Official JTR speaker thread - Page 550 - AVS Forum | Home Theater Discussions And Reviews
 7837Likes
post #16471 of 36710 Old 02-20-2014, 02:44 PM
Frohlich's Avatar
Quoted: 1169 Post(s)
Liked: 1116
Originally Posted by beastaudio View Post
Some good rules of thumb
~Place your subs at 1/4 space in from side walls
~Make your main listening position and the two main speakers an equilateral triangle. This will maximize placement and the soundstage from your mains.
~Side wall absorption at tertiary reflections would be recommended
~A-T screens rule @frolich
The thing Brandon won't tell you is that AT screens have been proven in rigourous scientific test to filter out any details above 500HZ. It will make your speakers sound like a wet blanket was thrown over them. That is fine with his Danley's since they are so bright they could break windows but for folks with neutral speakers like JTR...it will suck the life right out of them. Now I must also disclose that this response is total sarcasm.....an running joke between a few of us on this thread....that Brandon is heck of guy and knows 10X what I do about acoustics. Also, his Danleys, by all accounts, are awesome smile.gif
beastaudio likes this.
Frohlich is online now
post #16472 of 36710 Old 02-20-2014, 02:49 PM
Point Source
beastaudio's Avatar
Quoted: 3547 Post(s)
Liked: 2865
beastaudio is offline
post #16473 of 36710 Old 02-20-2014, 03:08 PM
carp's Avatar
Quoted: 2531 Post(s)
Liked: 1803
I suggest playing around with moving your L and R further apart than the equilateral triangle. I've done so much experimenting with speaker placement and I ALWAYS come back to having them further apart than they are from me. I'm 9'6 from each speaker and they are 11' 6" apart (that's 11'6" from the inside edges of the cabinets so CD's are even further apart than that).
I don't know... they just have a better and bigger soundstage - more seperation between instruments and better "singer is in the room" thing going on.
We've talked about this before so this is for anyone to try out if they are curious. I don't think you can go wider in your room than you are from the speakers?? From the pics it looks like your speakers are almost to the side walls anyway. Haha, I'd be moving up that front row!! biggrin.gif
carp is offline
post #16474 of 36710 Old 02-20-2014, 03:17 PM
Protium's Avatar
First off thank you for your reply.
Do you have recommended clearance for the front left and right speakers from the back and side walls?  My LP is ~12' with the spacing between the FL and FR being 12' would bring them within a foot of the side walls.
Also, with my second row of seating I would expect the listener's head to be ~2-3' from the back wall.  Any issues with this (reflections or rear speakers too close?)?  Should I look at reducing my LP distance?
Any insight is appreciated!
Protium is offline
post #16475 of 36710 Old 02-20-2014, 03:38 PM
Frohlich's Avatar
Liked: 1116
There are no rules of thumb that work 100% of the time because each room is different and each persons preferences are different. Some things to try:
1)move your speakers away from walls by a couple of feet if space allows..play around with placement, including toe in
2)use acoustical treatments if funding and room layout allow
3)the sweet spot will usually sound the best,especially for 2 channel stereo
4)dual subs tend to help smooth out the sound from seat to seat...so go that route if funding and placement allow it
5)use room correction..XT 32 is pretty common and works well with movies (Some differing opinions on how it treats music)
6)most of enjoy the hobby and the process..tweaking and playing around with placement and layout are part of the fun for many of us.
post #16476 of 36710 Old 02-20-2014, 04:15 PM
Point Source
beastaudio's Avatar
Liked: 2865
Did that a few weeks ago! 9 feet from a 138" 16:9 is pretty darn close, but it is pretty sweet. I am basically as equilateral as I can get with an 11 foot wide room. Can't get any closer. I think that is actually why I like a little less toe-in as I get a little off the (treated) side walls still. One of those Opeth tracks and DT stuff I can clearly hear instruments that extend past the 11 foot width and it is something else!!!! That one Tool track where the vocals alternate between the mains, the effect puts the vocals basically circling around your head. it is a full 360 effect that I think they were actually aiming for, but super cool nonetheless
post #16477 of 36710 Old 02-20-2014, 04:27 PM
carp's Avatar
Liked: 1803
Nice!!
