Official JTR speaker thread - Page 567 - AVS Forum | Home Theater Discussions And Reviews
 7786Likes
Old 03-05-2014, 11:04 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
Originally Posted by Archaea View Post
swolephile,
You are officially invited to the next amp blind testing in KC. (we need a redux of our first attempt - compliments of Audyssey engaging after a power cycle foiling our meet's attempt) Or if that's too far - I think Gorilla83 plans to do a meet of the same kind in the future on the east coast.
The Yorkville Unity line is also exceptionally sensitive and I'd expect no detectable difference.
Which amp and which AVR did you compare?
I suspect 1 of 3 things. Either your AVR wasn't matched to the impedance load properly, your AVR had a shortcoming of some sort, or you are listening at well above reference volumes to make a claim like this. There are multiple enthusiasts who have powered their hyper sensitive speakers off an AVR and compared to amps and come away shaking their heads at any kind of typical listening volumes up to reference. MKTheater, popalock (Denon AVR vs. Clone), n8dogg, and the KC crew (quite a few different AVRs and amps compared), including carp and I, being some seasoned folk who have played around with amp vs. avr and found no audible differences at typical (less than reference) listening volumes with high quality sensitive speakers.
I should just not respond, because I'm surely not going to change anyone's opinion until they experience it themselves --- so what's the point.
Only that a sweeping statement like it's painfully obvious to see the difference between a competent AVR and a quality amp violates real world realtime testing with quick switching ability that some of us have participated in and relies instead of audio memory, which is often notoriously poor.
I really appreciate the invite and will really try to make it if I can. It would be great to meet all of you guys. It's been hard to keep up with the thread and posts because I have totally torn my theater down and am replacing the ceiling with DD+GG on hat channel and clips (its a lot of work with variable ceiling heights) I did get some good news today though, I bought the real LG10K today off ebay and ordered my third OS and piano black slant 8's for surrounds Once I finish the theater we could consider doing the A/B test here too. I should be able to drive everything quite hard because I added two more 20 amp lines too!. BTW I don't think at reference indoors I would be able to tell the difference either.
lbrown105 is offline
Old 03-05-2014, 11:18 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Originally Posted by Swolephile View Post
Never said there was such a thing? But im talking all channels driven, not just bulk of power to mains with the reserves with reduced power to surrounds due to multiple channels sharing one power supply. For what the Sherbourne puts out I consider it receiver territory. Limited dynamics. Will get you to reference with many simpler systems. Not enough power to get multiple high power handling speakers to their full potential.
And audibly, they sound the same as a receiver to me but less clipping.
I'm still not aware of any receiver that even comes close to over 500watts @ 4ohms all channels driven.
So are you planning on taking Archaea up on his offer to go to his amp GTG?
jbrown15 is offline
Old 03-05-2014, 11:29 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
Once again, I'm not saying there is a 500 watt a channel receiver available. I'm merely saying I've never heard any audible differences between any receiver and a 300 watt per channel, multichannel amp.
As for Archaea's offer, I would only go if there is some equipment there. Ive been there, done that with comparing receivers, low wattage amps,power supply limited multichannel amp, and double blind listening tests including quick two min switching between receivers and low/average watt amps on a two channel system.
That is not going to present to me anything I have not already heard firsthand. I need to see a five or seven channel system with multiple Noesis, Danley Sh 50's, Yorkville Unities, JBL Pro, or the like being all channels driven between avr and clone amp/LG 14k/Peavey IPR 7500 to show me something.
Swolephile is offline
Old 03-06-2014, 12:20 AM
jbrown15's Avatar
Liked: 1993
What's your current setup Swolephile?
jbrown15 is offline
Old 03-06-2014, 06:01 AM
countryWV's Avatar
Quoted: 405 Post(s)
Liked: 579
The A/B switching challenge can only prove if one the amp/avrs are broken. Amps are designed to remain neutral with No added color. This design ensures that If all equipment is working properly a difference cannot be heard. If there is an obvious audible difference then something is wrong with that amp or it was purpose built with the intention to sound different.. Only when the amp/avr runs out of headroom and clipping occurs can differences be revealed.
