Official JTR speaker thread - Page 607 - AVS Forum | Home Theater Discussions And Reviews
 7793Likes
Old 04-15-2014, 08:31 AM
logicators's Avatar
Liked: 26
Originally Posted by beastaudio View Post
Solid. So for movies that switch ratios in the middle for IMAX content, like Tron and TDK, I guess you are kind of out of luck for those particular scenes no?
Correct. You can still watch them in 16:9 mode and live with some black bars (or keep switching all the time which gets annoying).
Good thing is that very few movies fall into that category.
logicators is offline
Old 04-15-2014, 08:40 AM
Point Source
beastaudio's Avatar
Quoted: 3542 Post(s)
Liked: 2845
Ok so talk me into 2.35:1. I don't game barely at all anymore, still listen to music 80% of the time, and only watch major sports events in the theater. The majority of viewing time my content is movies, and that is pretty much it. Is it a no-brainer for me?
beastaudio is offline
Old 04-15-2014, 08:45 AM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
Ok so talk me into 2.35:1. I don't game barely at all anymore, still listen to music 80% of the time, and only watch major sports events in the theater. The rest of the time my content is movies, and that is pretty much it. Is it a no-brainer for me?
If TV is your major, I would stick to the 16:9. I will only be using my theater for movies and considering the best ones are shot in 2:40:1 I have made up my mind to go wide.
Speaking of movies. I finally ripped open my copy of Elysium last night and what a LFE treat. The subs were digging deep on this one.
Reefdvr27 is offline
Old 04-15-2014, 08:46 AM
subyguy's Avatar
Liked: 26
How far is your PJ from the screen? I have been toying with the idea of a 4810. I had the RS40 back a few years ago and loved it, but my screen was 110" inches then, and now I am at 138" diagonal with a throw distance of around 18 feet. Think I would be in good shape there?
Honestly I don't remember but will measure when I have a chance. My room is dark with a full black velvet treatment of walls ceiling and floor 6' out from the screen. The pj is as close as I could get and still fill the 150" 16x9 screen. I don't use 3d but the 2d brightness is fine for me on low lamp mode. I had it professionally calibrated and he thought it was on the lower end of brightness but acceptable ... Unfortunately I don't remember how many fl he measured it at.
(3) JTR Noesis 212HT (LCR)
(2) JTR Single 8 (wides)
(2) JTR Slanted 8 (sides)
(2) DIY Eminence 10" coax (rear Surrounds)
(2) JTR Orbit Shifters
(2) Mach5 UXL-18's sealed
(2) Soundsplinter 15's sealed
Speakers powered by 6 crown xls 1500's
UXL's powered by Peavey IPR-7500
My theater:
http://www.avs...
subyguy is offline
Old 04-15-2014, 08:50 AM
Point Source
beastaudio's Avatar
Liked: 2845
I edited my post as it seemed a bit confusing. I really meant the majority of my viewing is Movies and blu ray concert discs. The thought of widescreen also just intrigues me. Perhaps I will start a thread in the screen section to keep from clogging this one up any more than I already have biggrin.gif
Old 04-15-2014, 09:06 AM
Gooddoc's Avatar
Quoted: 2709 Post(s)
Liked: 1878
Yea, really beast, you're the only one around here that clogs up the thread with your off-topic nonsense. Please move it off this laser focused thread immediately.
Gooddoc is online now
Old 04-15-2014, 09:08 AM
logicators's Avatar
Liked: 26
Your usage is pretty much like mine, and a scope screen is a no-brainer smile.gif I switched to it a few months ago and I am not going back.
The vast majority of action and adventure movies are shot in that aspect ratio, where filling the whole screen really matters. 16:9 movies are generally character dramas and you can easily live with a smaller picture.
Old 04-15-2014, 09:24 AM
Gooddoc's Avatar
Liked: 1878
I am stuck with this very same decision. I'm width constrained, so whether I go scope or 16:9 screen dimensions, the size of the scope picture will not change. It just seems like I'm throwing away a lot of 16:9 size for no good reason aside from the bars that really don't bother me much on my plasma now
Signed,
Old 04-15-2014, 10:36 AM
coolgeek's Avatar
Quoted: 616 Post(s)
Liked: 278
Signed,
I am not sure if this applies to you.. but I look at it this way. I want the largest screen possible.
So, for me, i'll see where the limitations is.. is it the height of the place or the width.. i'll go as large as is possible... for instance if you have a very wide room, but your ceiling isn't very high, then go scope.... so, even at scope your screen is from 20 inches above ground all the way up to almost the ceiling... so, when you're watching 16:9 that's the largest 16:9 you could get anyways...
In my case, my width is limited.. so i went with 16:9, which, when watching scope movies, it'll be the 'longest' as well (as if i chose scope to begin with).
I really like the immersive experience, so sitting near, with as large a screen in front of me as possible..
Plus, I believe there will be more and more movies in 16:9 eventually.. like Avatar 16:9 3D is just awesome if you have a screen in 16:9 format wall to wall, floor to ceiling...
coolgeek is offline
Old 04-15-2014, 10:37 AM
coolgeek's Avatar
Quoted: 616 Post(s)
Liked: 278
CG, use www.bobgolds.com to look at absorbtion coefficients for all sorts of materials.
