Official JTR speaker thread - Page 742 - AVS Forum | Home Theater Discussions And Reviews
 8504Likes
post #22231 of 37607 Old 08-19-2014, 12:27 PM
Archaea's Avatar
Quoted: 3061 Post(s)
Liked: 2665
Originally Posted by desertdome View Post
In JRiver you enter it under Tools > Options > Audio > Room Size. I forget that most are using receivers.
J/K
What is that document?
Archaea is offline
post #22232 of 37607 Old 08-19-2014, 12:31 PM
jlpowell84's Avatar
Quoted: 1873 Post(s)
Liked: 862
Originally Posted by N8DOGG View Post
if you sell the opendrc, let me know, I'd likely buy it from you. I could use another one. pm me with a price you have in mind if you do sell it.
lol, actually you came to mind first. What are your thoughts Nate on me going to a Nanoavr? Same capabilties as Open DRC (minus the auto filters I think) but I get speaker EQ ability. I would love to bring the 2k-4k region down a bit. Also want to try a "little" midbass" boost but I need to know if I need amps for that as my 4520 puts out around 90-100 watts a channel I think. It would just sit elsewhere in the signal chain...
Originally Posted by emr25 View Post
This falls right in line with what I saw while watching Olympus Has Fallen at 0 dB MV. I had my cheap Parts Express SPL meter on the "max" setting while watching and it was around 105 dB. I'm sure some LFE scenes where actually louder, but I don't know how accurate that SPL meter is for low frequencies with its weighting type and cheaper components.
I will have to try. I have the RS SPL $50 meter. I think it's common knowledge that one is consistenly 10db approx low on the subs usually. Immediately after an Audyssey cal it will read 64-66 which is further proof as it is really 75db Audyssey sets it at.
FTW21 Ported Build
Spoiler!
jlpowell84 is offline
post #22233 of 37607 Old 08-19-2014, 01:09 PM
7channelfreak's Avatar
Quoted: 290 Post(s)
Liked: 192
Who has dbox in kc?
And if you ever make it to Houston, I'll show you as well. I do owe you since I saw the JTR at your place.
We do have GTG to see theaters here occasionally. We have one next weekend actually at AV Texans.'
But you're always welcome.
thxman and Archaea like this.
7channelfreak is offline
post #22234 of 37607 Old 08-19-2014, 01:19 PM
desertdome's Avatar
Quoted: 1243 Post(s)
Liked: 1416
ATSC's A/85 – Techniques for Establishing and Maintaining Audio Loudness for Digital Television
Here is a list of all broadcast standards and how they interact:
http://www.tcelectronic.com/loudness...ast-standards/
desertdome is online now
post #22235 of 37607 Old 08-19-2014, 02:41 PM
ChldsPlay's Avatar
Quoted: 680 Post(s)
Liked: 354
I guess I should also ask how the Triple 8's compare to the 228's? I'm intrigued by the low profile option of the t8's.
ChldsPlay is offline
post #22236 of 37607 Old 08-19-2014, 02:52 PM
carp's Avatar
Quoted: 2711 Post(s)
Liked: 2007
Originally Posted by Reefdvr27 View Post
With the ported sub talk lately, I am curious to hear from the 215 guys how they are making out with pairing sealed with ported as most are. Are you using subs or just running full range. I have talked to you all individually, but wanted to see how things are now. Seeing this ported subs has me thinking maybe getting a pair of ported subs or just running full range.
For music the subs never get turned on, but for movies sometimes I run the mains large + subs and sometimes I cross the mains at 50 hz and run them small. There really isn't much difference other than the fact that for a demo I do get some more db's with large mains + subs if I want to go crazy and subjectively it is more impressive at the system's limits.
For normal movie watching either way is fine, I just turn down the bass eq a touch on the mains and turn down the trim on the subs a touch too if running large mains + subs compared to running the mains small and crossing them over.
I have reached the point where I don't want or need any more bass. My house and ears are at their limit when things are cranked up which doesn't even happen very often anyway.
carp is online now
post #22237 of 37607 Old 08-19-2014, 03:29 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1994
Okay, so who has a pair of 212HT's that they want to sell and who wants to buy a pair of 228HT's?.....lol
jlpowell84 likes this.
jbrown15 is offline
post #22238 of 37607 Old 08-19-2014, 07:04 PM
jlpowell84's Avatar
Liked: 862
In Olympus Has Fallen, a system playing back at 0 MV can have peaks of around 120 dB or more due to the combined channel output. The SPL meter really isn't fast enough to catch most of the peaks, though.
Reference Level varies with room volume. Attached is the recommended SPL at various room volumes:
Originally Posted by Mark Seaton View Post
It's important to remember the "why" driving this recommendation. This stems from assumed similar acoustics vs a changing room size as would be likely in either commercial theaters or mixing rooms. This is a huge factor in why those with heavily treated, dedicated theaters find higher main volume levels more comfortable than those in a typical, untreated living room.
