Official JTR speaker thread - Page 643 - AVS Forum | Home Theater Discussions And Reviews
 8655Likes
post #19261 of 37851 Old 05-10-2014, 10:32 AM
jlpowell84's Avatar
Quoted: 1941 Post(s)
Liked: 915
Originally Posted by Reefdvr27 View Post
We had a mini shootout back in January and I liked the Beymas. We compared the Beyma's (Beastaudio) Eminence (Sibuna) and my Slanted 8's. I found the Beyma's to be a bit crisper. However this was just 3 speakers hooked up and switched with the same speaker changer as used in NC. None of them were level matched and measured. I will say that I spent allot of money on the my 4 slanted 8's, but they have brought such an incredible experience for surround sound, they are an incredible speaker. If I was a little more handy in the DIY world, I would do something like Brandons Beastclops with the Beyma's.
Reef, this is my first DIY project. I tried to avoid it, just ask Nate and Beast! I listed tons of options in PM's and it always came back to the Volts. All at this lower price point of course smile.gif But I am a mechanically inclined person and a solder gun was very easy to use. Just need a little time and a few hundred bucks can get you a lot in performance. I always wonder what would I have had to paid for a new pair from somewhere to get equal performance. You see? I bet some of Eric's speakers that have the Denovo DNA 360 compression drivers such as the Fushon 15 sentinel would rival a 2k pair of speakers easy if not more.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
jlpowell84 is offline
post #19262 of 37851 Old 05-10-2014, 06:03 PM
raynist's Avatar
Quoted: 1567 Post(s)
Liked: 1543
Had the house to myself today and really cranked music for the first time. Have watched some movie scenes at reference but never music. Cranked the volume to +5 and it just kept sounding better the higher I cranked it - just amazing (228's)
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is offline
post #19263 of 37851 Old 05-10-2014, 07:02 PM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 485
Any thoughts on Marantz AV8801 pre-amp? Im thinking of just going all pro amps altogether. Maybe 3 Crown XLs 2000 to run the 3 215's. And 2 XLs1000 to run the 4 S8's.
rhed is offline
post #19264 of 37851 Old 05-10-2014, 08:18 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
its a great thought. That pre pro and those amps get good reviews. Does you DJ buddy have some of those you can try out?
lbrown105 is offline
post #19265 of 37851 Old 05-10-2014, 08:46 PM
GIEGAR's Avatar
Quoted: 805 Post(s)
Liked: 1375
Marantz: It looks overpriced compared to it's competitors, unless there's a good possibility you'll want to process 11 channels simultaneously in the future. I'd consider the Onkyo PR-SC5509 (or equivalent Integra); for over a grand less you don't miss much other than 11 channels and also pick up THX processing modes, some of which are pretty good (IMO). With the Onkyo you must choose between wide or height channels.
Here's a comparo: Onkyo PR-SC5509 -v- Marantz AV8801
The Onkyo and Marantz' rated XLR output levels are 2.0V and 2.4V respectively, so the Marantz has the edge here. The Onkyo's maximum XLR output level is 11V (wow!). Marantz don't quote a maximum XLR output level for some reason.
Crown XLS: I'm not positive, but I've read somewhere that the 1000 is a step down in build quality/components from the rest of the range. Therefore it's advisable to go for the at least the 1500. Others may clarify.
beastaudio likes this.
GIEGAR is online now
post #19266 of 37851 Old 05-10-2014, 09:02 PM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 485
Hey Ibrown.. Good to hear from you. Yea, he does but I think he has the first XTi series and QSC's. I've been reading a lot lately. And I think I'm just mainly going for XLR connectivity and good video processing at the same time. I also been on the Crown forums. And with my post there about the XLS series. The Crown admin there at first thought the xls 2000 would be to much for any home audio speakers in bridge mode. Until he ask what speakers I'm gonna use the amp for. I sent him the link for the 215RT from JTR website. I think Crown might be recommending the XTi 6002. http://www.crownaudio.com/forums/index.php?showtopic=4675
rhed is offline
post #19267 of 37851 Old 05-10-2014, 09:15 PM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 485
Thanks GIEGAR.. I never looked into Onkyo yet. Will do though. I've looked at the Integra 60.5. This model interest me. But we don't have a authorize dealer here in Hawaii. Yea, I kind of want to buy the audio gear locally incase something happen. With the Marantz, besides Audyssey XT32, it also features Audyssey Sub EQ HT. Is that a plus feature? Btw, I've read about the xls 1000. And yes it is a step down. But I don't know if it'll matter since I'm using the amp for the surrounds? If it does, then I guess I should look into the 1500.
http://www.hometheaterequipment.com/mono-stereo-amps-59/crown-audio-xls-drivecore-series-amplifier-official-thread-1319/
rhed is offline
post #19268 of 37851 Old 05-10-2014, 10:31 PM
jlpowell84's Avatar
Liked: 915
Hey all. I plan on glueing my Volt 10 cab's tomm. I was just planning on using Gorilla glue but on my Volt 10 thread I created I was advised not to use Gorilla glue as it expands. And referenced Titebond glue.