EDIT: The primate beat me to it smile.gif
Originally Posted by dgage View Post
I'm not an expert on acoustics but I would think the less dense material will be more absorbent to more frequencies, but it won't attenuate the deeper frequencies as much unless you use several inches. So if you are going to be at 4 or more inches in the corner then I'd get the S60, thinner than 4" then go for the 80. Also, if you find that your traps might need more than one package of insulation then get both and put the 60 in front to handle more frequencies and the 80 behind to handle the lower frequencies. Hopefully someone more versed can validate or correct my theories.
Thanks guys.. the link will really help me plan...
coolgeek is offline
Old 04-15-2014, 11:11 AM
jlpowell84's Avatar
Quoted: 1620 Post(s)
Liked: 715
Meh, we all know these type of threads are the best and why we come back. Nobody likes self imposed police thread forces!
jlpowell84 is offline
Old 04-15-2014, 11:15 AM
Point Source
beastaudio's Avatar
Liked: 2845
Signed,
Haha. Same thing with me. The screen will be the same width regardless. Maybe I will just wait until Rich can get some of those top/bottom masking panels to turn 16:9 to 2.35:1. That could be the best of both worlds come to think of it. The main reason I began thinking about widescreen format is my second row can't see the bottom of the screen with 16:9 content and I don't want to raise the riser any more than it already is so I am kind of at a standstill.
Old 04-15-2014, 11:24 AM
AlexBPM's Avatar
Originally Posted by jlpowell84 View Post
I will bite on this a bit. I am certainly on the lower end of experience with high end speakers but I feel I have enough experience and listening enough to tell why JTR's are good! Everyone knows JTR's are known for the high sensitivity ratings and ability to play extremely loud! And with minimal power, minus the 215 210 new models. We see this in Archaea's youtube video of powering two 212 Noesis with 1 single watt each at reference level volume. I think some audio snobs turn away from JTR because they assume all they do is play loud and sound decent doing so. Also the looks may drive some away. But for those looking for good sound I believe JTR's are the answer. Lower listening levels are great too, just ask Goodoc. He has lost sleep over his 212's like others. I spent an entire long day in Seattle at Kris Deerings GTG last year and spent lots of time listening too a set of flagship Paradigm towers downstairs and Legacy Audio sent him a set of 5 Legacy Focus SE model speaker (2 towers, center and two surrounds). They both sounded great and I would be happy with either in my home. But in the real world price is also a factor and even if I took home 10k a month you wouldn't see me buying the Legacies. They were extremely precise, accurate and very nice overall. But to me they just sounded like a set of good sounding speakers that had a tie bit of upper harshness. During this GTG I was offered to stay at Bill's, bsoko2, house. He has a 7 channel JTR system of Triple 8 surrounds x4 and LCR Quintuples. We watched the movie Oblivion the night before and it was great. I swore Tom Cruise was in the room during vocal scenes. I came away from that weekend liking the JTR sound best. THE number one factor I most enjoyed and solidified my future JTR seeking was there was no harshness anywhere! Even right now as I listen to my Triple 8's the cleanness and absolute zero distortion is key. My first system was a 7 channel Definitive Technology system consisting of L&R towers that were $2,000 retail each! That system was better than most american families will ever have but I could only go so loud until it would distort and I would have to turn it down. Right now as I type I am listening to lossless audio files through iTunes as well a a CD at -3 to -6. And it doesn't seem loud. Remember distortion sounds loud and makes one think the volume is too loud when it's just distortion they are hearing. People have claimed that well over reference on JTR's doesn't sound that loud. I have hit +16 over reference with the Dolby music listening preset and like +10 with stereo listening preset and the cleanness is just unreal! But it's not all about loudness I know. But I think the fact that these can play so loud with no distortion means that normal loud and reference are both so distortion free.
Thank you for addressing the low level capability of the JTR's. I've been waiting for someone to comment on how these speakers sound at low to moderate listening volumes. Everyone always comments on how these sound at reference and how loud they can go, but I have little to no reference playing music or HT at reference. I need a speaker that creates a sense of depth, spaciousness and detail at low volumes. Unfortunately I live in Los Angeles and have no way of auditioning these speakers. So I have no choice but to scour this thread for listening impressions with the intention of buying these speakers without even hearing them first. If anybody else can comment on the low to moderate volume performance of these speakers pleaese chime in.
"Now, a clever man would put the poison into his own goblet, because he would know that only a great fool would reach for what he was given. I am not a great fool, so I can clearly not choose the wine in front of you. But you must have known I was not a great fool, you would have counted on it, so I can clearly not choose the wine in front of me" -Vizzini
AlexBPM is offline
Old 04-15-2014, 11:49 AM
logicators's Avatar
Liked: 26
My listening levels are in -12 to -5 below reference range and I can vouch for the quality and clarity of 212s (and quintuples, which were my mains before I bought 212s) at these levels. My wife often listens to music at significantly lower volumes and the speakers maintain the same clarity and depth.
