Official JTR speaker thread - Page 724 - AVS Forum | Home Theater Discussions And Reviews
 8691Likes
post #21691 of 37926 Old 08-06-2014, 10:11 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
I don't think most would object here. This is almost as much of a community of fantastic fanatics than owners at this point Heck, I haven't owned JTR for years now, but I still hang around
+1 - I'm just a lurker that chimes in with an oohhh or an ahhh from time to time.
Reddig likes this.
Gorilla83 is offline
post #21692 of 37926 Old 08-06-2014, 11:50 AM
jlpowell84's Avatar
Quoted: 1941 Post(s)
Liked: 915
Originally Posted by hogues View Post
Then i would absolutely upgrade the display. As others have said, you have a pretty good setup right now. I think that you would get the biggest bang for your buck upgrading your display. Projectors are great, but if you don't want/can't go that route, you can still find the 64 in Samsung f8500. I have the Panny zt 60 and it is the best display that I have ever seen, but the Samsung is not far behind. In fact, a lot of people prefer it to the Panny and I can see why.
Originally Posted by buzzard767 View Post
The Vizio P series full array local dimming LCD's should be coming out next month and might well be worth waiting for.
http://www.vizio.com/p-series
Yea Buzz, I took a good look at those after you mentioned them to me awhile back. How are the blacks supposed to be on those? I have read that all of these new UHD TV's are all lcd/led and have black level issues and horrible lit up letterboxes on the movie 2:35:1 ratio. I read quite a bit in a thread mark herringer I think is is name (imagic is username) and all the purists said it is a tough time for videophiles because quality is going downhill and the blacks on theses lcd/led new tvs were bad. You would know though. Plus N8 said there are some good ones out there...
Anyway jedimastergrant got me thinking quite a bit today about a DIY AT screen and a decent PJ like the JVC RS45 range. I have been thinking today how my center is a Triple 8 LP and I could build a system/bracket that spaces the screen away from the wall to fit the T8 in the TRUE center position. I could also build into the screen holding frame a decoupling system for my nasty dual Submersives. I am opposite of a concrete slab so...I could do about a 95-115 ballpark diagonal screen. I think the immersion factor may win it for me. As a few said going for LCR 228 Noesis is really tempting but...Also how are the fans on projectors? Are they loud? What would an opinion be for the closest tolerable physical distance to the MLP?
JLPowell84's Room
FTW21 Ported Build
Spoiler!
jlpowell84 is offline
post #21693 of 37926 Old 08-06-2014, 11:54 AM
jlpowell84's Avatar
Liked: 915
Also mentioned in one of the PM's I got was selling my dual submersives and being able to build a couple good ported subs like JBrown's monsters and then sell the Triple 8's and get 228 Noesis. That could be swung by just wheeling and dealing and then still do the PJ and screen setup! But I was given a great deal on the Submersives from a GOOD friend and I am not entirely comfortable at this point just selling them away. Besides I feel the dual submersives are the cornerstone of my system currently. But it spurs thoughts nonetheless...
plus ported subs would eliminate single digits and low teens which could be looked at as a plus for PJ and screen movement worries...
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #21694 of 37926 Old 08-06-2014, 12:10 PM
dlbeck's Avatar
Quoted: 559 Post(s)
Liked: 666
Fan noise on the Sony 55 is very minimal. I don't ever recall a time that I was sitting down and watching something and thought "boy, that projector is loud." This is true even sitting directly below the projector (about 28" clearance).
Archaea and jlpowell84 like this.
dlbeck is offline
post #21695 of 37926 Old 08-06-2014, 12:20 PM
Frohlich's Avatar
Quoted: 1312 Post(s)
Liked: 1246
dlbeck, last time I read AVS in the Spring you were 70% done but just saw your avatar and went to your build thread. I know I am late to the party but it turned out flipping awesome!!! Great job.
Archaea likes this.
Frohlich is offline
post #21696 of 37926 Old 08-06-2014, 12:40 PM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2439
We won't know how good they are until we get our meters and eyes on them. That's why I said "might". All we're asking for are Kuro/Sharp Elite blacks AND VT60 calibration ability. "If" it happens it'll be the TV to buy despite typical degraded off angle viewing.
If you can incorporate a FP I'd say do it in a heartbeat for movie viewing. With a high end audio system there is no comparison despite lousy blacks. In flies in the face of the well known fact that contrast ratio is the most important picture quality aspect. The immersion effect overrules the "rules".
My last FP theater was 20-25 years ago and was nothing special due to low screen luminance and standard def material. My new theater, however, with both excellent picture and sound has made a believer out of me.
I can't hear the fans on my Sony and have no other experience.
