Official JTR speaker thread - Page 717 - AVS Forum | Home Theater Discussions And Reviews
 7773Likes
Old 07-28-2014, 01:57 PM
COACH2369's Avatar
Quoted: 801 Post(s)
Liked: 673
Originally Posted by dgage View Post
East TN is KC East. Coach, Beast, and I have been helping each other spend way too much money. My wife complains about me spending so much time at Coach's house...but he has nicer speakers than I do...she just doesn't understand.
We just need to get her over one night after my room is put back together..
I need to stop spending so much money, but I still need to so a few more things...
COACH2369 is offline
Old 07-28-2014, 02:04 PM
COACH2369's Avatar
Quoted: 801 Post(s)
Liked: 673
All this talk about how to run the 215RT's....full range or crossed over to the subs?
I am not sure how I will end up leaving things in my room.
The eq'ing will be put on hold until this Saturday due to the week of work I have ahead of me.
Not sure how many others have a 215RM, but it has the ability to run in full range and I plan on giving it a shot.
Trying to determine how much boost I can get in the mid bass without running out of head room...
So far, so good... but have A LONG way to go, IMO, to get it the way I want it.
Old 07-28-2014, 02:09 PM
SOWK's Avatar
Quoted: 468 Post(s)
Liked: 360
There is no question that you should run the 215RT's full range!
Especially if you have the ability to boost the bass to your liking.
I only did a crossover for music, not movies, as I ran my Seatons HOT to "undo" the bass removal that Audyssey did... lol.
SOWK is online now
carp's Avatar
Quoted: 2484 Post(s)
Liked: 1741
Those measurements you posted show quite a dip in the mid-bass region so I'm not sure you can get exactly what you want if you keep the same speakers and seating positions. Of course that's my opinion and I hope to be wrong - especially since you said you can't really tweak those positions....
carp is online now
Old 07-28-2014, 02:15 PM
carp's Avatar
Liked: 1741
Here is the main reason I don't like Audyssey. I had an Onkyo 811
for few days to try out Audyssey. When I first started listening it sounded exciting and I thought I liked it but very quickly I was fatigued and wanted to stop listening.
Here is why, this is what Audyssey did to the highs (red line Audyssey on green line off):
carp is online now
Old 07-28-2014, 02:16 PM
carp's Avatar
Liked: 1741
Does Audyssey do that to your highs?
carp is online now
Old 07-28-2014, 02:20 PM
SOWK's Avatar
Quoted: 468 Post(s)
Liked: 360
No mine does not, but I use Audyssey XT 32 with Pro Kit.
It makes it nice a flat, but I find myself preferring a boost in the bass region, that Audyssey doesn't allow.
SOWK is online now
Old 07-28-2014, 02:29 PM
carp's Avatar
Liked: 1741
The Onkyo I used has XT 32, not sure about pro kit, don't know if it had that or not.
carp is online now
Old 07-28-2014, 02:31 PM
SOWK's Avatar
Quoted: 468 Post(s)
Liked: 360
Pro kit is a separate purchase, about $600.00 and needs a $100 license for the receiver, so no it did not have that.
SOWK is online now
Old 07-28-2014, 02:38 PM
Point Source
beastaudio's Avatar
Quoted: 3487 Post(s)
Liked: 2821
Pro kit doesn't really do much more than xt32 from an overall capability standpoint though unfortunately. You get more measurement positions, and you get the ability to set a LITTLE bit of a custom EQ, but there have been extensive tests that don't really show much difference in the final untouched EQ of either system.
beastaudio is offline
Old 07-28-2014, 02:39 PM
COACH2369's Avatar
Quoted: 801 Post(s)
Liked: 673
I am still holding out hope that I can make it work and get things sounding the way I want.
If not, I will most likely look at other speaker options.....but I really don't want to because I don't want have to deal with lugging those bad boys down the steps again. lol
At the end of the day if things are dialed in the best way they can and I am still not happy, then I have to look at my own expectations on what I am trying to achieve and figure out if is even possible.