In short our hearing system senses loudness based on sound power, not just intensity. For those reading along, this means subjective loudness relates to intensity*time, not just peak SPL. The more reflections can keep bouncing around without dissipating, the longer any burst of sound will exist in the room, and will sound louder. Go slam a book shut in your bathroom/shower vs standing outside. The sound from the book closing didn't change, but in the bathroom the sound kept bouncing around at nearly the level it started at making it seem MUCH louder.
While such reflections do make the time averaged SPL (like the pink noise test tones) measure louder, most deteriorate the clarity, intelligibility and overall quality. Since we don't calibrate based on the direct sound only, but rather on direct and all reflected energy, this means that in a reflective room the "calibrated" playback will actually have less peak SPL but have much more sustained energy due to reflections.
Great posts here, thanks for the informative responses! My room definitely falls into the "reflective" category given it is small and completely untreated.
I will go into a little more detail from my own experience in my own space. My first full setup with the triple12's i had absolutely zero treatments in the room, and rarely went above -8 for any material, even showing off. The speakers could easily run well past -8 but the sound began to fall apart and not feel too good on the ears. I usually watched movies at a level between -12 and -14. Since treating the room, and optimizing the space quite a bit more, I have found that movies at reference are certainly "loud" but so clean it is hard to pass up. Beforehand, reference on the same movies was almost painful. Yes, I have always eq'd my system to the same spec at the same MLP give or take a few inches, but it just goes to show what a properly treated room can do to your listening levels.
The AVR doesn't. The link relates to mastering and playback across a wide range of spaces. Basically all "home" environments are assumed to fall in the same classification, and if your room does depart from the norm, you'll more than likely turn it up or down a few dB without prompting as it will be subjectively too loud or not loud enough.
When I first built all my room treatments I was hanging around -10 or -11 on the MV. After I built the Volt 10's and re-calibrated XT32 I was back to -17ish...The room was noticeably quieter and REW read my noise floor from 42.5db avg to 38.5 after the treatments. I understand Mark's description of reflections and the "hanging" energy changing the perceived loudness in a room, smaller in particular. But still don't grasp why I am at -17avg. I guess I just need to see what the SPL meter reads and go from there. Doesn't make any difference I was just curious as why some are at 0 and I am at -17avg? I have been thinking the 2k-4k region could be a chunk of the equation. My last graph had my Triple 8's a little bloated in that region...
FTW21 Ported Build
Spoiler!
post #22239 of 37607 Old 08-19-2014, 07:24 PM
N8DOGG's Avatar
Quoted: 1079 Post(s)
Liked: 1178
I have no idea about the Nanoavr but I'm gonna look into it. It would be nice to have a EQ although how much will that EQ degrade the sound on a box shoved into the middle of your chain... that I dunno.
N8DOGG is offline
post #22240 of 37607 Old 08-19-2014, 07:27 PM
jlpowell84's Avatar
Liked: 862
I guess dgage and coach are our lab rats there
One thing I want to know for sure is how it will do in my system. I actually might have to keep my Open DRC in the fact that it takes ALL, 100% of the noise out of my two Submersives. I took it out one time and the noise was horrible. I don't think the Nanoavr up in the chain will do that.
FTW21 Ported Build
Spoiler!
post #22241 of 37607 Old 08-19-2014, 08:10 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1616 Post(s)
Liked: 1439
You shouldn't have any noise in a normal system so I'm not sure why the OpenDRC would be cleaning the noise up. If you mean hiss or something, you could try grounding your amps to your receiver or use some cheater plugs.
One of the good things on the NanoAVR is that it is completely digital so just plugging it into the chain should not affect the sound at all and that has been my experience. The only negative thing Coach and I have noticed is a slight reduction in sound level, meaning you need to turn the volume up a little higher than normal for the same output. But there are multiple ways to address that.
dgage is offline
post #22242 of 37607 Old 08-19-2014, 09:19 PM
COACH2369's Avatar
Quoted: 892 Post(s)
Liked: 732
The NanoAvr has really taken my system to the next level. I have no doubt that without it, the 215's wouldn't had been able to sound as good as they did. Audyssey actually laid a solid foundation and the NanoAvr cleaned things up.
I highly recommend it if you are only using XT32 or one of the other Room correction offerings from the other brands like Pioneer, Yamaha or even Anthem.
COACH2369 is offline
post #22243 of 37607 Old 08-19-2014, 09:33 PM
jlpowell84's Avatar
Liked: 862
I currently use the Open DRC-AN version for Submersive EQ. I couldn't live without it or something similar As far as the noise I don't know exactly what it is. I just know right now I have the RCA to XLR's into the Open DRC from the Denon4520 and XLR to XLR out to the two Submersives. When I took it out briefly one time to experiment the SubM's were suddenly humming quite loudly. I know this place has issues because I got the hiss/buzz from the Sherbourn PA7350 before I sold it.
FTW21 Ported Build
Spoiler!
post #22244 of 37607 Old 08-20-2014, 05:18 AM
Gooddoc's Avatar
Quoted: 2980 Post(s)
Liked: 2169
Hang tight. A pair or 3 will be available very shortly.
Gooddoc is online now
post #22245 of 37607 Old 08-20-2014, 05:39 AM
BCRSS's Avatar
Quoted: 248 Post(s)
Liked: 188
Could you please expand on the cleaning up part?