The vocals on 212s were already pretty good but they are unreal after applying room treatments.
Old 04-15-2014, 12:46 PM
jlpowell84's Avatar
Liked: 715
Whatever you do having a properly treated room and dealing with specular reflections and reducing modal ringing will be a great push to clarity.
Old 04-15-2014, 12:51 PM
Gooddoc's Avatar
Liked: 1878
Seems we all kind of feel the same way about it here. It's just that I get sucked into a cult-like trance when I visit that 2.35:1 Constant Image Height thread and I start thinking that life is just not worth living if it means being stuck with a 16:9 aspect ratio...smile.gif
Old 04-15-2014, 01:04 PM
N8DOGG's Avatar
Quoted: 978 Post(s)
Liked: 1047
I had a hard debate for 2:35 vs 16:9. I game a lot so I went for 16:9. Ive yet to regret going that route. But ifI was movies only, Id for sure go 2:35.
N8DOGG is offline
Old 04-15-2014, 01:13 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1563 Post(s)
Liked: 1353
I quoted this one but based on what I've been reading in the previous posts, if I'm height-limited, I should go for 2.35-2.4 and then 16x9 will be the same height but not as wide. I'm looking at the Seymour electric screen with electric masking, which should be exactly what I need. I'm pretty sure everything I wrote is correct but it would be nice to have validation...of my ideas, not personal validation. smile.gif
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is offline
Old 04-15-2014, 01:19 PM
logicators's Avatar
Liked: 26
In your circumstances (width limited) it makes perfect sense to go 16:9 with a masking solution. I would do the same.
I had some flexibility with the seating position, and also some (but not a lot of) flexibility with the width. I discussed the screen dimensions with Chris Seymour over the phone and went with his advise. My 125" diagonal scope screen from a 11 feet distance is very immersive, and the masked 16:9 image is reasonably big but not equally immersive.
jlpowell84's Avatar
Liked: 715
on the phone with Emotiva about the 7350 noise issue...
Old 04-15-2014, 01:49 PM
Deep Sea Sound
dgage's Avatar
Liked: 1353
Actually, I'm height limited. Sorry if I wasn't clear. I'm planning to buy a 2.35 motorized screen with electric masking on the sides so that means I'm at a constant height (16:9, 2.35) for the screen with the 16x9 having less width than 2.35.
David Gage
Deep Sea Sound
dgage is offline
Old 04-15-2014, 01:51 PM
jlpowell84's Avatar
Liked: 715
And entirely unfruitful. Basically I am stuck with it they said. Very frustrating since someone recently posted the got their 999 back and got an XPA-5 and it was quiet and only power noise from 10-12 inches from tweeter...
Old 04-15-2014, 02:00 PM
Deep Sea Sound
dgage's Avatar
Liked: 1353
Thanks for the feedback. I bought the Sherbourn 7030 preamp and it has a few issues that will likely never be fixed. I don't think I'll ever buy a piece of Emotiva equipment.
David Gage
Deep Sea Sound
dgage is offline
Old 04-15-2014, 02:10 PM
jlpowell84's Avatar
Liked: 715
Yea i'm a bit irritated since someone else was refunded. They said they didn't know what I was talking about. I said, "well eihter it happened or he is lying lol." I may eventually find a buyer and never buy from them again. Go iNuke's or crown's perhaps. Or just run off of my AVR since i'm crossed to a couple Seaton Submersives lol. Basically they told me i'm doing it wrong because I don't have a dedicated circuit, 20 amp etc. I know the perfect world conditions it should be set up in but I also know 99% if it was in those conditions it wouldn't change. I have tried multiple circuits with nothing at all on etc. I know for a fact it's amp noise!
Old 04-15-2014, 02:11 PM
asoofi1's Avatar
Quoted: 933 Post(s)
Liked: 435
Keep in mind that a 150" diagonal 2:35 screen = 120" diagonal 16:9. So you still get great size 16:9 screen for anything that benefits from that ratio.
I'm still considering this route and possible add curtains for masking duties, but likely not even needed since it's dark anyway.
asoofi1 is offline
Old 04-15-2014, 02:12 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Why not just sell it? I highly doubt you'd have much trouble selling it. Try listing it on Audiogon.
jbrown15 is offline
Old 04-15-2014, 02:19 PM
Reefdvr27's Avatar
Liked: 1038
Are you using XLR's?
Old 04-15-2014, 02:20 PM
Deep Sea Sound
dgage's Avatar
Liked: 1353
I agree that you likely don't need the masking. I know Beast mentioned that issue at his GTG and I even meant to pay attention but caught up in the experience...it wasn't until I thought to look that I noticed the lack of masking on his 16:9 screen. By the way, wish you could have made it, would have been great to meet you in person.
David Gage
Deep Sea Sound
dgage is offline
Old 04-15-2014, 02:32 PM
jlpowell84's Avatar
Liked: 715
No but technically if they make the amp with RCA's it 'should operate with them...
The noise is present with just the amp plugged in and speaker wire to the speakers. Entirely disconnected from the processor...
jlpowell84's Avatar
Liked: 715
I agree, but they want 50 bucks to list it so I will try elsewhere...
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