Old 07-28-2014, 02:43 PM
SOWK's Avatar
Quoted: 468 Post(s)
Liked: 360
Exactly why I think I may need a miniDSP to allow my front three channels to get a custom curve.
May have to do an Lbrown105 25db HOT from 20htz to 60htz, then start slowly dropping to flat around 150htz
SOWK is online now
Old 07-28-2014, 02:45 PM
Point Source
beastaudio's Avatar
Liked: 2821
Definitely. I just got my open drc and have been playing with the software a little before I put it into the chain. Seems quite easy so far to set filters and such.
Old 07-28-2014, 02:55 PM
carp's Avatar
Liked: 1741
Any speaker in those same positions would measure like that I would think?
Can you pull them out from the wall some? My baffles are more than 4 feet out from the wall and measure the best like this - in my room of course.
I hear you, I don't ever want to carry these again!
carp is online now
Old 07-28-2014, 03:08 PM
COACH2369's Avatar
Quoted: 801 Post(s)
Liked: 673
That is something I could look at doing. Probably would effect my toe-in due to how close they are to the screen.
Old 07-28-2014, 05:34 PM
dlbeck's Avatar
Quoted: 488 Post(s)
Liked: 557
And I'll nominate Des Moines as KC North....God knows they've helped me spend lots of money. I still remember the phone call with Archaea when he told me to buy the dual S2's. Good advice
carp likes this.
dlbeck is offline
Old 07-28-2014, 05:52 PM
SOWK's Avatar
Quoted: 468 Post(s)
Liked: 360
Does anyone know if the minidsp nanoAVR can do custom curves for my front three channels?
And can it do it without using any other feature from the unit? I still want to use Audyssey as the room correction, just want the custom curves only.
SOWK is online now
Old 07-28-2014, 05:57 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1036
I really like my 4. I HATED those little 2x4's, they always introduced noise into my system. The opendrc though has been perfect.
jlpowell84 likes this.
N8DOGG is offline
Old 07-28-2014, 06:50 PM
jlpowell84's Avatar
Quoted: 1613 Post(s)
Liked: 712
Originally Posted by Reefdvr27 View Post
Man I wished I lived across the street, be great to be close to some peeps that share the same passion, you guys have all the fun. My neighborhood sucks. Bunch of high pinky stiffs. I thought this neighborhood was going to be cool when I first got here and and I seen all the guys had Harley's on the street and the guy next door had a Lamborghini and a Ferrari. Certainly not the case and I never once went on bike ride with any of my neighbors and I don't even talk to them. I sent my son over once to go look at my neighbors Ferrari and he told him not to come in the garage, but he could look from the door :roll eyes: GET OVER YOURSELF BRAH. I am moving out of here ASAP. Im going up by Andrew or going to KC.
Yea get out of there! Look from the door lol...Get over yourself is right! People that think they are better than others because they have money or in general are selfish and have a me first attitude is probably my biggest pet peeve. I have done some work recently for a guy here in town who owns a huge IT company and an offshoot big time bit coin minig operation and he is very cool. His wife is a specialty doctor as well and they have millions upon millions! But he is just cool and nice and is generous with paying people and buying them lunch and REALLY takes care of his employees and gives tons of vac time etc...Thats what I like to see!!! I told him we need to build him a big bad theater!!!
jlpowell84 is offline
Old 07-28-2014, 06:52 PM
jlpowell84's Avatar
Liked: 712
I went with the open DRC because it has XLR in and out and because Nate said he loves them. I have zero complaints. Has been flawless and really lets me tune in the dual SubM's perfectly with a nice house curve.
Old 07-28-2014, 07:24 PM
vince32837's Avatar
Quoted: 124 Post(s)
Liked: 110
Opendrc-an, is that the model to get? You need 2 of them for 215 LCR true?..they don't add noise/hiss to the signal chain ?
Thanks Vince
vince32837 is offline
Old 07-28-2014, 07:26 PM
RMK!'s Avatar
Quoted: 1599 Post(s)
Liked: 1465
Any DSP with enough inputs/outputs that lives between Audyssey and the amp should be able to add EQ to the post Audyssey FR. My Rane does that and has mixing as well as EQ.
