Official JTR speaker thread - Page 676 - AVS Forum | Home Theater Discussions And Reviews
 8691Likes
post #20251 of 37930 Old 06-04-2014, 01:35 PM
SomeOne Who Knows
SOWK's Avatar
Quoted: 587 Post(s)
Liked: 480
Question for the group...
Do you think I went a little overboard buying the 215RT's if I plan on using the Seaton Submersive HP's for LFE out?
What do I gain with my purposed setup of:
Three 215RT'S and two Seaton SubMersive HPs
over
Three 212HT's and two Seaton SubMersive HPs
What do I lose:
I know I would have a better 1 watt per DB Sensitivity rating with the 212HT's
I'm trying to make sure my choice of the 215RT's is the better choice for my theater.
Also Craig, I'm not sure I want to believe they "ever" play the same bass information in the mains as the LFE channel...
Because if they did and you setup a crossover on your speakers of lets say 60htz, you would be routing that "same" bass information of your mains into the LFE channel twice, creating a "double" bass effect. I know i'm not wording it correctly, but I hope you understand what I am trying to say.
I could be dead wrong, but I feel if they ever duplicated bass information between the LFE and mains, it would cause the intended sound to be at a much higher level if anyone did setup bass management.
Sorry for all the questions guys, I'm know a lot about Video, but I keep learning more and more about audio each day.
SOWK is offline
post #20252 of 37930 Old 06-04-2014, 01:47 PM
Reefdvr27's Avatar
Quoted: 1579 Post(s)
Liked: 1064
over
What do I lose:
I know I would have a better 1 watt per DB rating with the 212HT's
I could be dead wrong, but I feel if they ever duplicated bass information between the LFE and mains, it would cause the intended sound to be at a much higher level if anyone did bass management.
Honestly I have been weighing this for along time now and I came to the conclusion that for HT and music the 212's are good enough. When I heard N8 say that he still needs subs, I then decided that my subs and 212's are good enough. It's really your wallet, if I was starting from scratch maybe I would get the 215's, but for now I am so happy with my set up. I can also suggest that if you can get to the Savoy theater meet you will be able to hear the 212's and 215's and you can go from there. DLBeck is using the 212's or maybe you know that already. I can also say that you could save ALLOT of money buying Carps 3 212's.
Reefdvr27 is offline
post #20253 of 37930 Old 06-04-2014, 01:52 PM
beastaudio's Avatar
Quoted: 4158 Post(s)
Liked: 3515
With that, hey n8, you still thinking about keeping the 2242's around at all? Or are they done-done???
beastaudio is offline
post #20254 of 37930 Old 06-04-2014, 05:19 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
The 212HT if crossed at 80hz or above is not going to give up anything the the 215 except the 215 will have a little more directivity, something like 380 vs 300 hz I think. If you are talking two channel then it's going to be in a different universe. For the way I use them I will take the 212 with multiple OS any day. Now having said that there is no down side to the 215 you can do it all if you have mega subs too. (See n8dogg) I think 3 215rt may have more bass than two submersives but only speculating and only if driven with megawatt amp.
lbrown105 is offline
post #20255 of 37930 Old 06-04-2014, 05:31 PM
carp's Avatar
Quoted: 2884 Post(s)
Liked: 2171
You will need 4 times the power to get the same output - and that would be with crossing them over at he same frequency as the 212's. With a lower crossover you need even more power.
carp is offline
post #20256 of 37930 Old 06-04-2014, 05:33 PM
carp's Avatar
Liked: 2171
I'd like to see a comparison of what kind of bass we are talking about here. My guess a single 215 if driven with 2000 watts would have the same output of a single ported Captivator 2400? What do you guys think?
countryWV likes this.
carp is offline
post #20257 of 37930 Old 06-04-2014, 05:34 PM
carp's Avatar
Liked: 2171
btw, I know you know this lbrown, just in case some people do not.