Do you mean the Tool song with Henry Rollins? LOVE That effect.
carp is offline
post #16478 of 36710 Old 02-20-2014, 04:47 PM
Point Source
beastaudio's Avatar
Liked: 2865
Nice!!
post #16479 of 36710 Old 02-20-2014, 07:15 PM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
I don't think my room dimensions would support front wide speakers.  I do think that front heights would be possible.  Therefore I have limited my channel selection to
Are the internal components on the 4520 a significant upgrade from the X4000?  DAC, amps, etc.  if they are worth (I know a relative term) the money then I would consider it.
Heights are a waste and more value and performance will be achieved through second sub, quality surrounds, room treatments, etc. Strong 5.2 or 7.2.
asoofi1 is offline
post #16480 of 36710 Old 02-20-2014, 09:00 PM
RMK!'s Avatar
Quoted: 1613 Post(s)
Liked: 1490
Not sure I would call Height speakers a waste but clearly the other items you mention should take precedence. I just sold my height speakers because they didn't add that much to the experience (like ULF's wink.gif ). I guess it comes down to big rooms need more speakers and sound to fill them. My room was easily overpowered by my setup and that will probably continue to be the case if I push it. It is interesting to me how good a couple of Triple 8LP's mains and a Slanted 8 center sound even without subs. The fact that they are behind an AT screen removes the visual bias so I just listen.
Opinions are not facts.
RMK! is offline
post #16481 of 36710 Old 02-20-2014, 09:07 PM
N8DOGG's Avatar
Quoted: 985 Post(s)
Liked: 1055
I agree with a second sub being the better pick but in the right room, heights or wides are great. Have you heard Heights in a room that could accomidate them? I've setup over 60 systems now and believe me, in the right room, it can really add to fill in gaps. Unless you've been in a good one, it's hard to explain but I've never met anyone that had good sized room that had 9 or 11 channels and went back to 7 or 5. I've even done a 7.2 to 11.2 in a room for a client when I was doing pro calibrations just to see what he liked better, within 20 seconds, the 9 channel stayed and he quickly went online to buy a few more surrounds to add for wides, which we added later. In a small room I 100% agree but in a larger room, its great.
N8DOGG is offline
post #16482 of 36710 Old 02-20-2014, 09:37 PM
raynist's Avatar
Quoted: 1304 Post(s)
Liked: 1237
I have had my 228's in my system now for 3 days. We have to walk through this room to get to the garage. My wife still hasn't noticed or mentioned the 228's. I don't know how that is possible, I had to rearrange the placement of several things to make them fit and they are way more substantial than what they replaced. My 7 year old daughter noticed them right away. She even did a workout DVD on them.
Maybe she has just given up asking about new toys?
Before I got these I was 99.5% movies, in the last 3 days I have been about 90% music. I haven't really had time to sit down for a few hours to watch a movie though.
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is offline
post #16483 of 36710 Old 02-20-2014, 09:56 PM
Troll
ufokillerz's Avatar
Liked: 47
heights sound awesome in my room, have you tried heights with speakers with wide dispersion patterns. such as the single 8's etc.
heights are not a waste for someone looking to expand their already awesome system.
ufokillerz is offline
post #16484 of 36710 Old 02-20-2014, 09:58 PM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
Originally Posted by raynist View Post
After putting a few hours on my 228's listening to music I have to say I am loving them. They Are so clear and dynamic. I have to be careful about turning them up too loud. I am hearing things I haven't heard before in music, especially strange to hear a singer taking a breath during the song!
Watched a few demo scenes on blu ray and watched the last hour of Oblivion. Same thing, extremely clear and I want to turn them up louder. Need to be careful when my daughter is watching with me.
Stayed up way to late tonight listening to these.....
What is everyone crossing these over at? Audyssey recommended 60hz, I set them at 80hz.
I let Audyssey decide as it calculates to your certain room and applies the necessary corrections, so what someone else's XO setting is may not apply to your specific room & calibration.