Carp, what did you use for your SI flat packs? Or those of you who know? smile.gif
http://www.amazon.com/Franklin-International-5004-Titebond-2-16-Ounce/dp/B0000223UR
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #19269 of 37851 Old 05-10-2014, 10:38 PM
raynist's Avatar
Liked: 1543
Oh, I didn't know this. I used Gorilla glue and had no issues.
raynist is offline
post #19270 of 37851 Old 05-10-2014, 10:46 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1663 Post(s)
Liked: 1480
I use Titebond III for all of my woodworking but Titebond II would work fine as well. Besides being stronger and suitable for outdoor projects, Titebond III has a slightly longer open time, which is helpful when you are trying to clamp or screw larger items. You can get either from the big box stores and I think there is only a $1 or $2 difference in price for the 16 oz. bottle.
Gorilla glue isn't a wood glue and while it might work, it isn't the best tool for the job...IMO.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is online now
post #19271 of 37851 Old 05-11-2014, 12:31 AM
jlpowell84's Avatar
Liked: 915
Ok, I saw a cheap bottle on Amazon. Hopefully Lowes or Home Depot will have it.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #19272 of 37851 Old 05-11-2014, 01:47 AM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 485
The Yamaha CX-A5000 pre-amp seems well built also. Amazon has it for 2499 vs 2999. BB price matches with Amazon. smile.gif
rhed is offline
post #19273 of 37851 Old 05-11-2014, 04:50 AM
GIEGAR's Avatar
Quoted: 805 Post(s)
Liked: 1375
Integras are generally sold through custom installer channels rather than dealers, so if you haven't already you could check with local CI's. They'll probably push hard to sell you their services as well though. The Onkyo also features Audyssey Sub EQ HT, so it's even Stevens there. A feature that the Marantz has going for it is comprehensive support for Apple including AirPlay. The Onkyo does not support AirPlay.
Crown: I looked it up and the only thing that's reflected in the XLS1000's specs is has a higher noise floor than the rest of XLS's: a SNR of 97dB v 103dB for the rest. SNR of 97dB is still pretty good though, so probably not an issue.
http://www.crownaudio.com/media/wysiwyg/XLS/XLS-DC_datasheet.pdf
The Yamaha is a very solid unit. I have two issues with it though:
  1. It's YPAO isn't a patch on Audyssey XT32 (IMO) and does comparatively little for the subs in the way of EQ.
  2. No XLR outputs for the subs. This is a big oversight, especially for those of you with premium subs.
post #19274 of 37851 Old 05-11-2014, 05:48 AM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 485
Thanks again GIEGAR.. Didn't notice that the Yamaha doesn't have XLR sub outs. What a waste. The Onkyo is starting to get interesting also.
rhed is offline
post #19275 of 37851 Old 05-11-2014, 06:04 AM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
good to hear from you to Rhed. Forgot to mention about the xls 1000 maybe not being quite up to par but Giegar was all over it!! Great thread contributors hear. Funny they thought the Crown 2000 would be too much. 99.9% of the time they would be right. I got the same from one of the LG distributors. I really like your decision for XLR connections. I am not even going to hook up my pro amp until the XMC1 balanced pre pro gets here.
post #19276 of 37851 Old 05-11-2014, 06:17 AM
Deep Sea Sound
dgage's Avatar
Liked: 1480
I bought the Sherbourn PT-7030 preamp on clearance and even at the reduced price I'm not happy with it. Too many small issues and Emotiva now refuses to do an update even though they promised one around the time they were selling them. No way in hell I would buy a preamp from Emptiva again. I'll stick with the big boys that have been doing them longer and have a better track record.
David Gage
Deep Sea Sound
dgage is online now
post #19277 of 37851 Old 05-11-2014, 06:40 AM
carp's Avatar
Quoted: 2831 Post(s)
Liked: 2136
I used titebond 2 and that pl premium stuff but you won't need the pl on speakers I wouldn't think.
carp is online now
post #19278 of 37851 Old 05-11-2014, 06:42 AM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
yeah its a risk but if the Dirac is implemented correctly it could be a huge win. At the price I am getting it for there is no way I will lose money. If I need to go another direction after trying it I may be looking for something with triinnov or dirac (could be costly to do either if Emotiva fails). Maybe the minidsp with dirac if we could get something to handle 5 sat channels plus four subs.
post #19279 of 37851 Old 05-11-2014, 07:51 AM
staaled's Avatar
Quoted: 73 Post(s)
Liked: 85
The Marantz is a great match with JTR Noesis though.