carp is offline
post #20258 of 37930 Old 06-04-2014, 05:39 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
You are right on Carp and I discussed this with Jeff too. For my goals I dont think the 215 doesn't bring more to the table although I have heard them they were not in my room. They won't fit!!
post #20259 of 37930 Old 06-04-2014, 05:40 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
For two channel they will be very very difficult to beat especially if you like loud crystal clear levels
post #20260 of 37930 Old 06-04-2014, 05:56 PM
N8DOGG's Avatar
Quoted: 1117 Post(s)
Liked: 1218
Nope the 2242's sold last Thursday. Though, I still have 12 in storage, they won't be used until my next house.
N8DOGG is offline
post #20261 of 37930 Old 06-04-2014, 06:03 PM
Reefdvr27's Avatar
Liked: 1064
Electric going in the theater tomorrow and we were talking tonight and I decided to add a rear platform and make it a 5 seater. Maybe get the sheet rock started next week. Getting excited now.
post #20262 of 37930 Old 06-04-2014, 06:27 PM
RMK!'s Avatar
Quoted: 1698 Post(s)
Liked: 1630
Originally Posted by craig john View Post
TBH, I have no familiarity with the ICBM processor or the Rane processor that RMK uses. I can't help you with them.
Rob, what are the connection options on the 215RT's? Do they only have 1 set of speaker level inputs, or can the woofers be connected separately from the CD? IOW, can they be actively bi-amped? Or, are you performing all the mixing/re-directing at line level and then sending each remixed signal to a single amp channel for amplification?
I just skimmed through your build thread last night and didn't see the latest setup. That looks MUCH better! smile.gif
Excellent!
Craig
Standard stuff really. One pair of speaker inputs on the 215RT with internal crossover. The signal chain is HDMI from my source devices to my Integra pre/pro. Balanced ouput from the Integra to the Rane (in the case of the LCR's) where the mixing, PEQ and crossover filters are applied. Then, balanced output to the power amp (Lab Gruppen FP10000Q) and on to the speakers.
I am bypassing the Rane with the surrounds.
Anxiety is contagious, please keep yours to yourself.
RMK! is offline
post #20263 of 37930 Old 06-04-2014, 06:53 PM
coolgeek's Avatar
Quoted: 636 Post(s)
Liked: 287
over
What do I lose:
Right off the top of my head... 6db in sensitivity difference which means a lot more wattage to reference and above. Right now I can play my 212s as loud as u want with just a receiver. I like the simplicity and cost savings of receivers.
Pros. I would think you will get a lot more midbass that subwoofers can't deliver and I am including the orbit shifter. N8 needed a couple of 18inch 2242s mid bass units to get the mid bass he needs and with the 215s that's not going to be needed.
coolgeek is offline
post #20264 of 37930 Old 06-04-2014, 06:58 PM
SomeOne Who Knows
SOWK's Avatar
Quoted: 587 Post(s)
Liked: 480
Going to be staying with the 215RT's. I think it will be a pretty ultimate home theater speaker.
Plus I only want to go to reference anyhow.
SOWK is offline
post #20265 of 37930 Old 06-04-2014, 07:32 PM
Reddig's Avatar
Quoted: 252 Post(s)
Liked: 521
I really think you won't regret it. You have tons of setup options. Even crossing the 215RTs at 80hz should gain some midbass output over a 212HT. By how much not sure but as they say there is no
replacement for dissplacement. I would not making a crossover decision until they are in room and you do trial and error. Even tho my 2x15 theater mains have in room response below 40hz I still get the best sub to main integration crossed at 80hz with movies.
JBL Pro Cinema-JTR subwoofers-Sony SXRD projection-Elite AT screen-Denon AVR-Oppo BD player-Acoustimac panels-SeatCraft HT seating
MANCHESTER UNITED!!
