'm running xt32 again right now, but LFE was set at 120, and xo for LR at 80, and center at 60.
asoofi1 is offline
post #15679 of 37682 Old 02-05-2014, 09:57 AM
asoofi1's Avatar
Quoted: 934 Post(s)
Liked: 442
Agreed. Even clips on the demo discs I'm using right now have variances I didn't expect.
asoofi1 is offline
post #15680 of 37682 Old 02-05-2014, 09:59 AM
Point Source
beastaudio's Avatar
Quoted: 4000 Post(s)
Liked: 3308
haha, yep. My music to movie ratio is now close to 80/20 if I had to guess.
FS: BossoBass A-14K amplifier
beastaudio is offline
post #15681 of 37682 Old 02-05-2014, 10:06 AM
asoofi1's Avatar
Quoted: 934 Post(s)
Liked: 442
Reran xt32 and got these:
asoofi1 is offline
post #15682 of 37682 Old 02-05-2014, 10:12 AM
countryWV's Avatar
Quoted: 409 Post(s)
Liked: 591
Asim
Turn your OSs completely to 0 or as low as it will go then turn it up 1 click. You can also move the Mic back further from the avr/pre. An open room is hard on Audyssey settings. Back your front speakers up, 120hz is to high.
XT32 always sets my XO to 60hz and I raise them to 80hz.
You can manually raise the XO setting but if you lower the XO it will nullify Audyssey.
Chris
post #15683 of 37682 Old 02-05-2014, 10:20 AM
N8DOGG's Avatar
Quoted: 1092 Post(s)
Liked: 1194
the trim levels dont matter. Raise all your speakers to 0, adjust all speakers to be match, that will give you all the room to adjust your OS's however you need ( It doesnt have to be 0, jist whatever you meed to be able to adjust your OSs properly) Set all speakers to 80hz and have fun. Changing trims, channel levels does nothing to your calibration, it will always stay the same. There may be a slight change because of volume levels but it would be slight.
Your new reference will be however many dbs lower you had to turn up you channel levels ( or close to it, slp meter and find it, You should be able to adjuat your avr to the new reference in the menu.
N8DOGG is online now
post #15684 of 37682 Old 02-05-2014, 10:28 AM
countryWV's Avatar
Quoted: 409 Post(s)
Liked: 591
I agree with this but would only do it if I could not figure out how to make it work normally. This would work once frustration sets in and the phrase F' It rolls off my tongue. biggrin.gif
Chris
Chris
post #15685 of 37682 Old 02-05-2014, 10:31 AM
L0nestar's Avatar
Quoted: 18 Post(s)
So, just to recap correct xover settings..... 80hz rlc, 120hz sub. This would apply to 228hts and a cap 2400 too I suppose for 100% movies? Seems like I've heard this before.
Also, do you guys like dynamic volume and eq from audessy on or off?
Maximum Un-Intelligence.
L0nestar is offline
post #15686 of 37682 Old 02-05-2014, 10:31 AM
L0nestar's Avatar
Quoted: 18 Post(s)
Asim, your setup rocks btw.
L0nestar is offline
post #15687 of 37682 Old 02-05-2014, 10:32 AM
countryWV's Avatar
Quoted: 409 Post(s)
Liked: 591
Dynamic EQ On
Dynamic volume Off.
Chris
post #15688 of 37682 Old 02-05-2014, 10:47 AM
logicators's Avatar
Liked: 26
Interesting. Audyssey sets my 212 fronts to 90 or 100 Hz as well, and the center to 40 Hz which I generally raise to 60. But it suggested 60 Hz for my quintuple fronts.
post #15689 of 37682 Old 02-05-2014, 10:52 AM
asoofi1's Avatar
Quoted: 934 Post(s)
Liked: 442
Just arrived a day late. Good thing I'm good with scissors as a wire stripping tool wink.gif
asoofi1 is offline
post #15690 of 37682 Old 02-05-2014, 11:04 AM
Point Source
beastaudio's Avatar
Liked: 3308
Off, full stop
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
