Official JTR speaker thread - Page 723 - AVS Forum | Home Theater Discussions And Reviews
 8570Likes
post #21661 of 37755 Old 08-05-2014, 06:24 PM
jedimastergrant's Avatar
Quoted: 660 Post(s)
Liked: 412
Originally Posted by rjh65@verizon.ne View Post
Hello Jedimastergrant, this will be the winner sir! Great find! I will order some immediately and report back. I had to move the OS from the fronstage so I could make a change in that area. Looking to upgrade my projector from my older JVC DLA-RS1 to the Sony 55ES or JVC DLAX-500R so I will definately be using these either way thank you Jedi!
Yeah I think it is similar to what a few others suggested but I may have fleshed it out a bit better for you.
My situation is different than yours but here is what I did for reference. It is post 463 in my build thread. sunflower state cinema
Oh, and I need to update my thread. I now have 3 JTR Noesis 212 HT's up front. I am going to post some impressions after awhile here.
Congrats on the OS. I have one as well. It is an absolute beast of a sub. The best I have ever heard! One OS provides all of the headroom I need for my enclosed space. The shake is just incredible.
I have the JVC RS45 which is probably similar to your old PJ. I just saw the Sony 55ES at dlbeck
s and it was phenomenal even on a very large screen. If I was buying today that is what I would get. But, it will be a few years for me.
jedimastergrant is offline
post #21662 of 37755 Old 08-05-2014, 07:38 PM
Quoted: 660 Post(s)
Liked: 412
Originally Posted by jlpowell84 View Post
Hey JTR fanboys...looking for any or all of your input. I have been thinking the last couple days what the next upgrade for me would be in my system. Now I am restricted a bit by finances in the fact that there are other things in life that are more important than 10k worth of speakers at this point for me But I could swing a little bit after the turn of the year. I know not conventional JTR thread thinking and could be classified as blasphemy around here. I currently have Triple 8 LCR, two Seaton Submersives, two Volt 10 surrounds, Denon 4520ci AVR, Mac Mini and the Open DRC-AN mini dsp unit. Not a bad little conservative system...Basically I could swing around the cost of one 212 Noesis so there is the ballpark. So I was thinking...
1. A single 212 LP Noesis (or custom like N8's) for a center channel upgrade. Mark Seaton told me once the most import HT speakers are the center channel and the subs due the fact of how much activity and content they are responsible for. He said about 80% of movie content is from the center channel alone. So I think a single 212 upgrade there would provide quite a jump in movie experience. Much dialogue and other to be had there. And who is to say I can't be unconventional and listen to music out of just the center??? lol...
2. LCR 228 Noesis. I could get a little cash most likely from my Triple 8's and swing a sweet set of 228's and would provide a nice matched front set. Many of you say they are not far behind the 212 for music and almost the same for movies. I would also get the classic 2 channel music benefits from this orientation. I, like Carp, am a firm beleiver in 2 channel. I feel music is vastly superior in this listening preset. I like the dolby mult ch preset surround effect but I feel instruments "get lost" or are "blanketed" sounding.
3. Keep Triple 8 LCR and upgrade to a set of Single 8 surrounds. I would now be JTR 5 channel and they would be a serious boost over the Volt 10's. This is based soley on all of the comment you guys make. But those comments hold serious value and weight.
4. A couple DIY 18 inch subs with an pro amp like the inuke. Can never have too much woofage right? I am all about bass but my gut says I can get better performance with money spent elsewhere as I am flat to 8hz in my room and have had a 111db down to 8hz on a sweep once. I was scared to try any higher but that was on a single 15 amp line and no breaker pop so that tells me there is more. Also I operate on limited power so perhaps more woofage would not be smart...
5. Upgraded TV. I sit 9 ft from my beautiful Panasonic plasma (dying breed). It looks absolutely great with the Oppo and darbee processing (HD 42%) but I feel a 65 inch panel would provide a serious jump in viewing experience. The problem here is plasmas are gone and edgelit LCD's are bad for blacks and the letterbox bars are terrible in a dark room.
More idea's to come but what do you think?
#5 and it's not even close if you ask me. This is coming from an owner of a Pioneer Kuro. So I get it. The Kuro is basically the best image you have ever laid your eyes on. But, I don't use it in my theater. Immersion is really important. I also sit at 9 ft. Actually 9.5 ft. However, my screen is 9 ft wide. Trust me the tradeoff is well worth it. A good PJ and screen will give you a fantastic picture. It will not quite equal the plasma but you will never go back. Just make sure you are conserving brightness and sharpness by choosing a good pairing of PJ and screen. I mean don't go too big with the screen unless you plan to buy an absolute light canon which can cost more. You may or may not want/need a screen with gain to maintain foot lamberts. The Sony ES55 looks like the best thing going right now but you can buy a used Panny 8000 for probably a lot less (I don't know how much really). Make sure that your room is a black hole. Ambient light is the absolute KILLER for a front projection system.