BTW, I haven't usd Audyssey (XT32 with SubEQ)) since the 215RT's arrived and I don't miss it a bit.
beastaudio likes this.
Opinions are not facts.
RMK! is offline
Old 07-28-2014, 07:52 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1557 Post(s)
Liked: 1346
Coach and I have the NanoAVR and with 10 parametric EQ per channel, that gives you 80 (7.1) PEQs to work with. You can even use REQ automatic EQ to define a target curve, EQing to meet that curve, export for NanoAVR, and import from REW to the NanoAVR.
Since it is completely digital and resides between your sources (HDMI in/out) (Bluray) and your receiver, you can do whatever you need to with the signal and then let Audyssey take over from there.
I haven't used OpenDRC so I can't speak to the differences.
dgage is offline
Old 07-28-2014, 07:54 PM
Deep Sea Sound
dgage's Avatar
Liked: 1346
I purposely bought a preamp without Audyssey because I knew I wouldn't use it. Coach currently has his turned off using the NanoAVR but not sure if his calibrator, Chad, will keep it off.
dgage is offline
Old 07-28-2014, 08:04 PM
RMK!'s Avatar
Liked: 1465
Really? it is in the chain between the source device (bluray player) and the AVR/SSP? That's in the middle of the HDMI chain ... no?
RMK! is offline
Old 07-28-2014, 08:09 PM
SOWK's Avatar
Quoted: 468 Post(s)
Liked: 360
So yes, buy it? Lol.
Will it allow a custom curve without using a mic?
Or do I have to use the mic?
Can I just tell it I want to run 20db hot from 20htz to 50htz, then slowly drop off to flat at 125htz?
SOWK is online now
Old 07-28-2014, 08:12 PM
COACH2369's Avatar
Quoted: 801 Post(s)
Liked: 673
We are going to use Audyssey as a "base" and see what it does. After that, use the Nano to fine tune things and then disable Audyssey if it proves to be worthless..
Bottom line for me is, I am not experienced in what is the right or wrong way to set these speakers up nor have the knowledge to do it myself, so I have to lean on some good guys to help me out.
These 215's have been very challenging to get set in my room, unlike any other speaker I have had before. I just hope they can be tweaked to do what I want them to do in my room....something I know I said in an earlier post today.
Old 07-28-2014, 08:16 PM
Deep Sea Sound
dgage's Avatar
Liked: 1346
Yes. Your Bluray will decode the signal and output PCM. The NanoAVR is able to stay completely digital by jumping in the middle and also keeps the cost down for how powerful it is. And it is definitely powerful.
dgage is offline
Old 07-28-2014, 08:23 PM
RMK!'s Avatar
Liked: 1465
Interesting, thanks for the info ...
RMK! is offline
Old 07-28-2014, 08:34 PM
Deep Sea Sound
dgage's Avatar
Liked: 1346
Normally when doing DSP work you'd want a mic and measuring software (REW) to find out how the signal is being affected by changes.
Also, of you want to use REW AutoEQ, you'll need to specify a Target Curve and have a measurement from your speaker. AutoEQ will then put together some advanced EQ modifications that you'd export in the format for NanoAVR.
Notice we've hardly talked about the NanoAVR up until this point. Whatever changes you make in the DSP, the NanoAVR doesn't care if it made your signal sound better or worse. It has no mic to figure out if your settings were good or bad...which is why you'd want to use a mic with REW software so you can see how your changes in the NanoAVR are affecting the output from your speakers.
Regarding types of changes, you can specify a peak (most popular), high shelf (upper freq), or low shelf. You can specify whether the change should be broad or very narrow and anywhere in between. A positive change will increase the signal while a negative value will reduce that freq range.
Hope that helps. By the way, you might be able to download the software and play with it without even having the device. You can make changes on your computer and then upload the configuration or if you stay connected, you can make changes in real-time.
dgage is offline
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
