Official JTR speaker thread - Page 568 - AVS Forum | Home Theater Discussions And Reviews
 7773Likes
Old 03-06-2014, 01:07 PM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
Originally Posted by Swolephile View Post
Most people do not use all channel stereo for music. Most people dont believe in using matching towers all around the room. I was merely stating these are things important to me as an answer as to if I would attend a dbt gtg at Archaeas home.
If it is the same old stuff with two channel listening and lower watt equipment then I would not be interested and I was explaining why.
So your entire AVRs vs Amps argument was based on 5-7 full range setup that 99.9% of ppl don't even have or care to...and you actually have never tested 5 or 7 Noesis as you said you had?...even though noesis arent even designed for full range (minus the unreleased 215rt)?
Archaea likes this.
asoofi1 is offline
Old 03-06-2014, 01:46 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
Asim,
He has similar sensitivity speakers in his U215 Yorkvilles, with a similar low-end roll off as the Noesis (slightly lower actually at 45hz), so that isn't too far off.
beastaudio is offline
Old 03-06-2014, 01:57 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
I convinced my friend who is a pro DJ to purchase seven JTR Noesis for his new rig which we ran thorugh the gambit for a couple of weekend. My point is no avr can run seven high power handling speakers such as Jtr 212 or 215 to their potential. Now to fully understand my point you have to listen to speakers such seven ajtr 212s placed around a mid sized room as Fronts sides and rears. Im sorry but placing eights and six inch woofers as surrounds will not duplicate this experience.
But most guys in the home market consider a 212 or 215 as a ''main'' speaker then pair it to a smaller design they consider a ''surround''. However no where are these speakers labeled as such.
If you were to hear seven matching flagship speakers on a avr vs a couple of LG 10ks you would quickly see the shortcomings of an avr in a surround music or all channels driven environment.
And as beast stated my current setup is comparable, though the Noesis are better all around as they should be with the advances in new tech and higher price range.
Swolephile is offline
Old 03-06-2014, 02:07 PM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
Originally Posted by countryWV View Post
Archaea
I challenge you to a coin toss. Heads I win Tails you lose. smile.gif I know Shenanigans right? biggrin.gif
Word on the street is that Archaea has been practicing other forms of dispute resolution...
Edit: Fu#&ing Phone!
Archaea and countryWV like this.
popalock is offline
Old 03-06-2014, 02:40 PM
RMK!'s Avatar
Quoted: 1599 Post(s)
Liked: 1465
Originally Posted by Diesel 48 View Post
How is the vertical off axis response of the 212's or 228's? Planning out my stage now and If I stack the 212's on my sub woofer the center of the horn will be at 56". Is this two high? I will have two rows of seating. The first row will probably be 12-13' back from the screen. I know best practice is ear height but that may not be possible.
That is a good question and the only way you will know if it works for you is to try it. I found I liked the horn center right on my nose (vertically speaking smile.gif ). My 212 mains and center were on top of Orbit Shifters but I didn't have a stage so I guessing mine were a bit lower than yours would be. Angling the speakers down slightly for the front row is probably the answer but again, try it and see what you like.
Both the 212 and 228's use a 60/40 (H/V) horn. Below is the horizontal dispersion pattern of the Noesis 212.
Opinions are not facts.
RMK! is online now
Old 03-06-2014, 02:51 PM
yamahabadoo's Avatar
Two Yorkville U215's and seven Yorkville U15's.
Wow!!!
As they say "pics or it didn't happen"! :)
yamahabadoo is offline
Old 03-06-2014, 02:52 PM
dlbeck's Avatar
Quoted: 488 Post(s)
Liked: 557
Diesel - not sure if this would help but I took some off axis measurements. See post #302 here : http://www.avsforum.com/t/1498786/the-savoy/300
dlbeck is offline
Old 03-06-2014, 03:03 PM
PillPu$her's Avatar
Hi. Is there anyone in the Dallas/Plano area who has a home theatre setup using Noesis 228HTs that I can come and listen to? Please PM me. Thanks.
PillPu$her is offline
Old 03-06-2014, 03:20 PM
J
J's Avatar
Quoted: 14 Post(s)
Liked: 35
Originally Posted by lbrown105 View Post
I really appreciate the invite and will really try to make it if I can. It would be great to meet all of you guys. It's been hard to keep up with the thread and posts because I have totally torn my theater down and am replacing the ceiling with DD+GG on hat channel and clips (its a lot of work with variable ceiling heights) I did get some good news today though, I bought the real LG10K today off ebay and ordered my third OS and piano black slant 8's for surrounds Once I finish the theater we could consider doing the A/B test here too. I should be able to drive everything quite hard because I added two more 20 amp lines too!. BTW I don't think at reference indoors I would be able to tell the difference either.
