Official JTR speaker thread - Page 564 - AVS Forum | Home Theater Discussions And Reviews
 8531Likes
post #16891 of 37682 Old 03-04-2014, 03:01 PM
L0nestar's Avatar
Quoted: 18 Post(s)
Guys...I'm trying to sound treat my theater and Bryan from GIK is giving me some advice that seems questionable. Wanted to run it by you guys to see what you though.
He says the 120 inch screen is too big for the wall (13.5 ft) and the seating distance is too short (13 ft). He's saying the captivators are going to sound terrible because they are corner loaded and you can't treat the corners behind them.
He's recommending that I build out my stage more to move the caps somewhere else to treat the corners on the projection wall..........
Are corner loaded subs bad? I thought it was okay to corner load a sub. I'm confused. Can't I just treat the corner above the sub?
Maximum Un-Intelligence.
L0nestar is offline
post #16892 of 37682 Old 03-04-2014, 03:02 PM
L0nestar's Avatar
Quoted: 18 Post(s)
To be honest, untreated, the room doesn't sound bad at all to me if you stay seated. The screen works for us personally...doesn't seem too big. I'm not sure this is even going to be worth it.
L0nestar is offline
post #16893 of 37682 Old 03-04-2014, 03:09 PM
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
I sit 14 feet from a 200" scope/158" 16:9 CIH screen and wish I could go bigger. I'm not sure how big of a screen would be too big but I haven't reached it yet.
YMMV.
popalock likes this.
MX48 is offline
post #16894 of 37682 Old 03-04-2014, 03:14 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
I wouldn't listen to that either. Corner loading a sub will get you more output that is all. He can't tell you that a sub will sound good or bad anywhere in your room without testing it even if it is the sub crawl method. You can treat the corner the sub is in, but I would measure first to see if you actually need to treat it. You can also make your response worse by treating the room wrong and waste your money at the same time. Place your speakers where you want them and then treat your room.
YMMV.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #16895 of 37682 Old 03-04-2014, 03:18 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
I sit 11ft from a 120" diagonal 16:9 screen and my front wall is 14ft wide, I don't have any issues at all. In fact if anyone takes a look at the pictures of my front wall the screen and speakers aren't centered to the wall either, everything is offset to the right.
HTPCat likes this.
jbrown15 is offline
post #16896 of 37682 Old 03-04-2014, 03:21 PM
Point Source
beastaudio's Avatar
Quoted: 4000 Post(s)
Liked: 3308
Dang, does that not bug the heck out of you. My whole drop ceiling grid is only off by about 3-4 inches and it gets my OCD cookin pretty bad. Especially with my MLP being dead center between the side walls, I always want to look up and be directly under the center rail, but I am off a couple inches to the left. It bugs the crap out of me.....
FS: BossoBass A-14K amplifier
beastaudio is offline
post #16897 of 37682 Old 03-04-2014, 03:25 PM
jbrown15's Avatar
Liked: 1995
It does and it doesn't, there's nothing that I can really do about it because that's how the basement was designed in the house. It did allow for my to tuck in my AV rack and add a little mini bar and fridge, so it looks pretty good.
jbrown15 is offline
post #16898 of 37682 Old 03-04-2014, 03:28 PM
Point Source
beastaudio's Avatar
Liked: 3308
Yea, me either. I have a bar/rack area inset into what used to be a closet on the right wall and I turned it into a little makeshift bar by busting out the wall to half height and the door. It isn't that spectacular and needs a nice finish carpentry job on it. but it is a nice space to stick all the HT stuff.
post #16899 of 37682 Old 03-04-2014, 03:45 PM
Archaea's Avatar
Quoted: 3071 Post(s)
Liked: 2680
There may be truth to not corner loading very capable ported subs. (if not applying additional EQ - -- - because it may re-inforce the low end too much)
But without measuring in a room it may be an inaccurate recommendation.
I prefer my captivator pair about 1/3 room width each. Which happens to be on both left and right of my projector screen. I've measured all over my room. Literally spent hours moving the caps around and measuring, and at my seating position - luckily for me --- the cosmetic first choice was just about (but not quite) the best FR I could manage natively (with no EQ applied). The only better native FR was with the ported subs facing towards the outside walls rather than facing forward. But it was a minor difference, and could be EQ'ed out, and I much prefer both the looks, and exceptionally prefer the port wind effect of the subs facing forward.
Archaea is offline
post #16900 of 37682 Old 03-04-2014, 03:58 PM
L0nestar's Avatar
Quoted: 18 Post(s)
So I'm guessing before I do any room treatment at all....or buy anything else...I need to pic up an omni mic.