Reddig is offline
post #20266 of 37930 Old 06-04-2014, 07:50 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
With the OS / 212HT combo midbass is split between the sub and main. In each respective areas of freq covereage (OS up to 80 and 212HT from 80 up), each will put out more than the 215 so I am not convinced this is true.
I don't think Nate had the 212HT so he might have been slightly donw from 125-60hz on his mains compared to HT version. I noticed this too because I went from T12LP to Noesis 21HT and the 80-150hz jump placed near wall was about 8dB difference between vented vs sealed, in my room.
post #20267 of 37930 Old 06-04-2014, 07:57 PM
coolgeek's Avatar
Quoted: 636 Post(s)
Liked: 287
Sorry for the confusion... when I say mid bass I meant 80hz up to 200hz...
That big slap in the face feel..
I believe 6x15inch mid bass drivers on the 215s will do it
coolgeek is offline
post #20268 of 37930 Old 06-04-2014, 08:08 PM
rcohen's Avatar
Quoted: 1401 Post(s)
Liked: 630
Regarding ported vs sealed subs - I thought that the port is tuned to be IN phase at the tuning frequency, which is why you get a boost. My understanding was that the frequency dependent phase differences were actually caused by different high-pass filters. Some subs give you enough flexibility so that you can match the phase between ported and sealed, but you need to understand the hidden filters and EQ or measure to be sure.
rcohen is offline
post #20269 of 37930 Old 06-04-2014, 08:10 PM
coolgeek's Avatar
Quoted: 636 Post(s)
Liked: 287
Originally Posted by RMK! View Post
Rane RPM88 Mutiprocessor is capable of much more that just mixing (which you call re-direction) and channel input mixing is a common practice in the Pro Audio world. There are many inexpensive devices that can do this mixing. These devices are full blown DSP's with simple drag and drop interfaces.
In fact and as was demonstrated by desertdome at my recent GTG, the $50 JRiver software when combined with an HTPC can do nearly everything the Rane can do. The HTPC is the future of Home Theater and everyone serious about Home Theater should be looking at this as standalone players will be obsolete soon. smile.gif
Rmk... a few questions.
1. What is the boot up time of the htpc? Do you have to properly start up and shut down between uses? I am asking because a htpc is still mysterious to me. Is it a real pc ?
2. Can you control everything with a remote like you control your blu ray player for instance. Or do you have to sit by a keyboard.
3. How do you connect multiple sources to the htpc and easily switch between them like a receiver does? Or does the receiver pre amp sit between the htpc n the amps?
coolgeek is offline
post #20270 of 37930 Old 06-04-2014, 10:54 PM
RMK!'s Avatar
Liked: 1630
1. Mine is a Win7 machine so it is slow to boot up but Win 8.1 is in my near future. I shut it down like any other computer and yes, it is a PC with lots of storage (9TB) and HDMI output.
2. I use a wireless keyboard with touchpad to control the HTPC.
3. The HTPC is a source device and connects to my Integra via HDMI.
RMK! is offline
post #20271 of 37930 Old 06-05-2014, 12:45 AM
Deep Sea Sound
dgage's Avatar
Quoted: 1669 Post(s)
Liked: 1491
And Windows 8.1 can boot up very fast (15-20 sec if you have an SSD system drive) but if you want fast, just put the HTPC to sleep as it will wake up even faster.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is offline
post #20272 of 37930 Old 06-05-2014, 03:33 AM
coolgeek's Avatar
Quoted: 636 Post(s)
Liked: 287
Follow up question. If your htpc is one source then what about other sources? For example sat tv or xbox etc. Since you are using your htpc as the sound mixer then other sources can't be mixed properly for your setup... for instance what happens to the lfe channel in sat tv content?
coolgeek is offline
post #20273 of 37930 Old 06-05-2014, 05:55 AM
Reefdvr27's Avatar
Liked: 1064
Your going to be fine with what ever you choose. 212's 228's or the 215's are all good and will give an incredible HT experience.