This type of challenge has to be under clipping conditions. Clipping cause distortion = distortion causes harsh sound = harsh sound causes listing fatigue. Distortion also leads to a difference in the quality of the sound being reproduced. If someone is looking for the amp or avr to make a sound other then original reproduction it would no longer be considered neutral without color.
You also need a high wattage multichannel amp. 2 channel is too Easy for an avr. 7 channels is another animal entirely.
An A/B switching challenge is the wrong method to try to prove the theory: An amp vs AVR makes no difference in SQ.
Not hearing or detecting a difference is not the same as No Difference.
Archaea
I challenge you to a coin toss. Heads I win Tails you lose. smile.gif I know Shenanigans right? biggrin.gif
As long as the power source, be it avr or amp, maintains adequate headroom there will be no differences. Only when the power source fails to maintain adequate headroom can the SQ be affected. The more channels driven the harder it will be to maintain this headroom.
I noticed the general tones of posts about this theory are turning from "live let live" into "My way or the Highway attitudes". I think we all would love to have an agreeable valid testing method to prove this theory with an unbiased result.
Chris
Chris
countryWV is online now
Old 03-06-2014, 06:52 AM
Gooddoc's Avatar
Quoted: 2688 Post(s)
Liked: 1854
Country, the problem is that designing a test for listening fatigue may not be possible. The question is two-fold. How much distortion must be present before it's detectable in a A/B switch test and how long does it take for any given level of undetectable distortion to lead to listening fatigue? The answer is probably variable depending on the individual, but we know that every speaker has increasing products of distortion as volume increases, yet we don't "hear it" consciously. But it is heard subconsciously by the brain, it's simply filtered. Tube amps have higher distortion, yet many say they sound better to them than solid state amps.
A couple of links below regarding distortion and detectability that are interesting.
http://www.silcom.com/~aludwig/EARS.htm#Distortion
http://www.silcom.com/~aludwig/Amplifier_distortion.htm
"Everest quotes research indicating that amplitude distortion has to reach a level of 3% to be audible. However this varies greatly depending on the distortion harmonic products, and on the sound source."
"My audibility threshold for clipping occurs at an output level around 5-10% of maximum output power, where roughly 1% of the digital samples are clipped."
"THD lumps together all of the harmonics, but in reality some harmonics sound a lot worse than others."
"So far I have mainly tested myself on one short music segment, the Vivaldi sample. Based on this, my detection threshold is close to a value of alpha = 0.3 for the SS case, where 1% of the samples are clipped, and I am 90% accurate in selecting the distorted file. This corresponds to an average power output equal to 9% of the maximum power output. Further testing can only result in a lower threshold. I am guessing that if I run my amps at 5% of their rated power that clipping will not be audible."
"Amplifiers are rated based on average power. It is not unusual for me to play music on my system (quite loud) at 10 Watts average power (based on an eyeball estimate from an oscilloscope display of the voltage at the speaker terminals). One of the music samples used here played at an average power of 10 Watts would require a peak power of over 800 Watts! Clipping is not at all uncommon."
Edit: For any good A/B test, IMO, the listeners have to be trained to identify signal distortion using sound files with deliberate increasing levels of quantifiable and known distortion levels. Once trained I suspect the sensitivity of the test will rise dramatically. Files to achieve this are in my links. (Sorry, links to .wav files broken). Also, added one more quote above
countryWV likes this.
Gooddoc is offline
Old 03-06-2014, 08:01 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
Yesterday I had a dear friend over for a visit. We don't see each other often, so had some catching up to do on what had been going on the last 6 months.
Besides the obvious presence of the Noesis' and Captivators, I told him that I had spent al lot of time with music and movies.
More so than ever before.