L0nestar is offline
post #16901 of 37682 Old 03-04-2014, 04:09 PM
Gooddoc's Avatar
Quoted: 3014 Post(s)
Liked: 2251
In medicine that would be considered a class 1a evidence based recommendation. In other words, it's highly recommended. biggrin.gif
Gooddoc is offline
post #16902 of 37682 Old 03-04-2014, 04:09 PM
Frohlich's Avatar
Quoted: 1177 Post(s)
Liked: 1127
I must have a similar HT OCD to Brandon. Symmetry is in my blood. I measure things down to the inch to make sure everything stays symmetrical (screen, speakers,projector,etc..). Might explain why they keep me heavily medicated and under constant adult supervision tongue.gif
Frohlich is offline
post #16903 of 37682 Old 03-04-2014, 05:13 PM
desertdome's Avatar
Quoted: 1267 Post(s)
Liked: 1454
Is that 16:9 or 2.35:1 screen? Is 120" diagonal? The CEDIA recommendation is 43 degrees which is basically 3x screen height for a 2.35 screen. I think THX is a little further back.
I have a 12.5" wide room with a 126" diagonal 16:9 screen. I usually sit around 11' from the screen. I love the immersion.
I don't think the issue he is addressing is corner loading the subs. The issue is an acoustics one (which Bryan specialized in) because too large of a screen and the subs by the corners prevents one from putting bass traps floor to ceiling in the wall corners. Using floor to ceiling bass traps is the best treatment I've done in my room and greatly improved the bass. I use an AT screen so my subs are still in the corners and my screen is wide. wink.gif However, if you aren't going with an AT screen you have to compromise somewhere. Bryan's advice is looking at it from an audio priority perspective and is the correct advice from that perspective.
I would rather have subs between L/R and center with corner bass traps than have subs in the corners.
High Impact AV
desertdome is offline
post #16904 of 37682 Old 03-04-2014, 05:43 PM
L0nestar's Avatar
Quoted: 18 Post(s)
It's a 16:9.I'm starting to think that the projection wall needs to get knocked down so I can flush the speakers behind an AT screen.
L0nestar is offline
post #16905 of 37682 Old 03-04-2014, 05:46 PM
Nyal Mellor's Avatar
Quoted: 455 Post(s)
Liked: 334
exactly, just like this:
which looks like this with the screen on and the speakers lit up:
L0nestar likes this.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #16906 of 37682 Old 03-04-2014, 07:00 PM
Archaea's Avatar
Liked: 2680
^ that looks really cool!
Archaea is offline
post #16907 of 37682 Old 03-04-2014, 08:10 PM
cshuff's Avatar
Quoted: 26 Post(s)
Originally Posted by RMK! View Post
Yep, ordered this morning. Might be a good music demo for the 215RT GTG. cool.gif
Agreed….excellent DVD. Even better would be this….
http://www.amazon.com/Killers-Live-Royal-Albert-Blu-ray/dp/B002RBZ13Q/ref=sr_1_1?s=music&ie=UTF8&qid=1393992177&sr=1-1&keywords=killers+live+from+the+royal+albert+hall+bluray.
Recommend playing Dustland Fairytale as loud as your 215's can muster….you and your crowd will be impressed…even if your not a Killers fan.
cshuff is offline
post #16908 of 37682 Old 03-04-2014, 09:26 PM
Jedirun's Avatar
Liked: 49
I sit 9 feet from a 113" screen and would go bigger if I had the room on the wall.
Jedirun is offline
post #16909 of 37682 Old 03-04-2014, 09:54 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 354
Originally Posted by countryWV View Post
Your referring to 2 channel tests. Any high quality avr should be able to do 2 channel with HE/HS speakers just fine. Same goes for a 2 channel amp.
HT is about 5, 7, 9, or 11 speakers being driven. That is when the avr starts to fail. I have T12s for the LCR and Mythos tens for the SS and RS. They are supposedly 93dbs. Watching a highly dynamic movie or concert at reference level results in noticeably more listening fatigue at the end then it does when watching the same show (different day) powered with a 3 channel amp and letting the avr drive the 4 surrounds.
When watching the show at reference powered with the avr I usually cannot wait for it to end so I can turn the volume down. My ears start hurting about a half hour into it. When the amp is added I enjoy the show and do not even think about the volume. This difference is why I own an amp.
2 cents
Chris
Amen. Play 7 channels at full tilt and a avr's limits will be shown.
Swolephile is offline
post #16910 of 37682 Old 03-05-2014, 05:53 AM
Skylinestar's Avatar
Quoted: 1175 Post(s)
Liked: 213
What's the lead time for making a 228HT?
Skylinestar is offline
post #16911 of 37682 Old 03-05-2014, 06:21 AM
raynist's Avatar
Quoted: 1524 Post(s)
Liked: 1486
It took 4 weeks to ship from the time I ordered, best bet is to call and ask though.