Another thing to keep in mind is make sure to perform Audyssey correctly by measuring 8 points. This is the measuring guide I found & followed...it sounded much better than just measuring the MLP, which is a mistake many people make, including myself:
(Important: All points are relative to MLP position)
1 - MLP
2 - 3" inches forward of MLP
3 - 3" inches up of MLP
4 - 3" inches forward, and 3" up of MLP
5 - 3" inches left of MLP
6 - 3" right of MLP
7 - 6" inches left of MLP
8 - 6" inches right of MLP
After Audyssey, Minidsp is a no brainer and the next step IMHO.
asoofi1 is offline
post #16485 of 36710 Old 02-20-2014, 10:39 PM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
The AT screen is recommended due to aligning the tweeter of the center channel with ear height?  Any recommendations on screen manufacturers?  (Sorry to drag video discussion in a speaker thread).  I was looking at the Elite Screen EZFRAME AT screen material.  Does this manufacturer have a good reputation?
In terms of video projection, I have decided to purchase the Epson 5030 (can always be persuaded as I haven't purchased yet).  However, the lumen level, throw range and general quality all align with this projector IMO.  Anyone have experience with this projector?
Thanks to all who responded!
An AT screen is the best option, if space permits.
If going with 16:9 screen, then Epson 5030 is great. If 2:35, Panasonic 8000.
I was initially going to go with a 16:9, but now I'm going with 2:35 myself. Just better for majority of movie ratios and you only give up very little on 16:9 source...For instance, a 163" diagonal 2:35 screen will still give you about 130" diagonal 16:9 image. Plus, a 2:35 screen width will allow more displacement between the LCR speakers.
asoofi1 is offline
post #16486 of 36710 Old 02-20-2014, 11:05 PM
Skylinestar's Avatar
Quoted: 1077 Post(s)
Liked: 187
Has anyone compare the JTR 228HT against Klipsch RC64ii? Which gives a bigger & fuller voice in movies? Is there a night & day difference between these two?
Skylinestar is online now
post #16487 of 36710 Old 02-20-2014, 11:17 PM
Archaea's Avatar
Quoted: 2898 Post(s)
Liked: 2494
I'm not a big fan of the Klipsch RC-64ii. I've compared the 228HT against the RC-64ii at avsforum member and klipsch owner scrappydue's house directly. We both preferred the 228HT as a center. I think his Klipsch Towers were significantly better than the RC-64. But overall we both still liked the 228HT as a L/C/R setup. The Klipsch center channel gets a boxy sound about 6 or 7 dB below reference IMO. You don't get that at all with the 228HT.
Archaea is online now
post #16488 of 36710 Old 02-20-2014, 11:52 PM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
I think they may sound good in certain applications & much larger room...I've even considered using heights in the middle of the ceiling to get an Atmos type of effect and may try it. I do think it's a waste in majority of rooms, because most people just don't have the space to take full advantage of it, being that average rooms being only 7-9' feet high and under 3000^3. I should expand on my use of 'waste' to describe the application...it's more the ROI. One can put some less expensive surrounds up there, but certainly not something costing over a couple hundred bucks IMO...just not enough coming out and nothing even placed by the sound engineer beyond 5.1 anyway....I was just looking to pre-order Gravity, and even that is only 5.1 rolleyes.gif
Speaking of the 8's....I tried two of them as LR, and they were fantastic. If someone has limited space, five 8LP with 2 subs would be a great setup.
Yes, I built a dedicated theater with about 13-14' ceiling and installed a 11.1 setup with heights. I didn't hear a difference at the time with a variety of demo clips (scubasteve bd). I'm going to go back to that HT and retest and recalibrate. There are many factors that effect the final performance, so definitely willing to give it another chance and be convinced otherwise...just haven't thus far. I have some extra speakers, so I will try them out as heights in my current setup...I've got 9' ceilings, but as in most applications, I'm pretty sure the LCR will overpower heights just like they are doing with the wides I'm trying out right now. The R&D continues smile.gif
asoofi1 is offline
post #16489 of 36710 Old 02-21-2014, 12:34 AM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
I've tried it with speakers that have 90x90 degrees of dispersion. No discernible difference to me.
My take is that heights are expanding on the LR channels to give more of a 'wall' of sound and 'trailing' some effects over the head, but with speakers like the 212, or even 228, I don't think there will be enough displacement between location of the LR and Height speakers...essentially the LR overwhelms the Heights. As I mentioned, I'm always open minded to revisit and I will definitely try it again in my current setup...who knows, I may change my mind.