I can tell you that my JVC RS45 and EN4K 9 ft wide 2.35:1 screen sitting at 9.5 ft in a dark room looks pretty phenomenal. You can use the wall paint for very cheap or go with the spandex as suggested earlier. My suggestion for a great material is the Center Stage XD from Seymour. You can buy this material for very cheap and DIY the screen to save money. And then you have an AT screen for your center channel to sit behind which will be an audio upgrade for you as well.
Here is an excellent place for you to start. http://http://www.accucalhd.com/docu...een_report.pdf This guy has some other good info out there if you search for it.
I have heard the JTR Triple 8's and liked them very much. Yes, the 212's are an upgrade. A very expensive one though. I think you should buy a moderately priced PJ and do the Center Stage XD with a DIY frame. Then in a year or so you can buy your dream front 3 speakers. After that you can worry about surrounds. In my opinion they are the least important component.
Gorilla83 likes this.
post #21663 of 37755 Old 08-05-2014, 08:54 PM
Reddig's Avatar
Quoted: 214 Post(s)
Liked: 418
AMC Prime is the only thing that has rivaled my home theater experience. It is the whole thing - the incredible seats, the red glow JBL line arrays, the eight 18" subwoofers turned up loud!, the tactile transducers in the seats dialed into perfection, the enormous screen, high qauality projector, ATMOS. I've been to just two movies there, and while I agree the actual movies didn't really showcase atmos nearly as well as the opening Atmos demos - the entire experience was just fantastic.
AMC Prime Theaters! Dolby Atmos, Guitammer seat transducers, Reclining Electronic Leather Seats!
I totally agree. I go to that theater a lot too when I'm in KC and I LOVE the Prime theater as well as there IMAX. Seen Guardians of the Galaxy this weekend at the IMAX and loved it. Wanted to hear it in Atmos but the only showing we could make was in IMAX with our schedule. Both of those theaters have the bass hot for sure!
JBL Pro Cinema-JTR Subs
MANCHESTER UNITED!!
Reddig is offline
post #21664 of 37755 Old 08-05-2014, 09:05 PM
Gooddoc's Avatar
Quoted: 3089 Post(s)
Liked: 2368
Just a heads up to the JTR crowd. I'm going to be putting some speaker pairs up for sale in the classifieds shortly. Figured I'd give the peeps here an advance notice. Anyone with an interest just pm me.
Going in stages. Danley's first, then JTR's as soon as budget permits .
Gooddoc is offline
post #21665 of 37755 Old 08-05-2014, 09:06 PM
rhed's Avatar
Quoted: 642 Post(s)
Liked: 483
I had to haul out the def tech mains yesterday and reconnect. Cause the wifey wanted to watch movies. Btw, my speakers has landed here in Hawaii. FedEx just called today to confirm the delivery Thursday . Anyway I did some playing around with REW. And tried did some eq. A lot o cuts just to even out the peaks. Still have that nasty dip at 100. And now I have a nasty one at 40. No matter what I do I cant get it fixed. Well except moving the subs around again. But I'll just do everything with the new speakers. Hopefully with the new speakers I have more to play with response wise. Another question, is there a way to run sweeps with like the subs and 2 or more speakers to take measurements? Like L/R and subs If there is a way, I cant find how to.lol.. I only now how with subs with 1 speaker at a time. Upper response is with R main speaker and subs. thanks guys...
rhed is offline
post #21666 of 37755 Old 08-05-2014, 09:42 PM
jlpowell84's Avatar
Quoted: 1934 Post(s)
Liked: 913
Originally Posted by hogues View Post
Which Panny do you have? And how big is it?
50 inch Panasonic ST. It was the middle of the 5 models with the VT and GT above it in 2012.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
jlpowell84 is offline
post #21667 of 37755 Old 08-05-2014, 09:49 PM
rcohen's Avatar
Quoted: 1377 Post(s)
Liked: 604
Originally Posted by dgage View Post
Danley is off my list until they release their rumored SM60HT version. If that were a real product, I wouldn't be able to respond as I'd be on I-75 driving down to listen to it.