It has a smooth presentation while JTR s are very direct.
Combining these two sounds dynamic yet composed and pleasant.
The Onkyos I heard were all on the exciting side of the spectrum and my guess is these can be overwhelming with JTR.
staaled is offline
post #19280 of 37851 Old 05-11-2014, 08:07 AM
N8DOGG's Avatar
Quoted: 1111 Post(s)
Liked: 1212
Well, I've built DIY using pretty much every kind of glue there is. Gorilla glue works perfectly fine, yes it may expand a but but so does PL and everyone recommends that....
N8DOGG is offline
post #19281 of 37851 Old 05-11-2014, 08:27 AM
coolgeek's Avatar
Quoted: 636 Post(s)
Liked: 287
If you want to make your mom cry.. show her this video...
And play it on your Home Theater!!
RMK! likes this.
coolgeek is offline
post #19282 of 37851 Old 05-11-2014, 10:21 AM
Deep Sea Sound
dgage's Avatar
Liked: 1480
Here's a glue strength test that shows yellow carpenters glue, Gorilla Glue, Titebond 3, PL, and Weldbond would all work well. Based on the guys conclusions, if you don't use glue much, I'd get the carpenters glue as he says it doesn't have shelf life issues. After a year or two, I have seen Titebond 3 start to coagulate. Gorilla Glue's site claims a shelf life of 1 year and I've personally had to throw away half a bottle that became hard but had probably had it a couple years.
http://woodgears.ca/joint_strength/glue.html
David Gage
Deep Sea Sound
dgage is online now
post #19283 of 37851 Old 05-11-2014, 10:34 AM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 485
Been reading around the receiver thread. And the 8801 will be replaced by a newer pre-amp this year. I might just wait this one out till that happens. Hmm, who knows, maybe the current 8801 will see a price decrease. I guess for now, I'll just experiment with pro amps from the pre outs of my AVR.
rhed is offline
post #19284 of 37851 Old 05-11-2014, 10:49 AM
dlbeck's Avatar
Quoted: 551 Post(s)
Liked: 655
Thanks....and yes it worked!
dlbeck is online now
post #19285 of 37851 Old 05-11-2014, 10:56 AM
N8DOGG's Avatar
Liked: 1212
You realize that test proves that any of the glues will work 100% in building a speaker or sub. Their strength is 10 times what a sub box will go through, even the weakest glue is far overkill for what we use it for.
All I'm saying is you may have a preference to use this or that but in the end, anything you get will work 100%.
N8DOGG is offline
post #19286 of 37851 Old 05-11-2014, 11:33 AM
Deep Sea Sound
dgage's Avatar
Liked: 1480
When I first started that post I was going to show you how superior the Titebond 3 glue was for woodworking, as I had read other glue tests before. Then I had to redo my post when I read the results and figured out it really didn't matter. biggrin.gif So like you said and like my first sentence states, just about any of the glues would work well for our speaker/sub boxes, even without screws/staples.
If you have wood glue, Gorilla glue, or PL lying around, I'd use it. If you need to go out and buy some glue, I'd recommend yellow carpenters glue based on the fact it is cheaper and has a longer shelf life than most other glues we might use.
David Gage
Deep Sea Sound
dgage is online now
post #19287 of 37851 Old 05-11-2014, 11:46 AM
Deep Sea Sound
dgage's Avatar
Liked: 1480
Actually, regarding the glue, one key thing to look at is open time and dry time. I like Tightbond 3 as it has a longer open time than carpenters glue, which I sometimes need while putting clamps in place for a larger project. For me, I'll pay the premium for that right there. I don't use Gorilla glue enough to speak to its open time.
David Gage
Deep Sea Sound
dgage is online now
post #19288 of 37851 Old 05-11-2014, 12:13 PM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 485
rhed is offline
post #19289 of 37851 Old 05-11-2014, 12:22 PM
Toe
Toe's Avatar
Quoted: 1916 Post(s)
Liked: 2202
Thinking of upgrading my JBL S-38s to either Triple 8s or 228s all around (7 total). I am a firm believer in using the same speakers all around for a 100% seamless soundstage. The front left/right will be placed vertical while the center and 4 surrounds will be horizontal (I assume the triple 8 and 228 can be placed either way?).
I have a sealed 12x17.5 room with only 1 row of seating (a couch).
My question is which speaker would work best for my needs? It sounds like most have a slight preference for the 228, but I have also read the 228s don't work well as surrounds which has me thinking that the T8 might be a better choice. Thoughts?
Toe is online now
post #19290 of 37851 Old 05-11-2014, 12:31 PM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 485
That would be a wicked setup toe. 228's all around? Nice!
rhed is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