post #20274 of 37930 Old 06-05-2014, 06:48 AM
beastaudio's Avatar
Liked: 3515
Just make sure the seating is modular so you can fit some more subs back there for room smoothing issues if needed biggrin.gif
I have found this now with several different types of speakers in my space. The T12's I owned a while back had the most anemic midbass out of all my setups so far, and I think the culprit was the higher rolloff point. Moving to a single 12" SEOS build, you would think it would not even be as impressive, but I tuned that system to around 40hz and it was actually a pretty drastic difference. Since then, I have now gone through two different Danley setups and they have both had better midbass as well, between the dual 8" on the sm60f and the dual 12's on the sh50. I Think most of this is entirely due to the lower f3 points. Better speaker integration is the result. If you are crossing at the same point there is rolloff, there could be integration issues.
Hmmm, I would almost want to keep the HTPC up and running at all times so I have remote access to it without having to walk down to the theater every single day to boot it up....Is there an issue with that?
Also, I am getting increasingly interested in this HTPC thing as it would simplify so many aspects of my music storage and streaming, measuring the room, etc etc. How much are you on the hook for, if you are looking for something that will basically do storage, REW, and BD ripping? Nothing as extravagant as n8's as I would still do my gaming on consoles.
Reddig likes this.
post #20275 of 37930 Old 06-05-2014, 07:35 AM
desertdome's Avatar
Quoted: 1335 Post(s)
Liked: 1525
You can use the Hauppauge Colossus card or their external HD PVR's to route satellite in to the HTPC. In dlbeck's The Savoy theater, he uses a Colossus card and the DirecTV STB is connected via HDMI so it all stays digital. In some areas, the satellite is encrypted and the video needs to go analog into the HTPC while the audio stays digital. From what I've read, most doing satellite this way can't tell much difference between the analog and digital. He also has an HDHomeRun for tuning OTA channels. For both satellite and OTA, JRiver handles the recording and playback.
You can get a USB IR receiver for an HTPC and use any universal remote such as the Logitech Harmony to control the HTPC. The easier way that most are using now is to just use any Android or iOS device to control the HTPC. There are are apps for both. I use my Android phone mostly for control now. Of course for tagging and management I still grab my wireless keyboard.
Some use the HTPC as their only source including routing satellite through it. Others use a receiver for game boxes, cable, radio, satellite, SACD, etc. In the 2nd case, the HTPC is used for high quality playback of DVD, Blu-ray, and music and is routed through the receiver. The HTPC still is used for EQ of its sources with the receiver handling other sources.
The price of an HTPC is primarily dependent on your priorities and sources. You can spend $500 and get great results with Blu-ray. The best video renderer used by HTPC's is called madVR. It is a software plugin that uses pixel shaders in the video card for scaling and can use the video card similar to how a game uses it. With Blu-ray, you still need to upscale chroma. The most advanced and best quality require a lot of horsepower. If you also want to upscale DVD and other video at the highest quality you need even more power. Its all a trade off of what value you think you get by spending more money. Like audio. the improvements become more incremental. If you want to upscale to 4K you need a fast CPU. Same with decoding multi-channel DSD. You need a little faster CPU than if just doing Blu-ray. For the best HTPC just for Blu-ray you are looking more at $1000+ DIY. If you add on other requirements like satellite or OTA TV, then the price goes up. I'm not including storage in the price. That is a separate issue.
Reddig likes this.
High Impact AV
desertdome is offline
post #20276 of 37930 Old 06-05-2014, 07:55 AM
beastaudio's Avatar
Liked: 3515
I was looking at the audiophile and prestige options over at assassin's webpage. Both seem to have quite a bit of versatility... Sorry for the OT
post #20277 of 37930 Old 06-05-2014, 08:00 AM
coolgeek's Avatar
Quoted: 636 Post(s)
Liked: 287
Wow... this is very informative desertdome. Thanks.