The Elusive 1099 (L/C/R)---6 DIY Volt 10 (surrounds 9.4)---SVS PB 12 Plus---SVS PC 12 Plus---2 DIY 18's sealed--2 Pico Wreckers (tapped horns)---AVR Denon 4311CI---Emotiva Xpa-3---Behringer Nu6000DSP & Nu3000DSP iNuke---TV Vizio 70---110" Motorized Screen---Epson 8350 Projector---Unraid Network Storage---Gateway SX 2370 HTPC with 120 SSD
BCRSS is offline
post #22246 of 37607 Old 08-20-2014, 05:42 AM
Frohlich's Avatar
Quoted: 1177 Post(s)
Liked: 1127
Very nice. Sounds like somebody is going down the JBL route
Frohlich is offline
post #22247 of 37607 Old 08-20-2014, 06:31 AM
Deep Sea Sound
dgage's Avatar
Liked: 1439
Once again I'll speak for Coach since he's traveling today. I think "cleaning up" might be the wrong choice of words. Audyssey gave a nice base and evened out the frequency response for his calibrator but with Audyssey, even the Pro version, there is little control. So really what the NanoAVR allowed the calibrator to do is get the sound to Coach's preference which is strong midbass along with maybe increasing the upper end a little. Coach and I haven't actually looked at the NanoAVR configuration but that is what was communicated by the calibrator. And I must say it really made the215s sound sweet, better than Audyssey only and especially better than just hooked up out of the box.
dgage is offline
post #22248 of 37607 Old 08-20-2014, 06:43 AM
Gooddoc's Avatar
Liked: 2169
Nah. I was browsing through Best Buy the other day and settled on a Sony HTIB. UNBELIEVABLE SQ and dynamics.
But thanks for asking.
post #22249 of 37607 Old 08-20-2014, 06:43 AM
BCRSS's Avatar
Quoted: 248 Post(s)
Liked: 188
Thank you for the response. Not real happy with Audyssey and am looking to improve certain areas. So it looks like this could be a solid choice.
BCRSS is offline
post #22250 of 37607 Old 08-20-2014, 07:22 AM
Reefdvr27's Avatar
Quoted: 1574 Post(s)
Liked: 1054
I would not wait. I would strike while the iron is hot. I had mine forsale for 2 months and nothing. I decided to keep them.
Reefdvr27 is offline
post #22251 of 37607 Old 08-20-2014, 07:34 AM
Gooddoc's Avatar
Liked: 2169
Well, let me rephrase that. The 212HT's are for sale. I just don't know yet whether I'm keeping one for my center or not. So I definitely have two, and most likely three for sale. I just wanted to make a definitive decision on the third before I officially offered them up.
I'm surprised no one wanted to buy yours. Maybe your price was too high?
post #22252 of 37607 Old 08-20-2014, 07:52 AM
Reefdvr27's Avatar
Liked: 1054
I had no offers. I had em listed for $3900 with free stands. I was just letting you know the market is a little flat right now.
post #22253 of 37607 Old 08-20-2014, 08:04 AM
devarade's Avatar
Quoted: 31 Post(s)
do you have 212 HT for sale ? can you please post the link
devarade is offline
post #22254 of 37607 Old 08-20-2014, 08:05 AM
Point Source
beastaudio's Avatar
Quoted: 3924 Post(s)
Liked: 3233
I am not either. Manual EQ can really make your system shine, but using audyssey and then adjusting out to your preference is likely the most prudent as it would require less tweaking after audyssey... Doing it before would require quite a bit more work...
FS: BossoBass A-14K amplifier
beastaudio is offline
post #22255 of 37607 Old 08-20-2014, 08:21 AM
Gooddoc's Avatar
Liked: 2169
Ha! That's too cheap IMO. JTR's are built like tanks and for someone looking to save some money buying used JTR's is about as safe a purchase as I could imagine. At least as far as speakers go. When I bought mine there were no used to buy, otherwise I would have. About the only thing you'll miss out on going used is that overwhelming stench in your house as the finish cures.
jon_98 likes this.
post #22256 of 37607 Old 08-20-2014, 08:22 AM
Reefdvr27's Avatar
Liked: 1054
Hopefully I will be getting that soon again.
post #22257 of 37607 Old 08-20-2014, 08:26 AM
Gooddoc's Avatar
Liked: 2169
Just send me a pm if you're interested. I don't have them listed yet.
post #22258 of 37607 Old 08-20-2014, 09:00 AM
BrolicBeast's Avatar
Quoted: 1248 Post(s)
Liked: 1318
Hahahahaha--I chuckled quite loudly after reading this!
BrolicBeast is offline
post #22259 of 37607 Old 08-20-2014, 09:45 AM
jbrown15's Avatar
Liked: 1994
Gotcha, pm me with the details.
jbrown15 is offline
post #22260 of 37607 Old 08-20-2014, 10:38 AM
fatsow's Avatar
Quoted: 132 Post(s)
Liked: 59
Sorry to jump in too, but I just listed a pair of 212HTs. Will probably be listing of one of my two orbit shifters too. Have some 215s on the way.
fatsow is online now
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
