Official JTR speaker thread - Page 844 - AVS Forum | Home Theater Discussions And Reviews
 7784Likes
post #25291 of 36580 Old 11-09-2014, 11:23 AM
carp's Avatar
Quoted: 2493 Post(s)
Liked: 1752
Hmm it looks like I have to have my projector on or the audio HDMI connection fails. That won't work, i don't want to have the projector on every time I listen to music. Is there a way around this?
carp is offline
post #25292 of 36580 Old 11-09-2014, 11:25 AM
Gooddoc's Avatar
Quoted: 2685 Post(s)
Liked: 1850
@carp
I decided a couple of days ago to do exactly what your doing with the free Dirac trial. Ran the calibration, played some music and thought it was much better than Audyssey since I felt it didn't deaden the highs like Audyssey does. I thought I had a winner on my hands.
Then I had @DreamWarrior over the next day to listen to some music and I told him how Dirac was so much better than Audyssey, blah, blah. Well, we listened for a while and then I started turning the Dirac filters on and off and we couldn't tell any difference at all. So no wonder I thought it didn't mess with my highs at all. Apparently, as far as we could tell, it really wasn't doing anything at all in my room . So curious as to your impressions.
audiovideoholic likes this.
Gooddoc is offline
post #25293 of 36580 Old 11-09-2014, 11:27 AM
carp's Avatar
Liked: 1752
Originally Posted by Gooddoc View Post
@carp
What mic did you use for the calibration?
carp is offline
post #25294 of 36580 Old 11-09-2014, 11:29 AM
Gooddoc's Avatar
Liked: 1850
If you're just using Dirac for 2 channel music for evaluation, then run the HDMI out from the AVR to the monitor in the back of your room, not the projector. That would give you the handshake you need.
Gooddoc is offline
post #25295 of 36580 Old 11-09-2014, 11:31 AM
Gooddoc's Avatar
Liked: 1850
I used the UMIK-1
Gooddoc is offline
post #25296 of 36580 Old 11-09-2014, 11:35 AM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
Carp, after you get the Dirac running it will become your soundcard that you choose and you will see it listed in the Control Panel>Sound window you posted above. Then the Dirac controller will have an output selector and you choose the HDMI out. Hope this helps.
lbrown105 is offline
post #25297 of 36580 Old 11-09-2014, 11:40 AM
carp's Avatar
Liked: 1752
It works, the audio plays through my avr. What's strange though is I get no picture on the monitor. Fortunately I have remote desktop setup on my laptop which is how I'm typing this right now. I hardly ever use the monitor in the back of the room so it's not a huge issue, and I guess if I want to see the PC image on the projector I can just switch the cords in the next room.
Ok, now I'm all set to try Dirac assuming my omnimic will work. It will have to wait though since I watch football all day on Sundays.
carp is offline
post #25298 of 36580 Old 11-09-2014, 11:41 AM
carp's Avatar
Liked: 1752
Cool, thanks Lance. We had a heck of a time getting Dirac going at the GTG but now I kind of have an idea of what to do. Looks like a lot of fun just to play with, can't wait to mess with the target curve.
carp is offline
post #25299 of 36580 Old 11-09-2014, 11:43 AM
Gooddoc's Avatar
Liked: 1850
Hmmm. Don't know if I selected any output in the Dirac controller. Maybe that was my problem.
Gooddoc is offline
post #25300 of 36580 Old 11-09-2014, 11:46 AM
carp's Avatar
Liked: 1752
That could be it, plus I think the ability to pick a response curve to your liking would be something that you would definitely notice a difference between Dirac and no Dirac.
carp is offline
post #25301 of 36580 Old 11-09-2014, 11:54 AM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
That's the great part. Once you get the room measured adding different target curves is soooo fast. Then you can load up to four different target curves in the DIracc control box and instantly switch back and forth between them or Dirac off. Makes for great quick change comparisons.
Just make sure you run through the full measurement procedure a couple of times and save the projects separately. I go better impulse response improvements with a larger volume of measurement space (nine is the total number). Side to side, forward and back slightly and up and down slightly too.
My two week trial is over and this sucks. I would purchase it today but my pre pro is supposed to be implemented with it in Dec so I need to wait. This sucks!!!
Good luck and let us know how it goes. Oh yeah, also depending on how much boost you may add with a given target curve (I think Dirac maxes at +10dB) you need to make sure the clip light isn't coming on during music playback. It is an input clip indicator so MV does not factor in but filter boosting does. In default (-8dB) I have never seen the clip light come on though.
post #25302 of 36580 Old 11-09-2014, 11:58 AM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
easy to tell if you are actually getting correction. First by switching on and off I found an easily detectable difference. If still not sure hit the let arrow and go into that window and adjust the input level up or down (8dB of adjustment) you should hear volume go up or down, if not then you are not running through Dirac.
post #25303 of 36580 Old 11-09-2014, 11:59 AM
carp's Avatar
Liked: 1752
Ahhh what a pain!! If I switch inputs on my AVR (to directv is what I just did) and then go back to the HDMI PC input on my AVR then the audio doesn't work again and my computer says that the HDMI is not plugged in again.
To fix it I have to go back to the other room and unplug the HDMI cord and plug it back in and then it works again. Also, I have to shut down the music player on my computer and restart it before it will work again.