Samsung 55 inch lcd Marantz sr5400
Parasound HCA 1500 Parasound HCA 1000
JTR OS LFU (2013)
JTR OS LFU (2016)
Paradigm studio 40's -fronts Paradigm CC Paradigm atoms -rear
J is offline
Old 03-06-2014, 03:33 PM
Archaea's Avatar
Quoted: 2842 Post(s)
Liked: 2421
Archaea
Word on the street is that Archaea has need practicing other forms of dispute resolution...
I bought that machine, but broke it last week. Cheap chinese junk. Only rated for 600lbs. The metal just doesn't hold up to ~400 reps at max weight every three hours. For the last few nights I've had my wife put the Dodge Ram 1500 up against me with a tow chain. She throws it in 4 low and I've been getting better at holding the tow chain taut for a few seconds longer every time. You should see the ruts in our yard. Last night my wife rolled over and said honey we are gonna need a bigger truck.
Whens our next face off. Better have the doc prefabricate you a nice cast so I'll have a chance to sign it in advance.
popalock and countryWV like this.
Archaea is online now
Old 03-06-2014, 03:35 PM
Point Source
beastaudio's Avatar
Liked: 2826
OOOOOOOOOO SNAP!!!! Literally
Old 03-06-2014, 03:37 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
Lol. Archea is a big man. Gotta find a more peaceful option for conflict resolution with him.smile.gif
Old 03-06-2014, 03:38 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Originally Posted by Archaea View Post
I bought that machine, but broke it last week. Cheap chinese junk. Only rated for 600lbs. The metal just doesn't hold up to ~400 reps at max weight every three hours. For the last few nights I've had my wife put the Dodge Ram 1500 up against me with a tow chain. She throws it in 4 low and I've been getting better at holding the tow chain taught for a few seconds longer every time. You should see the ruts in our yard. Last night my wife rolled over and said honey we are gonna need a bigger truck.
jbrown15 is offline
Old 03-06-2014, 03:40 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
Originally Posted by J View Post
one of the best parts of the basement theater is you can hardly here it outside even at +17dBfr. Just a low rumble and funny earthquake feeling in the ground next to the house. We have had parties till 3 in the morning and played this loud, no cops ever. The neighbores are about 100-200 f away though. Once the ceiling is done maybe even less sound outside. If you want to come back and check it out when I am finished let me know. I may have another GTG, would be fun, more milk this time:rolleyes:.
lbrown105 is offline
Old 03-06-2014, 04:22 PM
Gooddoc's Avatar
Quoted: 2672 Post(s)
Liked: 1845
Good to see you reaching out. Give it some time if you haven't heard from anyone. I think I recall someone from your area, can't remember who it is though.
To all, Pillpusher is trying to decide on speakers for a dedicated theater AT screen setup and has only had the opportunity to listen to box store paradigm's, B&W's, and others. I pointed him over here after recommending JTR 228's.
Perhaps some that made a switch to 228's from similar models could chime in with their impressions after they switched.
Gooddoc is offline
Old 03-06-2014, 04:33 PM
DreamWarrior's Avatar
Quoted: 323 Post(s)
Liked: 239
I didn't end up switching to the JTR's, but I've heard them at Gooddoc's place and they'll handily beat similarly priced Paradigms. I loved my Digms, but they really don't have the impact that JTRs do. But, it depends on your tastes, like everything. If you're a bigger movie than music guy, then it's an even easier swing to go over to the JTRs. Music, I find, people have much different opinions about what makes a good speaker. But, certainly, the JTR Noesis are excellent music performers as well, IMO.
DreamWarrior is online now
Old 03-06-2014, 04:41 PM
RMK!'s Avatar
Liked: 1465
AVS member KevinH is in Austin. He has Noesis 3TX LCR's and Orbit Shifter subs. That would make for an interesting demo if you are ever in the Capital City. smile.gif
Gooddoc likes this.
RMK! is online now
Old 03-06-2014, 04:45 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Hey, did you guys know that there is actually an arm wrestling reality show now? tongue.gif
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
Old 03-06-2014, 04:46 PM
popalock's Avatar
Liked: 1712
popalock is offline
Old 03-06-2014, 04:47 PM
Quoted: 978 Post(s)
Liked: 506
Ok...so you know already. My wife of all people showed it to me.
Old 03-06-2014, 05:13 PM
Gooddoc's Avatar
Liked: 1845
Hey Brian,
Long time no talk. How are those Cats? I'd love to hear what you think of them now that you've been living with them for a while.
Gooddoc is offline
Old 03-06-2014, 05:38 PM
PillPu$her's Avatar
Thanks for the recommendation, and thank you Gooddoc for the intro.