After an elaborate intro on Jeff and JTRs , and some on the rest of my gear, the first track was playing and after 20 seconds or so he just nodded and said : "I understand".biggrin.gif
staaled is offline
Old 03-06-2014, 08:15 AM
Gooddoc's Avatar
Liked: 1854
Ha, that's funny!
Similar story. I had a guy over my house for some business stuff. We ended up listening to music before he left. A couple of days later we were in a meeting and someone asked him what we had discussed and he said he really didn't remember much, all he could remember were the speakers and music. biggrin.gif
Gooddoc is offline
Old 03-06-2014, 08:20 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
Originally Posted by Gooddoc View Post
Country, the problem is that designing a test for llistening fatigue may not be possible. The question is two-fold. How much distortion must be present before it's detectable in a A/B switch test and how long does it take for any given level of undetectable distortion to lead to listening fatigue? The answer is probably variable depending on the individual, but we know that every speaker has increasing products of distortion as volume increases, yet we don't "hear it" consciously. But it is heard subconsciously by the brain, it's simply filtered. Tube amps have higher distortion, yet many say they sound better to them than solid state amps.
I agree with your post entirely. I dont think you will hear any major differences between two amps running within their specs. However when the juice starts flowing an avr will not have the goods to push seven high power handling speakers past reference and sound good doing so while a good set of external amos will just keep chugging along.
That is the point I was trying to make.
Old 03-06-2014, 08:22 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
Two Yorkville U215's and seven Yorkville U15's.
RMK!'s Avatar
Quoted: 1600 Post(s)
Liked: 1472
I understand completely cool.gif.
These speakers continue to amaze me. I've been playing with the LG FP10000q amp and was listening to Lyle Lovett's Joshua Judges Ruth CD last night with just the Triple 8LP's horizontal, run full range behind the AT screen. It's a very well recorded disk and the clarity and detail was as good as I have heard in the room. The bass and drum hits on "She's already made up her mind" were fantastic. I don't know if it was the amp or just the fact that I am missing having the system (going on two months now) but the Triple 8LP's were playing way above their weight class. They can't do the volume that the larger 12" JTR's can but within their range, they are really good. I was playing them up to -8 or -9 ref and they were just pure ... smile.gif
BTW, I think this amp talk thing is just about played out rolleyes.gif. Let's discuss expensive cables and power cords next. tongue.gif
Opinions are not facts.
RMK! is offline
Old 03-06-2014, 08:42 AM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
You may have missed my post to you...So which Noesis did you say you had tested and what are the details on how you tested?
asoofi1 is offline
Old 03-06-2014, 09:02 AM
Gooddoc's Avatar
Liked: 1854
Originally Posted by RMK! View Post
I've been playing with the LG FP10000q amp...I don't know if it was the amp or just the fact that I am missing having the system (going on two months now) but the Triple 8LP's were playing way above their weight class.
Gooddoc is offline
Old 03-06-2014, 09:13 AM
Point Source
beastaudio's Avatar
Quoted: 3518 Post(s)
Liked: 2835
I certainly hope you aren't talking about the Sherbourn 7-350... If so, that is total hogwash. 550 watts all channels driven at 4 ohm. Close to 1,000 watts per channel in stereo mode at 4 ohm. That is no slouch, and FAR from AVR power. I would say my system is far from "Simple" and it destroys any type of content I run through it. I honestly don't think I need all the juice, but it was a nice deal so I jumped on it.
The next part, limited dynamics, I have no idea how you would quantify that.... vs. what? 2000 wpc?
The last thing, I don't know if you are talking about running high power sine waves here or what, but there is no content that i am aware of, if even out there, that is going to require peak play from every channel at the exact same time. If there is, it's certainly a very short burst of power and not sustained. The closest one might get is to be running All channel stereo or something, at which point the summing of all the speakers is going to make the system that much more efficient, and louder at lower power consumption. I know what you have in the Yorks, and they can take a load of wattage, but way less than you think they need, for HT use I promise. I obviously have plenty of power on tap as well, but any more than what I have now would be silly. Heck, I could even downsize IMO.