Distance is dependent on screen material and viewing angle. AT screens need a little room but I can get very close to my XD with it's mini holes. There are varying ideas re: viewing angle, THX, etc. Personally I believe you can nose up to a flat panel, see where too close begins, and calculate the angle from there. Then translate to a big screen. My front row is 11' from a 120" wide 16:9 screen and I could go closer by a couple feet with no problem. My second row is about 16' and I find that not as pleasurable.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #21697 of 37926 Old 08-06-2014, 01:04 PM
beastaudio's Avatar
Quoted: 4152 Post(s)
Liked: 3514
Then DO IT! Focus on the projector situation first, then focus on the screen later. If I were you:
1) Budget for great projector vs good PJ (Looking in the $1800-$2500) assuming your screen could be less than $100 all-in
2) See what comes of your speaker sales and work on improvement of the front stage.
3) Come back and look at a "real" Projection screen. It will improve that much more, but in the between time you may decide you want to go bigger, smaller, or to a different format, and the good news is, you are only out $100 bucks. By this point in time you will have the best grasp on what format and size screen you really want. I remember when I built out my 106" screen and thinking, "There is no way I would ever need bigger." Well, I moved from that about a year later up to 126" and now am at 138" and spent quite a bit of money during the process to get here. Now I am tossing the jvc 4910 which would be one of the "great" projectors onto a $60 screen and no one would know the difference between it and a $5,000 firefox screen if I didn't tell them...
beastaudio is offline
post #21698 of 37926 Old 08-06-2014, 02:22 PM
raynist's Avatar
Quoted: 1574 Post(s)
Liked: 1550
Originally Posted by Reefdvr27 View Post
Tom from PSA posted this on Facebook. Amp sale. Others available One Day
http://www.musiciansfriend.com/pro-a...uestid=1014927
http://www.musiciansfriend.com/pro-a...wer-amp?pfm=sp
Thanks for the link!! Bought two 1000's, don't need them right now but I am sure I can find a use for them!
raynist is offline
post #21699 of 37926 Old 08-06-2014, 03:07 PM
Gooddoc's Avatar
Quoted: 3110 Post(s)
Liked: 2414
First thing, the talk about the sony es55 is good, but you guys should also be considering the jvc4910. I am tossing it on a very lossy screen right now, from close to 16 feet back, and a 138" 16:9 image and it leaves nothing additional to be desired. Most incredible picture I have ever seen!!!!
Holy smokes! I have one sitting in a box in my basement. I guess I should finally buy a screen and actually use it!
Yea, true that.
The mystery speaker is(drum roll).......
The JBL M2 Master Reference Monitor
Although this is not news to many if my pm box is any indication
countryWV likes this.
Gooddoc is offline
post #21700 of 37926 Old 08-06-2014, 03:09 PM
Reefdvr27's Avatar
Quoted: 1579 Post(s)
Liked: 1064
Always nice to have an amp or two laying around.
Reefdvr27 is offline
post #21701 of 37926 Old 08-06-2014, 03:19 PM
dlbeck's Avatar
Quoted: 559 Post(s)
Liked: 666
Yeah Frohlich - you were my first poster on the thread - wondered where you disappeared to
dlbeck is offline
post #21702 of 37926 Old 08-06-2014, 03:21 PM
carp's Avatar
Quoted: 2881 Post(s)
Liked: 2168
Holy balls!!! 20,000! Man those look nice, has anyone heard them?
poolratt and Gorilla83 like this.
carp is offline
post #21703 of 37926 Old 08-06-2014, 03:31 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
Depends on the port tune of the cabinets, I can hit single digits with my four subs. Now I know four monster cabinets isn't ideal for most but they work for me. I have extremely solid output down to 10hz, probably more then dual SubM HP's would even put up and for less then 3 grand, kind of hard to argue against that if you can live with big cabinets.
I was also going to sell my 228HT's and build something, but the more I think about it the more I think I'm crazy to do that!....lol
jbrown15 is offline
post #21704 of 37926 Old 08-06-2014, 03:32 PM
jbrown15's Avatar
Liked: 1995
Holy cow Frohlich, I thought you feel off of the face of the earth. You haven't posted for a long time.
jbrown15 is offline
post #21705 of 37926 Old 08-06-2014, 03:35 PM
Reefdvr27's Avatar
Liked: 1064
I seen that they are listed at 6K a piece, still allot of coin. I am going to see if I can invite myself for a demo.
carp and NWCgrad like this.
post #21706 of 37926 Old 08-06-2014, 03:58 PM
Gooddoc's Avatar
Liked: 2414
That's without amplification or the DSP processor. It's an active design, so those are necessary components.
Gooddoc is offline
post #21707 of 37926 Old 08-06-2014, 04:15 PM
Frohlich's Avatar
Liked: 1246
This guy on this forum kept tormenting me about getting an AT screen so I went to Tibet for a few months to find the true meaning of HT. I saw a few Yeti but didn't find the inner HT peace I was looking for
dgage, beastaudio and jlpowell84 like this.
Frohlich is offline
post #21708 of 37926 Old 08-06-2014, 04:48 PM
NWCgrad's Avatar
Quoted: 1272 Post(s)
Liked: 1311
Originally Posted by Gooddoc View Post
The mystery speaker is(drum roll).......The JBL M2 Master Reference Monitor
I have read lots of great things about the M2's. The guy who runs AIX swears by them.