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is offline
post #16912 of 37682 Old 03-05-2014, 06:53 AM
RMK!'s Avatar
Quoted: 1696 Post(s)
Liked: 1621
Remember, Brian is selling product and his services are (or at least used to be) free. I suggest you read up on room acoustics a bit before purchasing or building panels.
Regarding screen size, I started with a 106" diag from 11ft. then a 126" and now have a 138' diag screen from the 11' front row viewing distance. I was happy with the 126" but needed the additional width of the 138" for the 215RT speakers. I have watched several movies on the 138" and have no problems with that size. My wife didn't even notice the difference but then she is pretty much oblivious to anything I do in the HT room. Very supportive, but oblivious ... It doesn't get any better than that! tongue.gifwink.gif
Dbuudo07 and L0nestar like this.
Anxiety is contagious, please keep yours to yourself.
RMK! is offline
post #16913 of 37682 Old 03-05-2014, 06:57 AM
Diesel 48's Avatar
Quoted: 71 Post(s)
Liked: 33
What projector are you using? Plenty bright?
Diesel 48 is offline
post #16914 of 37682 Old 03-05-2014, 07:12 AM
L0nestar's Avatar
Quoted: 18 Post(s)
I'm using an epson 5030ub. Its a great projector.
L0nestar is offline
post #16915 of 37682 Old 03-05-2014, 07:19 AM
RMK!'s Avatar
Liked: 1621
I have a Sony VPL-HW50ES and by the Projector Central calculator I am fine in a light controlled room. I have the throw distance right, run it in high power mode and it looks very good to me. smile.gif
I had a $10K projector once and feel I get an as good, if not better image from the Sony. The 3D isn't quite up to my brightness level preference but I don't watch much 3D. Apparently the format is loosing it's draw anyway now that 4K mania is gaining momentum. smile.gif
Video is too technologically volatile. I prefer to put my money in speakers and amps. cool.gif
RMK! is offline
post #16916 of 37682 Old 03-05-2014, 07:25 AM
Diesel 48's Avatar
Quoted: 71 Post(s)
Liked: 33
I have a Sony VPL-HW50ES and by the Projector Central calculator I am fine in a light controlled room. I have the throw distance right, run it in high power mode and it looks very good to me. smile.gif)
Do you have a scope screen or 16:9? How far away is the projector from the screen? I have a bit before doing so but the wish is to have a scope screen that is 130" wide or potentially larger.
post #16917 of 37682 Old 03-05-2014, 07:26 AM
asoofi1's Avatar
Quoted: 934 Post(s)
Liked: 442
Great projector. Just verify the throw, zoom, and focus on the largest image you can get from placement distance. This is 16:9 so maximize the size because 2.35-2.40 will be relatively smaller anyway.
asoofi1 is offline
post #16918 of 37682 Old 03-05-2014, 08:06 AM
RMK!'s Avatar
Liked: 1621
It's a 16:9 and the projector is a little close now (14') as I had to move the screen 1' farther off of the front wall to accommodate the new speakers. That shortened my viewing distance from 12.5' to 11.5' and the throw from 15' to 14'. It seems to work but I am debating moving the projector back 2' to get to the recommended throw. It means an hour (at least) of attic time that I don't look forward to. smile.gif
RMK! is offline
post #16919 of 37682 Old 03-05-2014, 08:51 AM
HTPCat's Avatar
Quoted: 623 Post(s)
Liked: 357
I have seen this picture on Jeff's FB site - looks awesome. I am in the early stages of designing my frontstage and would love to know more about this specific build - is there a build thread? I am going with a Seymour AV Center Stage XD AT 16 X 9 Screen (thanks RMK!) (126" diagonal 110" width) on a 14' wall. I have JTR T12s LCR that will go behind the screen and perhaps both of my Seaton HP subs. Only one corner as the left side is open (with draw curtains planned for light control). I can tear down the current wall and rebuild as it is not load bearing or just build out 20" or so. I will be sitting about 12' at MLP. No treatments yet, but would like to add some to the front perhaps just like this picture and then add some corner bass traps and small number of wall treatments to side and back.
HTPCat
"I have a need to feed the hole with more Audio & Video toys"
HTPCat is online now
post #16920 of 37682 Old 03-05-2014, 09:40 AM
jbrown15's Avatar
Liked: 1995
LOL.... that sounds exactly like my wife! She still hasn't even noticed that I bought a Sherbourn PA 7-350 amp. Hell I've been buying a new dirt bike every other year trading in the old one for like the past 6 years and my wife still hasn't noticed because I stayed with the same brand and color!..lol
jbrown15 is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