I am all for those that want to match power specs to their mains, fine. You know you have exactly what your speakers needs for 133dB in the Noesis, no questions. But to pair a close to 4kw amp with "receiver power" is simply ignorant.
asoofi1 likes this.
beastaudio is online now
Old 03-06-2014, 09:40 AM
RMK!'s Avatar
Liked: 1472
I was, my propagandizing was much more subtle and showed great tact …don't you think? tongue.gifwink.gif
RMK! is offline
Old 03-06-2014, 09:43 AM
desertdome's Avatar
Quoted: 1122 Post(s)
Liked: 1226
If the iNuke 3000 puts out a conservative 500 watts per channel to the four ohm 212ht, then an amp capable of putting out 2000 watts per channel would put out 6 more dB and max out the power rating on the 212ht.
The rule of thumb in pro audio is to have at least 2x the amplifier power than the RMS handling of the speaker. You can have up to 2.5x the RMS level depending on the crest factor of your content. Peavey, JBL, and others make this 2x recommendation for their speakers. This means you can easily use at least 4000 2000 watts per channel with the 212HT. The testing of the iNuke nu6000 shows it produces 2000 watts peak at 4 ohms. Its continuous power rating is around 1~1.2kW per channel at 4 ohms. You can use a lot more amplifier than the nu6000 on the 212HTs since it is rated at .5X the speaker's power handling. cool.gif
Edit: Actually, the JTR speakers are already rated at the max power handling for continuous amp output.
Besides thermal limits, there are also physical limits on drivers. For example, the Neo 8 planar transducer in my LS-6 speakers is rated at 50 watts RMS/150 watts peak. This means it can handle 3x its RMS rating for peaks. I have 6 of these per speaker for a maximum power handling of 900 watts. The 6 1/2" drivers can handle 100 watts RMS and 200 watts peak. I have 8 of these per speaker for a 1600 watt peak. Maximum RMS for my speaker is 1100 watts with peak level handling of 2500 watts per speaker! So, if I go 2x RMS I can still safely use an amp with 2200 watts per channel at 8 ohms. Hmm, I'm severely under-powered with my measly 400 watts. biggrin.gif
Originally Posted by Crown Audio
How much power can my speakers handle?
You can determine this by looking at the speaker's data sheet. Look for the Nominal Impedance spec. Typically it will be 2, 4, 8 or 16 ohms. Next, look for the loudspeaker specification called Continuous Power Handling or Continuous Power Rating. It might be called IEC rating or Power capacity.
If you can prevent the power amp from clipping (by using a limiter), use a power amp that supplies 2 to 4 times the speakers continuous power rating per channel. This allows 3 to 6 dB of headroom for peaks in the audio signal. Speakers are built to handle those short-term peaks. If you cant keep the power amp from clipping (say, you have no limiter and the system is overdriven or goes into feedback) the amplifier power should equal the speakers continuous power rating. That way the speaker wont be damaged if the amp clips by overdriving its input. In this case there is no headroom for peaks, so you'll have to drive the speaker at less than its full rated power if you want to avoid distortion.
If you are mainly doing light dance music or voice, we recommend that the amplifier power be 1.6 times the Continuous Power rating per channel. If you are doing heavy metal/grunge, try 2.5 times the Continuous Power rating per channel. The amplifier power must be rated for the impedance of the loudspeaker (2, 4, 8 or 16 ohms).
Here's an example. Suppose the impedance of your speaker is 4 ohms, and its Continuous Power Handling is 100 W. If you are playing light dance music, the amplifier's 4-ohm power should be 1.6 x 100 W or 160 W continuous per channel. To handle heavy metal/grunge, the amplifier's 4-ohm power should be 2.5 x 100 W or 250 W continuous per channel.