It's too bad the mini doesn't have an input for optical or coax digital this is a pain!!!!
I'm starting to hate HDMI....
carp is offline
post #25304 of 36580 Old 11-09-2014, 12:01 PM
carp's Avatar
Liked: 1752
Uh oh.... is that the Emotiva pre pro? Hasn't that had constant delays?
carp is offline
post #25305 of 36580 Old 11-09-2014, 12:02 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
This is the left window. If you hit the < arrow on the right side it takes you back to the main filter selector page. The hitting the > from that page n the right side takes you to the time alignment and level window. Also you can see the output selector on this screen shot. Right now none is selected, but here is where you select your HDMI out. Sorry if I am posting the obvious.
post #25306 of 36580 Old 11-09-2014, 12:07 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
yes they have missed deadlines but the unit has a great build quality and design and I really like it. They are now finalizing the microphones so I just have to be a little more patient. So far it has been worth the wait and from what I have seen from Dirac, audyssey may be in big trouble
post #25307 of 36580 Old 11-09-2014, 12:12 PM
pennynike1's Avatar
Quoted: 292 Post(s)
Liked: 131
terraforms
I have 4 Seaton terraforms, which should handle below 20 Hz content tremendously. Each is tuned to 12 hz.
Originally Posted by dgage View Post
Above 20 or 40 is nice and all but what about below 20 where you are made apart of the movies and various explosions? I'm definitely in the below 20 Hz camp as far as strong output. But I know many have said the OS above 20Hz is something to behold.
pennynike1 is online now
post #25308 of 36580 Old 11-09-2014, 12:14 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
screen shot didn't work before
Name:	Dirac screen shot.jpg
post #25309 of 36580 Old 11-09-2014, 12:17 PM
carp's Avatar
Liked: 1752
Do you mean you have the pre/pro already? Just waiting for a firmware update that includes Dirac?
carp is offline
post #25310 of 36580 Old 11-09-2014, 12:23 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
yes that's right. it is really nice and dead quiet. I had the LG on +35dB gain and the xmc-1 was still dead quiet even on the 212's. impressive build quality
carp likes this.
post #25311 of 36580 Old 11-09-2014, 01:04 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1559 Post(s)
Liked: 1347
Why only 12 Hz? Just kidding...EnduroBass it is. -
dgage is offline
post #25312 of 36580 Old 11-09-2014, 01:33 PM
Gooddoc's Avatar
Liked: 1850
I've tried my best to get this Dirac to do something and I just can't get it to work.
Edit: Whew(wipes brow). Close call. I had actually been considering setting up an HTPC. This has quickly reminded me that the last thing I want to do is bring the headaches of a computer into my music world.
NWCgrad likes this.
Gooddoc is offline
post #25313 of 36580 Old 11-09-2014, 01:46 PM
L0nestar's Avatar
Quoted: 18 Post(s)
I have a similar situation with an attic space behind my front wall. I have always wanted to flush the screen and mount the speakers (and IB subs)) in that front wall but there is a hip roof on the other side of the wall that doesn't allow for the L&R speakers to be in wall. If you don't have that limitation, that might be a good way for you to go...
Thanks for the input RMK!...
I'm getting some interesting advice in the home theater design section.
"Projection screen way too big." 120inches at 14 feet?
Wrong type of speakers for the room. "Picked the equipment before room design was done. This is a huge problem". Is it just me or shouldn't we all design our rooms around our speakers?
"Flushing speakers makes them sound worse." No one can tell me why.
I'm so confused. lol.
...Sometimes I wish I could just hang out in my JTR foxhole. You guys get me.
Maximum Un-Intelligence.
L0nestar is offline
post #25314 of 36580 Old 11-09-2014, 01:51 PM
Deep Sea Sound
dgage's Avatar
Liked: 1347
Wow. I guess I won't ask about any design decisions for my less than optimal living room home theater. I guess I'm with you on 2 of the 3 (not trying to flush mount though).
dgage is offline
post #25315 of 36580 Old 11-09-2014, 01:56 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
That's too bad Doc. Have you confirmed it is running as your soundcard yet? Not sure if you are having trouble getting it to work at all or just perform they way you want it too.
post #25316 of 36580 Old 11-09-2014, 02:22 PM
Gooddoc's Avatar
Liked: 1850
Can't get to work at all. Selected Dirac as soundcard and every output choice in Dirac processor and can't get it to process anything
Gooddoc is offline
post #25317 of 36580 Old 11-09-2014, 02:42 PM
NWCgrad's Avatar
Quoted: 1233 Post(s)
Liked: 1227
Hey @carp I hope you didn't miss the KC game futzing with HDMI. Man it sucks living on the east coast.
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #25318 of 36580 Old 11-09-2014, 02:50 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
were you able to measure your room with the Dirac calibration tool and create filters?
post #25319 of 36580 Old 11-09-2014, 02:59 PM
Gooddoc's Avatar
Liked: 1850
Yes, no problem there.
Gooddoc is offline
post #25320 of 36580 Old 11-09-2014, 03:18 PM
carp's Avatar
Liked: 1752
Yep, I always record and watch a little late so we can FF all commercials. We stole a win, but I'll take it!!
carp is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