Spill. Google turned up nothing.
rcohen is offline
post #21668 of 37755 Old 08-05-2014, 10:04 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1643 Post(s)
Liked: 1466
This is about as close as you'll get to information about a home theater version of the Danley SM60f. Sounds like they have a prototype but need to develop a new cabinet mold, which will likely take some time, more or less depending on priority level of the project.
DIY Danley Noesis?
If my initial listening of a single Cat12 is any indication...my journey may be over long before the new Danley's come out.
rcohen likes this.
dgage is offline
post #21669 of 37755 Old 08-05-2014, 10:12 PM
cvinfig's Avatar
Quoted: 193 Post(s)
Liked: 131
Yeah, I'm surprised you haven't posted about this upgrade yet...
cvinfig is offline
post #21670 of 37755 Old 08-05-2014, 10:15 PM
jlpowell84's Avatar
Liked: 913
Originally Posted by carp View Post
If I were you I would save up for a while longer and get LCR 228's and in the meantime watch the classifieds just to see if anyone is selling theirs - not a big chance but it could happen.
I think the 228 is the biggest non DIY bang for the buck speaker I have ever heard.
Thanks Carp. The music guy in me is intrigued by a SQ upgrade. Thinking Archaea directly saying how the T8's wouldn't open his wallet but the 228's did...
Haha, that's what I get for reading too fast you already have that option as #2 .
So, my vote is #2 .
Originally Posted by N8DOGG View Post
I vote for a new TV or projector. You have a pretty darn decent setup already. Although the 228's may be an upgrade, I think the a visual upgrade is what I would do. A big ass TV really can immerse you into a movie. There are lots of good LED TV's now that are close to on par with plasma in PQ.
I vote #5
This was another option I didn't have time to post. As others say the "immersion factor" with a big screen may the the biggest upgrade.
Or you could do a sweet projector and a DIY screen to get it really right! My current screen cost me a little over $60 to build with the brackets, wood, and material I bought at hancock fabrics. The PJ would be the cash outlay, and you could later improve on the screen with some legit material like the xd or falcon screens material and improve the picture quality even more, but to be honest, the little spandex fabric I am currently using does an absolute fantastic job....But I am not a video purist like some around here. I am sure my foot lamberts and color spectrum is not all that up to snuff for some around here, but the picture I am seeing looks better than my pretty good eyesight could poke any holes in
This is the route I would go if PJ is selected. I have never been a videophile but my new Oppo with darbee processing and a S&M video calibration disc have intrigued the hidden videophile in me
Originally Posted by dlbeck View Post
My vote is for #2 - big upgrade from what you have and an outstanding all around speaker!
Thanks for the input. I certainly hold all the opinions around here in high regard. Much experience for sure! This is a very tempting option. Selling the LCR Triple 8's would make them even cheaper! And I am a SQ guy above all.
Thanks you for the detailed response I just measured and I am actually 8.5 to 8.25ft from my TV. But it sits on a mounting neck off my stand that sits forward 1ft from the wall. I like your screen suggestion. I am pretty handy and building is fun for me. The Triple 8's are great speakers especially since Jeff did new crossovers and the BMS CD's in them (they were 2009 models). Listening to some Phil collins and it sounds amazing. They don't grab me like some of you have said about the Noesis line though. But speakers can always come later too. I am in a living room and not a dedicated room so light does get in. But my front wall I have put insulation in the window frame and have a large piece of black fabric. I get total blackout there and could easily enough do some blackout drapes that open and close over the other windows, not too hard at all. I agree I think that this would add the most "immersive upgrade" I have heard subs and a PJ and screen are tied for first place as far as top upgrades for HT you can do. So I just measured and I could do a 7ft-8ft horizontally wide PJ screen. I would most likely build a stand that would sit behind the couch and have the PJ peek up and over just as much as it needs. My main worry would be the two submersives. Sometimes I think parts of the house is going fall apart. Screen movement and or PJ movement...But I'm sure decoupling techniques could be done. AT could be done but would be another level of work and design, but I would be up for it. Center content coming up would be a big audio improvement.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #21671 of 37755 Old 08-05-2014, 10:16 PM
jlpowell84's Avatar
Liked: 913
What are you changing to?
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #21672 of 37755 Old 08-05-2014, 10:20 PM
rcohen's Avatar
Liked: 604
DIY Danley Noesis?
So, what's your detailed impression of 212 vs Cat12?
rcohen is offline
post #21673 of 37755 Old 08-05-2014, 11:02 PM
Gooddoc's Avatar
Liked: 2368
You had to ask! Should be a straight jacket...