If you use much more power, you are likely to damage the speaker by forcing the speaker cone to its limits. If you use much less power, you'll probably turn up the amp until it clips, trying to make the speaker loud enough. Clipping can damage speakers due to overheating. So stay with 1.6 to 2.5 times the speaker's continuous power rating.
High Impact AV
desertdome is online now
Old 03-06-2014, 09:49 AM
Scrappydue's Avatar
Quoted: 230 Post(s)
Liked: 196
Do u have two Noesis 212's and five single 8's or triple 8's?
LOL
Scrappydue is offline
Old 03-06-2014, 09:57 AM
Decadent_Spectre's Avatar
Quoted: 322 Post(s)
Liked: 144
Originally Posted by desertdome View Post
The rule of thumb in pro audio is to have at least 2x the amplifier power than the RMS handling of the speaker. You can have up to 2.5x the RMS level depending on the crest factor of your content. Peavey, JBL, and others make this 2x recommendation for their speakers. This means you can easily use at least 4000 watts per channel with the 212HT. The testing of the iNuke nu6000 shows it produces 2000 watts peak at 4 ohms. Its continuous power rating is around 1~1.2kW per channel at 4 ohms. You can use a lot more amplifier than the nu6000 on the 212HTs since it is rated at .5X the speaker's power handling. cool.gif
I think the JTRs already list a 2x power spec since Jeff specifies program. If you will notice he specs the OS Pro for 4000W and I have not heard of a driver with a 4000W AES rating. The power spec could be understood better if someone knows what drivers are used in the 212s. Even the IPAL21 lists a 2500W AES rating.
Decadent_Spectre is offline
Old 03-06-2014, 09:58 AM
Gooddoc's Avatar
Liked: 1854
Gooddoc is offline
Old 03-06-2014, 10:05 AM
RMK!'s Avatar
Liked: 1472
RMK! is offline
Old 03-06-2014, 10:11 AM
desertdome's Avatar
Liked: 1226
Yes, you are right. I'll edit my post.
High Impact AV
Old 03-06-2014, 10:15 AM
Gooddoc's Avatar
Liked: 1854
Yea, in the current political environment that was probably below the belt, even in jest. biggrin.gif
Gooddoc is offline
Old 03-06-2014, 10:22 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
Im talking about all channels driven without a crossover. I could care less about two channel playback. I listen to all channel stereo often without a sub and crossover at night. And in this type of use I could not distinguish between a receiver running my speakers or the Sherbourn, nor my old Outlaw 200 x 7 amp.
Now Im not saying they are the same. I merely said I could hear no differences between them up till clipping. And my speakers lacked bass with all three without a sub when listening to music. Without a sub the crown amps, lg amps, Peavey 7500, and Inuke 6000 sound good with no need for a sub.
Now for those using high crossovers, who dont use multiple speakers for music, mainly ht guys, and using the typical mains plus surrounds concept what Im looking for is none of their concern and they probably dont need it.
Old 03-06-2014, 10:49 AM
Point Source
beastaudio's Avatar
Liked: 2835
I have a peavey 7500 as well. Perhaps I will do a little switcheroo and see if I come up with the same consensus....Just for fun
Old 03-06-2014, 10:51 AM
Luke Kamp's Avatar
Quoted: 150 Post(s)
Liked: 201
I thought all channel stereo with music wasn't as hard on the amps as continuous sine wave testing?
http://www.avsforum.com/t/1481388/amplifier-power-output-rms-vs-peak-as-it-applies-to-home-theater-soundtracks#post_23532594
I imagine anyone using the current JTR's is crossing them over, since they are designed to be crossed to subwoofers. Is anyone else here using their system all channel stereo with speakers large? If not who are you discussing this with? Do you have anything objective to add? Any links to your extensive studies and tests, "comparing receivers, low wattage amps,power supply limited multichannel amp, and double blind listening tests including quick two min switching between receivers and low/average watt amps on a two channel system."?