Looks like the htpc can be extremely versatile. It might be something I would consider in the near future.
coolgeek is offline
post #20278 of 37930 Old 06-05-2014, 08:39 AM
RMK!'s Avatar
Liked: 1630
Yes, DD is very good with the HTPC setup and JRiver config. In my case, when using the HTPC it is doing the channel mixing, PEQ and bass management. With all of my other sources (NEOTV for streaming, 2 bluray players and Comcast DVR) te Rane handles the DSP.
Honestly, I prefer the Rane as it has more power and is easier to use. Many undocumented features and hidden menu options make the JRiver challenging and so hanging out on the JRiver support blog is essential. Not really my thing ... but eventually I need to get there. Hopefully by then it will become more user friendly. smile.gif
There is an old saying in the software biz ... "ease of use = use" and "use = ease of use"
RMK! is offline
post #20279 of 37930 Old 06-05-2014, 09:40 AM
desertdome's Avatar
Liked: 1525
I've used JRiver for about 10 years and don't even know of any hidden menu options. rolleyes.gifsmile.gif
High Impact AV
post #20280 of 37930 Old 06-05-2014, 11:15 AM
Deep Sea Sound
dgage's Avatar
Liked: 1491
I have a Windows Home Server 2008 running 24x7 with my home automation software and it has simply been bullet proof. I also have a 24x7 Windows 7 machine with Windows Media Center that I was previously using for my whole home cable TV and that is also rock solid but I don't really use it as much as I switched back to Tivo. Unfortunately, Windows Media Center was very successful but never made "Microsoft-type money" so it has been relegated to history. Windows 8 is even more reliable than Windows 7 so you shouldn't have any issues with 24x7 use. If you want slightly more reliability, you might want to look at a Windows Home Server 2011 system, which is based off of Windows Server 2008, which would make it even more robust. However, it wouldn't be as flexible in the drivers and software you could run but would be more reliable.
You could get a cheap Dell, Lenovo, HP, etc. that would meet your needs for under $400 but would be a gainly mini/mid-tower type computer. If you want a really small computer or a home-theater type computer chassis, it could cost up to $1000 or so. Here are some general specs to look at and if you want to discuss further, just PM me.
Processor: Intel i5 (midway between lower power i3 and more powerful i7)
Memory: 8GB min with 16GB being better
Hard drive for system/programs: SSD - 120 GB min with 240/250 being better
Hard drive for media/data storage: 3TB drives or even better, 4TB drives.
Redundancy: Many motherboards or system support RAID for redundancy. You might want to consider that for your system but especially your storage drive as drives are relatively cheap vs the hassle of losing data, even musics/movies that can be reripped. The simplest and most supported is RAID 1 (Mirroring) which would require 2 drives that would mirror each other so you'd only have 1 drives worth of available storage.
Case: Basic case or HTPC case. Note that if you go smaller or towards HTPC that it will be more expensive and won't have as many options for hard drives.
So with that said here are a few options.
1. Get a desktop machine from HP or Dell and stick it behind your equipment rack
2. Get a small Intel NUC, Gigabyte Brix, or similar mini computer and then add an external hard drive with RAID mirroring built in. Note, some of these mini computers are barebones, which would require you to add a hard drive, memory, and the operating system.
http://www.newegg.com/Mini-Booksize-Barebone-PCs/SubCategory/ID-309
3. Order something from AssassinPC or similar as has been mentioned.
4. Use a laptop or basic computer and then buy a Network Attached Storage (NAS) to store your data/music/videos that you could get access to from anywhere on your network. A NAS is a basic computer solely focused on being a file server (some have additional features).
5. Buy a Windows Home Server 2011 machine, which is pretty cheap and could handle many items but may not run applications designed for Windows 8. WHS would be your application server, storage server, media server, and backup server for other machines/laptops in your house. Good system.
Like I said, feel free to PM me if you want to discuss in more detail.
David Gage
Deep Sea Sound
dgage is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