Would love to hear a set someday.
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #21709 of 37926 Old 08-06-2014, 04:54 PM
audiovideoholic's Avatar
Quoted: 654 Post(s)
Liked: 216
I have a JVCRS1x that I haven't listed on classifieds but would let it go to an AVS member wanting to step into the big screen ht experience. I know it's a few years old but if not worried about 3D then would be a good first pj and save money for speakers, subs, screen,etc...
jlpowell84 likes this.
audiovideoholic is offline
post #21710 of 37926 Old 08-06-2014, 04:55 PM
RMK!'s Avatar
Quoted: 1698 Post(s)
Liked: 1630
Yea, true that.
What, someone was actually interested ...
Anxiety is contagious, please keep yours to yourself.
RMK! is online now
post #21711 of 37926 Old 08-06-2014, 05:00 PM
Gooddoc's Avatar
Liked: 2414
Your disinterest was notable
RMK! likes this.
Gooddoc is offline
post #21712 of 37926 Old 08-06-2014, 05:03 PM
RMK!'s Avatar
Liked: 1630
There will be no peace without transparency ... acoustic that is ...
RMK! is online now
post #21713 of 37926 Old 08-06-2014, 05:11 PM
Reddig's Avatar
Quoted: 252 Post(s)
Liked: 521
+2
I love this thread and all the cool fellas that post here. I'm always lurking around.
dgage and jlpowell84 like this.
JBL Pro Cinema-JTR subwoofers-Sony SXRD projection-Elite AT screen-Denon AVR-Oppo BD player-Acoustimac panels-SeatCraft HT seating
MANCHESTER UNITED!!
Reddig is offline
post #21714 of 37926 Old 08-06-2014, 05:46 PM
jbrown15's Avatar
Liked: 1995
LOL.... okay I'll try to lay off of the AT screen comments...lol
No it's funny, you get so use to certain forum members posting daily that when they don't for a while you almost wonder if everything is okay with them. For example steve nn hasn't posted in a LONG time and he would post daily and at least once a week we'd shoot pm's back and forth just shooting the *****, I haven't heard from him since April so no I genially worry a little that something has happened too him. It's strange, I don't really know anyone on this forum personally but if guys like Archaea, Carp, RMK and all of the regulars went like a few months without posting you start to wonder if something bad happened to them.
dgage, Archaea, NWCgrad and 1 others like this.
jbrown15 is offline
post #21715 of 37926 Old 08-06-2014, 05:53 PM
jlpowell84's Avatar
Liked: 915
This is great news. I don't have any PJ experience at all and want to cover all the possibilities. I could possibly build a custom shelf to house the PJ just behind the couch. Not too fond of it there since the room is open behind the couch into a little dining area. But it would work.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #21716 of 37926 Old 08-06-2014, 06:07 PM
jlpowell84's Avatar
Liked: 915
Yes time will tell. I have some research to do as far as the AT material in relation to sitting distance. I currently sit 8.5 ft from my TV screen. The wall is 9.5ft. The Triple 8LP I have for center channel is 7.5 inches thick and there is a window behind there I have stuffed with Roxul AFB. I could gain a little more clearance from that. So the screen could sit slightly closer to the wall than the tv. I could creep the couch back as well but I wouldn't want to go more than another half ft for physical layout reasons. But mainly I have the seating in the absolute best bass response area in the entire room.
Looked at the ES55 a little more and I like it so far...I can say I will calibrate correctly with the Spears & Munsill disc and my oppo and darbee processing should help. I do tend to prefer the brighter side. For example, I brush up against the correct calibration and too bright line...
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #21717 of 37926 Old 08-06-2014, 06:13 PM
jlpowell84's Avatar
Liked: 915
I like it! Like I just mentioned to buzz and earlier about jedimastergrant giving me some great ideas to even do AT and get my center in the perfect position. As far as the subwoofer situation and speaker situation I will think on that. But I am already mentally committed to a PJ like the ES55 range/quality and screen. I have plenty of time to get my research done. But when I mentally commit it as is good as done lol!
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #21718 of 37926 Old 08-06-2014, 06:17 PM
jlpowell84's Avatar
Liked: 915
Well I take first dibbs on your 228's if you do
What was the general cost of your monster ported sub? I would build two so what would that run?
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #21719 of 37926 Old 08-06-2014, 06:43 PM
N8DOGG's Avatar
Quoted: 1116 Post(s)
Liked: 1218
the 55 is probably the best all around projector under 5K period. If I wasn't waiting for better 4K projectors, thats exactly what I'd get. They get rave reviews and my ISF buddy says they are the tits! They do 3D really well, are bright, do 2K spot on and have decent lag if you were to use it for gaming.
N8DOGG is online now
post #21720 of 37926 Old 08-06-2014, 06:48 PM
dlbeck's Avatar
Quoted: 559 Post(s)
Liked: 666
+1 - the reason I went with the 55ES is after recommendations from both Jeff Meier and Nyal Mellor. Those are the guys that see hundreds of projectors every year.
dlbeck is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