Using a car analogy here is flawed as usual. It would be more like a receiver is a vette that morphs into a honda at 160mph, and a big power amp stays a vette to the max.
This isn't pro audio, you need the power that is needed for the room and desired playback levels. I do agree with Brandon that, "I am all for those that want to match power specs to their mains, fine. You know you have exactly what your speakers needs for 133dB in the Noesis, no questions."
There was a FOH shootout I found on the JTR thread a while back.
-Each person introduced their rig. Then we played the same CD track through the rig for a minute or so at approx 100DB. There was a SMAART rig there with a mic placed midway in the room and we used that for a DB meter.
-The Irving is an old movie house. The room is a 40' wide x 100' deep with a 16-20' ceiling (open rafters to the underside of a pitched roof). Floor is concrete. There is a stage at the front. A 30' x 40' flat area is in front of the stage and then the floor has a gentle slope up to the entrance area.
http://forums.prosoundweb.com/index.php/topic,140751.0.html
Seems to me you could get by with less power in a bit smaller space.
Luke Kamp is offline
Old 03-06-2014, 11:49 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
Most people do not use all channel stereo for music. Most people dont believe in using matching towers all around the room. I was merely stating these are things important to me as an answer as to if I would attend a dbt gtg at Archaeas home.
If it is the same old stuff with two channel listening and lower watt equipment then I would not be interested and I was explaining why.
Old 03-06-2014, 11:56 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
Sounds good. And I apologize if my earlier post came across as crass or rude. I do face to face audits all days so I have to run and make these posts on my phone in between appts. Im a super nice guy but my posts come across as offensive sometimes because Im always intensely rushing when I post.
What I mean to say earlier is that I personally not experience the dynamics with a receiver or multichannel in the 300 watt range like what I have experienced with say a IPR 7500 when using my speakers without a crossover, no sub, and all at the same time with music.
That is not to downtalk any receiver or the Sherbourn in any way. I know the Sherbourne is a great amp for its price. However I cant deny what I perceived to be a lack of bass with all of my setups with multichannel amps and receivers under 500 watts @ 8 ohms when running my speakers with no crossover and no sub.
Old 03-06-2014, 11:59 AM
Luke Kamp's Avatar
Quoted: 150 Post(s)
Liked: 201
Well it seems like most people would not be interested in your type of gtg then. Getting all stereo rigs like you propose would be difficult as would be the setup. Double blind testing those types of rigs seems difficult. It seems very difficult and not much fun so that kind of a meet will most likely not take place.
Old 03-06-2014, 12:03 PM
Diesel 48's Avatar
Quoted: 71 Post(s)
Liked: 33
How is the vertical off axis response of the 212's or 228's? Planning out my stage now and If I stack the 212's on my sub woofer the center of the horn will be at 56". Is this two high? I will have two rows of seating. The first row will probably be 12-13' back from the screen. I know best practice is ear height but that may not be possible.
Diesel 48 is offline
Old 03-06-2014, 12:06 PM
Point Source
beastaudio's Avatar
Liked: 2835
What I mean to say earlier is that I personally not experience the dynamics with a receiver or multichannel in the 300 watt range like what I have experienced with say a IPR 7500 when using my speakers withour a crossover, no sub, and all at the same time with music.
That is not to downtalk any receiver or the Sherbourn in any way. I know the Sherbourne is a great amp for its price. However I cant deny what I perceived to be a lack of bass with all of my setups with multichannel amps and receivers under 500 watts @ 8 ohms when running my speakers with no crossover and no sub. Now for speakers designed with a high crossover, always used with a sub, and mainly for HT, will not need what look for.
Understandable. and no problems here smile.gif It still does make me curious as I do often listen full range to my Danley's at night, and at decent levels as well. I get plenty of impact from them with the Sherbourn already and at blistering levels. The 50's and your Yorks have a similar rolloff on the low end IIRC, so I am still vexed as to what you were missing. the mere difference might very well come down to me listening stereo and you all channel stereo....which I also never do.
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