Old 03-06-2014, 06:30 PM
Gooddoc's Avatar
Liked: 1845
No problem. I hope you get a chance to listen. There are plenty of posts you'll find where folks upgraded to a design like JTR from speaker designs like you were looking at. But I doubt you'll find anyone that went from designs like JTR to the speaker designs you were looking at - at least anywhere close to your budget. That should tell you something. wink.gifsmile.gif
Gooddoc is offline
Old 03-06-2014, 06:57 PM
Frohlich's Avatar
Quoted: 1164 Post(s)
Liked: 1112
Well, all is back to normal in my HT. I have had the new amps for a week but with it needing attenuators, the system just didn't sound right over the last week. Kind of hard to get excited about new toys when something isn't right with the overall experience. Could never get it dialed in manually. Last night the attenuators came in. Today I ran audyssey and everything was back in range for Audyssey (-12 to +12 db) and the system sounds great again. First thing I did was put in the Tim Reynolds and Dave Matthews blu ray concert and man did my smile come back. That blu ray concert is the best recording I have ever heard in a blu ray concert (I own about 20). Then just now watched Gravity with the family. The soundtrack was much more active then I would have imagined and again my smile was back. Gonna try and not tinker with things for a while and just enjoy status quo.
Frohlich is offline
Old 03-06-2014, 07:17 PM
J
J's Avatar
Quoted: 14 Post(s)
Liked: 35
Let me know when you have another GTG . I would have had a good beverage but was getting over a bad cold and I thought if I had one or two , I would not have wanted to leave smile.gif
I think your new ceiling will be a huge improvement . That and powering your system with a real amp and not a weak receiver. cool.gif
JTR OS LFU (2013)
JTR OS LFU (2016)
J is offline
Old 03-06-2014, 08:26 PM
Quoted: 323 Post(s)
Liked: 239
Hey Brian,
My room still is not worthy of them. My brother comes home from school this weekend and I think I'm going to enlist him to help me get these things onto furniture sliders and help me measure and push 'em around. Right now they are still directed straight at me with no toe and nowhere near the ideal "golden ratio". I just plopped them where the old ones were because it was easiest and didn't require me moving around other furniture. They sound great, but I am pretty sure once I get them toed well (and thusly get some of the residual energy off my untreated side walls) they'll sound even better. Either way, they are a crazy improvement over my old Digms, adding impact and authority to music at levels those poor things would never achieve without letting out the ghost, lol.
You'll have to stop by some day to take a listen!
P.S. When you getting those treatments tongue.gif...though, I should shut my mouth since I need them, too, haha.
edit: oh, and some stupid/funny -- I still can't get past my old habits of wondering whether or not I've broken something. Last weekend I had the Metallica Through The Never soundtrack on, LOUD, like +8 for some songs. Then, I'd turn it back down to reference, and wonder "OMG, I hope I didn't hurt something." Usually it was because it seems on that disc much of the cymbals are mixed heavily to the right side of the soundstage, so I'd think, "wait, was all the high frequency content coming from that speaker all along, oh no, did I blow the left tweater, ahhhhhh!". Cuz, at +8, I'm sure my poor old digms would've smoked a tweater (and maybe a mid, too) and I keep thinking I'm going to hurt these things. But, I go behind them, switch off all the amplifiers, and turn on each in succession to make sure all drivers are there and working, and they are...no harm done, lol. Paranoid, much....eventually I'll get over it, I suppose, haha.
Old 03-06-2014, 08:37 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
you should have stayed. A few of us stayed and had quite a few beers while listening to music after the movie was over. I am hoping for something in May and I will definitely let you know.
Old 03-07-2014, 05:32 AM
Gooddoc's Avatar
Liked: 1845
Ha! I don't think you have anything to worry about and I'm not sure it's even possible to blow those drivers. Mark Seaton knows the crowd he's designing for and I'm sure he's designed them to take whatever you throw at them. biggrin.gif
As to my treatments, I went and bought a PJ without a game plan for a screen and little did I know that the screen would be such a PITA to figure out....Then I got on a kick to find a new processor....then I started launching my third business and between the three of them I simply don't have the time currently to install and deal with any of those HTC projects. So I'm in a holding pattern until things calm down and I have the time. smile.gif
Gooddoc is offline
Old 03-07-2014, 08:42 AM
RMK!'s Avatar
Liked: 1465
It's been my observation that the Catalyst buyer is different than the "average" JTR buyer. Seaton's demographic is a bit longer of tooth and looking for a more refined sound that only spending more money can deliver tongue.gifwink.gif. Where as the average JTR buyer is a bit younger, more reckless and impulsive and so tends to stomp down hard on the accelerator whenever the mood strikes.
That said, I have some of characteristics of both in that I enjoy a good Cabernet while riding that roller coaster. I actually feel more comfortable with the old geezers who buy Seaton, but I'm also relatively immature and find myself drawn to the darker side of my nature (e.g. Nero's remix of Ghosts N Stuff by Deadmau5 at +15db tongue.gif).
kma100 likes this.
RMK! is online now
Old 03-07-2014, 09:32 AM
kma100's Avatar
Quoted: 43 Post(s)
Liked: 27
kma100 is offline
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