For now, it's a waste of money IMHO. After going to 9.x, 11.x, and even 7.x now...I still believe 5.x gives the best ROI for majority of movies & applications.
asoofi1 is offline
post #16490 of 36710 Old 02-21-2014, 05:29 AM
countryWV's Avatar
Quoted: 408 Post(s)
Liked: 588
1 - MLP
6 - 3" right of MLP
Try it in 2' increments. MLP first then form a 2 foot square or circle with the MLP as the radius.
1 MLP
2 MLP 2' Back middle
3 MLP 2' Back R
4 MLP 2' Back L
5 MLP 2' Side L
6 MLP 2' Side R
7 MLP 2' Front R
8 MLP 2' Front L
Something like that with mic 2' feet from LP on other 7 points.
Another tip is make sure its quiet with no heat pump, no one walking around upstairs, no washer and dryer going, and no cars passing by outside. Early in the morning is usually the quietest.
Chris
Chris
countryWV is offline
post #16491 of 36710 Old 02-21-2014, 08:23 AM
Point Source
beastaudio's Avatar
Liked: 2865
Your 7 year old has workout DVD's? I see a slight problem with this....
You need to get her Blu Ray's.
post #16492 of 36710 Old 02-21-2014, 08:47 AM
RMK!'s Avatar
Liked: 1490
That is pretty close to my config. LP is 11' from the CC and the second row seat backs are 30" off of the back wall. Mains have always been within 18" of the front and side walls. All walls and the ceiling are treated with absorption panels. More space would be better but it is what it is as I converted and existing space and had to work within those parameters. I treated most of the back wall with 2'X4' GIK bass traps and added some unusual diffusion panels on top of the bass traps. The back row sounds pretty good to me but the front row (center) has, and will continue to be the sweet spot, Audyssey seems to do a reasonable job in making a much larger sweet spot (i.e. better sound across all seats) but it does slightly compromise imaging from the main LP IMO.
RMK! is offline
post #16493 of 36710 Old 02-21-2014, 11:35 AM
raynist's Avatar
Liked: 1237
Lol, after I typed that I thought maybe it sounded like they were hers. I actually meant my wife's. If but were my daughters it would have to be on an iPad. She knows nothing of physical media smile.gif
raynist is offline
post #16494 of 36710 Old 02-21-2014, 12:06 PM
subyguy's Avatar
Liked: 26
Second OS and (3) 212 HT's are enroute. TIme to swap out the T12s.
(3) JTR Noesis 212HT (LCR)
(2) JTR Single 8 (wides)
(2) JTR Slanted 8 (sides)
(2) DIY Eminence 10" coax (rear Surrounds)
(2) JTR Orbit Shifters
(2) Mach5 UXL-18's sealed
(2) Soundsplinter 15's sealed
Speakers powered by 6 crown xls 1500's
UXL's powered by Peavey IPR-7500
My theater:
http://www.avs...
subyguy is offline
post #16495 of 36710 Old 02-21-2014, 12:50 PM
countryWV's Avatar
Quoted: 408 Post(s)
Liked: 588
Very Nice. cool.gif T12s could make for a great set of Side surrounds. biggrin.gif
Congratulations on an Awesome system.
Chris
Chris
post #16496 of 36710 Old 02-21-2014, 01:27 PM
Troll
ufokillerz's Avatar
Liked: 47
i was blown away by having heights in place for black hawk down. to each their own. i have a pretty decent 9.2 system.
post #16497 of 36710 Old 02-21-2014, 01:38 PM
popalock's Avatar
Quoted: 1235 Post(s)
Liked: 1723
IREEEEENE...
popalock is offline
post #16498 of 36710 Old 02-21-2014, 02:04 PM
Troll
ufokillerz's Avatar
Liked: 47
IREEEEENE...
granted that its not the best example, but i found the heights effect to really stand out with the helicopter landings and all!
post #16499 of 36710 Old 02-21-2014, 03:35 PM
N8DOGG's Avatar
Quoted: 985 Post(s)
Liked: 1055
Well, I got the email today from Jeff and the 215's are officially ordered. He said the 210's are done as well, just needs to make the xover.
N8DOGG is offline
post #16500 of 36710 Old 02-21-2014, 03:50 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
awesome! post some impressions for sure.
lbrown105 is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