I have had a very long internal battle over this decision. Each way I turned it seemed I was faced with compromises or design and performance unknowns.
I decided that I don't want to settle on compromises or unknowns.. Although I know there is no perfect speaker, I've decided I will go with a speaker that is exceptionally engineered, tested objectively and comparatively in the most rigorous speaker testing facility in the world, meets my criteria for exceptionally dynamic output with a continuous clean output rating of at least 105+ dB at a listening position of 24 ft.(120+ dB peaks at 1M), world class clarity, resolution and imaging at ANY volume, 20Hz - 40kHz frequency response, active design and DSP tunable to my space for exceptional sound, and accepted and used by top music and movie industry mixers and professionals as reference speakers.
The only problem is I haven't listened to it yet .
dgage and jlpowell84 like this.
Gooddoc is offline
post #21674 of 37755 Old 08-05-2014, 11:31 PM
Deep Sea Sound
dgage's Avatar
Liked: 1466
Coach and I will have a thread comparing the Cat12s to the 215RM/RTs as well as my 212s. The Cat12s are at Coach's house with the 215s right now and then I'll move them to my house to compare against the 212s.
I think Gooddoc just described my speaker in the post between ours.
rcohen likes this.
dgage is offline
post #21675 of 37755 Old 08-06-2014, 03:56 AM
Gooddoc's Avatar
Liked: 2368
I get the impression you're thinking that's a hypothetical speaker . It's not. it's an actual speaker I intend to buy. I've been obsessed by this speaker for a while now but until recently couldn't (wouldn't ) commit my wallet to it.
Gooddoc is offline
post #21676 of 37755 Old 08-06-2014, 04:27 AM
countryWV's Avatar
Quoted: 409 Post(s)
Liked: 591
TMI not to reveal the speaker.
jlpowell84 likes this.
countryWV is offline
post #21677 of 37755 Old 08-06-2014, 04:37 AM
Frohlich's Avatar
Quoted: 1180 Post(s)
Liked: 1128
Good morning JTR brothers. Haven't been on AVS since the Spring. Spent the summer hacking it up at golf courses and lugging the family around for vacation. It's heading into fall and my addiction for college football and HT is coming back. Looking forward to catching up and seeing what everyone is up to.
carp likes this.
Frohlich is offline
post #21678 of 37755 Old 08-06-2014, 04:46 AM
COACH2369's Avatar
Quoted: 911 Post(s)
Liked: 737
Welcome back Frohlich!
Been a HUGE Summer in more ways than one.
COACH2369 is offline
post #21679 of 37755 Old 08-06-2014, 05:22 AM
Gooddoc's Avatar
Liked: 2368
It's like The Ring. Precious...
I'm hesitant to discuss other speakers in owners threads. Even if I am an owner.
Gooddoc is offline
post #21680 of 37755 Old 08-06-2014, 05:53 AM
Frohlich's Avatar
Liked: 1128
Sounds like somebody bought some new toys. I don't want to rehash on this thread but shoot me a PM if you have some time. Would love to know what summer Santa brought ya
Frohlich is offline
post #21681 of 37755 Old 08-06-2014, 06:18 AM
buzzard767's Avatar
Quoted: 1655 Post(s)
Liked: 2436
I agree 100%. I have a Samsung plasma on the BR wall where I view nearly nothing as I fall asleep, a 65VT50 in the LR where my wife watches girlie programs, a 55F8000 LCD on the office wall for news and sports, and a 65VT60 in the FR for sports. Since building my theater, ALL movies are viewed there with no exceptions. A Seymour 138" diagonal XD and a Sony 600ES 4K PJ provides the view and a 7.2 set of JTRs makes it come to life. Yesterday I finished black velvet surrounding the screen ceiling, floor, and side walls. When the lights go down there is nothing but picture. Yee haw.
With catering and a portapotty I could live there!!!!
September 4th marks the first Packer pre game and I'm have a tailgate party. Guess where all the men will be?
Archaea and jlpowell84 like this.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #21682 of 37755 Old 08-06-2014, 07:09 AM
hogues's Avatar
Quoted: 84 Post(s)
Liked: 62
Then i would absolutely upgrade the display. As others have said, you have a pretty good setup right now. I think that you would get the biggest bang for your buck upgrading your display. Projectors are great, but if you don't want/can't go that route, you can still find the 64 in Samsung f8500. I have the Panny zt 60 and it is the best display that I have ever seen, but the Samsung is not far behind. In fact, a lot of people prefer it to the Panny and I can see why.
hogues is online now
post #21683 of 37755 Old 08-06-2014, 07:56 AM
buzzard767's Avatar
Liked: 2436
The Vizio P series full array local dimming LCD's should be coming out next month and might well be worth waiting for.
http://www.vizio.com/p-series
Buzz
post #21684 of 37755 Old 08-06-2014, 08:17 AM
audiovideoholic's Avatar
Quoted: 654 Post(s)
Liked: 216
Yea I took forever to decide between the panny and Samsung but finally just bought the Samsung 65 since was cheaper. It's the best panel I've ever owned and gets the least amount of viewing since its in the bar room. The only noticeable difference I could see in best buy magnolia between the pan and Sam were blacks but I'd say both are top 5 panels every made.
hogues likes this.
audiovideoholic is offline
post #21685 of 37755 Old 08-06-2014, 08:25 AM
Bassfeen's Avatar
Quoted: 113 Post(s)
Originally Posted by cmryan821 View Post
Quote:Originally Posted by mhdiab
Well quite a few people run 4ohm speakers with the SC-05 / SC-07 but it is not officialy rated for it. Now different speakers spend different amount of time down at 4ohm - don't know the technical terms for putting that correctly so that is why I was asking for some specific JTR input.
I think I might go ahead and buy them and just be mentally (and financially) ready to get an amplifier if they start clipping.......
EDIT: I couldn't see if the Triple 8's are rear or front ported - maybe that is a given for you guys that are a bit smarter but not for me. The distance to the back-wall is a concern for me
Front ported. My first instinct tells me not to put any speaker against a wall but I've noticed some guys have done just that with their Triple 8's and they love 'em. That said, I still haven't noticed someone that was unhappy with any JTR product.
As for amps, I'm not at all sure of your budget or if you need two or three channels of amplification, but you can get some really nice two channel pro amps for pretty cheap.
I was unhappy with my JTR and moved up to the Danely SH50 and never looked back since then. Sold the JTR to an American feller on eBay. I am now selling my Danley speaker system not because im unhappy with it but am planning to move out into a smaller home in a new neighbour hood which has easy access to work. Otherwise I don't think I would ever part from them.
Bassfeen is offline
post #21686 of 37755 Old 08-06-2014, 08:48 AM
buzzard767's Avatar
Liked: 2436
Off topic but I should comment anyway. VT50, VT/ZT60, F8500, and the last couple Kuro generations are the best of the best. You really can't go wrong. We learned a year ago that the Panasonics can be calibrated near perfectly up to about 50 foot Lamberts output making them okay for daytime viewing as well as 30-32 FtL reference night.
This is the family room 65VT60 I was talking about. For a FR it's a good setup and includes a PSA XS30 sub with it's twin 15" drivers. There are a couple of ceiling speakers for 5.1. Too bad it's only used for sports now but the front projector/JTR combo trumps the hell out of it.
If I were to purchase a flat panel today it would be the F8500. However, the upcoming Vizio P series and especially the R series which will come a few months later "might" wind up being better.
Buzz
post #21687 of 37755 Old 08-06-2014, 08:54 AM
RMK!'s Avatar
Quoted: 1696 Post(s)
Liked: 1622
I would think the $4K Danley SH50 (passive version) might be a nice upgrade from a $1200 Triple 8LP.
Sorry you have to sell them ...
Anxiety is contagious, please keep yours to yourself.
RMK! is offline
post #21688 of 37755 Old 08-06-2014, 09:07 AM
Reefdvr27's Avatar
Quoted: 1578 Post(s)
Liked: 1062
I was wondering where you were. Sometimes a little break from AVS is a good thing, especially for the wallet.
Reefdvr27 is offline
post #21689 of 37755 Old 08-06-2014, 09:50 AM
Frohlich's Avatar
Liked: 1128
I hear ya. I always come to AVS with the best of intentions to just educate myself and chat with the boys and it always turns into an "upgrade" cycle...since my stuff is already 12 to 18 months old
Frohlich is offline
post #21690 of 37755 Old 08-06-2014, 09:54 AM
Point Source
beastaudio's Avatar
Quoted: 4026 Post(s)
Liked: 3345
First thing, the talk about the sony es55 is good, but you guys should also be considering the jvc4910. I am tossing it on a very lossy screen right now, from close to 16 feet back, and a 138" 16:9 image and it leaves nothing additional to be desired. Most incredible picture I have ever seen!!!!
I don't think most would object here. This is almost as much of a community of fantastic fanatics than owners at this point Heck, I haven't owned JTR for years now, but I still hang around
beastaudio is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
